Hello,
I am using system 64bit for full AMD build PC 2019.
There are 32-bit-packages of GPU driver:
lib32-mesa-vdpau lib32-libva lib32-libvdpau lib32-libva-vdpau-driver
Should I remove these 32-bit-packages of GPU driver without any issue?
Hello,
Some applications, like Steam, might depend on them.
Okay,
some applications automatically choose lib64 packages if my hardwares support full 64 bit system?
yes. Only if an application looks for a lib32, it will use a lib32.
