Hi, I installed Dwarf Fortress using pacman
. When I execute dwarffortress
in my console, the command outputs the following message:
/usr/bin/dwarffortress: line 15: 13472 Segmentation fault (core dumped) LD_LIBRARY_PATH="${LD_LIBRARY_PATH:+$LD_LIBRARY_PATH:}${DF_DIR}" $DF_DIR/dwarfort "$@"
How can I solve or debug this problem? Thanks.
Here, I will add my system information:
Kernel: 6.12.12-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=799cd1ed-8450-457b-8f4c-8d6b3149ec3d rw quiet splash
udev.log_priority=3
Desktop: KDE Plasma v: 6.2.5 tk: Qt v: N/A info: frameworks v: 6.10.0
Type: Laptop System: LENOVO product: 21FW000KLM v: ThinkPad P1 Gen 6
Mobo: LENOVO model: 21FW000KLM v: SDK0T76530 WIN
serial: <superuser required> part-nu: LENOVO_MT_21FW_BU_Think_FM_ThinkPad
P1 Gen 6 uuid: <superuser required> UEFI: LENOVO v: N3ZET45W (1.32 )
date: 09/05/2024
ID-1: BAT0 charge: 87.6 Wh (99.0%) condition: 88.5/90.1 Wh (98.2%)
volts: 17.4 min: 15.5 model: SMP 5B11K07736 type: Li-poly serial: <filter>
status: not charging cycles: 44
System RAM: total: 32 GiB available: 31.01 GiB used: 10.26 GiB (33.1%)
Array-1: capacity: 96 GiB slots: 2 modules: 2 EC: None
max-module-size: 48 GiB note: est.
Device-1: Controller0-ChannelA/B-DIMM0 type: DDR5 detail: synchronous
size: 16 GiB speed: 5600 MT/s volts: curr: 1 width (bits): data: 64
total: 64 manufacturer: Samsung part-no: M425R2GA3BB0-CWMOD
serial: <filter>
Device-2: Controller1-ChannelA/B-DIMM0 type: DDR5 detail: synchronous
serial: <filter>
Info: model: 13th Gen Intel Core i7-13700H bits: 64 type: MST AMCP
arch: Raptor Lake gen: core 13 level: v3 note: check built: 2022+
process: Intel 7 (10nm) family: 6 model-id: 0xBA (186) stepping: 2
microcode: 0x4123
Topology: cpus: 1x dies: 1 clusters: 8 cores: 14 threads: 20 mt: 6 tpc: 2
st: 8 smt: enabled cache: L1: 1.2 MiB desc: d-8x32 KiB, 6x48 KiB; i-6x32
KiB, 8x64 KiB L2: 11.5 MiB desc: 6x1.2 MiB, 2x2 MiB L3: 24 MiB
desc: 1x24 MiB
Speed (MHz): avg: 400 min/max: 400/4800:5000:3700 scaling:
driver: intel_pstate governor: powersave cores: 1: 400 2: 400 3: 400 4: 400
5: 400 6: 400 7: 400 8: 400 9: 400 10: 400 11: 400 12: 400 13: 400 14: 400
15: 400 16: 400 17: 400 18: 400 19: 400 20: 400 bogomips: 116780
de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
hwp_epp hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ibt ida intel_pt
msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pclmulqdq pdcm pdpe1gb
pebs pge pku pln pni popcnt pse pse36 pts rdpid rdrand rdseed rdtscp
rep_good sdbg sep serialize sha_ni smap smep smx split_lock_detect ss
ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc
xtopology xtpr
conditional; RSB filling; PBRSB-eIBRS: SW sequence; BHI: BHI_DIS_S
Device-1: Intel Raptor Lake-P [Iris Xe Graphics] vendor: Lenovo driver: i915
v: kernel alternate: xe arch: Xe process: Intel 7 (10nm) built: 2022+ ports:
active: none off: eDP-1 empty: none bus-ID: 00:02.0 chip-ID: 8086:a7a0
class-ID: 0300
Device-2: NVIDIA GA107GLM [RTX A1000 6GB Laptop GPU] vendor: Lenovo
driver: nvidia v: 550.144.03 alternate: nouveau,nvidia_drm
non-free: 550/565.xx+ status: current (as of 2025-01; EOL~2026-12-xx)
arch: Ampere code: GAxxx process: TSMC n7 (7nm) built: 2020-2023 pcie:
gen: 2 speed: 5 GT/s lanes: 8 link-max: gen: 4 speed: 16 GT/s lanes: 16
bus-ID: 01:00.0 chip-ID: 10de:25bc class-ID: 0300
Device-3: Logitech C920 PRO HD Webcam driver: snd-usb-audio,uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-7:3
chip-ID: 046d:08e5 class-ID: 0102 serial: <filter>
Device-4: Syntek Integrated Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-8:4 chip-ID: 174f:1812
Display: x11 server: X.Org v: 21.1.15 with: Xwayland v: 24.1.5
compositor: kwin_x11 driver: X: loaded: modesetting,nvidia
alternate: fbdev,nouveau,nv,vesa dri: iris gpu: i915 display-ID: :0
screens: 1
Screen-1: 0 s-res: 2560x1440 s-dpi: 96 s-size: 676x380mm (26.61x14.96")
s-diag: 775mm (30.53") monitors: <missing: xrandr>
Monitor-1: eDP-1 model: AU Optronics 0xb69d built: 2021 res: 1920x1200
dpi: 142 gamma: 1.2 chroma: red: x: 0.659 y: 0.329 green: x: 0.282 y: 0.635
blue: x: 0.145 y: 0.055 white: x: 0.314 y: 0.329
size: 344x215mm (13.54x8.46") diag: 406mm (16") ratio: 16:10
modes: 1920x1200
drv: nvidia gbm: drv: kms_swrast surfaceless: drv: nvidia x11: drv: iris
inactive: wayland
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: intel mesa v: 24.3.4-arch1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel Iris Xe Graphics (RPL-P)
device-ID: 8086:a7a0 memory: 15.14 GiB unified: yes
API: Vulkan v: 1.4.303 layers: 1 device: 0 type: discrete-gpu name: NVIDIA
RTX A1000 6GB Laptop GPU driver: N/A device-ID: 10de:25bc
surfaces: xcb,xlib
wl: wayland-info x11: xdpyinfo,xprop
Device-1: Intel Raptor Lake-P/U/H cAVS vendor: Lenovo
driver: sof-audio-pci-intel-tgl alternate: snd_hda_intel, snd_soc_avs,
snd_sof_pci_intel_tgl bus-ID: 00:1f.3 chip-ID: 8086:51ca class-ID: 0401
Device-2: NVIDIA GA107 High Definition Audio vendor: Lenovo
driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 8
link-max: lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:2291 class-ID: 0403
API: ALSA v: k6.12.12-2-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.2.7 status: active with: 1: pipewire-pulse
Device-1: Intel Raptor Lake PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:51f1 class-ID: 0280
Device-1: Intel AX211 Bluetooth driver: btusb v: 0.8 type: USB rev: 2.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-10:6 chip-ID: 8087:0033
class-ID: e001
Local Storage: total: 476.94 GiB used: 40.7 GiB (8.5%)
model: MZVL2512HDJD-00BLL size: 476.94 GiB block-size: physical: 512 B
fw-rev: 6L2QGXD7 temp: 43.9 C scheme: GPT
ID-1: / raw-size: 139.7 GiB size: 136.45 GiB (97.67%)
used: 19.32 GiB (14.2%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: 799cd1ed-8450-457b-8f4c-8d6b3149ec3d
ID-2: /boot/efi raw-size: 3.73 GiB size: 3.72 GiB (99.80%)
used: 288 KiB (0.0%) fs: vfat dev: /dev/nvme0n1p3 maj-min: 259:3 label: N/A
uuid: 2C40-9512
ID-3: /home raw-size: 288.81 GiB size: 283.22 GiB (98.06%)
used: 21.33 GiB (7.5%) fs: ext4 dev: /dev/nvme0n1p4 maj-min: 259:4
label: N/A uuid: b2397eec-b537-4dd5-8421-f88c868a6b64
ID-1: swap-1 type: partition size: 44.7 GiB used: 53.9 MiB (0.1%)
priority: -2 dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: a491f448-4685-4f6d-b187-1327a5744f47
Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 1-6:2 info: Shenzhen Goodix USB2.0 MISC type: <vendor specific>
driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
mode: 1.1 power: 100mA chip-ID: 27c6:6594 class-ID: ef00 serial: <filter>
Device-2: 1-7:3 info: Logitech C920 PRO HD Webcam type: video,audio
Device-3: 1-8:4 info: Syntek Integrated Camera type: video
driver: uvcvideo interfaces: 5 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
lanes: 1 mode: 2.0 power: 500mA chip-ID: 174f:1812 class-ID: fe01
serial: <filter>
Hub-2: 1-9:5 info: Terminus Hub ports: 4 rev: 2.0
chip-ID: 1a40:0101 class-ID: 0900
Device-1: 1-9.1:7 info: HP HyperX Alloy Origins Core type: keyboard,HID
lanes: 1 mode: 1.1 power: 500mA chip-ID: 03f0:098f class-ID: 0300
Device-2: 1-9.3:8 info: Logitech G102/G203 LIGHTSYNC Gaming Mouse
type: mouse,HID driver: hid-generic,usbhid interfaces: 2 rev: 2.0
speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 300mA
chip-ID: 046d:c092 class-ID: 0300 serial: <filter>
Device-3: 1-10:6 info: Intel AX211 Bluetooth type: bluetooth driver: btusb
power: 100mA chip-ID: 8087:0033 class-ID: e001
Hub-3: 2-0:1 info: super-speed hub ports: 4 rev: 3.1
Hub-4: 3-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
Hub-5: 4-0:1 info: super-speed hub ports: 2 rev: 3.1
System Temperatures: cpu: 62.0 C mobo: 51.5 C
Fan Speeds (rpm): fan-1: 2067 fan-2: 2376
Packages: pm: pacman pkgs: 1309 libs: 366 tools: pamac pm: flatpak pkgs: 0
1: https://mirror.math.princeton.edu/pub/manjaro/stable/$repo/$arch
2: http://ftp.belnet.be/mirrors/manjaro/repos/stable/$repo/$arch
3: http://ftp.free.org/mirrors/repo.manjaro.org/repos/stable/$repo/$arch
4: https://mirror.ufro.cl/manjaro/stable/$repo/$arch
5: https://mirrors.eric.ovh/manjaro/stable/$repo/$arch
6: https://mirrors.jlu.edu.cn/manjaro/stable/$repo/$arch
7: https://mirror.nyist.edu.cn/manjaro/stable/$repo/$arch
8: https://ftp.caliu.cat/pub/distribucions/manjaro/stable/$repo/$arch
Processes: 449 Power: uptime: 3h 10m states: freeze,mem,disk suspend: s2idle
image: 12.37 GiB services: org_kde_powerdevil, power-profiles-daemon,
upowerd Init: systemd v: 257 default: graphical tool: systemctl
Compilers: clang: 19.1.7 gcc: 14.2.1 Shell: Zsh v: 5.9 running-in: konsole
inxi: 3.3.37
