Hey!
I don’t know if I broke something or what happened, but I wanted to see what the command for shutting down is, and I first tried xfce4-session-logout --halt
in the terminal, and then I first saw how it looks when the session is preserved between bootups. Later, I found out you can right click-properties-commands the start menu to see the commands invoked by pressing the logout buttons, and there I saw that the full command is xfce4-session-logout --halt --fast
. I tried to run it in the terminal , but it behaved the same way as the one without --fast. Later, I noticed that even my start menu button preserves sessions now.
I don’t know what happened. Is it my fault? Probably. What are the chances that some bug was introduced the moment I started fiddling with commands.
