Set keyboard repeat delay before SDDM launches
I’m used to set a faster repeat delay on my keyboard but the setting is not set in SDDM yet.
I found the command I need:
xset r rate 200 30
But I have no clue in what file to put it. Since it’s a X feature, it can’t be too soon in the boot procedure but has to be run just before SDDM launches.
The problem is that SDDM is a service so I don’t think there is something launching it specifically, but it’s just the services starting… I may be wrong.
Yes, I would like to have this repeat delay as soon as I am in SDDM so that I can erase my password quickly when I mistype it.
I found some info here: Custom resolution for SDDM / Newbie Corner / Arch Linux Forums
TLDR: put the command in the /usr/share/sddm/scripts/Xsetup file.
#!/bin/sh
# Xsetup - run as root before the login dialog appears
# Set keyboard delay
xset r rate 200 30
