Setting up a NAT virtual network in KVM
I set up a Manjaro guest on KVM with NAT as default network. Same problem. It is not able to connect.
We did that, and verified through virsh above, and it’s set to auto-start.
I can’t say :100: %, but my first instinct is, hell yes!
I believe the default policy for ufw is to drop input and forward traffic.
And these are very restrictive outbound rules, but we don’t even care about those ones. But this is most likely blocking all forwarding.
I believe we need ufw status verbose to see. (I don’t have ufw atm.)
We could configure ufw to work with this. But it would be all manual down to every last rule.
I would rather rip out ufw.
Oh, found! I would have never guessed that :sweat_smile:.
Right now this is what I see
Do I have to uncheck On Boot? I did but the start button stays grayed out, either I check or uncheck On Boot.
No, the way it is now is perfectly fine. The start button is grayed out as it is started already (state: Active). Did you check in the meantime, if the network source, as in your very first screenshot, is still showing (Inactive)? That would be really strange. This should be the same as the state indicator in the virtual networks state.
It was ufw all along :see_no_evil_monkey:
I disabled it and it connected so fast it made my head spin. God!!
@Molski thanks a lot for you patience :folded_hands:
