[ 4.147]
X.Org X Server 1.20.10
[ 4.147] Build Operating System: Linux Manjaro Linux
[ 4.147] Current Operating System: Linux jvanriper-pc 5.10.2-2-MANJARO #1 SMP PREEMPT Tue Dec 22 08:14:42 UTC 2020 x86_64
[ 4.147] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.10-x86_64 root=UUID=5faa9f0f-2408-4afe-b887-7ec98d5885fd rw quiet apparmor=1 security=apparmor udev.log_priority=3
[ 4.147] Build Date: 16 December 2020 10:33:32PM
[ 4.147]
[ 4.147] Current version of pixman: 0.40.0
[ 4.147] Before reporting problems, check http://wiki.x.org
[ 4.147] Markers: (--) probed, (**) from config file, (==) default setting,
[ 4.147] (==) Log file: "/var/log/Xorg.0.log", Time: Sun Jan 17 02:36:30 2021
[ 4.153] (==) Using config directory: "/etc/X11/xorg.conf.d"
[ 4.153] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 4.164] (==) ServerLayout "layout"
[ 4.164] (==) No screen section available. Using defaults.
[ 4.164] (**) |-->Screen "Default Screen Section" (0)
[ 4.164] (**) | |-->Monitor "<default monitor>"
[ 4.164] (==) No monitor specified for screen "Default Screen Section".
[ 4.164] (==) Automatically adding devices
[ 4.164] (==) Automatically enabling devices
[ 4.164] (==) Automatically adding GPU devices
[ 4.164] (==) Automatically binding GPU devices
[ 4.164] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 4.183] (WW) The directory "/usr/share/fonts/OTF" does not exist.
[ 4.183] Entry deleted from font path.
[ 4.183] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[ 4.184] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/100dpi".
[ 4.184] Entry deleted from font path.
[ 4.184] (Run 'mkfontdir' on "/usr/share/fonts/100dpi").
[ 4.185] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/75dpi".
[ 4.185] Entry deleted from font path.
[ 4.185] (Run 'mkfontdir' on "/usr/share/fonts/75dpi").
[ 4.185] (==) FontPath set to:
/usr/share/fonts/misc,
/usr/share/fonts/TTF
[ 4.185] (==) ModulePath set to "/usr/lib/xorg/modules"
[ 4.185] (II) The server relies on udev to provide the list of input devices.
[ 4.185] (II) Module ABI versions:
[ 4.185] X.Org ANSI C Emulation: 0.4
[ 4.185] X.Org Video Driver: 24.1
[ 4.185] X.Org XInput driver : 24.1
[ 4.185] X.Org Server Extension : 10.0
[ 4.185] (++) using VT number 7
[ 4.185] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[ 4.185] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 4.195] (--) PCI:*(5@0:0:0) 1002:731f:1462:3810 rev 193, Mem @ 0xe0000000/268435456, 0xf0000000/2097152, 0xfc500000/524288, I/O @ 0x0000f000/256, BIOS @ 0x????????/131072
[ 4.195] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[ 4.195] (II) LoadModule: "glx"
[ 4.200] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 4.228] (II) Module glx: vendor="X.Org Foundation"
[ 4.228] compiled for 1.20.10, module version = 1.0.0
[ 4.228] ABI class: X.Org Server Extension, version 10.0
[ 4.228] (II) Applying OutputClass "AMDgpu" to /dev/dri/card0
[ 4.228] loading driver: amdgpu
[ 4.228] (==) Matched amdgpu as autoconfigured driver 0
[ 4.228] (==) Matched ati as autoconfigured driver 1
[ 4.228] (==) Matched modesetting as autoconfigured driver 2
[ 4.228] (==) Matched fbdev as autoconfigured driver 3
[ 4.228] (==) Matched vesa as autoconfigured driver 4
[ 4.228] (==) Assigned the driver to the xf86ConfigLayout
[ 4.228] (II) LoadModule: "amdgpu"
[ 4.228] (II) Loading /usr/lib/xorg/modules/drivers/amdgpu_drv.so
[ 4.244] (II) Module amdgpu: vendor="X.Org Foundation"
[ 4.244] compiled for 1.20.8, module version = 19.1.0
[ 4.244] Module class: X.Org Video Driver
[ 4.244] ABI class: X.Org Video Driver, version 24.1
[ 4.244] (II) LoadModule: "ati"
[ 4.244] (II) Loading /usr/lib/xorg/modules/drivers/ati_drv.so
[ 4.246] (II) Module ati: vendor="X.Org Foundation"
[ 4.246] compiled for 1.20.8, module version = 19.1.0
[ 4.246] Module class: X.Org Video Driver
[ 4.246] ABI class: X.Org Video Driver, version 24.1
[ 4.259] (II) LoadModule: "radeon"
[ 4.259] (II) Loading /usr/lib/xorg/modules/drivers/radeon_drv.so
[ 4.273] (II) Module radeon: vendor="X.Org Foundation"
[ 4.273] compiled for 1.20.8, module version = 19.1.0
[ 4.273] Module class: X.Org Video Driver
[ 4.273] ABI class: X.Org Video Driver, version 24.1
[ 4.273] (II) LoadModule: "modesetting"
[ 4.273] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[ 4.278] (II) Module modesetting: vendor="X.Org Foundation"
[ 4.278] compiled for 1.20.10, module version = 1.20.10
[ 4.278] Module class: X.Org Video Driver
[ 4.278] ABI class: X.Org Video Driver, version 24.1
[ 4.278] (II) LoadModule: "fbdev"
[ 4.278] (WW) Warning, couldn't open module fbdev
[ 4.278] (EE) Failed to load module "fbdev" (module does not exist, 0)
[ 4.278] (II) LoadModule: "vesa"
[ 4.278] (WW) Warning, couldn't open module vesa
[ 4.278] (EE) Failed to load module "vesa" (module does not exist, 0)
[ 4.278] (II) AMDGPU: Driver for AMD Radeon:
All GPUs supported by the amdgpu kernel driver
[ 4.278] (II) RADEON: Driver for ATI/AMD Radeon chipsets:
ATI Radeon Mobility X600 (M24), ATI FireMV 2400,
ATI Radeon Mobility X300 (M24), ATI FireGL M24 GL,
ATI Radeon X600 (RV380), ATI FireGL V3200 (RV380),
ATI Radeon IGP320 (A3), ATI Radeon IGP330/340/350 (A4),
ATI Radeon 9500, ATI Radeon 9600TX, ATI FireGL Z1, ATI Radeon 9800SE,
ATI Radeon 9800, ATI FireGL X2, ATI Radeon 9600, ATI Radeon 9600SE,
ATI Radeon 9600XT, ATI FireGL T2, ATI Radeon 9650, ATI FireGL RV360,
ATI Radeon 7000 IGP (A4+), ATI Radeon 8500 AIW,
ATI Radeon IGP320M (U1), ATI Radeon IGP330M/340M/350M (U2),
ATI Radeon Mobility 7000 IGP, ATI Radeon 9000/PRO, ATI Radeon 9000,
ATI Radeon X800 (R420), ATI Radeon X800PRO (R420),
ATI Radeon X800SE (R420), ATI FireGL X3 (R420),
ATI Radeon Mobility 9800 (M18), ATI Radeon X800 SE (R420),
ATI Radeon X800XT (R420), ATI Radeon X800 VE (R420),
ATI Radeon X850 (R480), ATI Radeon X850 XT (R480),
ATI Radeon X850 SE (R480), ATI Radeon X850 PRO (R480),
ATI Radeon X850 XT PE (R480), ATI Radeon Mobility M7,
ATI Mobility FireGL 7800 M7, ATI Radeon Mobility M6,
ATI FireGL Mobility 9000 (M9), ATI Radeon Mobility 9000 (M9),
ATI Radeon 9700 Pro, ATI Radeon 9700/9500Pro, ATI FireGL X1,
ATI Radeon 9800PRO, ATI Radeon 9800XT,
ATI Radeon Mobility 9600/9700 (M10/M11),
ATI Radeon Mobility 9600 (M10), ATI Radeon Mobility 9600 (M11),
ATI FireGL Mobility T2 (M10), ATI FireGL Mobility T2e (M11),
ATI Radeon, ATI FireGL 8700/8800, ATI Radeon 8500, ATI Radeon 9100,
ATI Radeon 7500, ATI Radeon VE/7000, ATI ES1000,
ATI Radeon Mobility X300 (M22), ATI Radeon Mobility X600 SE (M24C),
ATI FireGL M22 GL, ATI Radeon X800 (R423), ATI Radeon X800PRO (R423),
ATI Radeon X800LE (R423), ATI Radeon X800SE (R423),
ATI Radeon X800 XTP (R430), ATI Radeon X800 XL (R430),
ATI Radeon X800 SE (R430), ATI Radeon X800 (R430),
ATI FireGL V7100 (R423), ATI FireGL V5100 (R423),
ATI FireGL unknown (R423), ATI Mobility FireGL V5000 (M26),
ATI Mobility Radeon X700 XL (M26), ATI Mobility Radeon X700 (M26),
ATI Radeon X550XTX, ATI Radeon 9100 IGP (A5),
ATI Radeon Mobility 9100 IGP (U3), ATI Radeon XPRESS 200,
ATI Radeon XPRESS 200M, ATI Radeon 9250, ATI Radeon 9200,
ATI Radeon 9200SE, ATI FireMV 2200, ATI Radeon X300 (RV370),
ATI Radeon X600 (RV370), ATI Radeon X550 (RV370),
ATI FireGL V3100 (RV370), ATI FireMV 2200 PCIE (RV370),
ATI Radeon Mobility 9200 (M9+), ATI Mobility Radeon X800 XT (M28),
ATI Mobility FireGL V5100 (M28), ATI Mobility Radeon X800 (M28),
ATI Radeon X850, ATI unknown Radeon / FireGL (R480),
ATI Radeon X800XT (R423), ATI FireGL V5000 (RV410),
ATI Radeon X700 XT (RV410), ATI Radeon X700 PRO (RV410),
ATI Radeon X700 SE (RV410), ATI Radeon X700 (RV410),
ATI Radeon X1800, ATI Mobility Radeon X1800 XT,
ATI Mobility Radeon X1800, ATI Mobility FireGL V7200,
ATI FireGL V7200, ATI FireGL V5300, ATI Mobility FireGL V7100,
ATI FireGL V7300, ATI FireGL V7350, ATI Radeon X1600, ATI RV505,
ATI Radeon X1300/X1550, ATI Radeon X1550, ATI M54-GL,
ATI Mobility Radeon X1400, ATI Radeon X1550 64-bit,
ATI Mobility Radeon X1300, ATI Radeon X1300, ATI FireGL V3300,
ATI FireGL V3350, ATI Mobility Radeon X1450,
ATI Mobility Radeon X2300, ATI Mobility Radeon X1350,
ATI FireMV 2250, ATI Radeon X1650, ATI Mobility FireGL V5200,
ATI Mobility Radeon X1600, ATI Radeon X1300 XT/X1600 Pro,
ATI FireGL V3400, ATI Mobility FireGL V5250,
ATI Mobility Radeon X1700, ATI Mobility Radeon X1700 XT,
ATI FireGL V5200, ATI Radeon X2300HD, ATI Mobility Radeon HD 2300,
ATI Radeon X1950, ATI Radeon X1900, ATI AMD Stream Processor,
ATI RV560, ATI Mobility Radeon X1900, ATI Radeon X1950 GT, ATI RV570,
ATI FireGL V7400, ATI Radeon 9100 PRO IGP,
ATI Radeon Mobility 9200 IGP, ATI Radeon X1200, ATI RS740,
ATI RS740M, ATI Radeon HD 2900 XT, ATI Radeon HD 2900 Pro,
ATI Radeon HD 2900 GT, ATI FireGL V8650, ATI FireGL V8600,
ATI FireGL V7600, ATI Radeon 4800 Series, ATI Radeon HD 4870 x2,
ATI Radeon HD 4850 x2, ATI FirePro V8750 (FireGL),
ATI FirePro V7760 (FireGL), ATI Mobility RADEON HD 4850,
ATI Mobility RADEON HD 4850 X2, ATI FirePro RV770,
AMD FireStream 9270, AMD FireStream 9250, ATI FirePro V8700 (FireGL),
ATI Mobility RADEON HD 4870, ATI Mobility RADEON M98,
ATI FirePro M7750, ATI M98, ATI Mobility Radeon HD 4650,
ATI Radeon RV730 (AGP), ATI Mobility Radeon HD 4670,
ATI FirePro M5750, ATI RV730XT [Radeon HD 4670], ATI RADEON E4600,
ATI Radeon HD 4600 Series, ATI RV730 PRO [Radeon HD 4650],
ATI FirePro V7750 (FireGL), ATI FirePro V5700 (FireGL),
ATI FirePro V3750 (FireGL), ATI Mobility Radeon HD 4830,
ATI Mobility Radeon HD 4850, ATI FirePro M7740, ATI RV740,
ATI Radeon HD 4770, ATI Radeon HD 4700 Series, ATI RV610,
ATI Radeon HD 2400 XT, ATI Radeon HD 2400 Pro,
ATI Radeon HD 2400 PRO AGP, ATI FireGL V4000, ATI Radeon HD 2350,
ATI Mobility Radeon HD 2400 XT, ATI Mobility Radeon HD 2400,
ATI RADEON E2400, ATI FireMV 2260, ATI RV670, ATI Radeon HD3870,
ATI Mobility Radeon HD 3850, ATI Radeon HD3850,
ATI Mobility Radeon HD 3850 X2, ATI Mobility Radeon HD 3870,
ATI Mobility Radeon HD 3870 X2, ATI Radeon HD3870 X2,
ATI FireGL V7700, ATI Radeon HD3690, AMD Firestream 9170,
ATI Radeon HD 4550, ATI Radeon RV710, ATI Radeon HD 4350,
ATI Mobility Radeon 4300 Series, ATI Mobility Radeon 4500 Series,
ATI FirePro RG220, ATI Mobility Radeon 4330, ATI RV630,
ATI Mobility Radeon HD 2600, ATI Mobility Radeon HD 2600 XT,
ATI Radeon HD 2600 XT AGP, ATI Radeon HD 2600 Pro AGP,
ATI Radeon HD 2600 XT, ATI Radeon HD 2600 Pro, ATI Gemini RV630,
ATI Gemini Mobility Radeon HD 2600 XT, ATI FireGL V5600,
ATI FireGL V3600, ATI Radeon HD 2600 LE,
ATI Mobility FireGL Graphics Processor, ATI Radeon HD 3470,
ATI Mobility Radeon HD 3430, ATI Mobility Radeon HD 3400 Series,
ATI Radeon HD 3450, ATI Radeon HD 3430, ATI FirePro V3700,
ATI FireMV 2450, ATI Radeon HD 3600 Series, ATI Radeon HD 3650 AGP,
ATI Radeon HD 3600 PRO, ATI Radeon HD 3600 XT,
ATI Mobility Radeon HD 3650, ATI Mobility Radeon HD 3670,
ATI Mobility FireGL V5700, ATI Mobility FireGL V5725,
ATI Radeon HD 3200 Graphics, ATI Radeon 3100 Graphics,
ATI Radeon HD 3300 Graphics, ATI Radeon 3000 Graphics, SUMO, SUMO2,
ATI Radeon HD 4200, ATI Radeon 4100, ATI Mobility Radeon HD 4200,
ATI Mobility Radeon 4100, ATI Radeon HD 4290, ATI Radeon HD 4250,
AMD Radeon HD 6310 Graphics, AMD Radeon HD 6250 Graphics,
AMD Radeon HD 6300 Series Graphics,
AMD Radeon HD 6200 Series Graphics, PALM, CYPRESS,
ATI FirePro (FireGL) Graphics Adapter, AMD Firestream 9370,
AMD Firestream 9350, ATI Radeon HD 5800 Series,
ATI Radeon HD 5900 Series, ATI Mobility Radeon HD 5800 Series,
ATI Radeon HD 5700 Series, ATI Radeon HD 6700 Series,
ATI Mobility Radeon HD 5000 Series, ATI Mobility Radeon HD 5570,
ATI Radeon HD 5670, ATI Radeon HD 5570, ATI Radeon HD 5500 Series,
REDWOOD, ATI Mobility Radeon Graphics, CEDAR, ATI FirePro 2270,
ATI Radeon HD 5450, CAYMAN, AMD Radeon HD 6900 Series,
AMD Radeon HD 6900M Series, Mobility Radeon HD 6000 Series, BARTS,
AMD Radeon HD 6800 Series, AMD Radeon HD 6700 Series, TURKS, CAICOS,
ARUBA, TAHITI, PITCAIRN, VERDE, OLAND, HAINAN, BONAIRE, KABINI,
MULLINS, KAVERI, HAWAII
[ 4.279] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[ 4.299] (II) AMDGPU(0): [KMS] Kernel modesetting enabled.
[ 4.301] (WW) Falling back to old probe method for modesetting
[ 4.302] (II) AMDGPU(0): Creating default Display subsection in Screen section
"Default Screen Section" for depth/fbbpp 24/32
[ 4.302] (==) AMDGPU(0): Depth 24, (--) framebuffer bpp 32
[ 4.302] (II) AMDGPU(0): Pixel depth = 24 bits stored in 4 bytes (32 bpp pixmaps)
[ 4.302] (==) AMDGPU(0): Default visual is TrueColor
[ 4.302] (==) AMDGPU(0): RGB weight 888
[ 4.302] (II) AMDGPU(0): Using 8 bits per RGB (8 bit DAC)
[ 4.302] (--) AMDGPU(0): Chipset: "AMD Radeon RX 5700 XT" (ChipID = 0x731f)
[ 4.302] (II) Loading sub module "fb"
[ 4.302] (II) LoadModule: "fb"
[ 4.302] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 4.306] (II) Module fb: vendor="X.Org Foundation"
[ 4.306] compiled for 1.20.10, module version = 1.0.0
[ 4.306] ABI class: X.Org ANSI C Emulation, version 0.4
[ 4.306] (II) Loading sub module "dri2"
[ 4.306] (II) LoadModule: "dri2"
[ 4.306] (II) Module "dri2" already built-in
[ 4.852] (II) Loading sub module "glamoregl"
[ 4.852] (II) LoadModule: "glamoregl"
[ 4.852] (II) Loading /usr/lib/xorg/modules/libglamoregl.so
[ 4.867] (II) Module glamoregl: vendor="X.Org Foundation"
[ 4.867] compiled for 1.20.10, module version = 1.0.1
[ 4.867] ABI class: X.Org ANSI C Emulation, version 0.4
[ 5.037] (II) AMDGPU(0): glamor X acceleration enabled on AMD Radeon RX 5700 XT (NAVI10, DRM 3.40.0, 5.10.2-2-MANJARO, LLVM 11.0.0)
[ 5.037] (II) AMDGPU(0): glamor detected, initialising EGL layer.
[ 5.037] (==) AMDGPU(0): TearFree property default: auto
[ 5.037] (==) AMDGPU(0): VariableRefresh: disabled
[ 5.037] (II) AMDGPU(0): KMS Pageflipping: enabled
[ 5.037] (II) AMDGPU(0): Output DisplayPort-0 has no monitor section
[ 5.038] (II) AMDGPU(0): Output DisplayPort-1 has no monitor section
[ 5.038] (II) AMDGPU(0): Output DisplayPort-2 has no monitor section
[ 5.038] (II) AMDGPU(0): Output HDMI-A-0 has no monitor section
[ 5.076] (II) AMDGPU(0): EDID for output DisplayPort-0
[ 5.077] (II) AMDGPU(0): EDID for output DisplayPort-1
[ 5.077] (II) AMDGPU(0): Manufacturer: HPN Model: 360c Serial#: 16843009
[ 5.077] (II) AMDGPU(0): Year: 2019 Week: 43
[ 5.077] (II) AMDGPU(0): EDID Version: 1.3
[ 5.077] (II) AMDGPU(0): Digital Display Input
[ 5.077] (II) AMDGPU(0): Max Image Size [cm]: horiz.: 71 vert.: 40
[ 5.077] (II) AMDGPU(0): Gamma: 2.20
[ 5.077] (II) AMDGPU(0): DPMS capabilities: Off
[ 5.077] (II) AMDGPU(0): Supported color encodings: RGB 4:4:4 YCrCb 4:4:4
[ 5.077] (II) AMDGPU(0): First detailed timing is preferred mode
[ 5.077] (II) AMDGPU(0): redX: 0.651 redY: 0.339 greenX: 0.307 greenY: 0.629
[ 5.077] (II) AMDGPU(0): blueX: 0.146 blueY: 0.053 whiteX: 0.313 whiteY: 0.329
[ 5.077] (II) AMDGPU(0): Supported established timings:
[ 5.077] (II) AMDGPU(0): 720x400@70Hz
[ 5.077] (II) AMDGPU(0): 640x480@60Hz
[ 5.077] (II) AMDGPU(0): 800x600@60Hz
[ 5.077] (II) AMDGPU(0): 1024x768@60Hz
[ 5.077] (II) AMDGPU(0): Manufacturer's mask: 0
[ 5.077] (II) AMDGPU(0): Supported standard timings:
[ 5.077] (II) AMDGPU(0): #0: hsize: 1920 vsize 1080 refresh: 60 vid: 49361
[ 5.077] (II) AMDGPU(0): #1: hsize: 1600 vsize 900 refresh: 60 vid: 49321
[ 5.077] (II) AMDGPU(0): #2: hsize: 1280 vsize 720 refresh: 60 vid: 49281
[ 5.077] (II) AMDGPU(0): #3: hsize: 1920 vsize 1200 refresh: 60 vid: 209
[ 5.077] (II) AMDGPU(0): #4: hsize: 1680 vsize 1050 refresh: 60 vid: 179
[ 5.077] (II) AMDGPU(0): #5: hsize: 1440 vsize 900 refresh: 60 vid: 149
[ 5.077] (II) AMDGPU(0): #6: hsize: 1280 vsize 1024 refresh: 60 vid: 32897
[ 5.077] (II) AMDGPU(0): #7: hsize: 1600 vsize 1200 refresh: 60 vid: 16553
[ 5.077] (II) AMDGPU(0): Supported detailed timing:
[ 5.077] (II) AMDGPU(0): clock: 241.5 MHz Image Size: 709 x 399 mm
[ 5.077] (II) AMDGPU(0): h_active: 2560 h_sync: 2608 h_sync_end 2640 h_blank_end 2720 h_border: 0
[ 5.077] (II) AMDGPU(0): v_active: 1440 v_sync: 1443 v_sync_end 1448 v_blanking: 1481 v_border: 0
[ 5.077] (II) AMDGPU(0): Ranges: V min: 38 V max: 76 Hz, H min: 24 H max: 112 kHz, PixClock max 345 MHz
[ 5.077] (II) AMDGPU(0): Monitor name: HP 32 QHD
[ 5.077] (II) AMDGPU(0): Serial No: CNK9431MCS
[ 5.077] (II) AMDGPU(0): clock: 148.5 MHz Image Size: 709 x 399 mm
[ 5.077] (II) AMDGPU(0): h_active: 1920 h_sync: 2008 h_sync_end 2052 h_blank_end 2200 h_border: 0
[ 5.077] (II) AMDGPU(0): v_active: 1080 v_sync: 1084 v_sync_end 1089 v_blanking: 1125 v_border: 0
[ 5.077] (II) AMDGPU(0): h_active: 1920 h_sync: 2448 h_sync_end 2492 h_blank_end 2640 h_border: 0
[ 5.077] (II) AMDGPU(0): clock: 304.2 MHz Image Size: 709 x 399 mm
[ 5.077] (II) AMDGPU(0): v_active: 1440 v_sync: 1443 v_sync_end 1448 v_blanking: 1492 v_border: 0
[ 5.077] (II) AMDGPU(0): Number of EDID sections to follow: 1
[ 5.077] (II) AMDGPU(0): EDID (in hex):
[ 5.077] (II) AMDGPU(0): 00ffffffffffff00220e0c3601010101
[ 5.077] (II) AMDGPU(0): 2b1d0103804728782af8a5a6564ea125
[ 5.077] (II) AMDGPU(0): 0d5054a10800d1c0a9c081c0d100b300
[ 5.077] (II) AMDGPU(0): 95008180a940565e00a0a0a029503020
[ 5.077] (II) AMDGPU(0): 3500c58f2100001a000000fd00264c18
[ 5.077] (II) AMDGPU(0): 7022000a202020202020000000fc0048
[ 5.077] (II) AMDGPU(0): 50203332205148440a202020000000ff
[ 5.077] (II) AMDGPU(0): 00434e4b393433314d43530a20200110
[ 5.077] (II) AMDGPU(0): 02032af149101f041303120211012309
[ 5.077] (II) AMDGPU(0): 07078301000067030c0010000044681a
[ 5.077] (II) AMDGPU(0): 00000101264bede2002b023a80187138
[ 5.077] (II) AMDGPU(0): 2d40582c4500c58f2100001e023a80d0
[ 5.077] (II) AMDGPU(0): 72382d40102c4580c58f2100001ed976
[ 5.077] (II) AMDGPU(0): 00a0a0a0345030203500c58f2100001a
[ 5.077] (II) AMDGPU(0): 00000000000000000000000000000000
[ 5.077] (II) AMDGPU(0): 0000000000000000000000000000006d
[ 5.077] (--) AMDGPU(0): HDMI max TMDS frequency 340000KHz
[ 5.077] (II) AMDGPU(0): Printing probed modes for output DisplayPort-1
[ 5.077] (II) AMDGPU(0): Modeline "1920x1200"x60.0 154.00 1920 1968 2000 2080 1200 1203 1209 1235 +hsync -vsync (74.0 kHz e)
[ 5.077] (II) AMDGPU(0): Modeline "1920x1080"x60.0 148.50 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.5 kHz e)
[ 5.077] (II) AMDGPU(0): Modeline "1920x1080"x50.0 148.50 1920 2448 2492 2640 1080 1084 1089 1125 +hsync +vsync (56.2 kHz e)
[ 5.077] (II) AMDGPU(0): Modeline "1920x1080"x59.9 148.35 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.4 kHz e)
[ 5.077] (II) AMDGPU(0): Modeline "1600x1200"x60.0 162.00 1600 1664 1856 2160 1200 1201 1204 1250 +hsync +vsync (75.0 kHz e)
[ 5.077] (II) AMDGPU(0): Modeline "1680x1050"x59.9 119.00 1680 1728 1760 1840 1050 1053 1059 1080 +hsync -vsync (64.7 kHz e)
[ 5.077] (II) AMDGPU(0): Modeline "1600x900"x60.0 108.00 1600 1624 1704 1800 900 901 904 1000 +hsync +vsync (60.0 kHz e)
[ 5.077] (II) AMDGPU(0): Modeline "1280x1024"x60.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[ 5.077] (II) AMDGPU(0): Modeline "1440x900"x59.9 88.75 1440 1488 1520 1600 900 903 909 926 +hsync -vsync (55.5 kHz e)
[ 5.077] (II) AMDGPU(0): Modeline "1280x720"x60.0 74.25 1280 1390 1430 1650 720 725 730 750 +hsync +vsync (45.0 kHz e)
[ 5.077] (II) AMDGPU(0): Modeline "1280x720"x50.0 74.25 1280 1720 1760 1980 720 725 730 750 +hsync +vsync (37.5 kHz e)
[ 5.077] (II) AMDGPU(0): Modeline "1280x720"x59.9 74.18 1280 1390 1430 1650 720 725 730 750 +hsync +vsync (45.0 kHz e)
[ 5.077] (II) AMDGPU(0): Modeline "1024x768"x60.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e)
[ 5.077] (II) AMDGPU(0): Modeline "800x600"x60.3 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e)
[ 5.077] (II) AMDGPU(0): Modeline "720x576"x50.0 27.00 720 732 796 864 576 581 586 625 -hsync -vsync (31.2 kHz e)
[ 5.077] (II) AMDGPU(0): Modeline "720x480"x60.0 27.03 720 736 798 858 480 489 495 525 -hsync -vsync (31.5 kHz e)
[ 5.077] (II) AMDGPU(0): Modeline "720x480"x59.9 27.00 720 736 798 858 480 489 495 525 -hsync -vsync (31.5 kHz e)
[ 5.077] (II) AMDGPU(0): Modeline "640x480"x60.0 25.20 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 5.077] (II) AMDGPU(0): Modeline "640x480"x59.9 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 5.077] (II) AMDGPU(0): Modeline "720x400"x70.1 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz e)
[ 5.078] (II) AMDGPU(0): EDID for output DisplayPort-2
[ 5.078] (II) AMDGPU(0): Manufacturer: HPN Model: 360c Serial#: 16843009
[ 5.078] (II) AMDGPU(0): Year: 2019 Week: 24
[ 5.078] (II) AMDGPU(0): EDID Version: 1.3
[ 5.078] (II) AMDGPU(0): Digital Display Input
[ 5.078] (II) AMDGPU(0): Max Image Size [cm]: horiz.: 71 vert.: 40
[ 5.078] (II) AMDGPU(0): Gamma: 2.20
[ 5.078] (II) AMDGPU(0): DPMS capabilities: Off
[ 5.078] (II) AMDGPU(0): Supported color encodings: RGB 4:4:4 YCrCb 4:4:4
[ 5.078] (II) AMDGPU(0): First detailed timing is preferred mode
[ 5.078] (II) AMDGPU(0): redX: 0.651 redY: 0.339 greenX: 0.307 greenY: 0.629
[ 5.078] (II) AMDGPU(0): blueX: 0.146 blueY: 0.053 whiteX: 0.313 whiteY: 0.329
[ 5.078] (II) AMDGPU(0): Supported established timings:
[ 5.078] (II) AMDGPU(0): 720x400@70Hz
[ 5.078] (II) AMDGPU(0): 640x480@60Hz
[ 5.078] (II) AMDGPU(0): 800x600@60Hz
[ 5.078] (II) AMDGPU(0): 1024x768@60Hz
[ 5.078] (II) AMDGPU(0): Manufacturer's mask: 0
[ 5.078] (II) AMDGPU(0): Supported standard timings:
[ 5.078] (II) AMDGPU(0): #0: hsize: 1920 vsize 1080 refresh: 60 vid: 49361
[ 5.078] (II) AMDGPU(0): #1: hsize: 1600 vsize 900 refresh: 60 vid: 49321
[ 5.078] (II) AMDGPU(0): #2: hsize: 1280 vsize 720 refresh: 60 vid: 49281
[ 5.078] (II) AMDGPU(0): #3: hsize: 1920 vsize 1200 refresh: 60 vid: 209
[ 5.078] (II) AMDGPU(0): #4: hsize: 1680 vsize 1050 refresh: 60 vid: 179
[ 5.078] (II) AMDGPU(0): #5: hsize: 1440 vsize 900 refresh: 60 vid: 149
[ 5.078] (II) AMDGPU(0): #6: hsize: 1280 vsize 1024 refresh: 60 vid: 32897
[ 5.078] (II) AMDGPU(0): #7: hsize: 1600 vsize 1200 refresh: 60 vid: 16553
[ 5.078] (II) AMDGPU(0): Supported detailed timing:
[ 5.078] (II) AMDGPU(0): clock: 241.5 MHz Image Size: 709 x 399 mm
[ 5.078] (II) AMDGPU(0): h_active: 2560 h_sync: 2608 h_sync_end 2640 h_blank_end 2720 h_border: 0
[ 5.078] (II) AMDGPU(0): v_active: 1440 v_sync: 1443 v_sync_end 1448 v_blanking: 1481 v_border: 0
[ 5.078] (II) AMDGPU(0): Ranges: V min: 38 V max: 76 Hz, H min: 24 H max: 112 kHz, PixClock max 345 MHz
[ 5.078] (II) AMDGPU(0): Monitor name: HP 32 QHD
[ 5.078] (II) AMDGPU(0): Serial No: CNK9242F9J
[ 5.078] (II) AMDGPU(0): clock: 148.5 MHz Image Size: 709 x 399 mm
[ 5.078] (II) AMDGPU(0): h_active: 1920 h_sync: 2008 h_sync_end 2052 h_blank_end 2200 h_border: 0
[ 5.078] (II) AMDGPU(0): v_active: 1080 v_sync: 1084 v_sync_end 1089 v_blanking: 1125 v_border: 0
[ 5.078] (II) AMDGPU(0): h_active: 1920 h_sync: 2448 h_sync_end 2492 h_blank_end 2640 h_border: 0
[ 5.078] (II) AMDGPU(0): clock: 304.2 MHz Image Size: 709 x 399 mm
[ 5.078] (II) AMDGPU(0): v_active: 1440 v_sync: 1443 v_sync_end 1448 v_blanking: 1492 v_border: 0
[ 5.078] (II) AMDGPU(0): Number of EDID sections to follow: 1
[ 5.078] (II) AMDGPU(0): EDID (in hex):
[ 5.078] (II) AMDGPU(0): 00ffffffffffff00220e0c3601010101
[ 5.078] (II) AMDGPU(0): 181d0103804728782af8a5a6564ea125
[ 5.078] (II) AMDGPU(0): 0d5054a10800d1c0a9c081c0d100b300
[ 5.078] (II) AMDGPU(0): 95008180a940565e00a0a0a029503020
[ 5.078] (II) AMDGPU(0): 3500c58f2100001a000000fd00264c18
[ 5.078] (II) AMDGPU(0): 7022000a202020202020000000fc0048
[ 5.078] (II) AMDGPU(0): 50203332205148440a202020000000ff
[ 5.078] (II) AMDGPU(0): 00434e4b3932343246394a0a2020013d
[ 5.078] (II) AMDGPU(0): 02032af149101f041303120211012309
[ 5.078] (II) AMDGPU(0): 07078301000067030c0010000044681a
[ 5.078] (II) AMDGPU(0): 00000101264bede2002b023a80187138
[ 5.078] (II) AMDGPU(0): 2d40582c4500c58f2100001e023a80d0
[ 5.078] (II) AMDGPU(0): 72382d40102c4580c58f2100001ed976
[ 5.078] (II) AMDGPU(0): 00a0a0a0345030203500c58f2100001a
[ 5.078] (II) AMDGPU(0): 00000000000000000000000000000000
[ 5.078] (II) AMDGPU(0): 0000000000000000000000000000006d
[ 5.079] (--) AMDGPU(0): HDMI max TMDS frequency 340000KHz
[ 5.079] (II) AMDGPU(0): Printing probed modes for output DisplayPort-2
[ 5.079] (II) AMDGPU(0): Modeline "1920x1200"x60.0 154.00 1920 1968 2000 2080 1200 1203 1209 1235 +hsync -vsync (74.0 kHz e)
[ 5.079] (II) AMDGPU(0): Modeline "1920x1080"x60.0 148.50 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.5 kHz e)
[ 5.079] (II) AMDGPU(0): Modeline "1920x1080"x50.0 148.50 1920 2448 2492 2640 1080 1084 1089 1125 +hsync +vsync (56.2 kHz e)
[ 5.079] (II) AMDGPU(0): Modeline "1920x1080"x59.9 148.35 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.4 kHz e)
[ 5.079] (II) AMDGPU(0): Modeline "1600x1200"x60.0 162.00 1600 1664 1856 2160 1200 1201 1204 1250 +hsync +vsync (75.0 kHz e)
[ 5.079] (II) AMDGPU(0): Modeline "1680x1050"x59.9 119.00 1680 1728 1760 1840 1050 1053 1059 1080 +hsync -vsync (64.7 kHz e)
[ 5.079] (II) AMDGPU(0): Modeline "1600x900"x60.0 108.00 1600 1624 1704 1800 900 901 904 1000 +hsync +vsync (60.0 kHz e)
[ 5.079] (II) AMDGPU(0): Modeline "1280x1024"x60.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[ 5.079] (II) AMDGPU(0): Modeline "1440x900"x59.9 88.75 1440 1488 1520 1600 900 903 909 926 +hsync -vsync (55.5 kHz e)
[ 5.079] (II) AMDGPU(0): Modeline "1280x720"x60.0 74.25 1280 1390 1430 1650 720 725 730 750 +hsync +vsync (45.0 kHz e)
[ 5.079] (II) AMDGPU(0): Modeline "1280x720"x50.0 74.25 1280 1720 1760 1980 720 725 730 750 +hsync +vsync (37.5 kHz e)
[ 5.079] (II) AMDGPU(0): Modeline "1280x720"x59.9 74.18 1280 1390 1430 1650 720 725 730 750 +hsync +vsync (45.0 kHz e)
[ 5.079] (II) AMDGPU(0): Modeline "1024x768"x60.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e)
[ 5.079] (II) AMDGPU(0): Modeline "800x600"x60.3 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e)
[ 5.079] (II) AMDGPU(0): Modeline "720x576"x50.0 27.00 720 732 796 864 576 581 586 625 -hsync -vsync (31.2 kHz e)
[ 5.079] (II) AMDGPU(0): Modeline "720x480"x60.0 27.03 720 736 798 858 480 489 495 525 -hsync -vsync (31.5 kHz e)
[ 5.079] (II) AMDGPU(0): Modeline "720x480"x59.9 27.00 720 736 798 858 480 489 495 525 -hsync -vsync (31.5 kHz e)
[ 5.079] (II) AMDGPU(0): Modeline "640x480"x60.0 25.20 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 5.079] (II) AMDGPU(0): Modeline "640x480"x59.9 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 5.079] (II) AMDGPU(0): Modeline "720x400"x70.1 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz e)
[ 5.079] (II) AMDGPU(0): EDID for output HDMI-A-0
[ 5.079] (II) AMDGPU(0): Output DisplayPort-0 disconnected
[ 5.079] (II) AMDGPU(0): Output DisplayPort-1 connected
[ 5.079] (II) AMDGPU(0): Output DisplayPort-2 connected
[ 5.079] (II) AMDGPU(0): Output HDMI-A-0 disconnected
[ 5.079] (II) AMDGPU(0): Using fuzzy aspect match for initial modes
[ 5.079] (II) AMDGPU(0): Output DisplayPort-1 using initial mode 1920x1080 +0+0
[ 5.079] (II) AMDGPU(0): Output DisplayPort-2 using initial mode 1920x1080 +0+0
[ 5.079] (II) AMDGPU(0): mem size init: gart size :1fe5bd000 vram size: s:1fd7da000 visible:f82a000
[ 5.079] (==) AMDGPU(0): DPI set to (96, 96)
[ 5.079] (==) AMDGPU(0): Using gamma correction (1.0, 1.0, 1.0)
[ 5.079] (II) Loading sub module "ramdac"
[ 5.079] (II) LoadModule: "ramdac"
[ 5.079] (II) Module "ramdac" already built-in
[ 5.079] (II) UnloadModule: "radeon"
[ 5.079] (II) Unloading radeon
[ 5.079] (II) UnloadModule: "modesetting"
[ 5.079] (II) Unloading modesetting
[ 5.079] (II) AMDGPU(0): [DRI2] Setup complete
[ 5.079] (II) AMDGPU(0): [DRI2] DRI driver: radeonsi
[ 5.079] (II) AMDGPU(0): [DRI2] VDPAU driver: radeonsi
[ 5.083] (II) AMDGPU(0): Front buffer pitch: 7680 bytes
[ 5.087] (II) AMDGPU(0): SYNC extension fences enabled
[ 5.087] (II) AMDGPU(0): Present extension enabled
[ 5.087] (==) AMDGPU(0): DRI3 enabled
[ 5.087] (==) AMDGPU(0): Backing store enabled
[ 5.087] (II) AMDGPU(0): Direct rendering enabled
[ 5.124] (II) AMDGPU(0): Use GLAMOR acceleration.
[ 5.124] (II) AMDGPU(0): Acceleration enabled
[ 5.124] (==) AMDGPU(0): DPMS enabled
[ 5.124] (==) AMDGPU(0): Silken mouse disabled
[ 5.124] (II) AMDGPU(0): Set up textured video (glamor)
[ 5.160] (II) Initializing extension Generic Event Extension
[ 5.160] (II) Initializing extension SHAPE
[ 5.160] (II) Initializing extension MIT-SHM
[ 5.160] (II) Initializing extension XInputExtension
[ 5.160] (II) Initializing extension XTEST
[ 5.160] (II) Initializing extension BIG-REQUESTS
[ 5.160] (II) Initializing extension SYNC
[ 5.160] (II) Initializing extension XKEYBOARD
[ 5.160] (II) Initializing extension XC-MISC
[ 5.160] (II) Initializing extension SECURITY
[ 5.160] (II) Initializing extension XFIXES
[ 5.160] (II) Initializing extension RENDER
[ 5.160] (II) Initializing extension RANDR
[ 5.161] (II) Initializing extension COMPOSITE
[ 5.161] (II) Initializing extension DAMAGE
[ 5.161] (II) Initializing extension MIT-SCREEN-SAVER
[ 5.161] (II) Initializing extension DOUBLE-BUFFER
[ 5.161] (II) Initializing extension RECORD
[ 5.161] (II) Initializing extension DPMS
[ 5.161] (II) Initializing extension Present
[ 5.161] (II) Initializing extension DRI3
[ 5.161] (II) Initializing extension X-Resource
[ 5.161] (II) Initializing extension XVideo
[ 5.161] (II) Initializing extension XVideo-MotionCompensation
[ 5.161] (II) Initializing extension GLX
[ 5.164] (II) AIGLX: Loaded and initialized radeonsi
[ 5.164] (II) GLX: Initialized DRI2 GL provider for screen 0
[ 5.164] (II) Initializing extension XFree86-VidModeExtension
[ 5.164] (II) Initializing extension XFree86-DGA
[ 5.164] (II) Initializing extension XFree86-DRI
[ 5.164] (II) Initializing extension DRI2
[ 5.177] (II) AMDGPU(0): Setting screen physical size to 508 x 285
[ 5.585] (II) config/udev: Adding input device Power Button (/dev/input/event1)
[ 5.585] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 5.585] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[ 5.585] (**) Power Button: Applying InputClass "system-keyboard"
[ 5.585] (II) LoadModule: "libinput"
/\/\/\/\/\ Omitting logging from 'libinput' /\/\/\/\/\
[ 546.219] (--) AMDGPU(0): HDMI max TMDS frequency 340000KHz
[ 546.220] (II) AMDGPU(0): EDID vendor "HPN", prod id 13836
[ 546.220] (II) AMDGPU(0): Using EDID range info for horizontal sync
[ 546.220] (II) AMDGPU(0): Using EDID range info for vertical refresh
[ 546.220] (II) AMDGPU(0): Printing DDC gathered Modelines:
[ 546.220] (II) AMDGPU(0): Modeline "2560x1440"x0.0 241.50 2560 2608 2640 2720 1440 1443 1448 1481 +hsync -vsync (88.8 kHz eP)
[ 546.220] (II) AMDGPU(0): Modeline "1920x1080"x0.0 148.50 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.5 kHz e)
[ 546.220] (II) AMDGPU(0): Modeline "1920x1080"x0.0 148.50 1920 2448 2492 2640 1080 1084 1089 1125 +hsync +vsync (56.2 kHz e)
[ 546.220] (II) AMDGPU(0): Modeline "2560x1440"x0.0 304.25 2560 2608 2640 2720 1440 1443 1448 1492 +hsync -vsync (111.9 kHz e)
[ 546.220] (II) AMDGPU(0): Modeline "1280x720"x0.0 74.25 1280 1390 1430 1650 720 725 730 750 +hsync +vsync (45.0 kHz e)
[ 546.220] (II) AMDGPU(0): Modeline "1280x720"x0.0 74.25 1280 1720 1760 1980 720 725 730 750 +hsync +vsync (37.5 kHz e)
[ 546.220] (II) AMDGPU(0): Modeline "720x480"x0.0 27.00 720 736 798 858 480 489 495 525 -hsync -vsync (31.5 kHz e)
[ 546.220] (II) AMDGPU(0): Modeline "720x576"x0.0 27.00 720 732 796 864 576 581 586 625 -hsync -vsync (31.2 kHz e)
[ 546.220] (II) AMDGPU(0): Modeline "640x480"x0.0 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 546.220] (II) AMDGPU(0): Modeline "800x600"x0.0 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e)
[ 546.220] (II) AMDGPU(0): Modeline "720x400"x0.0 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz e)
[ 546.220] (II) AMDGPU(0): Modeline "1024x768"x0.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e)
[ 546.220] (II) AMDGPU(0): Modeline "1600x900"x60.0 119.00 1600 1696 1864 2128 900 901 904 932 -hsync +vsync (55.9 kHz e)
[ 546.220] (II) AMDGPU(0): Modeline "1920x1200"x0.0 154.00 1920 1968 2000 2080 1200 1203 1209 1235 +hsync -vsync (74.0 kHz e)
[ 546.220] (II) AMDGPU(0): Modeline "1680x1050"x0.0 119.00 1680 1728 1760 1840 1050 1053 1059 1080 +hsync -vsync (64.7 kHz e)
[ 546.220] (II) AMDGPU(0): Modeline "1440x900"x0.0 88.75 1440 1488 1520 1600 900 903 909 926 +hsync -vsync (55.5 kHz e)
[ 546.220] (II) AMDGPU(0): Modeline "1280x1024"x0.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[ 546.220] (II) AMDGPU(0): Modeline "1600x1200"x0.0 162.00 1600 1664 1856 2160 1200 1201 1204 1250 +hsync +vsync (75.0 kHz e)
[ 546.220] (--) AMDGPU(0): HDMI max TMDS frequency 340000KHz
[ 546.223] (II) AMDGPU(0): Allocate new frame buffer 3840x1200
[ 546.223] (II) AMDGPU(0): => pitch 15360 bytes
[ 547.010] (--) AMDGPU(0): HDMI max TMDS frequency 340000KHz
[ 547.010] (II) AMDGPU(0): EDID vendor "HPN", prod id 13836
[ 547.010] (II) AMDGPU(0): Using hsync ranges from config file
[ 547.010] (II) AMDGPU(0): Using vrefresh ranges from config file
[ 547.010] (II) AMDGPU(0): Printing DDC gathered Modelines:
[ 547.010] (II) AMDGPU(0): Modeline "2560x1440"x0.0 241.50 2560 2608 2640 2720 1440 1443 1448 1481 +hsync -vsync (88.8 kHz eP)
[ 547.010] (II) AMDGPU(0): Modeline "1920x1080"x0.0 148.50 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.5 kHz e)
[ 547.010] (II) AMDGPU(0): Modeline "1920x1080"x0.0 148.50 1920 2448 2492 2640 1080 1084 1089 1125 +hsync +vsync (56.2 kHz e)
[ 547.010] (II) AMDGPU(0): Modeline "2560x1440"x0.0 304.25 2560 2608 2640 2720 1440 1443 1448 1492 +hsync -vsync (111.9 kHz e)
[ 547.010] (II) AMDGPU(0): Modeline "1280x720"x0.0 74.25 1280 1390 1430 1650 720 725 730 750 +hsync +vsync (45.0 kHz e)
[ 547.010] (II) AMDGPU(0): Modeline "1280x720"x0.0 74.25 1280 1720 1760 1980 720 725 730 750 +hsync +vsync (37.5 kHz e)
[ 547.010] (II) AMDGPU(0): Modeline "720x480"x0.0 27.00 720 736 798 858 480 489 495 525 -hsync -vsync (31.5 kHz e)
[ 547.010] (II) AMDGPU(0): Modeline "720x576"x0.0 27.00 720 732 796 864 576 581 586 625 -hsync -vsync (31.2 kHz e)
[ 547.010] (II) AMDGPU(0): Modeline "640x480"x0.0 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 547.010] (II) AMDGPU(0): Modeline "800x600"x0.0 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e)
[ 547.010] (II) AMDGPU(0): Modeline "720x400"x0.0 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz e)
[ 547.010] (II) AMDGPU(0): Modeline "1024x768"x0.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e)
[ 547.010] (II) AMDGPU(0): Modeline "1600x900"x60.0 119.00 1600 1696 1864 2128 900 901 904 932 -hsync +vsync (55.9 kHz e)
[ 547.010] (II) AMDGPU(0): Modeline "1920x1200"x0.0 154.00 1920 1968 2000 2080 1200 1203 1209 1235 +hsync -vsync (74.0 kHz e)
[ 547.010] (II) AMDGPU(0): Modeline "1680x1050"x0.0 119.00 1680 1728 1760 1840 1050 1053 1059 1080 +hsync -vsync (64.7 kHz e)
[ 547.010] (II) AMDGPU(0): Modeline "1440x900"x0.0 88.75 1440 1488 1520 1600 900 903 909 926 +hsync -vsync (55.5 kHz e)
[ 547.010] (II) AMDGPU(0): Modeline "1280x1024"x0.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[ 547.010] (II) AMDGPU(0): Modeline "1600x1200"x0.0 162.00 1600 1664 1856 2160 1200 1201 1204 1250 +hsync +vsync (75.0 kHz e)
[ 552.035] (--) AMDGPU(0): HDMI max TMDS frequency 340000KHz
[ 552.035] (II) AMDGPU(0): EDID vendor "HPN", prod id 13836
[ 552.035] (II) AMDGPU(0): Using hsync ranges from config file
[ 552.035] (II) AMDGPU(0): Using vrefresh ranges from config file
[ 552.035] (II) AMDGPU(0): Printing DDC gathered Modelines:
[ 552.035] (II) AMDGPU(0): Modeline "2560x1440"x0.0 241.50 2560 2608 2640 2720 1440 1443 1448 1481 +hsync -vsync (88.8 kHz eP)
[ 552.035] (II) AMDGPU(0): Modeline "1920x1080"x0.0 148.50 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.5 kHz e)
[ 552.035] (II) AMDGPU(0): Modeline "1920x1080"x0.0 148.50 1920 2448 2492 2640 1080 1084 1089 1125 +hsync +vsync (56.2 kHz e)
[ 552.035] (II) AMDGPU(0): Modeline "2560x1440"x0.0 304.25 2560 2608 2640 2720 1440 1443 1448 1492 +hsync -vsync (111.9 kHz e)
[ 552.035] (II) AMDGPU(0): Modeline "1280x720"x0.0 74.25 1280 1390 1430 1650 720 725 730 750 +hsync +vsync (45.0 kHz e)
[ 552.035] (II) AMDGPU(0): Modeline "1280x720"x0.0 74.25 1280 1720 1760 1980 720 725 730 750 +hsync +vsync (37.5 kHz e)
[ 552.035] (II) AMDGPU(0): Modeline "720x480"x0.0 27.00 720 736 798 858 480 489 495 525 -hsync -vsync (31.5 kHz e)
[ 552.035] (II) AMDGPU(0): Modeline "720x576"x0.0 27.00 720 732 796 864 576 581 586 625 -hsync -vsync (31.2 kHz e)
[ 552.035] (II) AMDGPU(0): Modeline "640x480"x0.0 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 552.035] (II) AMDGPU(0): Modeline "800x600"x0.0 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e)
[ 552.035] (II) AMDGPU(0): Modeline "720x400"x0.0 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz e)
[ 552.035] (II) AMDGPU(0): Modeline "1024x768"x0.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e)
[ 552.035] (II) AMDGPU(0): Modeline "1600x900"x60.0 119.00 1600 1696 1864 2128 900 901 904 932 -hsync +vsync (55.9 kHz e)
[ 552.035] (II) AMDGPU(0): Modeline "1920x1200"x0.0 154.00 1920 1968 2000 2080 1200 1203 1209 1235 +hsync -vsync (74.0 kHz e)
[ 552.035] (II) AMDGPU(0): Modeline "1680x1050"x0.0 119.00 1680 1728 1760 1840 1050 1053 1059 1080 +hsync -vsync (64.7 kHz e)
[ 552.035] (II) AMDGPU(0): Modeline "1440x900"x0.0 88.75 1440 1488 1520 1600 900 903 909 926 +hsync -vsync (55.5 kHz e)
[ 552.035] (II) AMDGPU(0): Modeline "1280x1024"x0.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[ 552.035] (II) AMDGPU(0): Modeline "1600x1200"x0.0 162.00 1600 1664 1856 2160 1200 1201 1204 1250 +hsync +vsync (75.0 kHz e)
[ 567.020] (--) AMDGPU(0): HDMI max TMDS frequency 340000KHz
[ 567.021] (II) AMDGPU(0): EDID vendor "HPN", prod id 13836
[ 567.021] (II) AMDGPU(0): Using hsync ranges from config file
[ 567.021] (II) AMDGPU(0): Using vrefresh ranges from config file
[ 567.021] (II) AMDGPU(0): Printing DDC gathered Modelines:
[ 567.021] (II) AMDGPU(0): Modeline "2560x1440"x0.0 241.50 2560 2608 2640 2720 1440 1443 1448 1481 +hsync -vsync (88.8 kHz eP)
[ 567.021] (II) AMDGPU(0): Modeline "1920x1080"x0.0 148.50 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.5 kHz e)
[ 567.021] (II) AMDGPU(0): Modeline "1920x1080"x0.0 148.50 1920 2448 2492 2640 1080 1084 1089 1125 +hsync +vsync (56.2 kHz e)
[ 567.021] (II) AMDGPU(0): Modeline "2560x1440"x0.0 304.25 2560 2608 2640 2720 1440 1443 1448 1492 +hsync -vsync (111.9 kHz e)
[ 567.021] (II) AMDGPU(0): Modeline "1280x720"x0.0 74.25 1280 1390 1430 1650 720 725 730 750 +hsync +vsync (45.0 kHz e)
[ 567.021] (II) AMDGPU(0): Modeline "1280x720"x0.0 74.25 1280 1720 1760 1980 720 725 730 750 +hsync +vsync (37.5 kHz e)
[ 567.021] (II) AMDGPU(0): Modeline "720x480"x0.0 27.00 720 736 798 858 480 489 495 525 -hsync -vsync (31.5 kHz e)
[ 567.021] (II) AMDGPU(0): Modeline "720x576"x0.0 27.00 720 732 796 864 576 581 586 625 -hsync -vsync (31.2 kHz e)
[ 567.021] (II) AMDGPU(0): Modeline "640x480"x0.0 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 567.021] (II) AMDGPU(0): Modeline "800x600"x0.0 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e)
[ 567.021] (II) AMDGPU(0): Modeline "720x400"x0.0 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz e)
[ 567.021] (II) AMDGPU(0): Modeline "1024x768"x0.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e)
[ 567.021] (II) AMDGPU(0): Modeline "1600x900"x60.0 119.00 1600 1696 1864 2128 900 901 904 932 -hsync +vsync (55.9 kHz e)
[ 567.021] (II) AMDGPU(0): Modeline "1920x1200"x0.0 154.00 1920 1968 2000 2080 1200 1203 1209 1235 +hsync -vsync (74.0 kHz e)
[ 567.021] (II) AMDGPU(0): Modeline "1680x1050"x0.0 119.00 1680 1728 1760 1840 1050 1053 1059 1080 +hsync -vsync (64.7 kHz e)
[ 567.021] (II) AMDGPU(0): Modeline "1440x900"x0.0 88.75 1440 1488 1520 1600 900 903 909 926 +hsync -vsync (55.5 kHz e)
[ 567.021] (II) AMDGPU(0): Modeline "1280x1024"x0.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[ 567.021] (II) AMDGPU(0): Modeline "1600x1200"x0.0 162.00 1600 1664 1856 2160 1200 1201 1204 1250 +hsync +vsync (75.0 kHz e)
[ 567.021] (--) AMDGPU(0): HDMI max TMDS frequency 340000KHz
[ 592.031] (--) AMDGPU(0): HDMI max TMDS frequency 340000KHz
[ 592.031] (II) AMDGPU(0): EDID vendor "HPN", prod id 13836
[ 592.031] (II) AMDGPU(0): Using hsync ranges from config file
[ 592.031] (II) AMDGPU(0): Using vrefresh ranges from config file
[ 592.031] (II) AMDGPU(0): Printing DDC gathered Modelines:
[ 592.031] (II) AMDGPU(0): Modeline "2560x1440"x0.0 241.50 2560 2608 2640 2720 1440 1443 1448 1481 +hsync -vsync (88.8 kHz eP)
[ 592.031] (II) AMDGPU(0): Modeline "1920x1080"x0.0 148.50 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.5 kHz e)
[ 592.031] (II) AMDGPU(0): Modeline "1920x1080"x0.0 148.50 1920 2448 2492 2640 1080 1084 1089 1125 +hsync +vsync (56.2 kHz e)
[ 592.031] (II) AMDGPU(0): Modeline "2560x1440"x0.0 304.25 2560 2608 2640 2720 1440 1443 1448 1492 +hsync -vsync (111.9 kHz e)
[ 592.032] (II) AMDGPU(0): Modeline "1280x720"x0.0 74.25 1280 1390 1430 1650 720 725 730 750 +hsync +vsync (45.0 kHz e)
[ 592.032] (II) AMDGPU(0): Modeline "1280x720"x0.0 74.25 1280 1720 1760 1980 720 725 730 750 +hsync +vsync (37.5 kHz e)
[ 592.032] (II) AMDGPU(0): Modeline "720x480"x0.0 27.00 720 736 798 858 480 489 495 525 -hsync -vsync (31.5 kHz e)
[ 592.032] (II) AMDGPU(0): Modeline "720x576"x0.0 27.00 720 732 796 864 576 581 586 625 -hsync -vsync (31.2 kHz e)
[ 592.032] (II) AMDGPU(0): Modeline "640x480"x0.0 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 592.032] (II) AMDGPU(0): Modeline "800x600"x0.0 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e)
[ 592.032] (II) AMDGPU(0): Modeline "720x400"x0.0 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz e)
[ 592.032] (II) AMDGPU(0): Modeline "1024x768"x0.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e)
[ 592.032] (II) AMDGPU(0): Modeline "1600x900"x60.0 119.00 1600 1696 1864 2128 900 901 904 932 -hsync +vsync (55.9 kHz e)
[ 592.032] (II) AMDGPU(0): Modeline "1920x1200"x0.0 154.00 1920 1968 2000 2080 1200 1203 1209 1235 +hsync -vsync (74.0 kHz e)
[ 592.032] (II) AMDGPU(0): Modeline "1680x1050"x0.0 119.00 1680 1728 1760 1840 1050 1053 1059 1080 +hsync -vsync (64.7 kHz e)
[ 592.032] (II) AMDGPU(0): Modeline "1440x900"x0.0 88.75 1440 1488 1520 1600 900 903 909 926 +hsync -vsync (55.5 kHz e)
[ 592.032] (II) AMDGPU(0): Modeline "1280x1024"x0.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[ 592.032] (II) AMDGPU(0): Modeline "1600x1200"x0.0 162.00 1600 1664 1856 2160 1200 1201 1204 1250 +hsync +vsync (75.0 kHz e)
[ 592.032] (--) AMDGPU(0): HDMI max TMDS frequency 340000KHz
[ 594.024] (--) AMDGPU(0): HDMI max TMDS frequency 340000KHz
[ 594.025] (II) AMDGPU(0): EDID vendor "HPN", prod id 13836
[ 594.025] (II) AMDGPU(0): Using hsync ranges from config file
[ 594.025] (II) AMDGPU(0): Using vrefresh ranges from config file
[ 594.025] (II) AMDGPU(0): Printing DDC gathered Modelines:
[ 594.025] (II) AMDGPU(0): Modeline "2560x1440"x0.0 241.50 2560 2608 2640 2720 1440 1443 1448 1481 +hsync -vsync (88.8 kHz eP)
[ 594.025] (II) AMDGPU(0): Modeline "1920x1080"x0.0 148.50 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.5 kHz e)
[ 594.025] (II) AMDGPU(0): Modeline "1920x1080"x0.0 148.50 1920 2448 2492 2640 1080 1084 1089 1125 +hsync +vsync (56.2 kHz e)
[ 594.025] (II) AMDGPU(0): Modeline "2560x1440"x0.0 304.25 2560 2608 2640 2720 1440 1443 1448 1492 +hsync -vsync (111.9 kHz e)
[ 594.025] (II) AMDGPU(0): Modeline "1280x720"x0.0 74.25 1280 1390 1430 1650 720 725 730 750 +hsync +vsync (45.0 kHz e)
[ 594.025] (II) AMDGPU(0): Modeline "1280x720"x0.0 74.25 1280 1720 1760 1980 720 725 730 750 +hsync +vsync (37.5 kHz e)
[ 594.025] (II) AMDGPU(0): Modeline "720x480"x0.0 27.00 720 736 798 858 480 489 495 525 -hsync -vsync (31.5 kHz e)
[ 594.025] (II) AMDGPU(0): Modeline "720x576"x0.0 27.00 720 732 796 864 576 581 586 625 -hsync -vsync (31.2 kHz e)
[ 594.025] (II) AMDGPU(0): Modeline "640x480"x0.0 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 594.025] (II) AMDGPU(0): Modeline "800x600"x0.0 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e)
[ 594.025] (II) AMDGPU(0): Modeline "720x400"x0.0 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz e)
[ 594.025] (II) AMDGPU(0): Modeline "1024x768"x0.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e)
[ 594.025] (II) AMDGPU(0): Modeline "1600x900"x60.0 119.00 1600 1696 1864 2128 900 901 904 932 -hsync +vsync (55.9 kHz e)
[ 594.025] (II) AMDGPU(0): Modeline "1920x1200"x0.0 154.00 1920 1968 2000 2080 1200 1203 1209 1235 +hsync -vsync (74.0 kHz e)
[ 594.025] (II) AMDGPU(0): Modeline "1680x1050"x0.0 119.00 1680 1728 1760 1840 1050 1053 1059 1080 +hsync -vsync (64.7 kHz e)
[ 594.025] (II) AMDGPU(0): Modeline "1440x900"x0.0 88.75 1440 1488 1520 1600 900 903 909 926 +hsync -vsync (55.5 kHz e)
[ 594.025] (II) AMDGPU(0): Modeline "1280x1024"x0.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[ 594.025] (II) AMDGPU(0): Modeline "1600x1200"x0.0 162.00 1600 1664 1856 2160 1200 1201 1204 1250 +hsync +vsync (75.0 kHz e)
[ 594.025] (--) AMDGPU(0): HDMI max TMDS frequency 340000KHz
[ 598.152] (--) AMDGPU(0): HDMI max TMDS frequency 340000KHz
[ 598.153] (II) AMDGPU(0): EDID vendor "HPN", prod id 13836
[ 598.153] (II) AMDGPU(0): Using hsync ranges from config file
[ 598.153] (II) AMDGPU(0): Using vrefresh ranges from config file
[ 598.153] (II) AMDGPU(0): Printing DDC gathered Modelines:
[ 598.153] (II) AMDGPU(0): Modeline "2560x1440"x0.0 241.50 2560 2608 2640 2720 1440 1443 1448 1481 +hsync -vsync (88.8 kHz eP)
[ 598.153] (II) AMDGPU(0): Modeline "1920x1080"x0.0 148.50 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.5 kHz e)
[ 598.153] (II) AMDGPU(0): Modeline "1920x1080"x0.0 148.50 1920 2448 2492 2640 1080 1084 1089 1125 +hsync +vsync (56.2 kHz e)
[ 598.153] (II) AMDGPU(0): Modeline "2560x1440"x0.0 304.25 2560 2608 2640 2720 1440 1443 1448 1492 +hsync -vsync (111.9 kHz e)
[ 598.153] (II) AMDGPU(0): Modeline "1280x720"x0.0 74.25 1280 1390 1430 1650 720 725 730 750 +hsync +vsync (45.0 kHz e)
[ 598.153] (II) AMDGPU(0): Modeline "1280x720"x0.0 74.25 1280 1720 1760 1980 720 725 730 750 +hsync +vsync (37.5 kHz e)
[ 598.153] (II) AMDGPU(0): Modeline "720x480"x0.0 27.00 720 736 798 858 480 489 495 525 -hsync -vsync (31.5 kHz e)
[ 598.153] (II) AMDGPU(0): Modeline "720x576"x0.0 27.00 720 732 796 864 576 581 586 625 -hsync -vsync (31.2 kHz e)
[ 598.153] (II) AMDGPU(0): Modeline "640x480"x0.0 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 598.153] (II) AMDGPU(0): Modeline "800x600"x0.0 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e)
[ 598.153] (II) AMDGPU(0): Modeline "720x400"x0.0 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz e)
[ 598.153] (II) AMDGPU(0): Modeline "1024x768"x0.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e)
[ 598.153] (II) AMDGPU(0): Modeline "1600x900"x60.0 119.00 1600 1696 1864 2128 900 901 904 932 -hsync +vsync (55.9 kHz e)
[ 598.153] (II) AMDGPU(0): Modeline "1920x1200"x0.0 154.00 1920 1968 2000 2080 1200 1203 1209 1235 +hsync -vsync (74.0 kHz e)
[ 598.153] (II) AMDGPU(0): Modeline "1680x1050"x0.0 119.00 1680 1728 1760 1840 1050 1053 1059 1080 +hsync -vsync (64.7 kHz e)
[ 598.153] (II) AMDGPU(0): Modeline "1440x900"x0.0 88.75 1440 1488 1520 1600 900 903 909 926 +hsync -vsync (55.5 kHz e)
[ 598.153] (II) AMDGPU(0): Modeline "1280x1024"x0.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[ 598.153] (II) AMDGPU(0): Modeline "1600x1200"x0.0 162.00 1600 1664 1856 2160 1200 1201 1204 1250 +hsync +vsync (75.0 kHz e)
[ 598.153] (--) AMDGPU(0): HDMI max TMDS frequency 340000KHz
[ 603.951] (--) AMDGPU(0): HDMI max TMDS frequency 340000KHz
[ 603.952] (II) AMDGPU(0): EDID vendor "HPN", prod id 13836
[ 603.952] (II) AMDGPU(0): Using hsync ranges from config file
[ 603.952] (II) AMDGPU(0): Using vrefresh ranges from config file
[ 603.952] (II) AMDGPU(0): Printing DDC gathered Modelines:
[ 603.952] (II) AMDGPU(0): Modeline "2560x1440"x0.0 241.50 2560 2608 2640 2720 1440 1443 1448 1481 +hsync -vsync (88.8 kHz eP)
[ 603.952] (II) AMDGPU(0): Modeline "1920x1080"x0.0 148.50 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.5 kHz e)
[ 603.952] (II) AMDGPU(0): Modeline "1920x1080"x0.0 148.50 1920 2448 2492 2640 1080 1084 1089 1125 +hsync +vsync (56.2 kHz e)
[ 603.952] (II) AMDGPU(0): Modeline "2560x1440"x0.0 304.25 2560 2608 2640 2720 1440 1443 1448 1492 +hsync -vsync (111.9 kHz e)
[ 603.952] (II) AMDGPU(0): Modeline "1280x720"x0.0 74.25 1280 1390 1430 1650 720 725 730 750 +hsync +vsync (45.0 kHz e)
[ 603.952] (II) AMDGPU(0): Modeline "1280x720"x0.0 74.25 1280 1720 1760 1980 720 725 730 750 +hsync +vsync (37.5 kHz e)
[ 603.952] (II) AMDGPU(0): Modeline "720x480"x0.0 27.00 720 736 798 858 480 489 495 525 -hsync -vsync (31.5 kHz e)
[ 603.952] (II) AMDGPU(0): Modeline "720x576"x0.0 27.00 720 732 796 864 576 581 586 625 -hsync -vsync (31.2 kHz e)
[ 603.952] (II) AMDGPU(0): Modeline "640x480"x0.0 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 603.952] (II) AMDGPU(0): Modeline "800x600"x0.0 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e)
[ 603.952] (II) AMDGPU(0): Modeline "720x400"x0.0 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz e)
[ 603.952] (II) AMDGPU(0): Modeline "1024x768"x0.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e)
[ 603.952] (II) AMDGPU(0): Modeline "1600x900"x60.0 119.00 1600 1696 1864 2128 900 901 904 932 -hsync +vsync (55.9 kHz e)
[ 603.952] (II) AMDGPU(0): Modeline "1920x1200"x0.0 154.00 1920 1968 2000 2080 1200 1203 1209 1235 +hsync -vsync (74.0 kHz e)
[ 603.952] (II) AMDGPU(0): Modeline "1680x1050"x0.0 119.00 1680 1728 1760 1840 1050 1053 1059 1080 +hsync -vsync (64.7 kHz e)
[ 603.952] (II) AMDGPU(0): Modeline "1440x900"x0.0 88.75 1440 1488 1520 1600 900 903 909 926 +hsync -vsync (55.5 kHz e)
[ 603.952] (II) AMDGPU(0): Modeline "1280x1024"x0.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[ 603.952] (II) AMDGPU(0): Modeline "1600x1200"x0.0 162.00 1600 1664 1856 2160 1200 1201 1204 1250 +hsync +vsync (75.0 kHz e)
[ 603.952] (--) AMDGPU(0): HDMI max TMDS frequency 340000KHz
[ 603.953] (--) AMDGPU(0): HDMI max TMDS frequency 340000KHz
[ 603.954] (II) AMDGPU(0): EDID vendor "HPN", prod id 13836
[ 603.954] (II) AMDGPU(0): Using hsync ranges from config file
[ 603.954] (II) AMDGPU(0): Using vrefresh ranges from config file
[ 603.954] (II) AMDGPU(0): Printing DDC gathered Modelines:
[ 603.954] (II) AMDGPU(0): Modeline "2560x1440"x0.0 241.50 2560 2608 2640 2720 1440 1443 1448 1481 +hsync -vsync (88.8 kHz eP)
[ 603.954] (II) AMDGPU(0): Modeline "1920x1080"x0.0 148.50 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.5 kHz e)
[ 603.954] (II) AMDGPU(0): Modeline "1920x1080"x0.0 148.50 1920 2448 2492 2640 1080 1084 1089 1125 +hsync +vsync (56.2 kHz e)
[ 603.954] (II) AMDGPU(0): Modeline "2560x1440"x0.0 304.25 2560 2608 2640 2720 1440 1443 1448 1492 +hsync -vsync (111.9 kHz e)
[ 603.954] (II) AMDGPU(0): Modeline "1280x720"x0.0 74.25 1280 1390 1430 1650 720 725 730 750 +hsync +vsync (45.0 kHz e)
[ 603.954] (II) AMDGPU(0): Modeline "1280x720"x0.0 74.25 1280 1720 1760 1980 720 725 730 750 +hsync +vsync (37.5 kHz e)
[ 603.954] (II) AMDGPU(0): Modeline "720x480"x0.0 27.00 720 736 798 858 480 489 495 525 -hsync -vsync (31.5 kHz e)
[ 603.954] (II) AMDGPU(0): Modeline "720x576"x0.0 27.00 720 732 796 864 576 581 586 625 -hsync -vsync (31.2 kHz e)
[ 603.954] (II) AMDGPU(0): Modeline "640x480"x0.0 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 603.954] (II) AMDGPU(0): Modeline "800x600"x0.0 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e)
[ 603.954] (II) AMDGPU(0): Modeline "720x400"x0.0 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz e)
[ 603.954] (II) AMDGPU(0): Modeline "1024x768"x0.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e)
[ 603.954] (II) AMDGPU(0): Modeline "1600x900"x60.0 119.00 1600 1696 1864 2128 900 901 904 932 -hsync +vsync (55.9 kHz e)
[ 603.954] (II) AMDGPU(0): Modeline "1920x1200"x0.0 154.00 1920 1968 2000 2080 1200 1203 1209 1235 +hsync -vsync (74.0 kHz e)
[ 603.954] (II) AMDGPU(0): Modeline "1680x1050"x0.0 119.00 1680 1728 1760 1840 1050 1053 1059 1080 +hsync -vsync (64.7 kHz e)
[ 603.954] (II) AMDGPU(0): Modeline "1440x900"x0.0 88.75 1440 1488 1520 1600 900 903 909 926 +hsync -vsync (55.5 kHz e)
[ 603.954] (II) AMDGPU(0): Modeline "1280x1024"x0.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[ 603.954] (II) AMDGPU(0): Modeline "1600x1200"x0.0 162.00 1600 1664 1856 2160 1200 1201 1204 1250 +hsync +vsync (75.0 kHz e)
[ 603.954] (--) AMDGPU(0): HDMI max TMDS frequency 340000KHz
[ 608.456] (--) AMDGPU(0): HDMI max TMDS frequency 340000KHz
[ 608.456] (II) AMDGPU(0): EDID vendor "HPN", prod id 13836
[ 608.456] (II) AMDGPU(0): Using hsync ranges from config file
[ 608.456] (II) AMDGPU(0): Using vrefresh ranges from config file
[ 608.456] (II) AMDGPU(0): Printing DDC gathered Modelines:
[ 608.456] (II) AMDGPU(0): Modeline "2560x1440"x0.0 241.50 2560 2608 2640 2720 1440 1443 1448 1481 +hsync -vsync (88.8 kHz eP)
[ 608.456] (II) AMDGPU(0): Modeline "1920x1080"x0.0 148.50 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.5 kHz e)
[ 608.456] (II) AMDGPU(0): Modeline "1920x1080"x0.0 148.50 1920 2448 2492 2640 1080 1084 1089 1125 +hsync +vsync (56.2 kHz e)
[ 608.456] (II) AMDGPU(0): Modeline "2560x1440"x0.0 304.25 2560 2608 2640 2720 1440 1443 1448 1492 +hsync -vsync (111.9 kHz e)
[ 608.456] (II) AMDGPU(0): Modeline "1280x720"x0.0 74.25 1280 1390 1430 1650 720 725 730 750 +hsync +vsync (45.0 kHz e)
[ 608.456] (II) AMDGPU(0): Modeline "1280x720"x0.0 74.25 1280 1720 1760 1980 720 725 730 750 +hsync +vsync (37.5 kHz e)
[ 608.456] (II) AMDGPU(0): Modeline "720x480"x0.0 27.00 720 736 798 858 480 489 495 525 -hsync -vsync (31.5 kHz e)
[ 608.456] (II) AMDGPU(0): Modeline "720x576"x0.0 27.00 720 732 796 864 576 581 586 625 -hsync -vsync (31.2 kHz e)
[ 608.456] (II) AMDGPU(0): Modeline "640x480"x0.0 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 608.456] (II) AMDGPU(0): Modeline "800x600"x0.0 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e)
[ 608.456] (II) AMDGPU(0): Modeline "720x400"x0.0 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz e)
[ 608.456] (II) AMDGPU(0): Modeline "1024x768"x0.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e)
[ 608.456] (II) AMDGPU(0): Modeline "1600x900"x60.0 119.00 1600 1696 1864 2128 900 901 904 932 -hsync +vsync (55.9 kHz e)
[ 608.456] (II) AMDGPU(0): Modeline "1920x1200"x0.0 154.00 1920 1968 2000 2080 1200 1203 1209 1235 +hsync -vsync (74.0 kHz e)
[ 608.456] (II) AMDGPU(0): Modeline "1680x1050"x0.0 119.00 1680 1728 1760 1840 1050 1053 1059 1080 +hsync -vsync (64.7 kHz e)
[ 608.456] (II) AMDGPU(0): Modeline "1440x900"x0.0 88.75 1440 1488 1520 1600 900 903 909 926 +hsync -vsync (55.5 kHz e)
[ 608.456] (II) AMDGPU(0): Modeline "1280x1024"x0.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[ 608.456] (II) AMDGPU(0): Modeline "1600x1200"x0.0 162.00 1600 1664 1856 2160 1200 1201 1204 1250 +hsync +vsync (75.0 kHz e)
[ 608.457] (--) AMDGPU(0): HDMI max TMDS frequency 340000KHz
[ 608.457] (II) AMDGPU(0): EDID vendor "HPN", prod id 13836
[ 608.457] (II) AMDGPU(0): Using hsync ranges from config file
[ 608.457] (II) AMDGPU(0): Using vrefresh ranges from config file
[ 608.457] (II) AMDGPU(0): Printing DDC gathered Modelines:
[ 608.457] (II) AMDGPU(0): Modeline "2560x1440"x0.0 241.50 2560 2608 2640 2720 1440 1443 1448 1481 +hsync -vsync (88.8 kHz eP)
[ 608.457] (II) AMDGPU(0): Modeline "1920x1080"x0.0 148.50 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.5 kHz e)
[ 608.457] (II) AMDGPU(0): Modeline "1920x1080"x0.0 148.50 1920 2448 2492 2640 1080 1084 1089 1125 +hsync +vsync (56.2 kHz e)
[ 608.457] (II) AMDGPU(0): Modeline "2560x1440"x0.0 304.25 2560 2608 2640 2720 1440 1443 1448 1492 +hsync -vsync (111.9 kHz e)
[ 608.457] (II) AMDGPU(0): Modeline "1280x720"x0.0 74.25 1280 1390 1430 1650 720 725 730 750 +hsync +vsync (45.0 kHz e)
[ 608.457] (II) AMDGPU(0): Modeline "1280x720"x0.0 74.25 1280 1720 1760 1980 720 725 730 750 +hsync +vsync (37.5 kHz e)
[ 608.457] (II) AMDGPU(0): Modeline "720x480"x0.0 27.00 720 736 798 858 480 489 495 525 -hsync -vsync (31.5 kHz e)
[ 608.457] (II) AMDGPU(0): Modeline "720x576"x0.0 27.00 720 732 796 864 576 581 586 625 -hsync -vsync (31.2 kHz e)
[ 608.457] (II) AMDGPU(0): Modeline "640x480"x0.0 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 608.457] (II) AMDGPU(0): Modeline "800x600"x0.0 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e)
[ 608.457] (II) AMDGPU(0): Modeline "720x400"x0.0 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz e)
[ 608.458] (II) AMDGPU(0): Modeline "1024x768"x0.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e)
[ 608.458] (II) AMDGPU(0): Modeline "1600x900"x60.0 119.00 1600 1696 1864 2128 900 901 904 932 -hsync +vsync (55.9 kHz e)
[ 608.458] (II) AMDGPU(0): Modeline "1920x1200"x0.0 154.00 1920 1968 2000 2080 1200 1203 1209 1235 +hsync -vsync (74.0 kHz e)
[ 608.458] (II) AMDGPU(0): Modeline "1680x1050"x0.0 119.00 1680 1728 1760 1840 1050 1053 1059 1080 +hsync -vsync (64.7 kHz e)
[ 608.458] (II) AMDGPU(0): Modeline "1440x900"x0.0 88.75 1440 1488 1520 1600 900 903 909 926 +hsync -vsync (55.5 kHz e)
[ 608.458] (II) AMDGPU(0): Modeline "1280x1024"x0.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[ 608.458] (II) AMDGPU(0): Modeline "1600x1200"x0.0 162.00 1600 1664 1856 2160 1200 1201 1204 1250 +hsync +vsync (75.0 kHz e)
[ 608.458] (--) AMDGPU(0): HDMI max TMDS frequency 340000KHz
[ 913.534] (EE) event10 - Corsair Corsair STRAFE Gaming Keyboard: client bug: event processing lagging behind by 17ms, your system is too slow
[ 991.098] (EE) event10 - Corsair Corsair STRAFE Gaming Keyboard: client bug: event processing lagging behind by 34ms, your system is too slow
[ 1091.086] (EE) event10 - Corsair Corsair STRAFE Gaming Keyboard: client bug: event processing lagging behind by 13ms, your system is too slow
[ 1171.414] (EE) event10 - Corsair Corsair STRAFE Gaming Keyboard: client bug: event processing lagging behind by 14ms, your system is too slow
[ 1176.367] (EE) event10 - Corsair Corsair STRAFE Gaming Keyboard: client bug: event processing lagging behind by 11ms, your system is too slow
[ 1176.367] (EE) event10 - Corsair Corsair STRAFE Gaming Keyboard: WARNING: log rate limit exceeded (5 msgs per 60min). Discarding future messages.
[ 1494.611] (EE) client bug: timer event4 debounce: scheduled expiry is in the past (-6ms), your system is too slow
[ 1494.611] (EE) client bug: timer event4 debounce short: scheduled expiry is in the past (-19ms), your system is too slow
[ 1551.033] (EE) client bug: timer event4 debounce: scheduled expiry is in the past (-8ms), your system is too slow
[ 1556.639] (EE) event4 - Logitech MX Vertical: client bug: event processing lagging behind by 39ms, your system is too slow
[ 1557.929] (EE) client bug: timer event4 debounce short: scheduled expiry is in the past (-10ms), your system is too slow
[ 1622.495] (EE) client bug: timer event4 debounce short: scheduled expiry is in the past (-0ms), your system is too slow
[ 1676.461] (EE) event4 - Logitech MX Vertical: client bug: event processing lagging behind by 34ms, your system is too slow
[ 1688.841] (EE) event4 - Logitech MX Vertical: client bug: event processing lagging behind by 12ms, your system is too slow
[ 1983.128] (EE) event4 - Logitech MX Vertical: client bug: event processing lagging behind by 11ms, your system is too slow
[ 2000.878] (EE) client bug: timer event4 debounce short: scheduled expiry is in the past (-9ms), your system is too slow
[ 2071.194] (EE) event4 - Logitech MX Vertical: client bug: event processing lagging behind by 11ms, your system is too slow
[ 2071.194] (EE) event4 - Logitech MX Vertical: WARNING: log rate limit exceeded (5 msgs per 60min). Discarding future messages.
[ 2136.560] (EE) client bug: timer event4 debounce: scheduled expiry is in the past (-2ms), your system is too slow
[ 2136.560] (EE) client bug: timer event4 debounce short: scheduled expiry is in the past (-15ms), your system is too slow
[ 2180.811] (EE) client bug: timer event4 debounce short: scheduled expiry is in the past (-5ms), your system is too slow
[ 2277.903] (EE) client bug: timer event4 debounce: scheduled expiry is in the past (-1ms), your system is too slow
[ 2277.903] (EE) client bug: timer event4 debounce short: scheduled expiry is in the past (-14ms), your system is too slow
[ 2538.815] (EE) client bug: timer event4 debounce short: scheduled expiry is in the past (-0ms), your system is too slow
[ 2690.908] (EE) client bug: timer event4 debounce: scheduled expiry is in the past (-0ms), your system is too slow
[ 2690.908] (EE) client bug: timer event4 debounce short: scheduled expiry is in the past (-16ms), your system is too slow
[ 2968.879] (EE) client bug: timer event4 debounce: scheduled expiry is in the past (-11ms), your system is too slow
[ 2968.879] (EE) client bug: timer event4 debounce short: scheduled expiry is in the past (-24ms), your system is too slow
[ 2973.089] (EE) client bug: timer event4 debounce: scheduled expiry is in the past (-1ms), your system is too slow
[ 2973.089] (EE) client bug: timer event4 debounce short: scheduled expiry is in the past (-14ms), your system is too slow
[ 3972.029] (EE) client bug: timer event4 debounce: scheduled expiry is in the past (-1ms), your system is too slow
[ 3972.030] (EE) client bug: timer event4 debounce short: scheduled expiry is in the past (-15ms), your system is too slow
[ 5141.156] (EE) event10 - Corsair Corsair STRAFE Gaming Keyboard: client bug: event processing lagging behind by 20ms, your system is too slow
[ 5236.781] (EE) event10 - Corsair Corsair STRAFE Gaming Keyboard: client bug: event processing lagging behind by 24ms, your system is too slow
[ 5335.783] (EE) event10 - Corsair Corsair STRAFE Gaming Keyboard: client bug: event processing lagging behind by 20ms, your system is too slow
[ 5485.980] (EE) event10 - Corsair Corsair STRAFE Gaming Keyboard: client bug: event processing lagging behind by 30ms, your system is too slow
[ 5763.148] (EE) event4 - Logitech MX Vertical: client bug: event processing lagging behind by 36ms, your system is too slow
[ 5880.210] (EE) event10 - Corsair Corsair STRAFE Gaming Keyboard: client bug: event processing lagging behind by 33ms, your system is too slow
[ 5880.210] (EE) event10 - Corsair Corsair STRAFE Gaming Keyboard: WARNING: log rate limit exceeded (5 msgs per 60min). Discarding future messages.
[ 7413.432] (EE) client bug: timer event4 debounce short: scheduled expiry is in the past (-0ms), your system is too slow
[ 7510.552] (EE) client bug: timer event4 debounce: scheduled expiry is in the past (-7ms), your system is too slow
[ 7510.552] (EE) client bug: timer event4 debounce short: scheduled expiry is in the past (-21ms), your system is too slow
[ 7882.594] (EE) client bug: timer event4 debounce: scheduled expiry is in the past (-0ms), your system is too slow
[ 7882.594] (EE) client bug: timer event4 debounce short: scheduled expiry is in the past (-13ms), your system is too slow
[ 8785.810] (EE) event4 - Logitech MX Vertical: client bug: event processing lagging behind by 18ms, your system is too slow
[ 8790.620] (EE) event4 - Logitech MX Vertical: client bug: event processing lagging behind by 14ms, your system is too slow
[ 8793.174] (EE) client bug: timer event4 debounce short: scheduled expiry is in the past (-0ms), your system is too slow
[ 8797.218] (EE) event4 - Logitech MX Vertical: client bug: event processing lagging behind by 12ms, your system is too slow
[ 8799.572] (EE) event4 - Logitech MX Vertical: client bug: event processing lagging behind by 13ms, your system is too slow
[ 8799.572] (EE) event4 - Logitech MX Vertical: WARNING: log rate limit exceeded (5 msgs per 60min). Discarding future messages.
[ 8804.196] (EE) client bug: timer event4 debounce short: scheduled expiry is in the past (-8ms), your system is too slow
[ 9125.088] (EE) event10 - Corsair Corsair STRAFE Gaming Keyboard: client bug: event processing lagging behind by 29ms, your system is too slow
[ 9613.931] (EE) event4 - Logitech MX Vertical: client bug: event processing lagging behind by 18ms, your system is too slow
[ 9770.507] (EE) client bug: timer event4 debounce short: scheduled expiry is in the past (-9ms), your system is too slow
[ 9911.955] (EE) client bug: timer event4 debounce short: scheduled expiry is in the past (-11ms), your system is too slow
[ 10001.295] (EE) client bug: timer event4 debounce: scheduled expiry is in the past (-8ms), your system is too slow
[ 10001.295] (EE) client bug: timer event4 debounce short: scheduled expiry is in the past (-21ms), your system is too slow
[ 10079.842] (EE) client bug: timer event4 debounce: scheduled expiry is in the past (-14ms), your system is too slow
[ 10079.842] (EE) client bug: timer event4 debounce short: scheduled expiry is in the past (-27ms), your system is too slow
[ 10124.962] (EE) client bug: timer event4 debounce short: scheduled expiry is in the past (-1ms), your system is too slow
[ 10126.566] (EE) client bug: timer event4 debounce short: scheduled expiry is in the past (-8ms), your system is too slow
[ 11802.857] (EE) event10 - Corsair Corsair STRAFE Gaming Keyboard: client bug: event processing lagging behind by 11ms, your system is too slow
[ 11888.521] (EE) event10 - Corsair Corsair STRAFE Gaming Keyboard: client bug: event processing lagging behind by 16ms, your system is too slow
[ 11894.242] (EE) event10 - Corsair Corsair STRAFE Gaming Keyboard: client bug: event processing lagging behind by 33ms, your system is too slow
[ 11914.026] (EE) event10 - Corsair Corsair STRAFE Gaming Keyboard: client bug: event processing lagging behind by 27ms, your system is too slow
[ 11914.026] (EE) event10 - Corsair Corsair STRAFE Gaming Keyboard: WARNING: log rate limit exceeded (5 msgs per 60min). Discarding future messages.
[ 12656.544] (EE) event4 - Logitech MX Vertical: client bug: event processing lagging behind by 26ms, your system is too slow
[ 12657.244] (EE) client bug: timer event4 debounce: scheduled expiry is in the past (-1ms), your system is too slow
[ 12657.245] (EE) client bug: timer event4 debounce short: scheduled expiry is in the past (-14ms), your system is too slow
[ 12666.252] (EE) client bug: timer event4 debounce short: scheduled expiry is in the past (-5ms), your system is too slow
[ 12681.644] (EE) client bug: timer event4 debounce short: scheduled expiry is in the past (-7ms), your system is too slow
[ 12737.290] (EE) event10 - Corsair Corsair STRAFE Gaming Keyboard: client bug: event processing lagging behind by 31ms, your system is too slow
[ 12791.673] (EE) event10 - Corsair Corsair STRAFE Gaming Keyboard: client bug: event processing lagging behind by 21ms, your system is too slow
[ 12871.356] (EE) event10 - Corsair Corsair STRAFE Gaming Keyboard: client bug: event processing lagging behind by 14ms, your system is too slow
[ 12879.581] (EE) event10 - Corsair Corsair STRAFE Gaming Keyboard: client bug: event processing lagging behind by 29ms, your system is too slow
[ 12881.422] (EE) event10 - Corsair Corsair STRAFE Gaming Keyboard: client bug: event processing lagging behind by 23ms, your system is too slow
[ 12881.422] (EE) event10 - Corsair Corsair STRAFE Gaming Keyboard: WARNING: log rate limit exceeded (5 msgs per 60min). Discarding future messages.
[ 14773.945] (EE) client bug: timer event4 debounce short: scheduled expiry is in the past (-4ms), your system is too slow
[ 14776.097] (EE) event4 - Logitech MX Vertical: client bug: event processing lagging behind by 31ms, your system is too slow
[ 14801.045] (EE) event4 - Logitech MX Vertical: client bug: event processing lagging behind by 23ms, your system is too slow
[ 15016.173] (EE) event4 - Logitech MX Vertical: client bug: event processing lagging behind by 15ms, your system is too slow
[ 15352.930] (EE) event4 - Logitech MX Vertical: client bug: event processing lagging behind by 21ms, your system is too slow
[ 15469.170] (EE) event4 - Logitech MX Vertical: client bug: event processing lagging behind by 12ms, your system is too slow
[ 15469.170] (EE) event4 - Logitech MX Vertical: WARNING: log rate limit exceeded (5 msgs per 60min). Discarding future messages.
[ 17421.782] (EE) client bug: timer event4 debounce: scheduled expiry is in the past (-5ms), your system is too slow
[ 17421.782] (EE) client bug: timer event4 debounce short: scheduled expiry is in the past (-18ms), your system is too slow
[ 17885.947] (EE) client bug: timer event4 debounce: scheduled expiry is in the past (-7ms), your system is too slow
[ 17885.947] (EE) client bug: timer event4 debounce short: scheduled expiry is in the past (-20ms), your system is too slow
[ 19029.667] (EE) event4 - Logitech MX Vertical: client bug: event processing lagging behind by 22ms, your system is too slow
[ 20215.740] (EE) event4 - Logitech MX Vertical: client bug: event processing lagging behind by 16ms, your system is too slow
[ 20215.740] (EE) client bug: timer event4 debounce short: scheduled expiry is in the past (-4ms), your system is too slow
[ 20217.424] (EE) client bug: timer event4 debounce: scheduled expiry is in the past (-5ms), your system is too slow
[ 20217.424] (EE) client bug: timer event4 debounce short: scheduled expiry is in the past (-18ms), your system is too slow
[ 20219.358] (EE) client bug: timer event4 debounce short: scheduled expiry is in the past (-12ms), your system is too slow
