inxi -Fazy
Kernel: 5.8.11-1-MANJARO x86_64 bits: 64 compiler: N/A
parameters: BOOT_IMAGE=/boot/vmlinuz-5.8-x86_64
root=UUID=a13e0afa-9415-4297-80e9-a39e1f200679 rw quiet apparmor=1
Desktop: KDE Plasma 5.19.5 tk: Qt 5.15.1 wm: kwin_x11 dm: SDDM
Distro: Manjaro Linux
Type: Laptop System: ASUSTeK product: Strix GL704GM_GL704GM v: 1.0
serial: <filter>
Mobo: ASUSTeK model: GL704GM v: 1.0 serial: <filter>
UEFI: American Megatrends v: GL704GM.305 date: 04/24/2019
ID-1: BAT0 charge: 54.1 Wh condition: 55.2/66.0 Wh (84%) volts: 15.7/15.7
model: ASUSTeK ASUS Battery type: Li-ion serial: N/A status: Not charging
Topology: 6-Core model: Intel Core i7-8750H bits: 64 type: MT MCP
arch: Kaby Lake family: 6 model-id: 9E (158) stepping: A (10) microcode: D6
L2 cache: 9216 KiB
bogomips: 52815
Speed: 4078 MHz min/max: 800/4100 MHz Core speeds (MHz): 1: 4013 2: 4052
3: 4058 4: 4079 5: 4066 6: 4093 7: 4098 8: 4066 9: 4075 10: 4062 11: 4074
12: 4102
Type: l1tf
Device-1: Intel UHD Graphics 630 vendor: ASUSTeK driver: i915 v: kernel
bus ID: 00:02.0 chip ID: 8086:3e9b
Device-2: NVIDIA GP106M [GeForce GTX 1060 Mobile] vendor: ASUSTeK
driver: nvidia v: 450.66 alternate: nouveau,nvidia_drm bus ID: 01:00.0
chip ID: 10de:1c20
Device-3: IMC Networks USB2.0 HD UVC WebCam type: USB driver: uvcvideo
bus ID: 1-9:4 chip ID: 13d3:56a2 serial: <filter>
Display: x11 server: X.Org 1.20.9 compositor: kwin_x11
driver: modesetting,nvidia display ID: :0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: eDP-1-1 res: 1920x1080 dpi: 128 size: 382x215mm (15.0x8.5")
diag: 438mm (17.3")
OpenGL: renderer: GeForce GTX 1060/PCIe/SSE2 v: 4.6.0 NVIDIA 450.66
direct render: Yes
Device-1: Intel Cannon Lake PCH cAVS vendor: ASUSTeK driver: snd_hda_intel
v: kernel alternate: snd_soc_skl,snd_sof_pci bus ID: 00:1f.3
chip ID: 8086:a348
Device-2: NVIDIA GP106 High Definition Audio driver: snd_hda_intel v: kernel
bus ID: 01:00.1 chip ID: 10de:10f1
Device-3: Corsair CORSAIR VOID ELITE Wireless Gaming Dongle type: USB
driver: hid-generic,snd-usb-audio,usbhid bus ID: 1-6:3 chip ID: 1b1c:0a51
Sound Server: ALSA v: k5.8.11-1-MANJARO
Device-1: Intel Wireless-AC 9560 [Jefferson Peak] driver: iwlwifi v: kernel
port: 5000 bus ID: 00:14.3 chip ID: 8086:a370
vendor: ASUSTeK driver: r8169 v: kernel port: 3000 bus ID: 03:00.0
chip ID: 10ec:8168
IF: eno2 state: down mac: <filter>
Local Storage: total: 1.14 TiB used: 272.27 GiB (23.3%)
ID-1: /dev/nvme0n1 vendor: Western Digital model: PC SN520 SDAPNUW-256G-1002
size: 238.47 GiB block size: physical: 512 B logical: 512 B speed: 15.8 Gb/s
lanes: 2 serial: <filter> rev: 20110000 scheme: GPT
ID-2: /dev/sda vendor: Seagate model: ST1000LX015-1U7172 size: 931.51 GiB
block size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
rotation: 5400 rpm serial: <filter> rev: SDM1 scheme: GPT
ID-1: / raw size: 238.17 GiB size: 233.43 GiB (98.01%)
used: 33.01 GiB (14.1%) fs: ext4 dev: /dev/nvme0n1p2
System Temperatures: cpu: 60.0 C mobo: N/A gpu: nvidia temp: 55 C
Fan Speeds (RPM): cpu: 3800
Processes: 279 Uptime: 3h 13m Memory: 15.49 GiB used: 2.42 GiB (15.6%)
Init: systemd v: 246 Compilers: gcc: 10.2.0 Packages: pacman: 1273 lib: 385
flatpak: 0 Shell: Zsh v: 5.8 running in: konsole inxi: 3.1.05
Sensors output
coretemp-isa-0000
Adapter: ISA adapter
Package id 0: +59.0°C (high = +100.0°C, crit = +100.0°C)
Core 0: +57.0°C (high = +100.0°C, crit = +100.0°C)
Core 1: +56.0°C (high = +100.0°C, crit = +100.0°C)
Core 2: +54.0°C (high = +100.0°C, crit = +100.0°C)
Core 3: +54.0°C (high = +100.0°C, crit = +100.0°C)
Core 4: +55.0°C (high = +100.0°C, crit = +100.0°C)
Core 5: +58.0°C (high = +100.0°C, crit = +100.0°C)
I’d just done a fresh install to try fix a previous issues that I think may actually be hardware/peripheral related, and this just up and happened after sensors was working fine beforehand. Not really sure where to go to get more information on this problem, it doesn’t seem to be mentioned on the wiki. Either I’m misinterpreting stuff, or it’s changed and I don’t understand why? Nevermind, I did misinterpret the output, but why has it changed the way sensors represents it?
