Is there a way or an software that you can recommend for choosing an output device to a software that is playing a sound?
What I plan is that I want to play a two different audio device with two different audio playing. The built-in audio output is playing work and the usb sound card is playing a bg music.
I’m not sure, maybe use timeshift and set a restore point and then try it. If it doesn’t work or if it screws something up, you restore using timeshift.
