I am trying to improve audio quality, following this Arch wiki:
https://wiki.archlinux.org/title/PipeWire#Troubleshooting
It says in 5.1.9 Sound quality (resampling quality)
to set resample.quality = 10
in the config files mentioned there in the wiki,
and then to restart services
pipewire.service
and
pipewire-pulse.socket
but when I try to restart these services, it says “service not found”
How are you restarting the service?
They are run per user-session, so it should be systemctl --user restart pipewire pipewire-pulse
systemctl --user restart pipewire pipewire-pulse 13:21:28
Failed to restart pipewire-pulse.service: Unit pipewire-pulse.service not found.
Then it’s not installed.
Are you actually running pipewire?
I sure think so
See this output:
which pipewire 13:41:00
/usr/bin/pipewire
⋊> ~ inxi -F 13:41:06
Host: shmuel-manjaro Kernel: 6.3.3-1-MANJARO arch: x86_64 bits: 64
Desktop: Xfce v: 4.18.1 Distro: Manjaro Linux
Type: Desktop Mobo: ASUSTeK model: PRIME B365M-A v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 2208
date: 07/09/2021
Info: 8-core model: Intel Core i7-9700 bits: 64 type: MCP cache: L2: 2 MiB
Speed (MHz): avg: 900 min/max: 800/4700 cores: 1: 900 2: 900 3: 900 4: 900
5: 900 6: 900 7: 900 8: 900
Device-1: Intel CoffeeLake-S GT2 [UHD Graphics 630] driver: i915 v: kernel
Device-2: USB C Video Adaptor driver: N/A type: USB
Device-3: Microdia USB Live camera driver: snd-usb-audio,uvcvideo
type: USB
Display: x11 server: X.Org v: 21.1.8 driver: X: loaded: modesetting
dri: iris gpu: i915 resolution: 1: 1920x1080~120Hz 2: 1920x1080~60Hz
API: OpenGL v: 4.6 Mesa 23.0.3 renderer: Mesa Intel UHD Graphics 630 (CFL
GT2)
Device-1: Intel 200 Series PCH HD Audio driver: snd_hda_intel
Device-2: Microdia USB Live camera driver: snd-usb-audio,uvcvideo
type: USB
API: ALSA v: k6.3.3-1-MANJARO status: kernel-api
Server-1: PulseAudio v: 16.1 status: active
driver: r8169
IF: enp3s0 state: up speed: 1000 Mbps duplex: full mac: a8:5e:45:e2:87:3c
Device-2: Realtek RTL8153 Gigabit Ethernet Adapter driver: r8152 type: USB
IF: enp0s20f0u3u1 state: down mac: 00:e0:4c:68:51:92
Device-1: Cambridge Silicon Radio Bluetooth Dongle (HCI mode) driver: btusb
type: USB
Local Storage: total: 2.26 TiB used: 994.82 GiB (43.1%)
ID-1: /dev/sda vendor: Kingston model: SA400S37480G size: 447.13 GiB
ID-2: /dev/sdb vendor: Toshiba model: HDWD120 size: 1.82 TiB
ID-1: / size: 69.1 GiB used: 25.36 GiB (36.7%) fs: ext4 dev: /dev/sda7
ID-2: /boot/efi size: 96 MiB used: 31.4 MiB (32.7%) fs: vfat
dev: /dev/sda1
System Temperatures: cpu: 41.0 C mobo: N/A
Processes: 299 Uptime: 1h 37m Memory: available: 15.49 GiB
used: 8.91 GiB (57.5%) Shell: fish inxi: 3.3.27
But apparently not pipewire-pulse.
pamac install pipewire-pulse
Edit: And you’re running pulseaudio instead of pipewire anyway.
Please switch first completly to pipewire: pamac install manjaro-pipewire
Thanks, my bad.
Now I am listening to my music on my brand-new manjaro-pipewire
But two new problems:
1 I don’t have audio controls on my panel. I am running Xfce desktop. I removed the Pulse plugin because it was just greyed out and did not seem to be doing anything.
2 The desktop session takes an extra 5 seconds to start up, when I first log in to my user account.
Update: both problems were solved by removing the pulse audio panel plugin and then adding it again.
