Hi everyone.
I am using manjaro i3. I have installed zsh. I would like it to be the default every time I open the terminal, but that doesn’t happen. Can you tell me how I configure it?
Hi everyone.
You either set it in the config of the terminal app or even better follow this Command-line shell - ArchWiki (This shows you how to set a default shell for your user)
Thanks Arisa.
Running the chsh -l command to list the installed shells and the chsh -s full-path-to-shell command to set a default one worked for me.
I clarify that it was necessary to restart the computer for it to work.
Grettings!
"If you now log out and log in again, you will be greeted by the other shell. "
It’s written there, restart of the whole computer shouldn’t be needed
You’re rigth.
Thank you for clearing that up!
