Hello, im fresh installed Manjaro/KDE on my Tuxedo Pulse15 Gen1 Laptop and journalctl showed a few ACPI errors, is there something i can do about it… or should i just ignore and go with it?
journalctl -p 3 -xb:
Feb 05 21:10:02 laptop kernel: ACPI BIOS Error (bug): Failure creating named object [\SMIB], AE_ALREADY_EXISTS (20210730/dsfield-637)
Feb 05 21:10:02 laptop kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.GPP4.WLAN], AE_NOT_FOUND (20210730/dswload2-162)
Feb 05 21:10:02 laptop kernel: ACPI Error: AE_NOT_FOUND, During name lookup/catalog (20210730/psobject-220)
inxi --admin --verbosity=7 --filter --no-host --width:
Kernel: 5.15.16-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/vmlinuz-5.15-x86_64
root=UUID=fd3e69a3-c42a-450d-845f-791354306b7e rw quiet apparmor=1
security=apparmor resume=UUID=7f380c83-e7ea-4972-956d-3bcb0a800161
udev.log_priority=3
Desktop: KDE Plasma 5.23.5 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: TUXEDO product: TUXEDO Pulse 15 Gen1 v: Standard
serial: <superuser required>
Mobo: NB02 model: PULSE1501 v: Standard serial: <superuser required>
BIOS: American Megatrends v: N.1.07.A03 date: 05/11/2021
ID-1: BAT0 charge: 39.4 Wh (43.0%) condition: 91.6/91.6 Wh (100.0%)
volts: 12.3 min: 11.6 model: standard type: Li-ion serial: <filter>
status: Charging
RAM: total: 15.11 GiB used: 1.81 GiB (12.0%)
RAM Report:
Info: model: AMD Ryzen 7 4800H with Radeon Graphics bits: 64 type: MT MCP
arch: Zen 2 family: 0x17 (23) model-id: 0x60 (96) stepping: 1
microcode: 0x8600103
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB L3: 8 MiB
desc: 2x4 MiB
Speed (MHz): avg: 1413 high: 1599 min/max: 1400/2900 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1599 2: 1397
3: 1397 4: 1397 5: 1397 6: 1397 7: 1395 8: 1397 9: 1454 10: 1397 11: 1397
12: 1398 13: 1397 14: 1397 15: 1397 16: 1397 bogomips: 92666
f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibrs ibs
pfthreshold pge pni popcnt pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a
rdtscp rep_good sep sha_ni skinit smap smca smep ssbd sse sse2 sse4_1
sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce topoext tsc
tsc_scale umip v_spec_ctrl v_vmsave_vmload vgif vmcb_clean vme vmmcall
wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional,
Device-1: AMD Renoir vendor: Tongfang Hongkong Limited driver: amdgpu
v: kernel bus-ID: 03:00.0 chip-ID: 1002:1636 class-ID: 0300
Display: x11 server: X.org 1.21.1.3 compositor: kwin_x11 driver:
loaded: amdgpu,ati unloaded: modesetting alternate: fbdev,vesa
Device-1: AMD Renoir Radeon High Definition Audio
vendor: Tongfang Hongkong Limited driver: snd_hda_intel v: kernel
bus-ID: 03:00.1 chip-ID: 1002:1637 class-ID: 0403
Device-2: AMD Raven/Raven2/FireFlight/Renoir Audio Processor
vendor: Tongfang Hongkong Limited driver: N/A
alternate: snd_pci_acp3x, snd_rn_pci_acp3x, snd_pci_acp5x bus-ID: 03:00.5
chip-ID: 1022:15e2 class-ID: 0480
Device-3: AMD Family 17h HD Audio vendor: Tongfang Hongkong Limited
driver: snd_hda_intel v: kernel bus-ID: 03:00.6 chip-ID: 1022:15e3
class-ID: 0403
Sound Server-1: ALSA v: k5.15.16-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.43 running: yes
Device-1: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel bus-ID: 01:00.0
chip-ID: 8086:2723 class-ID: 0280
IF: wlp1s0 state: down mac: <filter>
vendor: Tongfang Hongkong Limited driver: r8169 v: kernel port: f000
bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8
bus-ID: 1-4.4:4 chip-ID: 8087:0029 class-ID: e001
Local Storage: total: 465.76 GiB used: 11.9 GiB (2.6%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO M.2 500GB
type: SSD serial: <filter> rev: 4B6Q scheme: MBR
ID-1: / raw-size: 240.66 GiB size: 235.82 GiB (97.99%)
used: 11.76 GiB (5.0%) fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: fd3e69a3-c42a-450d-845f-791354306b7e
ID-2: /boot raw-size: 500 MiB size: 458.3 MiB (91.67%)
used: 65.8 MiB (14.3%) fs: ext3 dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: 73b051a4-7a67-4c80-8e70-6bac959dce95
ID-3: /home raw-size: 175.78 GiB size: 171.96 GiB (97.83%)
used: 82.2 MiB (0.0%) fs: ext4 dev: /dev/sda3 maj-min: 8:3 label: Home
uuid: 357053fa-0d10-48a0-abee-591ffeffef2c
ID-1: swap-1 type: partition size: 2.93 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/sda4 maj-min: 8:4 label: N/A
uuid: 7f380c83-e7ea-4972-956d-3bcb0a800161
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Hub-2: 1-4:2 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
Device-1: 1-4.3:3 info: Realtek RTS5129 Card Reader Controller
interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 0bda:0129
class-ID: ff00 serial: <filter>
Device-2: 1-4.4:4 info: Intel AX200 Bluetooth type: Bluetooth
Hub-3: 2-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
Hub-4: 3-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Hub-5: 4-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 45.0 C mobo: N/A gpu: amdgpu temp: 37.0 C
Processes: 322 Uptime: 21m wakeups: 1 Init: systemd v: 250 tool: systemctl
Compilers: gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 1229 lib: 337
flatpak: 0 Shell: Zsh v: 5.8 default: Bash v: 5.1.16 running-in: konsole
inxi: 3.3.12
