setcustomres, set a custom resolution to a screen with a single command.
Description: Set custom resolution to a display using xrandr
Usage: setcustomres OPTIONS
Version: 2.1
-w | --width Mandatory: Width of resolution
-h | --height Mandatory: Hight of resolution
-o | --output Mandatory: Display output
-r | --refresh-rate Custom refresh rate (Default 60Hz)
-p | --param xrandr parameters, wrap with double quotes
--help Print this help message
---Usage Examples---
# This sets a custom resolution to HDMI-1
~$ setcustomres -w 1920 -h 1080 -o HDMI-1
# This sets a custom resolution to DP-1 and maps it to the right of VGA-1
~$ setcustomres --width 1366 --height 768 --output DP-1 --param "--right-of VGA-1"
# This sets a custom resolution to VGA-2 and makes it the primary screen
~$ setcustomres -w 1680 -h 1050 -o VGA-2 -p "--primary"
# This sets a custom resolution to HDMI-1 with a refresh rate of 120Hz
~$ setcustomres -w 1600 -h 900 -o HDMI-1 -r 120
Can be installed from the AUR:
yay -S setcustomres
