malawi
18 February 2021 10:56
1
Hello world, first post here!
I noticed that the shasum doesn’t match when downloading the latest manjaro-architect-20.0.3-200607-linux56.iso
The official download page on manjaro dot org gives me a SHA checksum. This doesn’t match the file I’ve downloaded (twice) from the osdn dot net site, which it links to.
bill_t
18 February 2021 11:26
2
Hi and welcome to the Forum!
I just downloaded the Architect ISO and the SHA1 sum matched exactly to the one displayed in the Manjaro website.
Which command did you use to verify the downloaded ISO?
sha1sum /path/to/manjaro-architect-20.0.3-200607-linux56.iso
You can also use the “normal” installation iso and then start the architect installer.
malawi
18 February 2021 11:54
4
ouch, learnt something new. Thanks for asking the right question. I did
shasum -a 256 manjaro-architect-20.0.3-200607-linux56.iso
thinking it’s the same as
shasum manjaro-architect-20.0.3-200607-linux56.iso
it’s obviously not. The sum matches now.
(I’m working on a Mac which doesn’t have sha1sum, only shasum, but seems to work as expected)
OK. The you can continue with installtion…
