Hi there!
I am still rather new to Manjaro and am having issues getting my mobile dedicated GPU (RTX 3060 mobile) to run. Googling solutions led me several times to this forum but all of the ideas I found did not help me get any further.
Situation: I am trying to run a fully updated Manjaro with GDM 40.2 and X11 on my ASUS Zephyrus G15 GA503, 2021 model. Almost everything seems to work except:
Problem: I cannot get Manjaro or any piece of software on it to find my RTX 3060 mobile. It runs well on the AMD integrated graphics, but none of the hardware tools find my dGPU. The card works well under Windows 10.
I tried:
- installing via mhwd -a pci nonfree 0300 (only installs AMD iGPU drivers)
- Installing Nvidia standalone drivers (did not find hardware)
- Installing Nvidia drivers from nvidia(dot)com (did not find hardware)
- Installing Nvidia-AMD-hybrid-prime drivers (did not find hardware)
- Using either USB-C or HDMI outputs. Only HDMI works. USB-C would be the one to be used with the dGPU
Since many people have issues with this kind of hardware and there are many discussions around it, I tried solving by myself - sadly, with no success. If the card would just show up! Thank you for your help!
uname -r
5.13.4-1-MANJARO
sudo pacman -Syyu
The system is up to date
sudo mhwd -li
Installed PCI configs: -------------------------------------------------------------------------------- NAME VERSION FREEDRIVER TYPE -------------------------------------------------------------------------------- video-hybrid-amd-nvidia-prime 2020.11.30 false PCI video-linux 2018.05.04 true PCI Warning: No installed USB configs!
pacman -Qs ‘nvidia’ | grep ‘[1]’
local/lib32-libvdpau 1.4-1 local/lib32-nvidia-utils 470.57.02-1 local/libvdpau 1.4-1 local/linux510-nvidia 470.57.02-1 (linux510-extramodules) local/linux513-nvidia 470.57.02-1 (linux513-extramodules) local/mhwd-nvidia 470.57.02-1 local/mhwd-nvidia-390xx 390.144-1 local/nvidia-prime 1.0-4 local/nvidia-utils 470.57.02-1 local/xf86-video-nouveau 1.0.17-1 (xorg-drivers)
sudo mhwd -a pci nonfree 0300
Skipping already installed config 'video-linux' for device: 0000:07:00.0 (0300:1002:1638) Display controller ATI Technologies Inc Cezanne
sudo lspci
00:00.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir Root Complex 00:00.2 IOMMU: Advanced Micro Devices, Inc. [AMD] Renoir IOMMU 00:01.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir PCIe Dummy Host Bridge 00:01.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Renoir PCIe GPP Bridge 00:01.3 PCI bridge: Advanced Micro Devices, Inc. [AMD] Renoir PCIe GPP Bridge 00:02.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir PCIe Dummy Host Bridge 00:02.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Renoir PCIe GPP Bridge 00:02.2 PCI bridge: Advanced Micro Devices, Inc. [AMD] Renoir PCIe GPP Bridge 00:02.3 PCI bridge: Advanced Micro Devices, Inc. [AMD] Renoir PCIe GPP Bridge 00:02.4 PCI bridge: Advanced Micro Devices, Inc. [AMD] Renoir PCIe GPP Bridge 00:08.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir PCIe Dummy Host Bridge 00:08.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Renoir Internal PCIe GPP Bridge to Bus 00:14.0 SMBus: Advanced Micro Devices, Inc. [AMD] FCH SMBus Controller (rev 51) 00:14.3 ISA bridge: Advanced Micro Devices, Inc. [AMD] FCH LPC Bridge (rev 51) 00:18.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 166a 00:18.1 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 166b 00:18.2 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 166c 00:18.3 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 166d 00:18.4 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 166e 00:18.5 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 166f 00:18.6 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 1670 00:18.7 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 1671 02:00.0 SD Host controller: Genesys Logic, Inc GL9755 SD Host Controller 03:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 15) 04:00.0 Network controller: Intel Corporation Wi-Fi 6 AX200 (rev 1a) 05:00.0 Non-Volatile memory controller: Samsung Electronics Co Ltd NVMe SSD Controller SM981/PM981/PM983 06:00.0 Non-Volatile memory controller: SK hynix Device 174a 07:00.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Cezanne (rev c4) 07:00.1 Audio device: Advanced Micro Devices, Inc. [AMD/ATI] Device 1637 07:00.2 Encryption controller: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 10h-1fh) Platform Security Processor 07:00.3 USB controller: Advanced Micro Devices, Inc. [AMD] Renoir USB 3.1 07:00.4 USB controller: Advanced Micro Devices, Inc. [AMD] Renoir USB 3.1 07:00.5 Multimedia controller: Advanced Micro Devices, Inc. [AMD] Raven/Raven2/FireFlight/Renoir Audio Processor (rev 01) 07:00.6 Audio device: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 10h-1fh) HD Audio Controller
inxi -Fazy
System: Kernel: 5.13.4-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0 parameters: BOOT_IMAGE=/boot/vmlinuz-5.13-x86_64 root=UUID=6a1537de-5339-4647-94d3-1a9be6af93c1 rw quiet splash apparmor=1 security=apparmor udev.log_priority=3 Desktop: GNOME 40.3 tk: GTK 3.24.30 wm: gnome-shell dm: GDM 40.0 Distro: Manjaro Linux base: Arch Linux Machine: Type: Laptop System: ASUSTeK product: ROG Zephyrus G15 GA503QM_GA503QM v: 1.0 serial: <filter> Mobo: ASUSTeK model: GA503QM v: 1.0 serial: <filter> UEFI: American Megatrends LLC. v: GA503QM.407 date: 05/11/2021 Battery: ID-1: BAT0 charge: 87.9 Wh (99.0%) condition: 88.8/90.0 Wh (98.6%) volts: 15.9 min: 15.9 model: ASUSTeK ASUS Battery type: Li-ion serial: N/A status: Discharging Device-1: hidpp_battery_0 model: Logitech Anywhere MX serial: <filter> charge: 85% rechargeable: yes status: Discharging CPU: Info: 8-Core model: AMD Ryzen 9 5900HS with Radeon Graphics bits: 64 type: MT MCP arch: Zen 3 family: 19 (25) model-id: 50 (80) stepping: 0 microcode: A50000C cache: L2: 4 MiB flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 105440 Speed: 1197 MHz min/max: 1200/3300 MHz boost: enabled Core speeds (MHz): 1: 1197 2: 1197 3: 1387 4: 1197 5: 1197 6: 1197 7: 1197 8: 1197 9: 1397 10: 1397 11: 1198 12: 1197 13: 1197 14: 1197 15: 1197 16: 1197 Vulnerabilities: Type: itlb_multihit status: Not affected Type: l1tf status: Not affected Type: mds status: Not affected Type: meltdown status: Not affected Type: spec_store_bypass mitigation: Speculative Store Bypass disabled via prctl and seccomp Type: spectre_v1 mitigation: usercopy/swapgs barriers and __user pointer sanitization Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional, IBRS_FW, STIBP: always-on, RSB filling Type: srbds status: Not affected Type: tsx_async_abort status: Not affected Graphics: Device-1: AMD Cezanne vendor: ASUSTeK driver: amdgpu v: kernel bus-ID: 07:00.0 chip-ID: 1002:1638 class-ID: 0300 Display: x11 server: X.org 1.20.11 compositor: gnome-shell driver: loaded: modesetting resolution: <missing: xdpyinfo> OpenGL: renderer: AMD RENOIR (DRM 3.41.0 5.13.4-1-MANJARO LLVM 12.0.1) v: 4.6 Mesa 21.1.5 direct render: Yes Audio: Device-1: AMD driver: snd_hda_intel v: kernel bus-ID: 07:00.1 chip-ID: 1002:1637 class-ID: 0403 Device-2: AMD Raven/Raven2/FireFlight/Renoir Audio Processor vendor: ASUSTeK driver: N/A alternate: snd_pci_acp3x, snd_rn_pci_acp3x bus-ID: 07:00.5 chip-ID: 1022:15e2 class-ID: 0480 Device-3: AMD Family 17h HD Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel bus-ID: 07:00.6 chip-ID: 1022:15e3 class-ID: 0403 Sound Server-1: ALSA v: k5.13.4-1-MANJARO running: yes Sound Server-2: JACK v: 0.125.0 running: no Sound Server-3: PulseAudio v: 14.2 running: yes Sound Server-4: PipeWire v: 0.3.32 running: yes Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: ASUSTeK driver: r8169 v: kernel port: d000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200 IF: enp3s0 state: down mac: <filter> Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel port: d000 bus-ID: 04:00.0 chip-ID: 8086:2723 class-ID: 0280 IF: wlp4s0 state: up mac: <filter> Bluetooth: Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 1-4:3 chip-ID: 8087:0029 class-ID: e001 Report: rfkill ID: hci0 rfk-id: 1 state: up address: see --recommends Drives: Local Storage: total: 2.75 TiB used: 178.98 GiB (6.4%) SMART Message: Required tool smartctl not installed. Check --recommends ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 970 EVO Plus 2TB size: 1.82 TiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: 3B2QEXM7 temp: 42.9 C scheme: GPT ID-2: /dev/nvme1n1 maj-min: 259:6 vendor: SK Hynix model: HFM001TD3JX013N size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: 41000C20 temp: 43.9 C scheme: GPT Partition: ID-1: / raw-size: 46.57 GiB size: 45.53 GiB (97.78%) used: 16.07 GiB (35.3%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2 ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%) used: 60.4 MiB (23.6%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:7 ID-3: /home raw-size: 186.26 GiB size: 182.28 GiB (97.86%) used: 162.85 GiB (89.3%) fs: ext4 dev: /dev/nvme0n1p3 maj-min: 259:3 Swap: Kernel: swappiness: 60 (default) cache-pressure: 100 (default) ID-1: swap-1 type: partition size: 14.9 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/nvme0n1p4 maj-min: 259:4 Sensors: System Temperatures: cpu: 47.0 C mobo: N/A gpu: amdgpu temp: 44.0 C Fan Speeds (RPM): cpu: 0 Info: Processes: 409 Uptime: 5m wakeups: 7 Memory: 15.04 GiB used: 2.69 GiB (17.9%) Init: systemd v: 248 tool: systemctl Compilers: gcc: 11.1.0 Packages: pacman: 1339 lib: 335 flatpak: 0 Shell: Zsh v: 5.8 running-in: gnome-terminal inxi: 3.3.06
lspci -v
00:00.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir Root Complex Subsystem: Advanced Micro Devices, Inc. [AMD] Renoir Root Complex Flags: fast devsel 00:00.2 IOMMU: Advanced Micro Devices, Inc. [AMD] Renoir IOMMU Subsystem: Advanced Micro Devices, Inc. [AMD] Renoir IOMMU Flags: bus master, fast devsel, latency 0, IRQ -2147483648 Capabilities: <access denied> 00:01.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir PCIe Dummy Host Bridge Flags: fast devsel, IOMMU group 0 00:01.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Renoir PCIe GPP Bridge (prog-if 00 [Normal decode]) Flags: bus master, fast devsel, latency 0, IRQ 26, IOMMU group 1 Bus: primary=00, secondary=01, subordinate=01, sec-latency=0 I/O behind bridge: 0000e000-0000efff [size=4K] Memory behind bridge: fb000000-fc0fffff [size=17M] Prefetchable memory behind bridge: 000000fc00000000-000000fe01ffffff [size=8224M] Capabilities: <access denied> Kernel driver in use: pcieport 00:01.3 PCI bridge: Advanced Micro Devices, Inc. [AMD] Renoir PCIe GPP Bridge (prog-if 00 [Normal decode]) Flags: bus master, fast devsel, latency 0, IRQ 27, IOMMU group 2 Bus: primary=00, secondary=02, subordinate=02, sec-latency=0 I/O behind bridge: [disabled] Memory behind bridge: fca00000-fcafffff [size=1M] Prefetchable memory behind bridge: [disabled] Capabilities: <access denied> Kernel driver in use: pcieport 00:02.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir PCIe Dummy Host Bridge Flags: fast devsel, IOMMU group 3 00:02.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Renoir PCIe GPP Bridge (prog-if 00 [Normal decode]) Flags: bus master, fast devsel, latency 0, IRQ 28, IOMMU group 4 Bus: primary=00, secondary=03, subordinate=03, sec-latency=0 I/O behind bridge: 0000d000-0000dfff [size=4K] Memory behind bridge: fc900000-fc9fffff [size=1M] Prefetchable memory behind bridge: [disabled] Capabilities: <access denied> Kernel driver in use: pcieport 00:02.2 PCI bridge: Advanced Micro Devices, Inc. [AMD] Renoir PCIe GPP Bridge (prog-if 00 [Normal decode]) Flags: bus master, fast devsel, latency 0, IRQ 29, IOMMU group 5 Bus: primary=00, secondary=04, subordinate=04, sec-latency=0 I/O behind bridge: 00001000-00001fff [size=4K] Memory behind bridge: fc800000-fc8fffff [size=1M] Prefetchable memory behind bridge: 0000000410000000-00000004101fffff [size=2M] Capabilities: <access denied> Kernel driver in use: pcieport 00:02.3 PCI bridge: Advanced Micro Devices, Inc. [AMD] Renoir PCIe GPP Bridge (prog-if 00 [Normal decode]) Flags: bus master, fast devsel, latency 0, IRQ 30, IOMMU group 6 Bus: primary=00, secondary=05, subordinate=05, sec-latency=0 I/O behind bridge: [disabled] Memory behind bridge: fc700000-fc7fffff [size=1M] Prefetchable memory behind bridge: [disabled] Capabilities: <access denied> Kernel driver in use: pcieport 00:02.4 PCI bridge: Advanced Micro Devices, Inc. [AMD] Renoir PCIe GPP Bridge (prog-if 00 [Normal decode]) Flags: bus master, fast devsel, latency 0, IRQ 31, IOMMU group 7 Bus: primary=00, secondary=06, subordinate=06, sec-latency=0 I/O behind bridge: [disabled] Memory behind bridge: fc600000-fc6fffff [size=1M] Prefetchable memory behind bridge: [disabled] Capabilities: <access denied> Kernel driver in use: pcieport 00:08.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir PCIe Dummy Host Bridge Flags: fast devsel, IOMMU group 8 00:08.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Renoir Internal PCIe GPP Bridge to Bus (prog-if 00 [Normal decode]) Flags: bus master, fast devsel, latency 0, IRQ 32, IOMMU group 8 Bus: primary=00, secondary=07, subordinate=07, sec-latency=0 I/O behind bridge: 0000c000-0000cfff [size=4K] Memory behind bridge: fc200000-fc5fffff [size=4M] Prefetchable memory behind bridge: 000000fe10000000-000000fe201fffff [size=258M] Capabilities: <access denied> Kernel driver in use: pcieport 00:14.0 SMBus: Advanced Micro Devices, Inc. [AMD] FCH SMBus Controller (rev 51) Subsystem: ASUSTeK Computer Inc. Device 1622 Flags: 66MHz, medium devsel, IOMMU group 9 Kernel driver in use: piix4_smbus Kernel modules: i2c_piix4, sp5100_tco 00:14.3 ISA bridge: Advanced Micro Devices, Inc. [AMD] FCH LPC Bridge (rev 51) Subsystem: ASUSTeK Computer Inc. Device 1622 Flags: bus master, 66MHz, medium devsel, latency 0, IOMMU group 9 00:18.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 166a Flags: fast devsel, IOMMU group 10 00:18.1 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 166b Flags: fast devsel, IOMMU group 10 00:18.2 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 166c Flags: fast devsel, IOMMU group 10 00:18.3 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 166d Flags: fast devsel, IOMMU group 10 00:18.4 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 166e Flags: fast devsel, IOMMU group 10 00:18.5 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 166f Flags: fast devsel, IOMMU group 10 00:18.6 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 1670 Flags: fast devsel, IOMMU group 10 00:18.7 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 1671 Flags: fast devsel, IOMMU group 10 02:00.0 SD Host controller: Genesys Logic, Inc GL9755 SD Host Controller (prog-if 01) Subsystem: ASUSTeK Computer Inc. Device 202f Flags: bus master, fast devsel, latency 0, IRQ 78, IOMMU group 11 Memory at fca00000 (32-bit, non-prefetchable) [size=4K] Capabilities: <access denied> Kernel driver in use: sdhci-pci Kernel modules: sdhci_pci 03:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 15) Subsystem: ASUSTeK Computer Inc. Device 208f Flags: fast devsel, IRQ 96, IOMMU group 12 I/O ports at d000 [size=256] Memory at fc904000 (64-bit, non-prefetchable) [size=4K] Memory at fc900000 (64-bit, non-prefetchable) [size=16K] Capabilities: <access denied> Kernel driver in use: r8169 Kernel modules: r8169 04:00.0 Network controller: Intel Corporation Wi-Fi 6 AX200 (rev 1a) Subsystem: Intel Corporation Wi-Fi 6 AX200NGW Physical Slot: 0-1 Flags: bus master, fast devsel, latency 0, IRQ 95, IOMMU group 13 Memory at fc800000 (64-bit, non-prefetchable) [size=16K] Capabilities: <access denied> Kernel driver in use: iwlwifi Kernel modules: iwlwifi 05:00.0 Non-Volatile memory controller: Samsung Electronics Co Ltd NVMe SSD Controller SM981/PM981/PM983 (prog-if 02 [NVM Express]) Subsystem: Samsung Electronics Co Ltd Device a801 Flags: bus master, fast devsel, latency 0, IRQ 33, NUMA node 0, IOMMU group 14 Memory at fc700000 (64-bit, non-prefetchable) [size=16K] Capabilities: <access denied> Kernel driver in use: nvme 06:00.0 Non-Volatile memory controller: SK hynix Device 174a (prog-if 02 [NVM Express]) Subsystem: SK hynix Device 174a Flags: bus master, fast devsel, latency 0, IRQ 35, NUMA node 0, IOMMU group 15 Memory at fc600000 (64-bit, non-prefetchable) [size=16K] Memory at fc605000 (32-bit, non-prefetchable) [size=4K] Memory at fc604000 (32-bit, non-prefetchable) [size=4K] Capabilities: <access denied> Kernel driver in use: nvme 07:00.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Cezanne (rev c4) (prog-if 00 [VGA controller]) Subsystem: ASUSTeK Computer Inc. Device 117c Flags: bus master, fast devsel, latency 0, IRQ 79, IOMMU group 8 Memory at fe10000000 (64-bit, prefetchable) [size=256M] Memory at fe20000000 (64-bit, prefetchable) [size=2M] I/O ports at c000 [size=256] Memory at fc500000 (32-bit, non-prefetchable) [size=512K] Capabilities: <access denied> Kernel driver in use: amdgpu Kernel modules: amdgpu 07:00.1 Audio device: Advanced Micro Devices, Inc. [AMD/ATI] Device 1637 Subsystem: Advanced Micro Devices, Inc. [AMD/ATI] Device 1637 Flags: bus master, fast devsel, latency 0, IRQ 116, IOMMU group 8 Memory at fc5c8000 (32-bit, non-prefetchable) [size=16K] Capabilities: <access denied> Kernel driver in use: snd_hda_intel Kernel modules: snd_hda_intel 07:00.2 Encryption controller: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 10h-1fh) Platform Security Processor Subsystem: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 10h-1fh) Platform Security Processor Flags: bus master, fast devsel, latency 0, IRQ 96, IOMMU group 8 Memory at fc400000 (32-bit, non-prefetchable) [size=1M] Memory at fc5cc000 (32-bit, non-prefetchable) [size=8K] Capabilities: <access denied> Kernel driver in use: ccp Kernel modules: ccp 07:00.3 USB controller: Advanced Micro Devices, Inc. [AMD] Renoir USB 3.1 (prog-if 30 [XHCI]) Subsystem: ASUSTeK Computer Inc. Device 201f Flags: bus master, fast devsel, latency 0, IRQ 69, IOMMU group 8 Memory at fc300000 (64-bit, non-prefetchable) [size=1M] Capabilities: <access denied> Kernel driver in use: xhci_hcd Kernel modules: xhci_pci 07:00.4 USB controller: Advanced Micro Devices, Inc. [AMD] Renoir USB 3.1 (prog-if 30 [XHCI]) Subsystem: ASUSTeK Computer Inc. Device 201f Flags: fast devsel, IRQ 79, IOMMU group 8 Memory at fc200000 (64-bit, non-prefetchable) [size=1M] Capabilities: <access denied> Kernel driver in use: xhci_hcd Kernel modules: xhci_pci 07:00.5 Multimedia controller: Advanced Micro Devices, Inc. [AMD] Raven/Raven2/FireFlight/Renoir Audio Processor (rev 01) Subsystem: ASUSTeK Computer Inc. Device 1e8e Flags: fast devsel, IRQ 94, IOMMU group 8 Memory at fc580000 (32-bit, non-prefetchable) [size=256K] Capabilities: <access denied> Kernel modules: snd_pci_acp3x, snd_rn_pci_acp3x 07:00.6 Audio device: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 10h-1fh) HD Audio Controller Subsystem: ASUSTeK Computer Inc. Device 1e8e Flags: bus master, fast devsel, latency 0, IRQ 117, IOMMU group 8 Memory at fc5c0000 (32-bit, non-prefetchable) [size=32K] Capabilities: <access denied> Kernel driver in use: snd_hda_intel Kernel modules: snd_hda_intel
