Segfault in libQt6Quick.so.6.9.1
I’ve conducted an update and can successfully boot and log into KDE plasma. When loading the session KDE starts switching off/on for couple of times until the screen is completely black. Only the cursor is visible then.
This is my system:
[manjaro@manjaro ~]$ inxi --admin --verbosity=8 --filter --no-host --width
  Kernel: 6.12.34-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.1.1
    parameters: BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=en_US keytable=de tz=UTC
    misobasedir=manjaro misolabel=MANJARO_KDE_2504 quiet systemd.show_status=1
    splash driver=free nouveau.modeset=1 i915.modeset=1 radeon.modeset=1
  Desktop: KDE Plasma v: 6.3.5 tk: Qt v: N/A info: frameworks v: 6.15.0
  Type: Desktop System: MSI product: MS-7798 v: 1.0
    serial: <superuser required>
  Mobo: MSI model: B75MA-P45 (MS-7798) v: 1.0 serial: <superuser required>
    uuid: <superuser required> UEFI: American Megatrends v: 1.9 date: 09/30/2013
  Device-1: hidpp_battery_0 model: Logitech M720 Triathlon Multi-Device Mouse
    serial: <filter> charge: 100% (should be ignored) rechargeable: yes
    status: discharging
  System RAM: total: 24 GiB available: 23.4 GiB used: 2.94 GiB (12.5%)
  Array-1: capacity: 32 GiB slots: 4 modules: 4 EC: None
  Device-1: ChannelA-DIMM0 type: DDR3 detail: synchronous size: 4 GiB
    speed: 1333 MT/s volts: N/A width (bits): data: 64 total: 64
    manufacturer: Corsair part-no: CML8GX3M2A1600C9 serial: N/A
  Device-2: ChannelA-DIMM1 type: DDR3 detail: synchronous size: 8 GiB
    manufacturer: Hynix/Hyundai part-no: HMT41GU6AFR8A-PB serial: <filter>
  Device-3: ChannelB-DIMM0 type: DDR3 detail: synchronous size: 4 GiB
  Device-4: ChannelB-DIMM1 type: DDR3 detail: synchronous size: 8 GiB
  Info: model: Intel Core i5-3450S bits: 64 type: MCP arch: Ivy Bridge
    gen: core 3 level: v2 built: 2012-15 process: Intel 22nm family: 6
    model-id: 0x3A (58) stepping: 9 microcode: 0x21
  Topology: cpus: 1x dies: 1 clusters: 4 cores: 4 smt: <unsupported> cache:
    L3: 6 MiB desc: 1x6 MiB
  Speed (MHz): avg: 1599 min/max: 1600/3500 scaling: driver: intel_cpufreq
    governor: schedutil cores: 1: 1599 2: 1599 3: 1599 4: 1599 bogomips: 22404
  Flags: acpi aes aperfmperf apic arat arch_perfmon avx bts clflush cmov
    constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb
    ept erms est f16c flexpriority flush_l1d fpu fsgsbase fxsr ht ibpb ibrs
    ida lahf_lm lm mca mce md_clear mmx monitor msr mtrr nonstop_tsc nopl nx
    pae pat pbe pcid pclmulqdq pdcm pebs pge pln pni popcnt pse pse36 pti pts
    rdrand rdtscp rep_good sep smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp
    syscall tm tm2 tpr_shadow tsc tsc_deadline_timer vme vmx vnmi vpid xsave
    xsaveopt xtopology xtpr
    disabled
    STIBP: disabled; RSB filling; PBRSB-eIBRS: Not affected; BHI: Not affected
  Type: srbds status: Vulnerable: No microcode
  Device-1: NVIDIA GA106 [GeForce RTX 3060 Lite Hash Rate]
    vendor: Micro-Star MSI driver: nouveau v: kernel non-free: 550-570.xx+
    status: current (as of 2025-04; EOL~2026-12-xx) arch: Ampere code: GAxxx
    process: TSMC n7 (7nm) built: 2020-2023 pcie: gen: 2 speed: 5 GT/s
    lanes: 16 link-max: gen: 4 speed: 16 GT/s ports: active: HDMI-A-1
    empty: DP-1,DP-2,DP-3 bus-ID: 01:00.0 chip-ID: 10de:2504 class-ID: 0300
  Display: x11 server: X.Org v: 21.1.18 with: Xwayland v: 24.1.8
    compositor: kwin_x11 driver: X: loaded: modesetting alternate: fbdev,vesa
    dri: zink gpu: nouveau display-ID: :0 screens: 1
  Screen-1: 0 s-res: 2560x1440 s-dpi: 96 s-size: 677x381mm (26.65x15.00")
    s-diag: 777mm (30.58")
  Monitor-1: HDMI-A-1 mapped: HDMI-1 model: Idek Iiyama PL2792Q
    serial: <filter> built: 2021 res: mode: 2560x1440 hz: 60 scale: 100% (1)
    dpi: 109 gamma: 1.2 chroma: red: x: 0.671 y: 0.333 green: x: 0.298 y: 0.627
    blue: x: 0.141 y: 0.051 white: x: 0.322 y: 0.329
    size: 597x336mm (23.5x13.23") diag: 685mm (27") ratio: 16:9
    modes: 2560x1440, 2048x1280, 1920x1200, 1920x1080, 1600x1200, 1680x1050,
    1600x900, 1280x1024, 1440x900, 1280x720, 1024x768, 800x600, 720x576,
    720x480, 640x480
  API: EGL v: 1.5 platforms: device: 0 drv: zink device: 1 drv: swrast gbm:
    drv: zink surfaceless: drv: zink x11: drv: zink inactive: wayland
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: mesa v: 25.1.4-arch1.1 glx-v: 1.4
    direct-render: yes renderer: zink Vulkan 1.4(NVIDIA GeForce RTX 3060 (NVK
    GA106) (MESA_NVK)) device-ID: 10de:2504 memory: 11.96 GiB unified: no
  API: Vulkan v: 1.4.313 layers: N/A device: 0 type: discrete-gpu name: NVIDIA
    GeForce RTX 3060 (NVK GA106) driver: mesa nvk v: 25.1.4-arch1.1
    device-ID: 10de:2504 surfaces: N/A
    x11: xdpyinfo, xprop, xrandr
  Device-1: Intel 7 Series/C216 Family High Definition Audio
    vendor: Micro-Star MSI driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
    chip-ID: 8086:1e20 class-ID: 0403
  Device-2: NVIDIA GA106 High Definition Audio vendor: Micro-Star MSI
    link-max: gen: 4 speed: 16 GT/s bus-ID: 01:00.1 chip-ID: 10de:228e
    class-ID: 0403
  API: ALSA v: k6.12.34-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.4.5 status: active with: 1: pipewire-pulse
    vendor: Micro-Star MSI driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
    lanes: 1 port: d000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
  Device-2: NetGear WNDA4100 802.11abgn 3x3:3 [Ralink RT3573]
    driver: rt2800usb type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0
    bus-ID: 1-3:3 chip-ID: 0846:9012 class-ID: 0000 serial: <filter>
  IF: wlp0s20u3 state: up mac: <filter>
  Device-1: Cambridge Silicon Radio Bluetooth Dongle (HCI mode) driver: btusb
    v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-1:2
    chip-ID: 0a12:0001 class-ID: e001
  Device-1: tmp maj-min: 254:0 type: LUKS dm: dm-0 size: 232.59 GiB
  Components:
  p-1: sda2 maj-min: 8:2 size: 232.59 GiB
  Local Storage: total: 1.62 TiB used: 133.23 GiB (8.0%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 250GB
    size: 232.89 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
    tech: SSD serial: <filter> fw-rev: 4B6Q scheme: GPT
  ID-2: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 870 EVO 1TB
    size: 931.51 GiB block-size: physical: 512 B logical: 512 B speed: 1.5 Gb/s
    tech: SSD serial: <filter> fw-rev: 3B6Q scheme: GPT
  ID-3: /dev/sdc maj-min: 8:32 vendor: Samsung model: SSD 860 EVO 500GB
    size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
    tech: SSD serial: <filter> fw-rev: 1B6Q scheme: GPT
  ID-4: /dev/sdd maj-min: 8:48 vendor: SanDisk model: Ultra Fit
    size: 28.64 GiB block-size: physical: 512 B logical: 512 B type: USB rev: 3.0
    spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: N/A serial: <filter>
    fw-rev: 1.00 scheme: MBR
  ID-1: /mnt raw-size: 232.59 GiB size: 227.88 GiB (97.98%)
    used: 133.23 GiB (58.5%) fs: ext4 dev: /dev/dm-0 maj-min: 254:0 mapped: tmp
    label: N/A uuid: N/A
  ID-2: /mnt/boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%)
    used: 472 KiB (0.2%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: NO_LABEL
    uuid: 04E7-F02F
  ID-1: /dev/sdd1 maj-min: 8:49 size: 4.13 GiB fs: iso9660
  ID-2: /dev/sdd2 maj-min: 8:50 size: 4 MiB fs: vfat label: MISO_EFI
    uuid: ECC9-5CDB
  Device-1: 1-1:2 info: Cambridge Silicon Radio Bluetooth Dongle (HCI mode)
    type: bluetooth driver: btusb interfaces: 2 rev: 2.0
  Device-2: 1-3:3 info: NetGear WNDA4100 802.11abgn 3x3:3 [Ralink RT3573]
    type: Network driver: rt2800usb interfaces: 1 rev: 2.0
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 power: 450mA
  Hub-2: 1-4:4 info: Huasheng USB2.0 HUB ports: 4 rev: 2.0
    chip-ID: 214b:7250 class-ID: 0900
  Hub-3: 1-4.3:5 info: Monterey BakkerElkhuizen Wired Keyboard S-board 840
    Design USB-Hub ports: 3 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
    mode: 2.0 power: 100mA chip-ID: 0566:3020 class-ID: 0900
  Device-1: 1-4.3.2:6 info: Logitech Unifying Receiver
    type: keyboard,mouse,HID driver: logitech-djreceiver,usbhid interfaces: 3
    rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 98mA
    chip-ID: 046d:c52b class-ID: 0300
  Device-2: 1-4.3.3:7 info: Monterey BakkerElkhuizen Wired Keyboard S-board
    840 Design type: keyboard,HID driver: hid-generic,usbhid interfaces: 2
    rev: 1.1 speed: 1.5 Mb/s (183 KiB/s) lanes: 1 mode: 1.0 power: 100mA
    chip-ID: 0566:3013 class-ID: 0300
  Hub-4: 2-0:1 info: full speed or root hub ports: 2 rev: 2.0
  Hub-5: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 6 rev: 2.0
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 8087:0024
  Hub-6: 2-1.5:3 info: Realtek 4-Port USB 2.0 Hub ports: 2 rev: 2.1
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 0bda:5412
  Hub-7: 3-0:1 info: super-speed hub ports: 4 rev: 3.0
  Device-1: 3-2:2 info: SanDisk Ultra Fit type: mass storage
    driver: usb-storage interfaces: 1 rev: 3.0 speed: 5 Gb/s (596.0 MiB/s)
    lanes: 1 mode: 3.2 gen-1x1 power: 896mA chip-ID: 0781:5583 class-ID: 0806
    serial: <filter>
  Hub-8: 4-0:1 info: full speed or root hub ports: 2 rev: 2.0
  Hub-9: 4-1:2 info: Intel Integrated Rate Matching Hub ports: 6 rev: 2.0
  System Temperatures: cpu: 36.0 C mobo: N/A
  Fan Speeds (rpm): N/A
  Packages: pm: pacman pkgs: 1258 libs: 329 tools: pamac pm: flatpak pkgs: 0
    1: https://mirrors.sonic.net/manjaro/stable/$repo/$arch
    2: https://mirror.yandex.ru/mirrors/manjaro/stable/$repo/$arch
    3: https://ba.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
    4: https://manjaro.mirror.wearetriple.com/stable/$repo/$arch
    5: http://ftp.uni-kl.de/pub/linux/manjaro/stable/$repo/$arch
    6: https://ask4.mm.fcix.net/manjaro/stable/$repo/$arch
    7: http://ftp.belnet.be/mirrors/manjaro/repos/stable/$repo/$arch
    8: https://ftp.cc.uoc.gr/mirrors/linux/manjaro/stable/$repo/$arch
    9: https://opencolo.mm.fcix.net/manjaro/stable/$repo/$arch
    10: http://ftp.rz.tu-bs.de/pub/mirror/manjaro.org/repos/stable/$repo/$arch
    11: https://mirror.koddos.net/manjaro/stable/$repo/$arch
    12: https://mirror1.sox.rs/manjaro/stable/$repo/$arch
    13: http://ftp.free.org/mirrors/repo.manjaro.org/repos/stable/$repo/$arch
    14: https://mirror.kku.ac.th/manjaro/stable/$repo/$arch
    15: https://mirror.kamtv.ru/manjaro/stable/$repo/$arch
    16: https://ohioix.mm.fcix.net/manjaro/stable/$repo/$arch
    17: https://manjaro.c3sl.ufpr.br/stable/$repo/$arch
    18: https://mirror.vinehost.net/manjaro/stable/$repo/$arch
    19: https://mirror.aarnet.edu.au/pub/manjaro/stable/$repo/$arch
    20: http://mirror.terrahost.no/linux/manjaro/stable/$repo/$arch
    21: https://repo.iut.ac.ir/repo/manjaro/stable/$repo/$arch
    22: http://kartolo.sby.datautama.net.id/manjaro/stable/$repo/$arch
    23: https://repos.silknet.com/manjaro/stable/$repo/$arch
    24: https://volico.mm.fcix.net/manjaro/stable/$repo/$arch
    25: http://ftp.snt.utwente.nl/pub/linux/manjaro/stable/$repo/$arch
    26: http://ftp.tu-chemnitz.de/pub/linux/manjaro/stable/$repo/$arch
    27: https://mirror.freedif.org/Manjaro/stable/$repo/$arch
    28: https://muug.ca/mirror/manjaro/stable/$repo/$arch
    29: https://mirrors.ucr.ac.cr/manjaro/stable/$repo/$arch
    30: https://quantum-mirror.hu/mirrors/pub/manjaro/stable/$repo/$arch
    31: https://mirrors.sjtug.sjtu.edu.cn/manjaro/stable/$repo/$arch
    32: https://mirror.telepoint.bg/manjaro/stable/$repo/$arch
    33: https://mirror.truenetwork.ru/manjaro/stable/$repo/$arch
    34: https://mirrors.xtom.jp/manjaro/stable/$repo/$arch
    35: https://mirror.ibakerserver.pt/manjaro/stable/$repo/$arch
    36: https://bd.mirror.vanehost.com/Manjaro/stable/$repo/$arch
    37: https://mirrors.gigenet.com/manjaro/stable/$repo/$arch
    38: https://mirrors.dotsrc.org/manjaro/stable/$repo/$arch
    39: https://mirrors.ocf.berkeley.edu/manjaro/stable/$repo/$arch
    40: https://mirror.csclub.uwaterloo.ca/manjaro/stable/$repo/$arch
    41: https://mirrors.xtom.de/manjaro/stable/$repo/$arch
    42: https://mirror.komelt.dev/manjaro/stable/$repo/$arch
    43: https://ipng.mm.fcix.net/manjaro/stable/$repo/$arch
    44: https://mirror.alpix.eu/manjaro/stable/$repo/$arch
    45: https://nnenix.mm.fcix.net/manjaro/stable/$repo/$arch
    46: https://manjaro.ipacct.com/manjaro/stable/$repo/$arch
    47: https://manjarolinux-mirror.cloud.mu/stable/$repo/$arch
    48: https://mirror.futureweb.be/manjaro/stable/$repo/$arch
    49: https://cofractal-ewr.mm.fcix.net/manjaro/stable/$repo/$arch
    50: http://mirror.fcix.net/manjaro/stable/$repo/$arch
    51: https://manjaro.ynh.ovh/stable/$repo/$arch
    52: http://ftp.dei.uc.pt/pub/linux/manjaro/stable/$repo/$arch
    53: https://mirror.it4i.cz/manjaro/stable/$repo/$arch
    54: http://manjaro.mirrors.uk2.net/stable/$repo/$arch
    55: https://mirror.dc.uz/manjaro/stable/$repo/$arch
    56: https://mirrors.nic.cz/manjaro/stable/$repo/$arch
    57: https://coresite.mm.fcix.net/manjaro/stable/$repo/$arch
    58: https://mirror.ufro.cl/manjaro/stable/$repo/$arch
    59: https://mirrors.aliyun.com/manjaro/stable/$repo/$arch
    60: https://mirror.albony.xyz/manjaro/stable/$repo/$arch
    61: https://ftp.linux.org.tr/manjaro/stable/$repo/$arch
    62: https://mirrors.piconets.webwerks.in/manjaro-mirror/stable/$repo/$arch
    63: https://mirror.leitecastro.com/manjaro/stable/$repo/$arch
    64: https://ftp.nluug.nl/pub/os/Linux/distr/manjaro/stable/$repo/$arch
    65: http://mirror.is.co.za/mirrors/manjaro.org/stable/$repo/$arch
    66: https://codingflyboy.mm.fcix.net/manjaro/stable/$repo/$arch
    67: https://mirror.netcologne.de/manjaro/stable/$repo/$arch
    68: https://mirror.archlinux.tw/Manjaro/stable/$repo/$arch
    69: https://mnvoip.mm.fcix.net/manjaro/stable/$repo/$arch
    70: https://uvermont.mm.fcix.net/manjaro/stable/$repo/$arch
    71: https://mirrors.up.pt/pub/manjaro/stable/$repo/$arch
    72: https://ziply.mm.fcix.net/manjaro/stable/$repo/$arch
    73: https://mirror.init7.net/manjaro/stable/$repo/$arch
    74: https://mirror.phoepsilonix.love/manjaro/stable/$repo/$arch
    75: https://ftp.caliu.cat/pub/distribucions/manjaro/stable/$repo/$arch
    76: https://mirrors.atlas.net.co/manjaro/stable/$repo/$arch
    77: https://mirrors.pku.edu.cn/manjaro/stable/$repo/$arch
    78: http://ftp.riken.jp/Linux/manjaro/stable/$repo/$arch
    79: https://forksystems.mm.fcix.net/manjaro/stable/$repo/$arch
    80: https://manjaro.kurdy.org/stable/$repo/$arch
    81: https://nocix.mm.fcix.net/manjaro/stable/$repo/$arch
    82: https://fosszone.csd.auth.gr/manjaro/stable/$repo/$arch
    83: https://mirrors.ustc.edu.cn/manjaro/stable/$repo/$arch
    84: https://mirror.dkm.cz/manjaro/stable/$repo/$arch
    85: https://repo.ialab.dsu.edu/manjaro/stable/$repo/$arch
    86: https://mirrors.jlu.edu.cn/manjaro/stable/$repo/$arch
    87: https://mirror.nyist.edu.cn/manjaro/stable/$repo/$arch
    88: https://mirror.ufam.edu.br/manjaro/stable/$repo/$arch
    89: https://mirror.hostiko.network/manjaro/stable/$repo/$arch
    90: http://manjaro.grena.ge/stable/$repo/$arch
    91: https://mirrors.cicku.me/manjaro/stable/$repo/$arch
    92: http://ftp.tsukuba.wide.ad.jp/Linux/manjaro/stable/$repo/$arch
    93: https://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
    94: https://mirrors.manjaro.org/repo/stable/$repo/$arch
    95: https://mirrors.eric.ovh/manjaro/stable/$repo/$arch
    96: http://free.nchc.org.tw/manjaro/stable/$repo/$arch
    97: https://mirror.raiolanetworks.com/manjaro/stable/$repo/$arch
    98: https://mirrors.ft.uam.es/manjaro/stable/$repo/$arch
    99: https://ftp.lysator.liu.se/pub/manjaro/stable/$repo/$arch
    100: https://mirror.2degrees.nz/manjaro/stable/$repo/$arch
    101: https://mirror.23m.com/manjaro/stable/$repo/$arch
    102: https://manjaro.mirrors.lavatech.top/stable/$repo/$arch
    103: https://mirror.nju.edu.cn/manjaro/stable/$repo/$arch
    104: https://mirror.bardia.tech/manjaro/stable/$repo/$arch
    105: https://manjaro.repo.cure.edu.uy/stable/$repo/$arch
    106: https://edgeuno-bog2.mm.fcix.net/manjaro/stable/$repo/$arch
    107: https://www.mirrorservice.org/sites/repo.manjaro.org/repos/stable/$repo/$arch
    108: http://mirror.datacenter.by/pub/mirrors/manjaro/stable/$repo/$arch
    109: https://ftpmirror1.infania.net/mirror/manjaro/stable/$repo/$arch
    110: https://ct.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
    111: https://irltoolkit.mm.fcix.net/manjaro/stable/$repo/$arch
    112: https://gsl-syd.mm.fcix.net/manjaro/stable/$repo/$arch
    113: http://manjaro.mirror.ac.za/stable/$repo/$arch
    114: https://manjaro.mirror.liquidtelecom.com/stable/$repo/$arch
    115: https://mirror.alwyzon.net/manjaro/stable/$repo/$arch
    116: https://ridgewireless.mm.fcix.net/manjaro/stable/$repo/$arch
    117: https://manjaro.mirror.garr.it/manjaro/stable/$repo/$arch
    118: http://mirror.xeonbd.com/manjaro/stable/$repo/$arch
    119: https://southfront.mm.fcix.net/manjaro/stable/$repo/$arch
    120: http://ossmirror.mycloud.services/os/linux/manjaro/stable/$repo/$arch
    121: https://mirror.math.princeton.edu/pub/manjaro/stable/$repo/$arch
    122: https://mirror.zetup.net/manjaro/stable/$repo/$arch
    123: https://mirror.funami.tech/manjaro/stable/$repo/$arch
    124: https://mirrors.netix.net/manjaro/stable/$repo/$arch
    125: https://mirror.easyname.at/manjaro/stable/$repo/$arch
    126: https://mirror.xenyth.net/manjaro/stable/$repo/$arch
    127: https://mirrors.xtom.ee/manjaro/stable/$repo/$arch
    128: https://mirror.seahost.de/manjaro/stable/$repo/$arch
    129: https://distrohub.kyiv.ua/manjaro/stable/$repo/$arch
    130: https://ftp.psnc.pl/linux/manjaro/stable/$repo/$arch
    131: https://ftp.halifax.rwth-aachen.de/manjaro/stable/$repo/$arch
    132: https://linorg.usp.br/manjaro/stable/$repo/$arch
    133: https://mirror.bouwhuis.network/manjaro/stable/$repo/$arch
    134: https://mirrors2.manjaro.org/stable/$repo/$arch
    135: https://mirrors.tuna.tsinghua.edu.cn/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 230
  1: cpu: 10.6% command: firefox pid: 2011 mem: 530.7 MiB (2.2%)
  2: cpu: 4.9% command: [kworker/u16:3-phy0] pid: 4089 mem: 0.00 MiB (0.0%)
  3: cpu: 3.3% command: firefox pid: 2377 mem: 271.2 MiB (1.1%)
  4: cpu: 2.2% command: kwin_x11 pid: 1257 mem: 181.5 MiB (0.7%)
  5: cpu: 2.2% command: firefox pid: 2820 mem: 269.5 MiB (1.1%)
  Memory top: 5 of 230
  1: mem: 530.7 MiB (2.2%) command: firefox pid: 2011 cpu: 10.6%
  2: mem: 360.9 MiB (1.5%) command: plasmashell pid: 1332 cpu: 1.0%
  3: mem: 280.0 MiB (1.1%) command: firefox pid: 2293 cpu: 1.2%
  4: mem: 271.2 MiB (1.1%) command: firefox pid: 2377 cpu: 3.3%
  5: mem: 269.5 MiB (1.1%) command: firefox pid: 2820 cpu: 2.2%
  Processes: 230 Power: uptime: 16m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 9.31 GiB services: org_kde_powerdevil,
    tool: systemctl
  Compilers: N/A Shell: Bash v: 5.2.37 default: Zsh v: 5.9
    running-in: konsole inxi: 3.3.38
Checking the session’s journal reveals core dumps:
Jul 18 19:32:54 schatzi-pc kernel: ksmserver-logou[1591]: segfault at 56313fb6454b ip 00007fb9be09dda8 sp 00007ffc40524280 error 4 in libQt6Quick.so.6.9.1[29dda8,7fb9bdf3e000+455000] likely on CPU 2 (core 2, socket 0)
Jul 18 19:32:54 schatzi-pc kernel: Code: ff ff ff 66 0f fe c2 f3 0f e6 c0 0f 29 85 70 ff ff ff e9 c5 fa ff ff 0f 1f 00 48 8b 7b 08 48 8b 07 ff 50 48 48 8b 10 48 89 c7 <ff> 52 78 84 c0 0f 85 74 fa ff ff c6 43 10 01 e9 6b fa ff ff 0f 1f
Jul 18 19:32:54 schatzi-pc systemd-coredump[1607]: Process 1591 (ksmserver-logou) of user 1000 terminated abnormally with signal 11/SEGV, processing...
Jul 18 19:32:54 schatzi-pc systemd[1]: Started Process Core Dump (PID 1607/UID 0).
Jul 18 19:32:54 schatzi-pc systemd-coredump[1608]: Process 1591 (ksmserver-logou) of user 1000 dumped core.
                                                   Stack trace of thread 1591:
                                                   #0  0x00007fb9be09dda8 _ZN25QSGSoftwareRenderableNode6updateEv (libQt6Quick.so.6 + 0x29dda8)
                                                   #1  0x00007fb9be094e55 _ZN27QSGAbstractSoftwareRenderer11nodeChangedEP7QSGNode6QFlagsINS0_13DirtyStateBitEE (libQt6Quick.so.6 + 0x294e55)
                                                   #2  0x00007fb9be0e2cd8 _ZN7QSGNode9markDirtyE6QFlagsINS_13DirtyStateBitEE (libQt6Quick.so.6 + 0x2e2cd8)
                                                   #3  0x00007fb9aec4eb3b n/a (libKirigamiPrimitives.so.6 + 0x1fb3b)
                                                   #4  0x00007fb9be0e51c4 _ZN11QSGRenderer10preprocessEv (libQt6Quick.so.6 + 0x2e51c4)
                                                   #5  0x00007fb9be0e6727 n/a (libQt6Quick.so.6 + 0x2e6727)
                                                   #6  0x00007fb9be07a68c _ZN19QQuickWindowPrivate16renderSceneGraphEv (libQt6Quick.so.6 + 0x27a68c)
                                                   #7  0x00007fb9be0aca10 n/a (libQt6Quick.so.6 + 0x2aca10)
                                                   #8  0x00007fb9be07b9e5 _ZN12QQuickWindow5eventEP6QEvent (libQt6Quick.so.6 + 0x27b9e5)
                                                   #9  0x00007fb9bc768118 _ZN16QCoreApplication15notifyInternal2EP7QObjectP6QEvent (libQt6Core.so.6 + 0x168118)
                                                   #10 0x00007fb9bcfe9828 _ZN15QPlatformWindow20deliverUpdateRequestEv (libQt6Gui.so.6 + 0x1e9828)
                                                   #11 0x00007fb9bcfe5d65 _ZN15QPlatformWindow11windowEventEP6QEvent (libQt6Gui.so.6 + 0x1e5d65)
                                                   #12 0x00007fb9bcf94901 _ZN15QGuiApplication6notifyEP7QObjectP6QEvent (libQt6Gui.so.6 + 0x194901)
                                                   #13 0x00007fb9bc768118 _ZN16QCoreApplication15notifyInternal2EP7QObjectP6QEvent (libQt6Core.so.6 + 0x168118)
                                                   #14 0x00007fb9bc91bc6f _ZN14QTimerInfoList14activateTimersEv (libQt6Core.so.6 + 0x31bc6f)
                                                   #15 0x00007fb9bca3fc79 n/a (libQt6Core.so.6 + 0x43fc79)
                                                   #16 0x00007fb9bad1187d n/a (libglib-2.0.so.0 + 0x5e87d)
                                                   #17 0x00007fb9bad12cd7 n/a (libglib-2.0.so.0 + 0x5fcd7)
                                                   #18 0x00007fb9bad12ee5 g_main_context_iteration (libglib-2.0.so.0 + 0x5fee5)
                                                   #19 0x00007fb9bca3c5e2 _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt6Core.so.6 + 0x43c5e2)
                                                   #20 0x00007fb9bc7744b6 _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt6Core.so.6 + 0x1744b6)
                                                   #21 0x00007fb9bc76c7c1 _ZN16QCoreApplication4execEv (libQt6Core.so.6 + 0x16c7c1)
                                                   #22 0x000056345443adaf n/a (/usr/lib/ksmserver-logout-greeter + 0x6daf)
                                                   #23 0x00007fb9bc0376b5 n/a (libc.so.6 + 0x276b5)
                                                   #24 0x00007fb9bc037769 __libc_start_main (libc.so.6 + 0x27769)
                                                   #25 0x000056345443b055 n/a (/usr/lib/ksmserver-logout-greeter + 0x7055)
                                                   Stack trace of thread 1599:
                                                   #0  0x00007fb9bc0ade22 n/a (libc.so.6 + 0x9de22)
                                                   #1  0x00007fb9bc0a1fda n/a (libc.so.6 + 0x91fda)
                                                   #2  0x00007fb9bc0a2024 n/a (libc.so.6 + 0x92024)
                                                   #3  0x00007fb9bc11c5a6 ppoll (libc.so.6 + 0x10c5a6)
                                                   #4  0x00007fb9bad12e04 n/a (libglib-2.0.so.0 + 0x5fe04)
                                                   #5  0x00007fb9bad12ee5 g_main_context_iteration (libglib-2.0.so.0 + 0x5fee5)
                                                   #6  0x00007fb9bca3c5e2 _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt6Core.so.6 + 0x43c5e2)
                                                   #7  0x00007fb9bc7744b6 _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt6Core.so.6 + 0x1744b6)
                                                   #8  0x00007fb9bc88e054 _ZN7QThread3runEv (libQt6Core.so.6 + 0x28e054)
                                                   #9  0x00007fb9bc91ee69 n/a (libQt6Core.so.6 + 0x31ee69)
                                                   #10 0x00007fb9bc0a57eb n/a (libc.so.6 + 0x957eb)
                                                   #11 0x00007fb9bc12918c n/a (libc.so.6 + 0x11918c)
                                                   Stack trace of thread 1605:
                                                   #2  0x00007fb9bc0a264c n/a (libc.so.6 + 0x9264c)
                                                   #3  0x00007fb9bc0a4f28 pthread_cond_timedwait (libc.so.6 + 0x94f28)
                                                   #4  0x00007fb9bc92dd25 _ZN14QWaitCondition4waitEP6QMutex14QDeadlineTimer (libQt6Core.so.6 + 0x32dd25)
                                                   #5  0x00007fb9bc927c40 n/a (libQt6Core.so.6 + 0x327c40)
                                                   #6  0x00007fb9bc91ee69 n/a (libQt6Core.so.6 + 0x31ee69)
                                                   #7  0x00007fb9bc0a57eb n/a (libc.so.6 + 0x957eb)
                                                   #8  0x00007fb9bc12918c n/a (libc.so.6 + 0x11918c)
                                                   Stack trace of thread 1592:
                                                   #8  0x00007fb9bc8873c6 _ZN7QThread4execEv (libQt6Core.so.6 + 0x2873c6)
                                                   #9  0x00007fb9bd77adae n/a (libQt6DBus.so.6 + 0x37dae)
                                                   #10 0x00007fb9bc91ee69 n/a (libQt6Core.so.6 + 0x31ee69)
                                                   #11 0x00007fb9bc0a57eb n/a (libc.so.6 + 0x957eb)
                                                   #12 0x00007fb9bc12918c n/a (libc.so.6 + 0x11918c)
                                                   Stack trace of thread 1601:
                                                   Stack trace of thread 1606:
                                                   Stack trace of thread 1593:
                                                   #3  0x00007fb9bc11c05e __poll (libc.so.6 + 0x10c05e)
                                                   #4  0x00007fb9bd72520b n/a (libxcb.so.1 + 0xd20b)
                                                   #5  0x00007fb9bd726f3d xcb_wait_for_event (libxcb.so.1 + 0xef3d)
                                                   #6  0x00007fb9b5fb56e9 n/a (libQt6XcbQpa.so.6 + 0x566e9)
                                                   #7  0x00007fb9bc91ee69 n/a (libQt6Core.so.6 + 0x31ee69)
                                                   #8  0x00007fb9bc0a57eb n/a (libc.so.6 + 0x957eb)
                                                   #9  0x00007fb9bc12918c n/a (libc.so.6 + 0x11918c)
                                                   Stack trace of thread 1602:
Jul 18 19:32:54 schatzi-pc systemd[1]: systemd-coredump@3-1607-0.service: Deactivated successfully.
Jul 18 19:32:54 schatzi-pc systemd[1]: systemd-coredump@3-1607-0.service: Consumed 317ms CPU time, 105.6M memory peak.
Jul 18 19:32:54 schatzi-pc systemd[910]: dbus-:1.2-org.kde.LogoutPrompt@0.service: Main process exited, code=dumped, status=11/SEGV
Jul 18 19:32:54 schatzi-pc systemd[910]: dbus-:1.2-org.kde.LogoutPrompt@0.service: Failed with result 'core-dump'.
I’d be happy to share the full journal. Should I post it here?
What is going on here? Can someone help?
Should I rewrite the title in order to better highlight the observed segfault of ksmserver-logout?
Title changed for you.
Maybe this will attract some attention, but keep in mind that you posted at the weekend, which isn’t always ideal (the forum seems less busy generally at weekends).
Yes, better too much info than not enough.
I have seen a couple of topic with roughly the same description
I specifically note that the system info is generated while using a Manjaro installation ISO - so it is difficult to conclude anything from this - other than your system work.
From your system info I looked for and found
Please check what Nvidia recommends for your specific GPU by using the utilities
nvidia-driver-assistant
or
nvidia-recommended-driver
The latter is simply a wrapper around the former and will give you a single clue.
See this for instruction on how to chroot your system [root tip] [recovery] Basic Manjaro Linux Recovery
When you have succesfully entered the chroot environment - please install the driver recommended by the above utility.
some say it might be some widgets crashing it …
https://bugreports.qt.io/browse/QTBUG-138457
Solution: update mesa to at least 25.1.6.
Thanks for the replies.
This is the full journal from that session: https://0x0.st/8dd_.txt
This is the messy system information from within chroot:
sh-5.3# inxi --admin --verbosity=8 --filter --no-host --width
  Kernel 6.12.34-1-MANJARO arch x86_64 bits 64 compiler gcc v 15.1.1
    clocksource tsc avail hpet,acpi_pm parameters BOOT_IMAGE=/boot/vmlinuz-x86_64
    lang=en_US keytable=de tz=UTC misobasedir=manjaro
    misolabel=MANJARO_KDE_2504 quiet systemd.show_status=1 splash driver=free
  Desktop KDE Plasma v ERR-101 tk Qt v N/A wm kwin_x11 dm N/A Distro Manjaro
    base Arch Linux
  Type Desktop System MSI product MS-7798 v 1.0 serial N/A
  Mobo MSI model B75MA-P45 (MS-7798) v 1.0 serial N/A
    uuid 00000000-0000-0000-0000-8c89a5dbb51e UEFI American Megatrends v 1.9
    date 09/30/2013
  Device-1 hidpp_battery_0 model Logitech M720 Triathlon Multi-Device Mouse
    serial <filter> charge Full status discharging
  System RAM total 24 GiB available 23.4 GiB used 2.78 GiB (11.9%)
  Array-1 capacity 32 GiB slots 4 modules 4 EC None max-module-size 8 GiB
    note est.
  Device-1 ChannelA-DIMM0 type DDR3 detail synchronous size 4 GiB
    speed 1333 MT/s volts N/A width (bits) data 64 total 64 manufacturer Corsair
    part-no CML8GX3M2A1600C9 serial N/A
  Device-2 ChannelA-DIMM1 type DDR3 detail synchronous size 8 GiB
    manufacturer Hynix/Hyundai part-no HMT41GU6AFR8A-PB serial <filter>
  Device-3 ChannelB-DIMM0 type DDR3 detail synchronous size 4 GiB
  Device-4 ChannelB-DIMM1 type DDR3 detail synchronous size 8 GiB
  Slot 0 type PCIe status available info J6B2 length short volts 3.3
    bus-ID 00:11.4
  Slot 1 type PCIe status in use info J6B1 length long volts 3.3
    bus-ID 00:01.0 children 1 01:00.0 class-ID 0300 type display 2 01:00.1
    class-ID 0403 type audio
  Slot 2 type PCIe status available info J6D1 length short volts 3.3
    bus-ID 00:1c.1 children 1 03:00.0 class-ID 0200 type network
  Slot 3 type PCIe status available info J7B1 length short volts 3.3
    bus-ID 00:1c.2
  Slot 4 type PCIe status available info J8B4 length long volts 3.3
    bus-ID ff:01.1
  Slot 5 type PCI status available info J8D1 length short volts 3.3
    bus-ID 00:00.0
  Slot 6 type PCI status in use info J8B3 length short volts 3.3
  Info model Intel Core i5-3450S socket BGA1155 bits 64 type MCP
    arch Ivy Bridge gen core 3 level v2 built 2012-15 process Intel 22nm family 6
    model-id 0x3A (58) stepping 9 microcode 0x21
  Topology cpus 1x dies 1 clusters 4 cores 4 smt <unsupported> cache
    L1 256 KiB desc d-4x32 KiB; i-4x32 KiB L2 1024 KiB desc 4x256 KiB L3 6 MiB
    desc 1x6 MiB
  Speed (MHz) avg 1600 min/max 1600/3500 base/boost 2800/3800 scaling
    driver intel_cpufreq governor schedutil volts 5.0 V ext-clock 100 MHz cores
    1 1600 2 1600 3 1600 4 1600 bogomips 22410
  Flags acpi aes aperfmperf apic arat arch_perfmon avx bts clflush cmov
  Vulnerabilities
  Type gather_data_sampling status Not affected
  Type indirect_target_selection status Not affected
  Type itlb_multihit status KVM: Split huge pages
  Type l1tf mitigation PTE Inversion; VMX: conditional cache flushes, SMT
    disabled
  Type mds mitigation Clear CPU buffers; SMT disabled
  Type meltdown mitigation PTI
  Type mmio_stale_data status Unknown: No mitigations
  Type reg_file_data_sampling status Not affected
  Type retbleed status Not affected
  Type spec_rstack_overflow status Not affected
  Type spec_store_bypass mitigation Speculative Store Bypass disabled via
  Type spectre_v1 mitigation usercopy/swapgs barriers and __user pointer
  Type spectre_v2 mitigation Retpolines; IBPB: conditional; IBRS_FW; STIBP:
  Type srbds status Vulnerable: No microcode
  Type tsx_async_abort status Not affected
  Device-1 NVIDIA GA106 [GeForce RTX 3060 Lite Hash Rate] vendor Micro-Star MSI
    driver nouveau v kernel non-free 550-570.xx+ status current (as of 2025-04;
    EOL~2026-12-xx) arch Ampere code GAxxx process TSMC n7 (7nm)
    built 2020-2023 pcie gen 2 speed 5 GT/s lanes 16 link-max gen 4
    speed 16 GT/s ports active HDMI-A-1 empty DP-1,DP-2,DP-3 bus-ID 01:00.0
    chip-ID 10de:2504 class-ID 0300
  Display server X.org v 1.21.1.18 with Xwayland v 24.1.8 compositor kwin_x11
    driver X loaded nvidia gpu nouveau display-ID :0
  Monitor-1 HDMI-A-1 model Idek Iiyama PL2792Q serial <filter> built 2021
    res 2560x1440 dpi 109 gamma 1.2 chroma red x 0.671 y 0.333 green x 0.298
    y 0.627 blue x 0.141 y 0.051 white x 0.322 y 0.329
    size 597x336mm (23.5x13.23") diag 685mm (27") ratio 16:9 modes 2560x1440,
    2048x1280, 1920x1200, 1920x1080, 1600x1200, 1680x1050, 1600x900,
    1280x1024, 1440x900, 1280x720, 1024x768, 800x600, 720x576, 720x480,
    640x480
  API EGL v 1.5 platforms device 0 drv zink device 1 drv swrast gbm drv zink
    surfaceless drv zink inactive wayland,x11
  API OpenGL v 4.6 compat-v 4.5 vendor mesa v 25.1.5-arch1.1 note incomplete
    (EGL sourced) renderer zink Vulkan 1.4(NVIDIA GeForce RTX 3060 (NVK GA106)
    (MESA_NVK)), llvmpipe (LLVM 20.1.7 256 bits)
  API Vulkan Message No Vulkan data available.
  Info Tools api clinfo, eglinfo, glxinfo, vulkaninfo
    de kscreen-console,kscreen-doctor gpu nvidia-settings,nvidia-smi
    wl wayland-info x11 xdpyinfo, xprop, xrandr
  Device-1 Intel 7 Series/C216 Family High Definition Audio
    vendor Micro-Star MSI driver snd_hda_intel v kernel bus-ID 00:1b.0
    chip-ID 8086:1e20 class-ID 0403
  Device-2 NVIDIA GA106 High Definition Audio vendor Micro-Star MSI
    driver snd_hda_intel v kernel pcie gen 2 speed 5 GT/s lanes 16 link-max gen 4
    speed 16 GT/s bus-ID 01:00.1 chip-ID 10de:228e class-ID 0403
  API ALSA v k6.12.34-1-MANJARO status kernel-api with aoss type oss-emulator
    tools alsactl,alsamixer,amixer
  Server-1 JACK v 1.9.22 status off tools N/A
  Server-2 PipeWire v 1.4.6 status n/a (root, process) with 1 pipewire-pulse
    status active 2 pipewire-media-session status off 3 pipewire-alsa type plugin
    tools pactl,pw-cat,pw-cli
  Device-1 Realtek RTL8111/8168/8211/8411 PCI Express Gigabit Ethernet
    vendor Micro-Star MSI driver r8169 v kernel pcie gen 1 speed 2.5 GT/s lanes 1
    port d000 bus-ID 03:00.0 chip-ID 10ec:8168 class-ID 0200
  IF enp3s0 state down mac <filter>
  Device-2 NetGear WNDA4100 802.11abgn 3x3:3 [Ralink RT3573] driver rt2800usb
    type USB rev 2.0 speed 480 Mb/s lanes 1 mode 2.0 bus-ID 1-3:4
    chip-ID 0846:9012 class-ID 0000 serial <filter>
  IF wlp0s20u3 state up mac <filter>
  IP v4 <filter> type dynamic noprefixroute scope global broadcast <filter>
  IP v6 <filter> type dynamic noprefixroute scope global
  IP v6 <filter> type noprefixroute scope link
  Info services NetworkManager, systemd-timesyncd, wpa_supplicant
  WAN IP <filter>
  Device-1 Cambridge Silicon Radio Bluetooth Dongle (HCI mode) driver btusb
    v 0.8 type USB rev 2.0 speed 12 Mb/s lanes 1 mode 1.1 bus-ID 1-1:2
    chip-ID 0a12:0001 class-ID e001
  Report rfkill ID hci0 rfk-id 0 state up address see --recommends
  Message No logical block device data found.
  Message No RAID data found.
  Local Storage total 1.62 TiB used 133.23 GiB (8.0%)
  ID-1 /dev/sda maj-min 8:0 vendor Samsung model SSD 860 EVO 250GB
    family based SSDs size 232.89 GiB block-size physical 512 B logical 512 B
    sata 3.2 speed 6.0 Gb/s tech SSD serial <filter> fw-rev 4B6Q temp 26 C
  SMART yes state enabled health PASSED on 157d 11h cycles 1074
    written 7.47 TiB
  ID-2 /dev/sdb maj-min 8:16 vendor Samsung model SSD 870 EVO 1TB
    family based SSDs size 931.51 GiB block-size physical 512 B logical 512 B
    sata 3.3 speed 3.0 Gb/s tech SSD serial <filter> fw-rev 3B6Q temp 26 C
  SMART yes state enabled health PASSED on 86 hrs cycles 18
    written 446.23 GiB
  ID-3 /dev/sdc maj-min 8:32 vendor Samsung model SSD 860 EVO 500GB
    family based SSDs size 465.76 GiB block-size physical 512 B logical 512 B
    sata 3.1 speed 3.0 Gb/s tech SSD serial <filter> fw-rev 1B6Q temp 25 C
  SMART yes state enabled health PASSED on 299d 22h cycles 1627
    written 7.33 TiB
  ID-4 /dev/sdd maj-min 8:48 vendor SanDisk model Ultra Fit size 28.64 GiB
    block-size physical 512 B logical 512 B type USB rev 3.0 spd 5 Gb/s lanes 1
    mode 3.2 gen-1x1 tech N/A serial <filter> fw-rev 1.00
  SMART Message Unknown USB bridge. Flash drive/Unsupported enclosure?
  Message No optical or floppy data found.
  ID-1 / raw-size 232.59 GiB size 227.88 GiB (97.98%) used 133.23 GiB (58.5%)
    fs ext4 block-size 4096 B dev /dev/dm-0 maj-min 254:0 mapped tmp label N/A
    uuid N/A
  ID-2 /boot/efi raw-size 300 MiB size 299.4 MiB (99.80%) used 472 KiB (0.2%)
    fs vfat block-size 512 B dev /dev/sda1 maj-min 8:1 label NO_LABEL
    uuid 04E7-F02F
  Alert No swap data was found.
  ID-1 /dev/sda2 maj-min 8:2 size 232.59 GiB fs N/A label N/A
    uuid ac37595d-5b67-408c-82b8-547a678e97e6
  ID-2 /dev/sdb1 maj-min 8:17 size 931.51 GiB fs N/A label N/A
    uuid 8e70af97-5288-4227-b43f-15c7ae8b158e
  ID-3 /dev/sdc1 maj-min 8:33 size 465.76 GiB fs N/A label N/A
    uuid 97478fb5-267e-493d-8774-49eef2f55050
  ID-4 /dev/sdd1 maj-min 8:49 size 4.13 GiB fs N/A label MANJARO_KDE_2504
    uuid 2025-06-23-07-30-54-00
  ID-5 /dev/sdd2 maj-min 8:50 size 4 MiB fs N/A label MISO_EFI uuid ECC9-5CDB
  Hub-1 1-0:1 info hi-speed hub with single TT ports 4 rev 2.0
    speed 480 Mb/s (57.2 MiB/s) lanes 1 mode 2.0 chip-ID 1d6b:0002 class-ID 0900
  Device-1 1-1:2 info Cambridge Silicon Radio Bluetooth Dongle (HCI mode)
    type bluetooth driver btusb interfaces 2 rev 2.0 speed 12 Mb/s (1.4 MiB/s)
    lanes 1 mode 1.1 power 100mA chip-ID 0a12:0001 class-ID e001
  Device-2 1-3:4 info NetGear WNDA4100 802.11abgn 3x3:3 [Ralink RT3573]
    type Network driver rt2800usb interfaces 1 rev 2.0
    speed 480 Mb/s (57.2 MiB/s) lanes 1 mode 2.0 power 450mA chip-ID 0846:9012
  Hub-2 1-4:5 info Huasheng USB2.0 HUB ports 4 rev 2.0
    speed 480 Mb/s (57.2 MiB/s) lanes 1 mode 2.0 power 100mA chip-ID 214b:7250
    class-ID 0900
  Hub-3 1-4.3:6 info Monterey BakkerElkhuizen Wired Keyboard S-board 840
    Design USB-Hub ports 3 rev 2.0 speed 480 Mb/s (57.2 MiB/s) lanes 1 mode 2.0
    power 100mA chip-ID 0566:3020 class-ID 0900
  Device-1 1-4.3.2:7 info Logitech Unifying Receiver type keyboard,mouse,HID
    driver logitech-djreceiver,usbhid interfaces 3 rev 2.0
    speed 12 Mb/s (1.4 MiB/s) lanes 1 mode 1.1 power 98mA chip-ID 046d:c52b
    class-ID 0300
  Device-2 1-4.3.3:8 info Monterey BakkerElkhuizen Wired Keyboard S-board
    840 Design type keyboard,HID driver hid-generic,usbhid interfaces 2 rev 1.1
    speed 1.5 Mb/s (183 KiB/s) lanes 1 mode 1.0 power 100mA chip-ID 0566:3013
    class-ID 0300
  Hub-4 2-0:1 info full speed or root hub ports 2 rev 2.0
  Hub-5 2-1:2 info Intel Integrated Rate Matching Hub ports 6 rev 2.0
    speed 480 Mb/s (57.2 MiB/s) lanes 1 mode 2.0 chip-ID 8087:0024 class-ID 0900
  Hub-6 3-0:1 info super-speed hub ports 4 rev 3.0 speed 5 Gb/s (596.0 MiB/s)
    lanes 1 mode 3.2 gen-1x1 chip-ID 1d6b:0003 class-ID 0900
  Device-1 3-2:2 info SanDisk Ultra Fit type mass storage driver usb-storage
    interfaces 1 rev 3.0 speed 5 Gb/s (596.0 MiB/s) lanes 1 mode 3.2 gen-1x1
    power 896mA chip-ID 0781:5583 class-ID 0806 serial <filter>
  Hub-7 4-0:1 info full speed or root hub ports 2 rev 2.0
  Hub-8 4-1:2 info Intel Integrated Rate Matching Hub ports 6 rev 2.0
  Hub-9 4-1.5:3 info Realtek 4-Port USB 2.0 Hub ports 2 rev 2.1
    speed 480 Mb/s (57.2 MiB/s) lanes 1 mode 2.0 chip-ID 0bda:5412 class-ID 0900
  System Temperatures cpu 36.0 C mobo N/A
  Fan Speeds (rpm) N/A
  Packages pm pacman pkgs 1892 libs 449 tools pamac pm flatpak pkgs 0
  Active pacman repo servers in /etc/pacman.d/mirrorlist
    1 http: //ftp.rz.tu-bs.de/pub/mirror/manjaro.org/repos/stable/$repo/$arch
    2 https: //mirrors.dotsrc.org/manjaro/stable/$repo/$arch
    3 https: //coresite.mm.fcix.net/manjaro/stable/$repo/$arch
    4 https: //forksystems.mm.fcix.net/manjaro/stable/$repo/$arch
    5 https: //ohioix.mm.fcix.net/manjaro/stable/$repo/$arch
    6 http: //manjaro.grena.ge/stable/$repo/$arch
    7 https: //fosszone.csd.auth.gr/manjaro/stable/$repo/$arch
    8 https: //gsl-syd.mm.fcix.net/manjaro/stable/$repo/$arch
Processes:
  CPU top 5 of 226
  1 cpu 200% command ps pid 4577 mem 3.88 MiB (0.0%)
  2 cpu 9.8% command firefox pid 2738 mem 478.1 MiB (1.9%)
  3 cpu 2.5% command kwin_x11 pid 1247 mem 194.2 MiB (0.8%)
  4 cpu 2.2% command Xorg pid 994 mem 120.1 MiB (0.5%)
  5 cpu 2.2% command firefox pid 3116 mem 250.9 MiB (1.0%)
  Memory top 5 of 226
  1 mem 478.1 MiB (1.9%) command firefox pid 2738 cpu 9.8%
  2 mem 362.0 MiB (1.5%) command plasmashell pid 1325 cpu 0.9%
  3 mem 259.0 MiB (1.0%) command firefox pid 2957 cpu 0.7%
  4 mem 257.5 MiB (1.0%) command firefox pid 2976 cpu 1.8%
  5 mem 250.9 MiB (1.0%) command firefox pid 3116 cpu 2.2%
  Processes 226 Power uptime 17m states freeze,mem,disk suspend deep
    avail s2idle wakeups 0 hibernate platform avail shutdown, reboot, suspend,
    test_resume image 9.31 GiB services org_kde_powerdevil,
    power-profiles-daemon, upowerd Init systemd v 257 default graphical
    tool systemctl
  Compilers clang 20.1.7 gcc 15.1.1 Client systemd inxi 3.3.38
I could not manage to get rid of these '12’s.
This is about the recommended drivers:
sh-5.3# nvidia-driver-assistant
Detected GPUs:
  NVIDIA GeForce RTX 3060 - (pci_id 0x2504)
Detected system:
  Manjaro Linux
Please copy and paste the following command to install the open kernel module flavour:
  sudo pacman -S linux612-nvidia-open
sh-5.3# nvidia-recommended-driver
open
sh-5.3# mhwd -li
> Installed PCI configs:
          video-nvidia            2025.01.13               false            PCI
           video-linux            2024.05.06                true            PCI
I’d say the tool recommends the open source driver. Will try to fix this.
You can still boot your real system?
provide the inxi from within that,
rather than from a chroot from a live system
From within chroot, the output will be essentially the same as from without - just unreadable, as you noticed.
Ok, thanks!
The output of inxi is already posted above. I think I misunderstood @linux-aarhus. My bad, sorry!
I can only boot into live system. Then I changed the driver to open like this:
[manjaro /]# mhwd -li
[manjaro /]# mhwd -r pci video-nvidia
> Removing video-nvidia...
Sourcing /etc/mhwd-x86_64.conf
Has lib32 support: true
Sourcing /var/lib/mhwd/local/pci/video-nvidia/MHWDCONFIG
Processing classid: 0300
Sourcing /var/lib/mhwd/scripts/include/0300
Processing classid: 0302
checking dependencies...
:: ffmpeg optionally requires nvidia-utils: Nvidia NVDEC/NVENC support
:: ffmpeg4.4 optionally requires nvidia-utils: Nvidia NVDEC/NVENC support
:: lib32-libvdpau optionally requires lib32-nvidia-utils: driver for NVIDIA
:: lib32-vulkan-icd-loader optionally requires lib32-vulkan-driver: packaged vulkan driver
:: libvdpau optionally requires nvidia-utils: driver for NVIDIA
:: sdl3 optionally requires vulkan-driver: vulkan renderer
:: vulkan-icd-loader optionally requires vulkan-driver: packaged vulkan driver
warning: dependency cycle detected:
warning: eglexternalplatform will be removed after its nvidia-utils dependency
Packages (10) egl-gbm-1.1.2.1-1  egl-wayland-4:1.1.19-1  egl-x11-1.0.2-1  eglexternalplatform-1.2.1-1  lib32-nvidia-utils-575.64.03-1  libxnvctrl-575.64-1  linux54-nvidia-open-575.64.03-2  linux612-nvidia-open-575.64.03-5  nvidia-settings-575.64.03-1  nvidia-utils-575.64.03-1
Total Removed Size:  1162.95 MiB
:: Do you want to remove these packages? [Y/n]
removing linux612-nvidia-open...
removing linux54-nvidia-open...
removing lib32-nvidia-utils...
xorg configuration symlink valid...
removing libxnvctrl...
removing nvidia-settings...
removing nvidia-utils...
Removed '/etc/systemd/system/systemd-hibernate.service.wants/nvidia-hibernate.service'.
Removed '/etc/systemd/system/systemd-hibernate.service.wants/nvidia-resume.service'.
Removed '/etc/systemd/system/systemd-suspend-then-hibernate.service.wants/nvidia-resume.service'.
Removed '/etc/systemd/system/systemd-suspend.service.wants/nvidia-suspend.service'.
Removed '/etc/systemd/system/systemd-suspend.service.wants/nvidia-resume.service'.
removing egl-x11...
removing egl-wayland...
removing egl-gbm...
removing eglexternalplatform...
(1/8) Reloading system manager configuration...
  Skipped: Running in chroot.
(2/8) Reloading device manager configuration...
(3/8) Arming ConditionNeedsUpdate...
(4/8) Updating module dependencies...
(5/8) Updating linux initcpios...
==> Building image from preset: /etc/mkinitcpio.d/linux54.preset: 'default'
==> Using default configuration file: '/etc/mkinitcpio.conf'
==> WARNING: Deprecated option 'ALL_microcode' found. Update '/etc/mkinitcpio.d/linux54.preset' to use the 'microcode' hook instead.
  -> -k /boot/vmlinuz-5.4-x86_64 -g /boot/initramfs-5.4-x86_64.img
==> Starting build: '5.4.296-1-MANJARO'
  -> Running build hook: [base]
  -> Running build hook: [udev]
  -> Running build hook: [kms]
==> WARNING: No module containing the symbol 'drm_privacy_screen_register' found in: 'drivers/platform'
  -> Running build hook: [consolefont]
==> WARNING: consolefont: no font found in configuration
  -> Running build hook: [encrypt]
  -> Running build hook: [fsck]
==> Creating gzip-compressed initcpio image: '/boot/initramfs-5.4-x86_64.img'
  -> Early uncompressed CPIO image generation successful
==> Initcpio image generation successful
==> Building image from preset: /etc/mkinitcpio.d/linux54.preset: 'fallback'
  -> -k /boot/vmlinuz-5.4-x86_64 -g /boot/initramfs-5.4-x86_64-fallback.img -S autodetect
==> WARNING: Possibly missing firmware for module: 'ast'
==> WARNING: Possibly missing firmware for module: 'qla1280'
==> WARNING: Possibly missing firmware for module: 'qed'
==> WARNING: Possibly missing firmware for module: 'bfa'
==> WARNING: Possibly missing firmware for module: 'qla2xxx'
==> WARNING: Possibly missing firmware for module: 'aic94xx'
==> WARNING: Possibly missing firmware for module: 'wd719x'
==> Creating gzip-compressed initcpio image: '/boot/initramfs-5.4-x86_64-fallback.img'
==> Building image from preset: /etc/mkinitcpio.d/linux612.preset: 'default'
  -> -k /boot/vmlinuz-6.12-x86_64 -g /boot/initramfs-6.12-x86_64.img
==> Starting build: '6.12.39-1-MANJARO'
==> Creating zstd-compressed initcpio image: '/boot/initramfs-6.12-x86_64.img'
==> Building image from preset: /etc/mkinitcpio.d/linux612.preset: 'fallback'
  -> -k /boot/vmlinuz-6.12-x86_64 -g /boot/initramfs-6.12-x86_64-fallback.img -S autodetect
==> WARNING: Possibly missing firmware for module: 'xhci_pci_renesas'
==> Creating zstd-compressed initcpio image: '/boot/initramfs-6.12-x86_64-fallback.img'
(6/8) Refreshing PackageKit...
Error connecting: Could not connect: No such file or directory
error: command failed to execute correctly
(7/8) Reloading system bus configuration...
(8/8) Updating the desktop file MIME type cache...
'/etc/X11/xorg.conf.d/90-mhwd.conf' symlink is invalid! Removing it...
> Successfully removed video-nvidia
[manjaro /]# sudo pacman -Syu
 core is up to date
 extra is up to date
 multilib is up to date
warning: ksystemstats: local (6.4.0-1) is newer than extra (6.3.6-1)
 there is nothing to do
I can reboot until I stuck at a black screen now. This is different than the original behaviour, where I was able to login.
Both the inxi outputs you posted are obtained from a live system - not from the real one.
… black screen?
You can’t switch to TTY?
If you could, you could use the same approach as you already used:
generating the output and posting it to 0x0.st (for example) and sharing the link.
This is a good idea: :flushed:
https://0x0.st/8dnZ.txt
Same story, but different:
systemd-coredump[857]: Process 844 (sddm-greeter-qt) of user 964 terminated abnormally with signal 11/SEGV, processing...
… but that was not inxi output - it was the journal log again :grin:
You could also - if you can get to a TTY - disable sddm (temporarily)
in the hopes that you then end up directly in a TTY after boot
systemctl disable sddm.service
There are other ways to boot to single user mode or without starting the graphical target.
(by editing the grub command line …)
Here you go, with hopefully better inxi-output: https://0x0.st/8dnV.txt
Is this ok now?
It is the output you where asked for, yes.
Thank you.
Now, @linux-aarhus recommended some things.
He knows what for and can interpret the result - I can’t.
I do not have an NVIDIA GPU and know literally nothing about it, except to steer clear of those whenever I can. :grimacing:
Could you please confirm, that I inferred and installed correctly?
My installed version matches the requirement:
sh-5.3# pacman -Qi mesa
Version         : 1:25.1.6-1
Description     : Open-source OpenGL drivers
Architecture    : x86_64
URL             : https://www.mesa3d.org/
Licenses        : MIT AND BSD-3-Clause AND SGI-B-2.0
Groups          : None
Provides        : libva-mesa-driver=1:25.1.6-1  mesa-libgl=1:25.1.6-1  mesa-vdpau=1:25.1.6-1  libva-driver
                  opengl-driver  vdpau-driver
Depends On      : expat  gcc-libs  glibc  libdrm  libelf  libglvnd  libx11  libxcb  libxext  libxshmfence
                  libxxf86vm  llvm-libs  lm_sensors  spirv-tools  wayland  zlib  zstd
Optional Deps   : opengl-man-pages: for the OpenGL API man pages
Required By     : cogl  gst-plugins-bad-libs  gst-plugins-base-libs  kpipewire  kwin  lib32-mesa  libglvnd
                  mhwd  mpv  qemu-ui-opengl  qt5-base  qt6-base  qt6-webengine  signal-desktop  virglrenderer
                  webkit2gtk-4.1  xf86-video-amdgpu  xf86-video-ati  xf86-video-intel  xf86-video-nouveau
                  xorg-xwayland
Optional For    : libva  libvdpau  vlc-plugins-video-output
Conflicts With  : libva-mesa-driver<1:24.2.7-1  mesa-libgl<17.0.1-2  mesa-vdpau<1:24.2.7-1
Replaces        : libva-mesa-driver<1:24.2.7-1  mesa-libgl<17.0.1-2  mesa-vdpau<1:24.2.7-1
Installed Size  : 40.79 MiB
Packager        : Jan Alexander Steffens (heftig) <heftig@archlinux.org>
Build Date      : Wed Jul 16 19:59:09 2025
Install Date    : Sun Jul 20 15:48:54 2025
Install Reason  : Installed as a dependency for another package
Install Script  : No
Validated By    : Signature
Corrected for you this one time only; 5 minutes with a capable text editor, and a keen eye. No charge.
… the easy way is not to do it from within chroot … :nerd_face:
I’m about to investigate where that strange, although quite consistently distorted, output results from.
Maybe I find something, maybe not. :nerd_face:
Or do you happen to know how these not really random 12 come about?
These links are not intended as possible fixes; but, to indicate similar issues which may have the same root cause;
It’s an annoyance that has been lingering for quite some time. :man_shrugging: It seems to happen with a fairly limited amount of systems, but that’s a long way from being definitive.
hm - I know.
mhwd-kernel -i something
doesn’t work either in chroot …
I don’t remember any similar “problem” from earlier, using other, more “manual” methods to enter chroot.
I’ll look - maybe I discover the reason.
Likely not - I’m not that good. :grinning:
But still curious.
This might get overlooked, therefore I post it here explicitly again. It is neither captured from live system, nor from chroot, but after normal boot by switching to tty:
  Kernel: 6.12.39-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.1.1
    root=UUID=4c2ea2f1-3cfa-4377-8778-97f19f2453fe rw quiet
    cryptdevice=UUID=ac37595d-5b67-408c-82b8-547a678e97e6:luks-ac37595d-5b67-408c-82b8-547a678e97e6
    root=/dev/mapper/luks-ac37595d-5b67-408c-82b8-547a678e97e6
    udev.log_priority=3
  Console: pty pts/0 DM: SDDM Distro: Manjaro base: Arch Linux
  Type: Desktop System: MSI product: MS-7798 v: 1.0 serial: N/A
  Mobo: MSI model: B75MA-P45 (MS-7798) v: 1.0 serial: N/A
    uuid: 00000000-0000-0000-0000-8c89a5dbb51e UEFI: American Megatrends v: 1.9
    date: 09/30/2013
    status: discharging
  System RAM: total: 24 GiB available: 23.4 GiB used: 650.4 MiB (2.7%)
  Slot: 0 type: PCIe status: available info: J6B2 length: short volts: 3.3
    bus-ID: 00:11.4
  Slot: 1 type: PCIe status: in use info: J6B1 length: long volts: 3.3
    bus-ID: 00:01.0 children: 1: 01:00.0 class-ID: 0300 type: display 2: 01:00.1
    class-ID: 0403 type: audio
  Slot: 2 type: PCIe status: available info: J6D1 length: short volts: 3.3
    bus-ID: 00:1c.1 children: 1: 03:00.0 class-ID: 0200 type: network
  Slot: 3 type: PCIe status: available info: J7B1 length: short volts: 3.3
    bus-ID: 00:1c.2
  Slot: 4 type: PCIe status: available info: J8B4 length: long volts: 3.3
    bus-ID: ff:01.1
  Slot: 5 type: PCI status: available info: J8D1 length: short volts: 3.3
    bus-ID: 00:00.0
  Slot: 6 type: PCI status: in use info: J8B3 length: short volts: 3.3
  Info: model: Intel Core i5-3450S socket: BGA1155 bits: 64 type: MCP
    arch: Ivy Bridge gen: core 3 level: v2 built: 2012-15 process: Intel 22nm
    family: 6 model-id: 0x3A (58) stepping: 9 microcode: 0x21
  Speed (MHz): avg: 1600 min/max: 1600/3500 base/boost: 2800/3800 scaling:
    driver: intel_cpufreq governor: schedutil volts: 5.0 V ext-clock: 100 MHz
    cores: 1: 1600 2: 1600 3: 1600 4: 1600 bogomips: 22410
    disabled
    process: TSMC n7 (7nm) built: 2020-2023 pcie: gen: 1 speed: 2.5 GT/s
  Display: unspecified server: X.org v: 1.21.1.18 with: Xwayland v: 24.1.8
    driver: X: loaded: modesetting alternate: fbdev,vesa dri: zink gpu: nouveau
    tty: 160x45
  Monitor-1: HDMI-A-1 model: Idek Iiyama PL2792Q serial: <filter> built: 2021
    res: 2560x1440 dpi: 109 gamma: 1.2 chroma: red: x: 0.671 y: 0.333 green:
    x: 0.298 y: 0.627 blue: x: 0.141 y: 0.051 white: x: 0.322 y: 0.329
    720x480, 640x480
    drv: zink surfaceless: drv: zink inactive: wayland,x11
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: mesa v: 25.1.6-arch1.1
    note: console (EGL sourced) renderer: zink Vulkan 1.4(NVIDIA GeForce RTX
    3060 (NVK GA106) (MESA_NVK)), llvmpipe (LLVM 20.1.8 256 bits)
  API: Vulkan v: 1.4.321 layers: N/A device: 0 type: discrete-gpu name: NVIDIA
    GeForce RTX 3060 (NVK GA106) driver: mesa nvk v: 25.1.6-arch1.1
    class-ID: 0403
  API: ALSA v: k6.12.39-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.4.6 status: off with: 1: pipewire-pulse status: off
    2: pipewire-media-session status: off 3: pipewire-alsa type: plugin
    tools: pactl,pw-cat,pw-cli
  IF: wlp0s20u3 state: down mac: <filter>
  WAN IP: No WAN IP found. Connected to web? SSL issues?
  Device-1: luks-ac37595d-5b67-408c-82b8-547a678e97e6 maj-min: 254:0
  Components:
  Device-2: luks-8e70af97-5288-4227-b43f-15c7ae8b158e maj-min: 254:2
    type: LUKS dm: dm-2 size: 931.51 GiB
  Components:
  p-1: sdb1 maj-min: 8:17 size: 931.51 GiB
  Device-3: luks-97478fb5-267e-493d-8774-49eef2f55050 maj-min: 254:1
    type: LUKS dm: dm-1 size: 465.76 GiB
  Components:
  p-1: sdc1 maj-min: 8:33 size: 465.76 GiB
  Local Storage: total: 1.59 TiB used: 133.68 GiB (8.2%)
    family: based SSDs size: 232.89 GiB block-size: physical: 512 B
    logical: 512 B sata: 3.2 speed: 6.0 Gb/s tech: SSD serial: <filter>
    fw-rev: 4B6Q temp: 27 C scheme: GPT
  SMART: yes state: enabled health: PASSED on: 157d 12h cycles: 1074
    written: 7.48 TiB
    family: based SSDs size: 931.51 GiB block-size: physical: 512 B
    logical: 512 B sata: 3.3 speed: 1.5 Gb/s tech: SSD serial: <filter>
    fw-rev: 3B6Q temp: 28 C scheme: GPT
  SMART: yes state: enabled health: PASSED on: 88 hrs cycles: 18
    written: 446.23 GiB
    family: based SSDs size: 465.76 GiB block-size: physical: 512 B
    logical: 512 B sata: 3.1 speed: 3.0 Gb/s tech: SSD serial: <filter>
    fw-rev: 1B6Q temp: 26 C scheme: GPT
  SMART: yes state: enabled health: PASSED on: 299d 23h cycles: 1627
    written: 7.33 TiB
  ID-1: / raw-size: 232.59 GiB size: 227.88 GiB (97.98%)
    used: 133.68 GiB (58.7%) fs: ext4 block-size: 4096 B dev: /dev/dm-0
    maj-min: 254:0 mapped: luks-ac37595d-5b67-408c-82b8-547a678e97e6
    label: System uuid: 4c2ea2f1-3cfa-4377-8778-97f19f2453fe
    used: 472 KiB (0.2%) fs: vfat block-size: 512 B dev: /dev/sda1 maj-min: 8:1
    label: NO_LABEL uuid: 04E7-F02F
  ID-1: swap-1 type: file size: 8 GiB used: 0 KiB (0.0%) priority: -2
    file: /swapfile
  ID-1: /dev/dm-1 maj-min: 254:1
    mapped: luks-97478fb5-267e-493d-8774-49eef2f55050 size: 465.76 GiB fs: ext4
    label: Data uuid: aea89950-6192-4055-8c45-0991f2477684
  ID-2: /dev/dm-2 maj-min: 254:2
    mapped: luks-8e70af97-5288-4227-b43f-15c7ae8b158e size: 931.51 GiB fs: ext4
    label: Extra uuid: a584c501-ec7f-44d1-8912-433590b0e4a3
  Hub-6: 3-0:1 info: super-speed hub ports: 4 rev: 3.0
  Hub-7: 4-0:1 info: full speed or root hub ports: 2 rev: 2.0
  Hub-8: 4-1:2 info: Intel Integrated Rate Matching Hub ports: 6 rev: 2.0
  Hub-9: 4-1.5:3 info: Realtek 4-Port USB 2.0 Hub ports: 2 rev: 2.1
  System Temperatures: cpu: 42.0 C mobo: N/A
  Packages: pm: pacman pkgs: 1881 libs: 447 tools: pamac pm: flatpak pkgs: 0
    1: http://ftp.rz.tu-bs.de/pub/mirror/manjaro.org/repos/stable/$repo/$arch
    2: https://mirrors.dotsrc.org/manjaro/stable/$repo/$arch
    3: https://coresite.mm.fcix.net/manjaro/stable/$repo/$arch
    4: https://forksystems.mm.fcix.net/manjaro/stable/$repo/$arch
    5: https://ohioix.mm.fcix.net/manjaro/stable/$repo/$arch
    6: http://manjaro.grena.ge/stable/$repo/$arch
    7: https://fosszone.csd.auth.gr/manjaro/stable/$repo/$arch
    8: https://gsl-syd.mm.fcix.net/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 161
  1: cpu: 0.5% command: upowerd pid: 960 mem: 11.9 MiB (0.0%)
  2: cpu: 0.4% command: init pid: 1 mem: 13.8 MiB (0.0%)
  3: cpu: 0.3% command: [kworker/u16:5-events_unbound] pid: 84
  4: cpu: 0.2% command: [kworker/u16:1-kcryptd-254:0-1] pid: 14
  5: cpu: 0.2% command: [kworker/u16:10-kcryptd-254:0-1] pid: 90
  Memory top: 5 of 161
  1: mem: 62.2 MiB (0.2%) command: Xorg pid: 800 cpu: 0.2%
  2: mem: 22.2 MiB (0.0%) command: sddm pid: 790 cpu: 0.0%
  3: mem: 21.8 MiB (0.0%) command: NetworkManager pid: 700 cpu: 0.1%
  4: mem: 17.5 MiB (0.0%) command: colord pid: 791 cpu: 0.0%
  5: mem: 16.0 MiB (0.0%) command: systemd-journald pid: 348 cpu: 0.0%
  Processes: 161 Power: uptime: 3m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 9.33 GiB services: upowerd Init: systemd v: 257
  Compilers: clang: 20.1.8 gcc: 15.1.1 Shell: Sudo (sudo) v: 1.9.17p1
    default: Bash v: 5.3.0 running-in: pty pts/0 inxi: 3.3.38
Thanks for the clarification! I am trying to understand the similar issues but cannot draw conclusions.
from chroot rerun the update:
pacman-mirrors -f 5 && pacman -Syyu
if there are errors post the output here, if there are no errors and you are up to date, post output from:
ldconfig - (this should return nothing)
ls /etc/X11/* /etc/modprobe.d
pacman -Qm
