Should I reinstall?
Feb 11 22:51:21 firasmanjaro-systemproductname kernel: x86/cpu: VMX (outside TXT) disabled by BIOS
Feb 11 22:51:21 firasmanjaro-systemproductname kernel: x86/cpu: SGX disabled by BIOS.
Feb 11 22:51:21 firasmanjaro-systemproductname systemd-udevd[430]: event10: Failed to call EVIOCSKEYCODE with scan code 0x7c, and key code 190: Invalid argument
Feb 11 22:51:50 firasmanjaro-systemproductname pulseaudio[1084]: GetManagedObjects() failed: org.freedesktop.DBus.Error.TimedOut: Failed to activate service ‘org.bluez’: timed out (service_start_timeout=25000ms)
Feb 11 23:07:08 firasmanjaro-systemproductname konsole[1889]: kf.xmlgui: Shortcut for action “” “Show Quick Commands” set with QAction::setShortcut()! Use KActionCollection::setDefaultShortcut(s) instead.
Feb 11 23:07:08 firasmanjaro-systemproductname konsole[1889]: kf.xmlgui: Shortcut for action “” “Show SSH Manager” set with QAction::setShortcut()! Use KActionCollection::setDefaultShortcut(s) instead.
Feb 11 23:16:10 firasmanjaro-systemproductname konsole[3224]: kf.xmlgui: Shortcut for action “” “Show Quick Commands” set with QAction::setShortcut()! Use KActionCollection::setDefaultShortcut(s) instead.
Feb 11 23:16:10 firasmanjaro-systemproductname konsole[3224]: kf.xmlgui: Shortcut for action “” “Show SSH Manager” set with QAction::setShortcut()! Use KActionCollection::setDefaultShortcut(s) instead.
Feb 11 23:18:16 firasmanjaro-systemproductname systemd-coredump[3532]: Failed to connect to coredump service: Connection refused
Feb 11 23:18:16 firasmanjaro-systemproductname pulseaudio[1084]: Lost I/O connection in module “module-gsettings”
Feb 11 23:18:18 firasmanjaro-systemproductname kernel: watchdog: watchdog0: wathdog did not stop!
 Kernel: 6.1.9-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
   root=UUID=b38f29f8-4b75-44a5-a175-8dcfba6c73db rw quiet splash
   udev.log_priority=3
 Desktop: KDE Plasma v: 5.26.5 tk: Qt v: 5.15.8 wm: kwin_x11 vt: 1 dm: SDDM
 Mobo: ASUSTeK model: PRIME Z490-A v: Rev 1.xx serial: <superuser required>
   UEFI: American Megatrends v: 2601 date: 05/17/2022
 RAM: total: 31.25 GiB used: 4.03 GiB (12.9%)
 Info: model: Intel Core i7-10700K bits: 64 type: MT MCP arch: Comet Lake
   gen: core 10 level: v3 note: check built: 2020 process: Intel 14nm family: 6
   model-id: 0xA5 (165) stepping: 5 microcode: 0xF4
 Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
   L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 2 MiB desc: 8x256 KiB L3: 16 MiB
   desc: 1x16 MiB
 Speed (MHz): avg: 3430 high: 3800 min/max: 800/5100 scaling:
   driver: intel_pstate governor: powersave cores: 1: 892 2: 3800 3: 3800
   4: 3800 5: 3800 6: 3800 7: 3800 8: 3800 9: 3800 10: 3800 11: 3800 12: 3800
   13: 800 14: 3800 15: 3800 16: 3800 bogomips: 121639
   dtherm dts epb erms est f16c flush_l1d fma fpu fsgsbase fxsr ht hwp
   hwp_act_window hwp_epp hwp_notify ibpb ibrs ibrs_enhanced ida intel_pt
   invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe mpx
   msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq pdcm pdpe1gb
   pebs pge pku pln pni popcnt pse pse36 pts rdrand rdseed rdtscp rep_good
   sdbg sep smap smep smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall
   tm tm2 tsc tsc_adjust tsc_deadline_timer vme x2apic xgetbv1 xsave xsavec
   xsaveopt xsaves xtopology xtpr
 Type: itlb_multihit status: KVM: VMX unsupported
 Type: retbleed mitigation: Enhanced IBRS
 Type: spectre_v2 mitigation: Enhanced IBRS, IBPB: conditional, RSB
   filling, PBRSB-eIBRS: SW sequence
 Device-1: AMD Ellesmere [Radeon RX 470/480/570/570X/580/580X/590]
   vendor: ASUSTeK driver: amdgpu v: kernel arch: GCN-4 code: Arctic Islands
   process: GF 14nm built: 2016-20 pcie: gen: 3 speed: 8 GT/s lanes: 16 ports:
   active: HDMI-A-1 empty: DP-1, DP-2, DVI-D-1, HDMI-A-2 bus-ID: 01:00.0
   chip-ID: 1002:67df class-ID: 0300 temp: 50.0 C
 Display: x11 server: X.Org v: 21.1.6 compositor: kwin_x11 driver: X:
   loaded: amdgpu unloaded: modesetting alternate: fbdev,vesa dri: radeonsi
   gpu: amdgpu display-ID: :0 screens: 1
 Screen-1: 0 s-res: 2560x1440 s-dpi: 96 s-size: 677x381mm (26.65x15.00")
   s-diag: 777mm (30.58")
 Monitor-1: HDMI-A-1 mapped: HDMI-A-0 model: AOC Q32G1WG4 serial: <filter>
   built: 2019 res: 2560x1440 dpi: 93 gamma: 1.2 size: 697x393mm (27.44x15.47")
   diag: 800mm (31.5") ratio: 16:9 modes: max: 2560x1440 min: 720x400
 API: OpenGL v: 4.6 Mesa 22.3.4 renderer: AMD Radeon RX 580 Series
   (polaris10 LLVM 15.0.7 DRM 3.49 6.1.9-1-MANJARO) direct-render: Yes
 Device-1: Intel Comet Lake PCH cAVS vendor: ASUSTeK driver: snd_hda_intel
   chip-ID: 8086:06c8 class-ID: 0403
 Device-2: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590]
   vendor: ASUSTeK driver: snd_hda_intel v: kernel pcie: gen: 1 speed: 2.5 GT/s
   lanes: 16 link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.1 chip-ID: 1002:aaf0
   class-ID: 0403
 Sound API: ALSA v: k6.1.9-1-MANJARO running: yes
 Sound Server-3: PipeWire v: 0.3.65 running: yes
 Device-1: Intel Ethernet I225-V vendor: ASUSTeK driver: igc v: kernel pcie:
   gen: 2 speed: 5 GT/s lanes: 1 port: N/A bus-ID: 04:00.0 chip-ID: 8086:15f3
   class-ID: 0200
 IF: enp4s0 state: up speed: 100 Mbps duplex: full mac: <filter>
 Local Storage: total: 3.18 TiB used: 1.08 TiB (34.0%)
   model: WDS250G2B0C-00PXH0 size: 232.89 GiB block-size: physical: 512 B
   rev: 211070WD temp: 35.9 C scheme: GPT
 ID-2: /dev/nvme1n1 maj-min: 259:3 vendor: Samsung
   model: SSD 970 EVO Plus 250GB size: 232.89 GiB block-size: physical: 512 B
   rev: 2B2QEXM7 temp: 43.9 C scheme: MBR
 ID-3: /dev/sda maj-min: 8:0 vendor: Toshiba model: HDWD130 size: 2.73 TiB
   block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s type: HDD
   rpm: 7200 serial: <filter> rev: ACF0 scheme: GPT
 ID-1: / raw-size: 232.59 GiB size: 227.88 GiB (97.98%) used: 18.43 GiB (8.1%)
   fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
   uuid: b38f29f8-4b75-44a5-a175-8dcfba6c73db
   used: 312 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
   uuid: 162A-0C78
 ID-3: /run/media/firasmanjaro/THREE TYRAB raw-size: 1.38 TiB
   size: 1.38 TiB (100.00%) used: 1.06 TiB (76.9%) fs: ntfs dev: /dev/sda1
   maj-min: 8:1 label: THREE TYRAB uuid: 1243EB32F255284D
 ID-1: /dev/nvme1n1p1 maj-min: 259:4 size: 232.88 GiB fs: ext4
   label: FREE/BACKUP uuid: 7022d619-0c2e-4ccb-a7ce-25945767a8d2
 ID-2: /dev/sda2 maj-min: 8:2 size: 700.98 GiB fs: ext4 label: N/A
   uuid: 3f0c4116-45df-4b76-b68c-3ddf08483038
 Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 16 rev: 2.0
 Hub-2: 1-6:2 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
 Device-1: 1-9:3 info: Logitech G502 SE HERO Gaming Mouse type: Mouse,HID
   driver: hid-generic,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 300mA
   chip-ID: 046d:c08b class-ID: 0300 serial: <filter>
 Device-2: 1-10:4 info: Corsair K95 RGB Platinum Keyboard [RGP0056]
   type: Keyboard,HID driver: hid-generic,usbhid interfaces: 2 rev: 2.0
   speed: 12 Mb/s power: 500mA chip-ID: 1b1c:1b2d class-ID: 0300
   serial: <filter>
 Device-3: 1-11:5 info: ASUSTek AURA LED Controller type: HID
   driver: hid-generic,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 16mA
   chip-ID: 0b05:18f3 class-ID: 0300 serial: <filter>
 Hub-3: 2-0:1 info: Super-speed hub ports: 10 rev: 3.1 speed: 10 Gb/s
 System Temperatures: cpu: 44.0 C mobo: N/A gpu: amdgpu temp: 50.0 C
 Fan Speeds (RPM): N/A gpu: amdgpu fan: 1194
 Processes: 318 Uptime: 3h 8m wakeups: 0 Init: systemd v: 252
 default: graphical tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7
 Packages: 1242 pm: pacman pkgs: 1236 libs: 328 tools: octopi,pamac,yay
 pm: flatpak pkgs: 6 Shell: fish v: 3.6.0 default: Bash v: 5.1.16
 running-in: konsole inxi: 3.3.25
See:
Hint: it’s ``` (` backticks), not ‘’’ (' apostrophe / single quote). :wink:
Please edit your first post accordingly and restore the information you removed that would help others help you.
I fail to understand what the title of the topic wants…:thinking:
:woman_shrugging:
I chose this command Line to see logs and if I have any errors Because I made a few mistakes and want to know if I should reinstall
do a fresh install?
That’s very seldom necessary. I see nothing wrong, personally. Please see below for more information:
But that is one of my Problems
Pacman doesn’t open up
I will take a look at your link
thank you
Pacman != pamac (Yeah, took me a while to get it too.
AFAIK pacman is command-line only, so there’s nothing to open. Visually speaking.
On the other hand, pamac is CLI-based, and it has a visual front-end.
So when you say
…that’s expected behavior, to not see anything.
Exactly what i was talking about many thanks
That has nothing todo with the topic title… :woman_facepalming:
I will rename the topic for readers in the future…
:vulcan_salute:
sorry not me today :disappointed:
