Hello, I wanted to try Gnome with Xorg today (to share my screen during a video conference).
When I wanted to come back to Gnome with Wayland (in the choice of Gnome sessions at the connection I can choose between Gnome, classic Gnome and Gnome with Xorg).
But the display is not the same, and in gnome-tweak-tool, for the shell I have an error.
I’m sorry I can’t include screenshot nor link in my message. But I’ve got a little warning symbol just next to the word shell in the gnome-tweak-tool application, in the appearance section, just under icons, and above sound. And I can’t select any shell, the drop-down menu is grayed out and nothing happens when I click on it.
How to solve this ? I don’t understand well where the problem comes from.
Ok, I just click on the little wheel down-right on the login panel. I didn’t think it would be so much trouble.
I can’t activate any gnome-shell extension for example now. All my tray icons on the top bar have disappeard (I can see my wi-fi logo for example but not my mullvad-vpn tray icon).
How could I fix it ? Is there a way to re-install all my gnome-shell ? Or would it be worse ? Or if it would be better, how to do so ?
Ok, I launched the layouts progam, I switched it to an other (just to try) and went back to manjaro, and it works just fine now.
But, the package gnome-initial-setup is now 3.38.4-2, and not 40.0-1, i didn’t really downgraded it, I just re-installed it, I hope it won’t cause any problem ^^’
