Slayd
1
I wanted to add some key mappings to my new cinnamon desktop. I made these changes using the shortcuts tab on keyboard settings.
Super-1 now works to move to workspace-1 as I desired.
Super-2 brings up nemo, doesn’t move to workspace-2.
Is there another configuration file that overrides some of the settings I make using the System Settings approach?
Is there a problem you have?
What is the one configuration file
(and which is it?)
which you seem to suspect to be overridden by another?
What is the actual problem?
Assign it to “super +3” it seems the launcher for home super + E hijacks super + 2
system
Closed
5
