Hi,
I’m trying to get Manjaro-Cinnamon to display sensor data (cpu temp, fan speed, ect…) in the panel just like I can in Mint-Cinnamon.
In Mint I have installed: lm-sensors, xsensors, and as an ‘Applet’ sensors monitor by claudiux
In Manjaro I tried the same, but the ‘Applet’ does not work? so there is nothing in the panel.
I tried replacing xsensors with psensors and that gives me a thermometer icon in the panel that when clicked opens a window with all the temps fan speeds, etc…
Is there a way I can get Manjaro to permanently display the temps in the panel like I can in Mint? Thanks
First screenshot is of a Mint-Cinnamon system where ‘lm-sensors’ and ‘xsensors’ are installed as well as the applet ‘sensors monitor by claudiux’ In this setup I have the cpu temps always visible in the ‘panel’
Screenshot 2 and 3 are of Manjaro-Cinnamon system where ‘lm-sensors’ and ‘Psensors’ are installed (xsensors did not work well) The applet ‘sensors monitor by claudiux’ is downloaded but can not be switch on (the cog is greyed out?) so all I have in the panel is a temp icon, clicking on this icon brings up the ‘Psensors’ window as seen in screenshot3. What I’m looking for is for an applet (or something else) that will permanently display the cpu temps in the panel just like under Mint.
My question aimed at:
where did you get that applet - how did you install it in Manjaro?
I cannot find it when I look in the repositories or in the AUR.
I have found this description here.
Seems similar to Gnome extensions being installed via a web service - for which to work a browser extension is necessary.
I don’t run Cinnamon and cannot test.
It’s not in the repo or AUR, it’s part of ‘Cinnamon spices’ probably only available with the Cinnamon DE
Anyway In my case the steps are:
Menu/system settings (control center)/click on ‘Applets’/this opens the window that you see in my ‘ScreenshotManjaroTemp1’ go to the Download tab, search for the app and click on the ‘install’ arrow. then go back to the Manage tab, highlight the app and click on add (the + button) and then you should be able to modify the app settings as needed. But I could not get that last step to work - clicking on the settings button (cog icon) nothing happens - furthermore, on re-start, cinnamon throw up an error that an applet could not be started!! hence my post here to see if anybody has a solution
I solved my issue I added another applet ‘Spices Update by Claudiux’ that triggered an update of ‘Sensors Monitor by Claudiux’ and after that I could configure what temps to display in the panel. Thanks all for your help.
