"Shaking Cursor" entry under "System Settings -> Accessibility" missing
Manjaro Linux KDE Plasma Version 6.3.0 missing this entry. KDE Neon has it, Kubuntu (beta) has it.
Thanks for letting us know.
Update Announcements:
System Information:
inxi --filter --verbosity=8
or the short form:
inxi -zv8
Be prepared to provide more information and outputs from other commands whenever asked.
Required Reading:
Resources:
Hi @Michelle :slight_smile:
I’m on 6.3 and it’s not missing for me.
I can also repeat that it is available here.
The feature has been present since … if not Plasma 6.0, then at least Plasma 6.1.
No, it was introduced in 6.2. :stuck_out_tongue:
Everything seems to point to 6.1
https://bugs.kde.org/show_bug.cgi?id=488882
https://www.reddit.com/r/kde/comments/1dk9trj/shaking_a_big_cursor_on_plasma_61
I’d link an actual git source but I have no idea where this would be.
kwin maybe?
The option is under an ‘Accessibility’ kcm now …
Irrespective of when the Shake Cursor option first appeared in Plasma’s System Settings, it certainly seems to exist in Plasma 6.2.5-1 currently available in the Stable branch:
@Michelle
Are you sure you were looking in the right place? :slight_smile:
On my system it did not appear under X11 but as soon as I switched to Wayland. May be worth a trial.
Yes! I switched to Wayland and now it appears! Thanks for the suggestion.
