Hi there. Today I ran into a problem that makes my system unusable. Maybe you can help.
The Login screen is displayed without any problems. After login XFCE fails to show. I use two monitors. The main one shows some friction at the top area. Rest is blacked out. Mouse works.
I encountered this before every now and then (not often). In the past I booted my second system (Trisquel), opened an ssh and rebooted Manjaro. After reboot XFCE did come up normally. Until today. So far neither machine reboot did bring up XFCE.
My Manajro is up to date and it worked these last day without problems.
Via Trisquel notebook I have access to journalctl during XFCE boot. (Output appended)
Would really appreciate ideas. Thanks.
-- Logs begin at Mon 2020-08-17 13:31:01 CEST. --
Aug 21 11:46:44 Panther systemd[610]: Listening on D-Bus User Message Bus Socket.
Aug 21 11:46:44 Panther systemd[610]: Reached target Sockets.
Aug 21 11:46:44 Panther systemd[610]: Reached target Basic System.
Aug 21 11:46:44 Panther systemd[1]: Started User Manager for UID 1000.
Aug 21 11:46:44 Panther systemd[1]: Started Session 1 of user ak.
Aug 21 11:46:44 Panther systemd[610]: Starting Update XDG user dir configuration...
Aug 21 11:46:44 Panther systemd[610]: xdg-user-dirs-update.service: Succeeded.
Aug 21 11:46:44 Panther systemd[610]: Finished Update XDG user dir configuration.
Aug 21 11:46:44 Panther systemd[610]: Reached target Main User Target.
Aug 21 11:46:44 Panther systemd[610]: Startup finished in 415ms.
Aug 21 11:46:56 Panther NetworkManager[512]: <warn> [1598003216.7508] dhcp6 (enp0s25): request timed out
Aug 21 11:46:56 Panther NetworkManager[512]: <info> [1598003216.7508] dhcp6 (enp0s25): state changed unknown -> timeout
Aug 21 11:47:04 Panther audit[549]: USER_AUTH pid=549 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:authentication grantors=pam_unix acct="ak" exe="/usr/bin/mdm-binary" hostname=? addr=? terminal=:0 res=success'
Aug 21 11:47:04 Panther kernel: kauditd_printk_skb: 2 callbacks suppressed
Aug 21 11:47:04 Panther kernel: audit: type=1100 audit(1598003224.117:79): pid=549 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:authentication grantors=pam_unix acct="ak" exe="/usr/bin/mdm-binary" hostname=? addr=? terminal=:0 res=success'
Aug 21 11:47:04 Panther kernel: audit: type=1101 audit(1598003224.121:80): pid=549 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:accounting grantors=pam_unix acct="ak" exe="/usr/bin/mdm-binary" hostname=? addr=? terminal=:0 res=success'
Aug 21 11:47:04 Panther audit[549]: USER_ACCT pid=549 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:accounting grantors=pam_unix acct="ak" exe="/usr/bin/mdm-binary" hostname=? addr=? terminal=:0 res=success'
Aug 21 11:47:04 Panther audit[549]: CRED_ACQ pid=549 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:setcred grantors=pam_unix acct="ak" exe="/usr/bin/mdm-binary" hostname=? addr=? terminal=:0 res=success'
Aug 21 11:47:04 Panther mdm-binary[549]: pam_unix(mdm:session): session opened for user ak by (uid=0)
Aug 21 11:47:04 Panther kernel: audit: type=1103 audit(1598003224.121:81): pid=549 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:setcred grantors=pam_unix acct="ak" exe="/usr/bin/mdm-binary" hostname=? addr=? terminal=:0 res=success'
Aug 21 11:47:04 Panther systemd-logind[514]: New session c1 of user ak.
Aug 21 11:47:04 Panther systemd[1]: Started Session c1 of user ak.
Aug 21 11:47:04 Panther audit[549]: USER_START pid=549 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_systemd acct="ak" exe="/usr/bin/mdm-binary" hostname=? addr=? terminal=:0 res=success'
Aug 21 11:47:04 Panther kernel: audit: type=1105 audit(1598003224.127:82): pid=549 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_systemd acct="ak" exe="/usr/bin/mdm-binary" hostname=? addr=? terminal=:0 res=success'
Aug 21 11:47:04 Panther mdm-binary[549]: GLib-CRITICAL: g_key_file_get_string: assertion 'key_file != NULL' failed
Aug 21 11:47:04 Panther mdm-binary[549]: GLib-CRITICAL: g_key_file_free: assertion 'key_file != NULL' failed
Aug 21 11:47:04 Panther systemd[610]: Started D-Bus User Message Bus.
Aug 21 11:47:06 Panther dbus-daemon[646]: [session uid=1000 pid=646] Activating via systemd: service name='org.gtk.vfs.Daemon' unit='gvfs-daemon.service' requested by ':1.4' (uid=1000 pid=623 comm="xfce4-session ")
Aug 21 11:47:06 Panther systemd[610]: Starting Virtual filesystem service...
Aug 21 11:47:06 Panther dbus-daemon[646]: [session uid=1000 pid=646] Successfully activated service 'org.gtk.vfs.Daemon'
Aug 21 11:47:06 Panther systemd[610]: Started Virtual filesystem service.
Aug 21 11:47:06 Panther kernel: fuse: init (API version 7.31)
Aug 21 11:47:06 Panther kernel: *** VALIDATE fuse ***
Aug 21 11:47:06 Panther systemd[1]: Mounting FUSE Control File System...
Aug 21 11:47:06 Panther systemd[1]: Mounted FUSE Control File System.
Aug 21 11:47:06 Panther dbus-daemon[646]: [session uid=1000 pid=646] Activating via systemd: service name='org.a11y.Bus' unit='at-spi-dbus-bus.service' requested by ':1.6' (uid=1000 pid=623 comm="xfce4-session ")
Aug 21 11:47:06 Panther systemd[610]: Starting Accessibility services bus...
Aug 21 11:47:06 Panther dbus-daemon[646]: [session uid=1000 pid=646] Successfully activated service 'org.a11y.Bus'
Aug 21 11:47:06 Panther systemd[610]: Started Accessibility services bus.
Aug 21 11:47:06 Panther dbus-daemon[646]: [session uid=1000 pid=646] Activating service name='org.xfce.Xfconf' requested by ':1.4' (uid=1000 pid=623 comm="xfce4-session ")
Aug 21 11:47:07 Panther dbus-daemon[646]: [session uid=1000 pid=646] Successfully activated service 'org.xfce.Xfconf'
Aug 21 11:47:07 Panther at-spi-bus-launcher[687]: dbus-daemon[687]: Activating service name='org.a11y.atspi.Registry' requested by ':1.0' (uid=1000 pid=623 comm="xfce4-session ")
Aug 21 11:47:07 Panther at-spi-bus-launcher[687]: dbus-daemon[687]: Successfully activated service 'org.a11y.atspi.Registry'
Aug 21 11:47:07 Panther at-spi-bus-launcher[695]: SpiRegistry daemon is running with well-known name - org.a11y.atspi.Registry
Aug 21 11:47:07 Panther systemd[610]: Started GnuPG cryptographic agent and passphrase cache.
Aug 21 11:47:07 Panther gpg-agent[700]: gpg-agent (GnuPG) 2.2.21 starting in supervised mode.
Aug 21 11:47:07 Panther gpg-agent[700]: using fd 3 for browser socket (/run/user/1000/gnupg/S.gpg-agent.browser)
Aug 21 11:47:07 Panther gpg-agent[700]: using fd 4 for std socket (/run/user/1000/gnupg/S.gpg-agent)
Aug 21 11:47:07 Panther gpg-agent[700]: using fd 5 for ssh socket (/run/user/1000/gnupg/S.gpg-agent.ssh)
Aug 21 11:47:07 Panther gpg-agent[700]: using fd 6 for extra socket (/run/user/1000/gnupg/S.gpg-agent.extra)
Aug 21 11:47:07 Panther gpg-agent[700]: listening on: std=4 extra=6 browser=3 ssh=5
Aug 21 11:47:08 Panther systemd[610]: Starting Sound Service...
Aug 21 11:47:09 Panther dbus-daemon[511]: [system] Activating via systemd: service name='org.freedesktop.RealtimeKit1' unit='rtkit-daemon.service' requested by ':1.39' (uid=1000 pid=713 comm="/usr/bin/pulseaudio --daemonize=no ")
Aug 21 11:47:09 Panther systemd[1]: Starting RealtimeKit Scheduling Policy Service...
Aug 21 11:47:09 Panther dbus-daemon[511]: [system] Successfully activated service 'org.freedesktop.RealtimeKit1'
Aug 21 11:47:09 Panther audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=rtkit-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Aug 21 11:47:09 Panther systemd[1]: Started RealtimeKit Scheduling Policy Service.
Aug 21 11:47:09 Panther rtkit-daemon[719]: Successfully called chroot.
Aug 21 11:47:09 Panther rtkit-daemon[719]: Successfully dropped privileges.
Aug 21 11:47:09 Panther rtkit-daemon[719]: Successfully limited resources.
Aug 21 11:47:09 Panther rtkit-daemon[719]: Running.
Aug 21 11:47:09 Panther rtkit-daemon[719]: Canary thread running.
Aug 21 11:47:09 Panther rtkit-daemon[719]: Watchdog thread running.
Aug 21 11:47:09 Panther kernel: audit: type=1130 audit(1598003229.577:83): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=rtkit-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Aug 21 11:47:10 Panther rtkit-daemon[719]: Successfully made thread 713 of process 713 owned by '1000' high priority at nice level -11.
Aug 21 11:47:10 Panther rtkit-daemon[719]: Supervising 1 threads of 1 processes of 1 users.
Aug 21 11:47:11 Panther rtkit-daemon[719]: Supervising 1 threads of 1 processes of 1 users.
Aug 21 11:47:11 Panther rtkit-daemon[719]: Successfully made thread 730 of process 713 owned by '1000' RT at priority 5.
Aug 21 11:47:11 Panther rtkit-daemon[719]: Supervising 2 threads of 1 processes of 1 users.
Aug 21 11:47:11 Panther rtkit-daemon[719]: Successfully made thread 734 of process 713 owned by '1000' RT at priority 5.
Aug 21 11:47:11 Panther rtkit-daemon[719]: Supervising 3 threads of 1 processes of 1 users.
Aug 21 11:47:12 Panther dbus-daemon[646]: [session uid=1000 pid=646] Activating service name='org.freedesktop.thumbnails.Thumbnailer1' requested by ':1.18' (uid=1000 pid=736 comm="xfdesktop ")
Aug 21 11:47:12 Panther rtkit-daemon[719]: Supervising 3 threads of 1 processes of 1 users.
Aug 21 11:47:12 Panther rtkit-daemon[719]: Successfully made thread 742 of process 713 owned by '1000' RT at priority 5.
Aug 21 11:47:12 Panther rtkit-daemon[719]: Supervising 4 threads of 1 processes of 1 users.
Aug 21 11:47:12 Panther dbus-daemon[511]: [system] Activating via systemd: service name='org.bluez' unit='dbus-org.bluez.service' requested by ':1.44' (uid=1000 pid=713 comm="/usr/bin/pulseaudio --daemonize=no ")
Aug 21 11:47:12 Panther systemd[1]: Condition check resulted in Bluetooth service being skipped.
Aug 21 11:47:12 Panther tumblerd[741]: Failed to load plugin "tumbler-raw-thumbnailer.so": libopenrawgnome.so.7: cannot open shared object file: No such file or directory
Aug 21 11:47:13 Panther polkitd[513]: Registered Authentication Agent for unix-session:c1 (system bus name :1.45 [/usr/lib/polkit-gnome/polkit-gnome-authentication-agent-1], object path /org/gnome/PolicyKit1/AuthenticationAgent, locale de_DE.UTF-8)
Aug 21 11:47:13 Panther systemd[610]: Started Sound Service.
Aug 21 11:47:14 Panther NetworkManager[512]: <info> [1598003234.0717] agent-manager: agent[7a41ac53102ed52e,:1.48/org.freedesktop.nm-applet/1000]: agent registered
Aug 21 11:47:15 Panther dbus-daemon[646]: [session uid=1000 pid=646] Activating via systemd: service name='org.gnome.zeitgeist.Engine' unit='zeitgeist.service' requested by ':1.26' (uid=1000 pid=787 comm="zeitgeist-datahub ")
Aug 21 11:47:15 Panther systemd[610]: Starting Zeitgeist activity log service...
Aug 21 11:47:16 Panther kernel: [UFW BLOCK] IN=enp0s25 OUT= MAC=01:00:5e:00:00:01:dc:39:6f:52:2b:b3:08:00 SRC=192.168.178.1 DST=224.0.0.1 LEN=36 TOS=0x00 PREC=0xC0 TTL=1 ID=49046 DF PROTO=2
Aug 21 11:47:16 Panther org.freedesktop.thumbnails.Thumbnailer1[741]: Registered thumbnailer ffmpegthumbnailer -i %i -o %o -s %s -f
Aug 21 11:47:16 Panther org.freedesktop.thumbnails.Thumbnailer1[741]: Registered thumbnailer heif-thumbnailer -s %s %i %o
Aug 21 11:47:16 Panther org.freedesktop.thumbnails.Thumbnailer1[741]: Registered thumbnailer gsf-office-thumbnailer -i %i -o %o -s %s
Aug 21 11:47:16 Panther org.freedesktop.thumbnails.Thumbnailer1[741]: Registered thumbnailer mypaint-ora-thumbnailer %i %o %s
Aug 21 11:47:16 Panther org.freedesktop.thumbnails.Thumbnailer1[741]: Registered thumbnailer /usr/bin/gdk-pixbuf-thumbnailer -s %s %u %o
Aug 21 11:47:17 Panther org.freedesktop.thumbnails.Thumbnailer1[741]: Registered thumbnailer evince-thumbnailer -s %s %u %o
Aug 21 11:47:17 Panther dbus-daemon[646]: [session uid=1000 pid=646] Activating via systemd: service name='org.gtk.vfs.UDisks2VolumeMonitor' unit='gvfs-udisks2-volume-monitor.service' requested by ':1.19' (uid=1000 pid=741 comm="/usr/lib/tumbler-1/tumblerd ")
Aug 21 11:47:17 Panther systemd[610]: Starting Virtual filesystem service - disk device monitor...
Aug 21 11:47:17 Panther dbus-daemon[511]: [system] Activating via systemd: service name='org.freedesktop.UDisks2' unit='udisks2.service' requested by ':1.49' (uid=1000 pid=799 comm="/usr/lib/gvfs-udisks2-volume-monitor ")
Aug 21 11:47:17 Panther systemd[1]: Starting Disk Manager...
Aug 21 11:47:17 Panther udisksd[805]: udisks daemon version 2.9.0 starting
Aug 21 11:47:18 Panther dbus-daemon[511]: [system] Activating via systemd: service name='org.manjaro.pamac.daemon' unit='pamac-daemon.service' requested by ':1.52' (uid=1000 pid=783 comm="pamac-tray ")
Aug 21 11:47:18 Panther systemd[1]: Starting Pamac Daemon...
Aug 21 11:47:18 Panther dbus-daemon[511]: [system] Successfully activated service 'org.manjaro.pamac.daemon'
Aug 21 11:47:18 Panther systemd[1]: Started Pamac Daemon.
Aug 21 11:47:18 Panther audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=pamac-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Aug 21 11:47:18 Panther kernel: audit: type=1130 audit(1598003238.757:84): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=pamac-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Aug 21 11:47:18 Panther systemd[1]: pamac-daemon.service: Succeeded.
Aug 21 11:47:18 Panther audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=pamac-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Aug 21 11:47:18 Panther kernel: audit: type=1131 audit(1598003238.760:85): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=pamac-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Aug 21 11:47:19 Panther dbus-daemon[511]: [system] Successfully activated service 'org.freedesktop.UDisks2'
Aug 21 11:47:19 Panther systemd[1]: Started Disk Manager.
Aug 21 11:47:19 Panther audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=udisks2 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Aug 21 11:47:19 Panther kernel: audit: type=1130 audit(1598003239.254:86): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=udisks2 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Aug 21 11:47:19 Panther udisksd[805]: Acquired the name org.freedesktop.UDisks2 on the system message bus
Aug 21 11:47:19 Panther dbus-daemon[646]: [session uid=1000 pid=646] Successfully activated service 'org.gtk.vfs.UDisks2VolumeMonitor'
Aug 21 11:47:19 Panther systemd[610]: Started Virtual filesystem service - disk device monitor.
Aug 21 11:47:19 Panther dbus-daemon[646]: [session uid=1000 pid=646] Activating via systemd: service name='org.gtk.vfs.AfcVolumeMonitor' unit='gvfs-afc-volume-monitor.service' requested by ':1.19' (uid=1000 pid=741 comm="/usr/lib/tumbler-1/tumblerd ")
Aug 21 11:47:19 Panther systemd[610]: Starting Virtual filesystem service - Apple File Conduit monitor...
Aug 21 11:47:19 Panther dbus-daemon[646]: [session uid=1000 pid=646] Successfully activated service 'org.gtk.vfs.AfcVolumeMonitor'
Aug 21 11:47:19 Panther systemd[610]: Started Virtual filesystem service - Apple File Conduit monitor.
Aug 21 11:47:19 Panther dbus-daemon[646]: [session uid=1000 pid=646] Activating via systemd: service name='org.gtk.vfs.MTPVolumeMonitor' unit='gvfs-mtp-volume-monitor.service' requested by ':1.19' (uid=1000 pid=741 comm="/usr/lib/tumbler-1/tumblerd ")
Aug 21 11:47:19 Panther systemd[610]: Starting Virtual filesystem service - Media Transfer Protocol monitor...
Aug 21 11:47:19 Panther dbus-daemon[646]: [session uid=1000 pid=646] Successfully activated service 'org.gtk.vfs.MTPVolumeMonitor'
Aug 21 11:47:19 Panther systemd[610]: Started Virtual filesystem service - Media Transfer Protocol monitor.
Aug 21 11:47:19 Panther dbus-daemon[646]: [session uid=1000 pid=646] Activating via systemd: service name='org.gtk.vfs.GPhoto2VolumeMonitor' unit='gvfs-gphoto2-volume-monitor.service' requested by ':1.19' (uid=1000 pid=741 comm="/usr/lib/tumbler-1/tumblerd ")
Aug 21 11:47:19 Panther systemd[610]: Starting Virtual filesystem service - digital camera monitor...
Aug 21 11:47:19 Panther dbus-daemon[646]: [session uid=1000 pid=646] Successfully activated service 'org.gtk.vfs.GPhoto2VolumeMonitor'
Aug 21 11:47:19 Panther systemd[610]: Started Virtual filesystem service - digital camera monitor.
Aug 21 11:47:19 Panther dbus-daemon[646]: [session uid=1000 pid=646] Successfully activated service 'org.freedesktop.thumbnails.Thumbnailer1'
Aug 21 11:47:24 Panther dbus-daemon[646]: [session uid=1000 pid=646] Activating via systemd: service name='org.freedesktop.Notifications' unit='xfce4-notifyd.service' requested by ':1.21' (uid=1000 pid=751 comm="xfce4-power-manager ")
Aug 21 11:47:24 Panther systemd[610]: Starting XFCE notifications service...
Aug 21 11:47:24 Panther dbus-daemon[646]: [session uid=1000 pid=646] Successfully activated service 'org.freedesktop.Notifications'
Aug 21 11:47:24 Panther systemd[610]: Started XFCE notifications service.
Aug 21 11:47:24 Panther dbus-daemon[511]: [system] Activating via systemd: service name='org.freedesktop.UPower' unit='upower.service' requested by ':1.54' (uid=1000 pid=751 comm="xfce4-power-manager ")
Aug 21 11:47:24 Panther systemd[1]: Starting Daemon for power management...
Aug 21 11:47:24 Panther dbus-daemon[646]: [session uid=1000 pid=646] Activating via systemd: service name='org.gnome.zeitgeist.SimpleIndexer' unit='zeitgeist-fts.service' requested by ':1.28' (uid=1000 pid=794 comm="/usr/bin/zeitgeist-daemon ")
Aug 21 11:47:24 Panther dbus-daemon[646]: [session uid=1000 pid=646] Successfully activated service 'org.gnome.zeitgeist.Engine'
Aug 21 11:47:24 Panther systemd[610]: Started Zeitgeist activity log service.
Aug 21 11:47:24 Panther systemd[610]: Starting Zeitgeist full-text search indexer...
Aug 21 11:47:25 Panther dbus-daemon[511]: [system] Successfully activated service 'org.freedesktop.UPower'
Aug 21 11:47:25 Panther systemd[1]: Started Daemon for power management.
Aug 21 11:47:25 Panther audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=upower comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Aug 21 11:47:25 Panther kernel: audit: type=1130 audit(1598003245.434:87): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=upower comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Aug 21 11:47:26 Panther dbus-daemon[646]: [session uid=1000 pid=646] Successfully activated service 'org.gnome.zeitgeist.SimpleIndexer'
Aug 21 11:47:26 Panther systemd[610]: Started Zeitgeist full-text search indexer.
Aug 21 11:47:29 Panther dbus-daemon[646]: [session uid=1000 pid=646] Activating via systemd: service name='org.gtk.vfs.Metadata' unit='gvfs-metadata.service' requested by ':1.18' (uid=1000 pid=736 comm="xfdesktop ")
Aug 21 11:47:29 Panther systemd[610]: Starting Virtual filesystem metadata service...
Aug 21 11:47:29 Panther dbus-daemon[646]: [session uid=1000 pid=646] Successfully activated service 'org.gtk.vfs.Metadata'
Aug 21 11:47:29 Panther systemd[610]: Started Virtual filesystem metadata service.
Aug 21 11:47:37 Panther dbus-daemon[511]: [system] Failed to activate service 'org.bluez': timed out (service_start_timeout=25000ms)
Aug 21 11:47:37 Panther pulseaudio[713]: E: [pulseaudio] bluez5-util.c: GetManagedObjects() failed: org.freedesktop.DBus.Error.NoReply: Did not receive a reply. Possible causes include: the remote application did not send a reply, the message bus security policy blocked the reply, the reply timeout expired, or the network connection was broken.
