Hello, how can I set clang compiler as a default in manjaro?
Add
export CC=clang
and (for C++)export CXX=clang++
to your/etc/makepkg.conf
thank you, okay I did it. But can you please help me, how can I check that this option is working for now?
well, even after this set options. Cmake generate make files with GCC compiler as default. I suppose this is bc of symbolic link is set to gcc compiler still. How can I change it for a system, and is it safe to do?
What’s your use case? Edits to makepkg.conf
only apply to using makepkg
Since I use always a clang too lchain to write my programs I just wanna that cmake will set clang as a default compiler when I use it, and I wanna that it will be set implicitly without any explicit use. Like to write a compiler name in cmake file itself or without using explicit cmake commands.
You’d have to set the two variables above when building or add them as environment variables.
It works, thank you. How can I close this topic?
There’s no need to close it, however it’s customary to mark the post that solved your issue as the Solution.
