Setting up custom DNS in NetworkManager
Solution:
Create file in /etc/NetworkManager/conf.d/dns-servers.conf , like
[global-dns-domain-*]
servers=::1,1.1.1.1
For more info, read this.
Hello, my problem seems related to a recent topic of similar title.
When, in ipv4 settings of my wifi connection, I change method to ‘automatic (dhcp) addresses only’ and add addresses 1.1.1.1 and 1.0.0.1, the ‘save’ button does not become active, indicating red the ‘netmask’ column.
(NetworkManager is not shown in the main gui -only ‘advanced network configuration’- and running it from commandline has no visible results; though pacman -Q confirms the version.)
Is there more to setting up 1.1.1.1 than in their setup guide or is it about the NetworkManager (or am I losing it)?
Many thanks
On KDE setting the DNS in the NetworkManager applet doesn’t change it. Try setting the DNS then restart with
sudo systemctl restart NetworkManager
the newly applied changes should be loaded.
Thanks, this helped to check the immediate effect of setting a global dns in networkmanager.
Solution:
servers=::1,1.1.1.1
