Should I keep reporting issues with kernels when they get updated
I have reported here before that I had an issue with the backlight on my keyboard with different kernel updates. The problem went away and it is now back. 6.12-rc7 has the issue and 6.11.7 has the issue again. 6.10.14 works fine.
If I remember correctly I was told here to just use the one that works. Of course I would do that.
But wanted to know if I should keep reporting this issue.
Hi @MAYBL8,
Nah, I don’t think you need to do it over and over again. I am not 100% on that, but I don’t think so.
Side note:
That kernel is EOL and will probably be removed with the next update. Best find an LTS one that works. Or something. I remember you had WiFi problems, so I don’t know if it’ll work with an older kernel or not, but 6.10 will have to be wished a good retirement.
