Wolf user]# pacman -S sudo-selinux
resolving dependencies...
:: sudo-selinux and sudo are in conflict. Remove sudo? [y/N] y
Packages (2) sudo-1.9.8.p2-1 [removal] sudo-selinux-1.9.8.p2-1
Total Download Size: 1.98 MiB
Total Installed Size: 6.83 MiB
Net Upgrade Size: 0.05 MiB
:: Proceed with installation? [Y/n] y
:: Retrieving packages...
sudo-selinux-1.9.8.p2-1-x86_64 2027.5 KiB 2.70 MiB/s 00:01 [######################################] 100%
(1/1) checking keys in keyring [######################################] 100%
(1/1) checking package integrity [######################################] 100%
(1/1) loading package files [######################################] 100%
(1/1) checking for file conflicts [######################################] 100%
(2/2) checking available disk space [######################################] 100%
(1/1) removing sudo [######################################] 100%
(1/1) installing sudo-selinux [######################################] 100%
(1/5) Reloading system manager configuration...
(2/5) Creating temporary files...
(3/5) Arming ConditionNeedsUpdate...
(4/5) Refreshing PackageKit...
(5/5) SELinux: relabel installed files
[Wolf user]# pacman -S util-linux-selinux systemd-selinux logrotate-selinux dbus-selinux
:: util-linux-selinux and util-linux are in conflict (rfkill). Remove util-linux? [y/N] y
:: util-linux-libs-selinux and util-linux-libs are in conflict. Remove util-linux-libs? [y/N] y
:: systemd-selinux and systemd are in conflict (nss-myhostname). Remove systemd? [y/N] y
:: systemd-libs-selinux and systemd-libs are in conflict (libsystemd). Remove systemd-libs? [y/N] y
:: logrotate-selinux and logrotate are in conflict. Remove logrotate? [y/N] y
:: dbus-selinux and dbus are in conflict (libdbus). Remove dbus? [y/N] y
Packages (12) dbus-1.12.20-1 [removal] logrotate-3.18.1-1 [removal] systemd-249.4-2 [removal]
systemd-libs-249.4-2 [removal] systemd-libs-selinux-249.5-1 util-linux-2.37.2-1 [removal]
util-linux-libs-2.37.2-1 [removal] util-linux-libs-selinux-2.37.2-1 dbus-selinux-1.12.20-1
logrotate-selinux-3.18.1-1 systemd-selinux-249.5-1 util-linux-selinux-2.37.2-1
Total Download Size: 13.64 MiB
Total Installed Size: 44.87 MiB
Net Upgrade Size: 0.36 MiB
systemd-selinux-249.5-1-x86_64 8.6 MiB 7.31 MiB/s 00:01 [######################################] 100%
util-linux-selinux-2.37.2-1-x86_64 3.4 MiB 6.60 MiB/s 00:01 [######################################] 100%
systemd-libs-selinux-249.5-1-x86_64 788.1 KiB 2.51 MiB/s 00:00 [######################################] 100%
util-linux-libs-selinux-2.37.2-1-x86_64 499.7 KiB 1922 KiB/s 00:00 [######################################] 100%
dbus-selinux-1.12.20-1-x86_64 374.2 KiB 1701 KiB/s 00:00 [######################################] 100%
logrotate-selinux-3.18.1-1-x86_64 57.8 KiB 309 KiB/s 00:00 [######################################] 100%
Total (6/6) 13.6 MiB 5.13 MiB/s 00:03 [######################################] 100%
(6/6) checking keys in keyring [######################################] 100%
(6/6) checking package integrity [######################################] 100%
(6/6) loading package files [######################################] 100%
(6/6) checking for file conflicts [######################################] 100%
(12/12) checking available disk space [######################################] 100%
warning: could not get file information for usr/share/man/man3/sd_bus_creds_get_selinux_context.3.gz
(1/6) removing logrotate [######################################] 100%
(2/6) removing systemd [######################################] 100%
(3/6) removing dbus [######################################] 100%
(4/6) removing util-linux [######################################] 100%
(5/6) removing systemd-libs [######################################] 100%
(6/6) removing util-linux-libs [######################################] 100%
(1/6) installing util-linux-libs-selinux [######################################] 100%
(2/6) installing systemd-libs-selinux [######################################] 100%
(3/6) installing util-linux-selinux [######################################] 100%
Optional dependencies for util-linux-selinux
python: python bindings to libmount [installed]
words: default dictionary for look
(4/6) installing dbus-selinux [######################################] 100%
(5/6) installing systemd-selinux [######################################] 100%
:: Append 'init=/usr/lib/systemd/systemd' to your kernel command line in your
bootloader to replace sysvinit with systemd, or install systemd-sysvcompat
mkdir: cannot create directory ‘var/log/journal/remote’: File exists
Optional dependencies for systemd-selinux
libmicrohttpd: remote journald capabilities [installed]
quota-tools: kernel-level quota management
systemd-sysvcompat: symlink package to provide sysvinit binaries [installed]
polkit: allow administration as unprivileged user [installed]
curl: machinectl pull-tar and pull-raw [installed]
libfido2: unlocking LUKS2 volumes with FIDO2 token
tpm2-tss: unlocking LUKS2 volumes with TPM2 [installed]
(6/6) installing logrotate-selinux [######################################] 100%
( 1/12) Creating system user accounts...
( 2/12) Updating journal message catalog...
( 3/12) Reloading system manager configuration...
( 4/12) Updating udev hardware database...
( 5/12) Applying kernel sysctl settings...
( 6/12) Creating temporary files...
( 7/12) Reloading device manager configuration...
( 8/12) Arming ConditionNeedsUpdate...
( 9/12) Updating linux initcpios...
==> Building image from preset: /etc/mkinitcpio.d/linux414.preset: 'default'
-> -k /boot/vmlinuz-4.14-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-4.14-x86_64.img
==> Starting build: 4.14.248-1-MANJARO
-> Running build hook: [base]
-> Running build hook: [udev]
libkmod: kmod_config_parse: /etc/modprobe.d/blacklist.conf line 2: ignoring bad line starting with 'snd_soc_skl_hda_dsp'
-> Running build hook: [consolefont]
==> WARNING: consolefont: no font found in configuration
-> Running build hook: [encrypt]
-> Running build hook: [fsck]
==> Creating gzip-compressed initcpio image: /boot/initramfs-4.14-x86_64.img
==> Building image from preset: /etc/mkinitcpio.d/linux414.preset: 'fallback'
-> -k /boot/vmlinuz-4.14-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-4.14-x86_64-fallback.img -S autodetect
==> Creating gzip-compressed initcpio image: /boot/initramfs-4.14-x86_64-fallback.img
==> Building image from preset: /etc/mkinitcpio.d/linux510.preset: 'default'
-> -k /boot/vmlinuz-5.10-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.10-x86_64.img
==> Starting build: 5.10.70-1-MANJARO
==> Creating gzip-compressed initcpio image: /boot/initramfs-5.10-x86_64.img
==> Building image from preset: /etc/mkinitcpio.d/linux510.preset: 'fallback'
-> -k /boot/vmlinuz-5.10-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.10-x86_64-fallback.img -S autodetect
==> Creating gzip-compressed initcpio image: /boot/initramfs-5.10-x86_64-fallback.img
==> Building image from preset: /etc/mkinitcpio.d/linux514.preset: 'default'
-> -k /boot/vmlinuz-5.14-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.14-x86_64.img
==> Starting build: 5.14.10-1-MANJARO
==> WARNING: Possibly missing firmware for module: qat_4xxx
==> Creating gzip-compressed initcpio image: /boot/initramfs-5.14-x86_64.img
==> Building image from preset: /etc/mkinitcpio.d/linux514.preset: 'fallback'
-> -k /boot/vmlinuz-5.14-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.14-x86_64-fallback.img -S autodetect
==> Creating gzip-compressed initcpio image: /boot/initramfs-5.14-x86_64-fallback.img
(10/12) Refreshing PackageKit...
(11/12) Reloading system bus configuration...
(12/12) SELinux: relabel installed files
error: unable to write to pipe (Broken pipe)
[Wolf user]#
I’m having a hard time to replicate what you are doing, I might not understand so please elaborate, below the steps
The sudo-selinux package is a AUR package (I’ve take the liberty to change the category)
$ pamac search --aur sudo-selinux
sudo-selinux 1.9.8.p2-1 AUR
Installing it with that pacman command should not work, unless you changed something in the repositories?
Installing it with pamac should work if you enable AUR support.
$ pamac install sudo-selinux
However this results in an error on my end:
Warning: sudo-selinux is only available from AUR
Preparing...
<snip>
Verifying source file signatures with gpg...
Linux-PAM-1.5.2.tar.xz ... FAILED (unknown public key A8041FA839E16E36)
==> ERROR: One or more PGP signatures could not be verified!
Error: Failed to build pam-selinux
I’ve followed the steps from https://github.com/archlinuxhardened/selinux down to:
Now we start replacing core packages:
- pambase-selinux
- pam-selinux
- coreutils-selinux shadow-selinux cronie-selinux sudo-selinux
- util-linux-selinux
- systemd-selinux
- logrotate-selinux
- dbus-selinux
Ah I see, it is a extra repository with specific selinux binaries for arch-linux witch you added to the pacman.conf file.
I’ve never done installs this way so cannot help you further. if the pacman.log does not show anything where the error occurs I am of no use to you.
Ok, thank you very much for your help.
Solved.
