So, this is a bit of a surprise. inxi
can’t get the drive temperature off a Samsung T7 2.5" SSD plugged directly into the Pi.
Local Storage: total: 465.76 GiB used: 30.78 GiB (6.6%)
ID-1: /dev/sda maj-min: 8:0 type: USB vendor: Samsung model: PSSD T7
size: 465.76 GiB block-size: physical: 512 B logical: 512 B type: SSD
serial: <filter> scheme: MBR
The unknown USB bridge
part is odd. It’s a USB-C drive, using a USB-C to USB-A cable that came out of the box.
It’s hard to imagine that there’s not a temperature sensor in the enclosure.
(I’m not really worried about cooking the drive, but I do like to check temps from time to time. I’ve caught drives and Pis running hot just because they weren’t getting good airflow.)
EDIT: Here’s what hdparm
reports about the drive:
❯ sudo hdparm -I /dev/sda
/dev/sda:
Unknown device type:
bits 15&14 of general configuration word 0 both set to 1.
❯ sudo hdparm -I /dev/sda2
/dev/sda2:
ATA device, with non-removable media
Standards:
Likely used: 1
Configuration:
Logical max current
cylinders 0 0
heads 0 0
sectors/track 0 0
Logical/Physical Sector size: 512 bytes
device size with M = 1024*1024: 0 MBytes
device size with M = 1000*1000: 0 MBytes
cache/buffer size = unknown
Capabilities:
IORDY not likely
Cannot perform double-word IO
R/W multiple sector transfer: not supported
DMA: not supported
PIO: pio0
❯ lsusb -t
/: Bus 02.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/4p, 5000M
|__ Port 1: Dev 2, If 0, Class=Mass Storage, Driver=uas, 5000M
/: Bus 01.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/1p, 480M
|__ Port 1: Dev 2, If 0, Class=Hub, Driver=hub/4p, 480M
❯ sudo hdparm -I /dev/sda1
/dev/sda1:
ATAPI , with removable media
Media Serial Num: � � � �p�B�@� �p�F�@
Media Manufacturer: "� �p�J�@B�
Transport: 0x23e2; Revision: 0x9100
Standards:
Likely used: 3
Configuration:
DRQ response: 50us.
Packet size: 12 bytes
Nominal Media Rotation Rate: 53888
Capabilities:
IORDY(may be)(cannot be disabled)
Overlap support: 40888us to clear BSY after SERVICE cmd.
DMA: not supported
PIO: pio0
Thanks!
