Hi there,
since ~4 weeks my computer will not return from suspend correctly - I get a red screen. Additionally, the system freezes more or less every time using any Android development tools (adb, emulator, …).
Currently, I’m running the latest kernel (5.19.0-2-MANJARO) but I get the same dumps with current LTS 5.15 (I tried 5.19 to see if it’s a kernel issue). I’m using SWAY (amd64) with the HiDPI extensions.
Looking into journalctl I get several errors during the day. But I don’t know how to proceed from there on. I post the errors in the following but I’m also glad for any hint/advise how I can further troubleshoot the actual problem(s).
$ lscpu
Architecture: x86_64
CPU op-mode(s): 32-bit, 64-bit
Address sizes: 48 bits physical, 48 bits virtual
Byte Order: Little Endian
CPU(s): 16
On-line CPU(s) list: 0-15
Vendor ID: AuthenticAMD
Model name: AMD Ryzen 7 5700G with Radeon Graphics
APPIMAGELAUNCHER DUMP
Aug 09 09:20:07 [COMPUTER_NAME] systemd-coredump[3013]: [🡕] Process 1419 (appimagelaunche) of user 1001 dumped core.
Module linux-vdso.so.1 with build-id 125b0285aa529b1b1396ff79a856cc580f53371b
Module libdatrie.so.1 with build-id 6fe3b6ece2c8e7d11869fa051375128d8f808f58
Module libblkid.so.1 with build-id 140694a62d8d4d07c6c320a501f948dd1b389d73
Module libgpg-error.so.0 with build-id 4738b8a9478177c202cccd64e0eb65d3dea2bfae
Module libXdmcp.so.6 with build-id d864159ab0008415667db8d5f251696d75c90df2
Module libXau.so.6 with build-id 60db1eac70f819bea9d4c366603c1583067510b4
Module libthai.so.0 with build-id a7ac5010b4275c49308021200d23690533952702
Module libfribidi.so.0 with build-id fe9f35ac2a0074108c8306c517793f7279bd9b37
Module libpangoft2-1.0.so.0 with build-id 1d293edcbaefc8c1b024f83d0935e88e6f09dfcb
Module libmount.so.1 with build-id 4436aeea0cd8c01b5a77969e0531184f8b3513ce
Module libtiff.so.5 with build-id 31895d2bd133f34f0cdc2d4ac855ed838ec927b6
Module libjpeg.so.8 with build-id 8e6d3f3e8f438912b561c43b6e7f66e6e5e097d0
Module libgmodule-2.0.so.0 with build-id abd986222e2cf12fc7324cb0182dfc2c8f2269c0
Module libgraphite2.so.3 with build-id ce58945ebb55b86d3a4e717b6eae29efc4720d8e
Module libGLX.so.0 with build-id 02bd4ac6acc4da9288c543ea1a0cdaa70c5e151a
Module libGLdispatch.so.0 with build-id de981c020bd9dbdc159b11f4a2a541310cc3b8d5
Module libbrotlicommon.so.1 with build-id acfd597a977c8087bb6184383daae2e828a9ce42
Module libresolv.so.2 with build-id 89a368a6ad1b392d126a2a5beb9c2f61ade00279
Module libkeyutils.so.1 with build-id ac405ddd17be10ce538da3211415ee50c8f8df79
Module libkrb5support.so.0 with build-id 15f223925ef59dee4379ebbc0fcd14eda9ba81a2
Module libcom_err.so.2 with build-id 3360a28740ffbbd5a5c0c21d09072445908707e5
Module libk5crypto.so.3 with build-id cc77a742cb62447a53d98285b41558b8acd92866
Module libkrb5.so.3 with build-id 371cc767dacb17cb42c9c44b88eebbed5ee9a756
Module libunistring.so.2 with build-id 617dbf3d3d6f85d6556a7a036e23845e95490158
Module libicudata.so.71 with build-id 4fef196388e678deb881978139e125e20ee2d94d
Module libgcrypt.so.20 with build-id 8bf3cb884124273640de797a3e77d86c98434ea4
Module libcap.so.2 with build-id 1f87347b85b55db2f75a2ecea5cb45d846dc7093
Module libpthread.so.0 with build-id 95ae4f30a6f12ccbff645d30f8e1a3ee23ec7d36
Module libpixman-1.so.0 with build-id d2170a3ac106c2a68597bf7910ab04b1cdd69c14
Module libxcb-shm.so.0 with build-id 828fec4d856e2710e732ea8d92c3f250c807b1c2
Module libxcb-render.so.0 with build-id b1ca498d665807ab0ccdafbe8070853efd058173
Module libxcb.so.1 with build-id 13d677412a71468381b11092915d231f664d18d3
Module libXrender.so.1 with build-id 42e386d2acf3cde61081959d9671ca74acfb3edc
Module libXext.so.6 with build-id 17beadf1cb40d41ab36629db3b4eed74110678a7
Module libX11.so.6 with build-id 21e886e968772b7964d646f54c1faecc56734de9
Module libfreetype.so.6 with build-id f89dd5502e75aca28fb5c3ccd0dbd26fe822bfef
Module libfontconfig.so.1 with build-id 36be6951b8c1e42a7dd05684a37400fc8ef9147c
Module libffi.so.8 with build-id f0a9586cf0f42d2b9971bd1065ca3a6b19f4a2c2
Module libpango-1.0.so.0 with build-id b358a862a5ca8b1e4e69235edce1780e9f860a0a
Module libpangocairo-1.0.so.0 with build-id e7a2a9e56f2e2f6121d9c5741b3e93871b673cfa
Module libxml2.so.2 with build-id 8cdf00fa954d9a27f2f184c4d354cb14677446ac
Module libgio-2.0.so.0 with build-id 7a769ec24a9a705d04ee0297730032f70ed0835b
Module libgdk_pixbuf-2.0.so.0 with build-id 5b8422ab971b1a8a8e1c43b88738d4ee217f609e
Module libcairo-gobject.so.2 with build-id 9927090dddfb180365695a8f37d1cac89463f109
Module libbz2.so.1.0 with build-id 919597c477c9b2cb9cdbb7745ed6494ac0e6da60
Module liblz4.so.1 with build-id e63600ab23b2f6997f42fac2fa56e1f02ce159a1
Module liblzma.so.5 with build-id 28b40c7af8098a66af6ee093b6986b91cad7694d
Module libexpat.so.1 with build-id 113bb5a3e9ad856801bfcfc029102c9bdc13d67e
Module libacl.so.1 with build-id 27869ed0219ade5d2ffd50eaee11f967187faa8b
Module libboost_atomic.so.1.79.0 with build-id ad9294c9165513a5fd44de17ac2749d91f87d953
Module libmd4c.so.0 with build-id 2151dba72cdc9960097e6e960a58a2f03c8bb96e
Module libharfbuzz.so.0 with build-id b7daeb45a60c6cc012417c5cfaa09c91235d06bd
Module libpng16.so.16 with build-id 2dc0bce07f199bf983c07a05fb95a6f4af83a9b3
Module libGL.so.1 with build-id b915a2e48be6c9fd3cc6f9f4c7aab1f7aeed8a4c
Module libbrotlidec.so.1 with build-id 66c54e9301f7e102ecc1d88547e5f0e8a056fe22
Module libgssapi_krb5.so.2 with build-id 292f1ce32161c0ecc4a287bc8494d5d7c420a03f
Module libcrypto.so.1.1 with build-id 7981ea3d69f3c28e46ee312a815af96eab93775c
Module libssl.so.1.1 with build-id e6b1f97a5b60b4248c49dfc5b11f53f281b507d0
Module libpsl.so.5 with build-id 0229a201aaf5652186c9fdc192ebe52baf19d7f1
Module libssh2.so.1 with build-id a4adfe44cc7ebd295b3b783361acc3dcfcea1d50
Module libidn2.so.0 with build-id b16e7570b102789b13ff77289762dbfe3f8f46bc
Module libnghttp2.so.14 with build-id 16f0981d5251b03b11a49236ac403562ee458887
Module ld-linux-x86-64.so.2 with build-id 0effd0e43efa4468d3c31871c93af0b7f3005673
Module libzstd.so.1 with build-id ab54c2881f53ab314e134f3e08c76d504376dd5d
Module libpcre2-16.so.0 with build-id 68a5c2d52b45bfa6b1e93d2766e80094f52d9ebf
Module libicuuc.so.71 with build-id 633fdc0c5385d916571f6140e7a978ad0630ef55
Module libicui18n.so.71 with build-id 6fd5c97fd2808ee29958bf809656d5885e7e8963
Module libdouble-conversion.so.3 with build-id d162eb67b00f523a3f146b1077ae00fe04d5fb85
Module libz.so.1 with build-id fefe3219a96d682ec98fcfb78866b8594298b5a2
Module libsystemd.so.0 with build-id 761a39da56f185d6f1ef6f7bb95a3299789eb3e2
Module libpcre.so.1 with build-id 845483dd0acba86de9f0313102bebbaf3ce52767
Module libcairo.so.2 with build-id a222d042e56108d2786ece7bf291b56ba2069591
Module libgobject-2.0.so.0 with build-id a7515bd8cd51064d187953c0f506a43958de31a6
Module librsvg-2.so.2 with build-id 1cb5dfb747cdb53ba90f504acbe23de518c29ad9
Module libsquashfuse.so.0 with build-id 77045798a877374d704f808cb2f7131d660048c2
Module libarchive.so.13 with build-id 79dc2cbd51eb8ff72ee83974b3244027bd970ea4
Module libboost_filesystem.so.1.79.0 with build-id 78b6dbba53b1ee327f048c9f4845a6a476ee1a1d
Module libm.so.6 with build-id 1b7296ef9fd806e47060788389293c824b09ad72
Module libQt5Gui.so.5 with build-id 5dc44434b080822ff6271acce3a21cc1dc08d632
Module libcurl.so.4 with build-id 8e801dde5d7263a70bb78c67350f5762277ab9c1
Module libdbus-1.so.3 with build-id 7f4b16b4b407cbae2d7118d6f99610e29a18a56a
Module libc.so.6 with build-id 60df1df31f02a7b23da83e8ef923359885b81492
Module libgcc_s.so.1 with build-id 0e3de903950e35ae59a5de8c00b1817a4a71ca01
Module libstdc++.so.6 with build-id a24b312bb5881ceae0ffbed599201690f2a1747b
Module libQt5Core.so.5 with build-id d0b7a28d507dd3904c4566fcb8cbb3b006a93040
Module libglib-2.0.so.0 with build-id 1340f3a762b2293ebf6d725edf0eb14839f85317
Module libappimage.so.1.0 with build-id d4213836d298987b134f709f2e7847f44ff2c50b
Module libQt5Widgets.so.5 with build-id daaeb7c87490a699b9b5a98577fde1cdc6ed1819
Module libappimageupdate.so with build-id 531346ef72056cf637e5b05f2b05ddf507c48e92
Module libQt5DBus.so.5 with build-id cb4975246458c1f3591617bc981289d39c812a1c
Module appimagelauncherd with build-id a6c7d2a03a4b0575e872b32f89fcab6bdae1e612
Stack trace of thread 1419:
#0 0x00007fd1ecdd63d4 local_Rb_tree_increment (libstdc++.so.6 + 0xbf3d4)
#1 0x000055a2bd806e71 n/a (appimagelauncherd + 0x16e71)
#2 0x000055a2bd80064a n/a (appimagelauncherd + 0x1064a)
#3 0x00007fd1ed20d341 n/a (libQt5Core.so.5 + 0x2bd341)
#4 0x00007fd1ed20f6ff _ZN6QTimer7timeoutENS_14QPrivateSignalE (libQt5Core.so.5 + 0x2bf6ff)
#5 0x00007fd1ed2003e6 _ZN7QObject5eventEP6QEvent (libQt5Core.so.5 + 0x2b03e6)
#6 0x00007fd1ed1dcabc _ZN16QCoreApplication15notifyInternal2EP7QObjectP6QEvent (libQt5Core.so.5 + 0x28cabc)
#7 0x00007fd1ed226b73 _ZN14QTimerInfoList14activateTimersEv (libQt5Core.so.5 + 0x2d6b73)
#8 0x00007fd1ed22716a n/a (libQt5Core.so.5 + 0x2d716a)
#9 0x00007fd1ed4c6c6b g_main_context_dispatch (libglib-2.0.so.0 + 0x54c6b)
#10 0x00007fd1ed51d001 n/a (libglib-2.0.so.0 + 0xab001)
#11 0x00007fd1ed4c4392 g_main_context_iteration (libglib-2.0.so.0 + 0x52392)
#12 0x00007fd1ed22732c _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt5Core.so.5 + 0x2d732c)
#13 0x00007fd1ed1d527c _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt5Core.so.5 + 0x28527c)
#14 0x00007fd1ed1dfda9 _ZN16QCoreApplication4execEv (libQt5Core.so.5 + 0x28fda9)
#15 0x000055a2bd7fb0e1 n/a (appimagelauncherd + 0xb0e1)
#16 0x00007fd1ecb14290 n/a (libc.so.6 + 0x29290)
#17 0x00007fd1ecb1434a __libc_start_main (libc.so.6 + 0x2934a)
#18 0x000055a2bd7fbb55 n/a (appimagelauncherd + 0xbb55)
XWAYLAND DUMP
Aug 09 10:41:15 [COMPUTER_NAME] systemd-coredump[11439]: [🡕] Process 1859 (Xwayland) of user 1001 dumped core.
Module linux-vdso.so.1 with build-id 8297ab26ede141ebb72c7adbf64763e8b69511b8
Module libvulkan.so.1 with build-id dd97393da4f886994c9dfc153b35ea6d906f57ff
Module libdrm_nouveau.so.2 with build-id 78e99e753be2b598acf02a6f30bc6615a6a3067f
Module libdrm_amdgpu.so.1 with build-id e03ead624f04700b1fd00df43863fecfb1ff8b72
Module libelf.so.1 with build-id 5ba0792747dce7480d031794ed90c620da72dbff
Module libdrm_radeon.so.1 with build-id 5c9c31961c5f0dd9b40cb3e134b8d9189ee59fbb
Module libsensors.so.5 with build-id dc8b2c1c0d8525411aca188ea3cc3fb86d381d30
Module radeonsi_dri.so with build-id f58adac87bbda2e5f4ea270dcbff1d077a7acaf7
Module libncursesw.so.6 with build-id b9917757481e6fa6097e2a1f31f5bb5eaf138c4e
Module libedit.so.0 with build-id 4b0babfcad161c2ad0af6e59e2493258db23a331
Module libstdc++.so.6 with build-id e0dd3ec5b0a62b122b4141c956c0b33a4d719144
Module libLLVM-14.so with build-id 16d23f3ab6fb7269b2f13a9932a2a7ec4b1d5104
Module libxcb-sync.so.1 with build-id 13025f6de23a271636ad321c77eda98801e62e8e
Module libxcb-present.so.0 with build-id 8ed389d9cd6ad7110fbb00c93b32e0efaa71a6b1
Module libxcb-dri3.so.0 with build-id 088c750254cc139e7d62b8a3fc7795a138447ccf
Module libxcb-xfixes.so.0 with build-id e231a68d00ee4cfa12a2c31e755a9e2c1e7be450
Module libxcb-dri2.so.0 with build-id 7bde0abc84135ae6258a8d1d130864071c2cc327
Module libX11-xcb.so.1 with build-id f92352eae0a30aea89d11beb22367fa985288925
Module libglapi.so.0 with build-id c9cb2897599baa12a671ac84a813ef3d63c665a8
Module libEGL_mesa.so.0 with build-id 704e8022bd0cba83c053cfb72e77256933872870
Module libEGL.so.1 with build-id 30b30de54f2f848a7b8bed469349c9a7ab1b7c22
Module libresolv.so.2 with build-id 33760dd6cc690f3a695616d6ae8fda65f939c4bc
Module libharfbuzz.so.0 with build-id 236ab65053439e673a39fcb7aadedb28b17a338a
Module libwayland-server.so.0 with build-id 4c54fc8a7c0d4eb8adf2a69e44ebf12d16969c74
Module libfontenc.so.1 with build-id 5a11f1fb8c3f2714be9eb6697318f20e301e1d2f
Module ld-linux-x86-64.so.2 with build-id 8dac9e5903543a5f8a5f7339139c14444b9b4e0e
Module libgcc_s.so.1 with build-id 308aed8b7d7e38f5efa23f75c25601668c1fc009
Module libc.so.6 with build-id e637217a46491314667a7a37b2155cb07afc1a40
Module libpthread.so.0 with build-id beb247374758b5c4cdc7a45b934fff02bfd90a71
Module libtirpc.so.3 with build-id 5bef2adfdee3df283f593b3e2d37b6dac405256a
Module libmd.so.0 with build-id 7c217cafdf98b55b7faa9b29c4fc6d7be56e48bc
Module libdl.so.2 with build-id 7a21bd4abe98057a730df3fcdea5099251e0d1e0
Module libxshmfence.so.1 with build-id d9b3ce4edb0b6a0818bcc57dda020d2da5e3c895
Module libm.so.6 with build-id 598f2cb2b61d6ba52686c3d0d380daea7e55e97c
Module libgbm.so.1 with build-id 589489ebc39c7c4de46d25028fd54896e0da464d
Module libepoxy.so.0 with build-id edc178a150c4255d124e1e1ecbdbecebd1a388cd
Module libdrm.so.2 with build-id 39847bc84bc769f632f8f599a62fdcc98c9270cd
Module libxcvt.so.0 with build-id 30bad674c8227152bb709556a3657d0258554309
Module libwayland-client.so.0 with build-id 515c72111400d7bdbfbdfcec78d597e4986a5943
Module libXfont2.so.2 with build-id 154202dd7ddb86f6ae4d3bc762dfd8570b86882a
Module libbsd.so.0 with build-id 696b3f699acdb6ff03a0b77d0d92ee0f927756c3
Module Xwayland with build-id 951ea97960b998772e48a4ec78873a09c95a5b37
Stack trace of thread 1859:
#0 0x00007f157cd8a4dc n/a (libc.so.6 + 0x884dc)
#1 0x00007f157cd3a998 raise (libc.so.6 + 0x38998)
#2 0x00007f157cd2453d abort (libc.so.6 + 0x2253d)
#3 0x0000561ce243c191 n/a (Xwayland + 0x167191)
#4 0x0000561ce244539d n/a (Xwayland + 0x17039d)
#5 0x0000561ce2307b41 n/a (Xwayland + 0x32b41)
#6 0x00007f157d20e45a n/a (libwayland-client.so.0 + 0x645a)
#7 0x00007f157d20e9bb n/a (libwayland-client.so.0 + 0x69bb)
#8 0x00007f157c99d536 n/a (libffi.so.8 + 0x7536)
#9 0x00007f157c99a037 n/a (libffi.so.8 + 0x4037)
#10 0x00007f157d20f645 n/a (libwayland-client.so.0 + 0x7645)
#11 0x00007f157d20fe03 n/a (libwayland-client.so.0 + 0x7e03)
#12 0x00007f157d20ffcf wl_display_dispatch_queue_pending (libwayland-client.so.0 + 0x7fcf)
#13 0x0000561ce230e28d n/a (Xwayland + 0x3928d)
#14 0x0000561ce243b7f1 n/a (Xwayland + 0x1667f1)
#15 0x0000561ce2378340 n/a (Xwayland + 0xa3340)
#16 0x0000561ce230590f n/a (Xwayland + 0x3090f)
#17 0x00007f157cd252d0 n/a (libc.so.6 + 0x232d0)
#18 0x00007f157cd2538a __libc_start_main (libc.so.6 + 0x2338a)
#19 0x0000561ce230716e n/a (Xwayland + 0x3216e)
Stack trace of thread 2005:
#0 0x00007f157cd85346 n/a (libc.so.6 + 0x83346)
#1 0x00007f157cd87b60 pthread_cond_wait (libc.so.6 + 0x85b60)
#2 0x00007f1569eb27cc n/a (radeonsi_dri.so + 0xb27cc)
#3 0x00007f1569eabecc n/a (radeonsi_dri.so + 0xabecc)
#4 0x00007f157cd8878d n/a (libc.so.6 + 0x8678d)
#5 0x00007f157ce098e4 __clone (libc.so.6 + 0x1078e4)
Stack trace of thread 2006:
Stack trace of thread 2007:
Stack trace of thread 2008:
Stack trace of thread 2010:
Stack trace of thread 2009:
Stack trace of thread 2013:
Stack trace of thread 2012:
Stack trace of thread 2015:
Stack trace of thread 2017:
Stack trace of thread 2016:
Stack trace of thread 2014:
Stack trace of thread 2018:
Stack trace of thread 2024:
Stack trace of thread 2021:
Stack trace of thread 2020:
Stack trace of thread 2025:
Stack trace of thread 2019:
Stack trace of thread 2034:
Stack trace of thread 2011:
ERRORS ON BOOT
Aug 09 10:42:57 [COMPUTER_NAME] systemd-modules-load[416]: Failed to find module 'v4l2loopback card_label="LOOPBACK" exclusive_caps=1,1,1'
Aug 09 10:42:59 [COMPUTER_NAME] kernel: gspca_vc032x: reg_r err -32
Aug 09 10:42:59 [COMPUTER_NAME] kernel: usb 5-1.4: 1:1: cannot get freq at ep 0x81
Aug 09 10:42:59 [COMPUTER_NAME] kernel: usb 5-1.4: 2:1: cannot get freq at ep 0x2
Aug 09 10:43:05 [COMPUTER_NAME] kernel: usb 5-1.4: 2:1: cannot get freq at ep 0x2
Aug 09 10:44:33 [COMPUTER_NAME] bluetoothd[1249]: profiles/input/device.c:ioctl_is_connected() Can't get HIDP connection info
lines 2154-2220/2220 (END)
