New update this morning for Shortwave but it is not compiling. Error
Citation Updating crates.io index
warning: spurious network error (2 tries remaining): error inflating zlib stream; class=Zlib (5)
warning: spurious network error (1 tries remaining): incorrect data check; class=Zlib (5)
error: Unable to update registry `crates-io`
Caused by:
failed to fetch `https://github.com/rust-lang/crates.io-index`
Caused by:
[34/35] Generating data/de.haeckerfelix.Shortwave.metainfo.xml with a custom command
FAILED: src/shortwave
/usr/bin/env CARGO_HOME=/var/tmp/pamac-build-maurice/shortwave/src/build/cargo-home /usr/bin/cargo build --manifest-path /var/tmp/pamac-build-maurice/shortwave/src/Shortwave-3.0.0/Cargo.toml --target-dir /var/tmp/pamac-build-maurice/shortwave/src/build/target --release && cp target/release/shortwave src/shortwave
ninja: build stopped: subcommand failed.
==> ERREUR : Une erreur s’est produite dans build().
Abandon…
Moderator edit: In the future, please use proper formatting: [HowTo] Post command output and file content as formatted text
