Hi, I have a broken Manjaro partition that only boots to tty3.
How can I delete it? From the grub command line or from another OS on my system.
Thanks
Thanks
You should use Timeshift in this case for a broken OS, but of course you have to create a snapshot in a runnig state, befor you run into problems.
You can also reinstall Manjaro with a USB stick and boot from that drive.
So there is no way to remove it from my storage other than to reinstall?
I just gave you the easiest solution. You can also boot from the usb stick and easy remove your install, its all your choice.
Boot in Manjaro Live Boot and open KDE Partition Manjaro if you using KDE…
There you can Delete all Partitions what you no longer want to use anymore.
