After updating my Manjaro, my multi monitor setup broke. My secondary monitor is always shown as “off” in nvidia-settings. I can turn it on there and even drag windows to it, but without any gnome gui and with lots of artifacts.
First I thought that it is a kernel/nonfree driver issue, but even with an architect install with the 5.4 kernel, the problem persisted.
Then I found this For multi-monitor setup you will need to specify ForceCompositionPipeline=On
for each display. in the Arch wiki, it sounds like my problem, but I have no idea how to do it.
I can check the option in nvidia-settings and save it to xorg.conf, but to no avail. An the generated xorg.conf shows just my primary device.
Any advice? Thanks!
~ >>> inxi -Gaz
Device-1: Intel vendor: ASUSTeK driver: i915 v: kernel bus ID: 00:02.0
chip ID: 8086:9bc5
Device-2: NVIDIA vendor: Micro-Star MSI driver: nvidia v: 455.45.01
alternate: nouveau,nvidia_drm bus ID: 02:00.0 chip ID: 10de:2206
Display: x11 server: X.org 1.20.10 compositor: gnome-shell v: 3.38.2
driver: modesetting,nvidia alternate: fbdev,intel,nouveau,nv,vesa
OpenGL: renderer: GeForce RTX 3080/PCIe/SSE2 v: 4.6.0 NVIDIA 455.45.01
direct render: Yes
~ >>> mhwd -li [1]
> Installed PCI configs:
NAME VERSION FREEDRIVER TYPE
video-modesetting 2020.01.13 true PCI
video-hybrid-intel-nvidia-prime 2020.11.30 false PCI
~ >>> cat /var/log/Xorg.0.log [1]
[ 2.459] (--) Log file renamed from "/var/log/Xorg.pid-667.log" to "/var/log/Xorg.0.log"
[ 2.459] (WW) Failed to open protocol names file lib/xorg/protocol.txt
[ 2.459]
X.Org X Server 1.20.10
[ 2.459] Build Operating System: Linux Manjaro Linux
[ 2.459] Current Operating System: Linux manjaro 5.9.16-1-MANJARO #1 SMP PREEMPT Mon Dec 21 22:00:46 UTC 2020 x86_64
[ 2.460] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.9-x86_64 root=UUID=27d3e348-51b3-4bb2-9a07-0d98c7e4b4a5 rw quiet splash apparmor=1 security=apparmor udev.log_priority=3
[ 2.460] Build Date: 16 December 2020 10:33:32PM
[ 2.460]
[ 2.460] Current version of pixman: 0.40.0
[ 2.460] Before reporting problems, check http://wiki.x.org
[ 2.460] Markers: (--) probed, (**) from config file, (==) default setting,
[ 2.460] (==) Log file: "/var/log/Xorg.0.log", Time: Sun Jan 3 02:56:11 2021
[ 2.460] (==) Using config directory: "/etc/X11/xorg.conf.d"
[ 2.460] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 2.461] (==) ServerLayout "layout"
[ 2.461] (==) No screen section available. Using defaults.
[ 2.461] (**) |-->Screen "Default Screen Section" (0)
[ 2.461] (**) | |-->Monitor "<default monitor>"
[ 2.461] (==) No monitor specified for screen "Default Screen Section".
[ 2.461] (==) Automatically adding devices
[ 2.461] (==) Automatically enabling devices
[ 2.461] (==) Automatically adding GPU devices
[ 2.461] (==) Automatically binding GPU devices
[ 2.461] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 2.462] (WW) The directory "/usr/share/fonts/OTF" does not exist.
[ 2.462] Entry deleted from font path.
[ 2.462] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[ 2.462] (WW) The directory "/usr/share/fonts/100dpi" does not exist.
[ 2.462] (WW) The directory "/usr/share/fonts/75dpi" does not exist.
[ 2.462] (==) FontPath set to:
/usr/share/fonts/misc,
/usr/share/fonts/TTF
[ 2.462] (==) ModulePath set to "/usr/lib/xorg/modules"
[ 2.462] (II) The server relies on udev to provide the list of input devices.
[ 2.462] (II) Module ABI versions:
[ 2.462] X.Org ANSI C Emulation: 0.4
[ 2.462] X.Org Video Driver: 24.1
[ 2.462] X.Org XInput driver : 24.1
[ 2.462] X.Org Server Extension : 10.0
[ 2.463] (++) using VT number 1
[ 2.463] (II) systemd-logind: took control of session /org/freedesktop/login1/session/_31
[ 2.464] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 2.464] (II) systemd-logind: got fd for /dev/dri/card0 226:0 fd 11 paused 0
[ 2.464] (II) xfree86: Adding drm device (/dev/dri/card1)
[ 2.464] (II) systemd-logind: got fd for /dev/dri/card1 226:1 fd 12 paused 0
[ 2.465] (**) OutputClass "nvidia" ModulePath extended to "/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/xorg/modules"
[ 2.465] (**) OutputClass "nvidia" ModulePath extended to "/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/xorg/modules"
[ 2.466] (--) PCI: (0@0:2:0) 8086:9bc5:1043:8694 rev 5, Mem @ 0x6012000000/16777216, 0x4000000000/268435456, I/O @ 0x00004000/64
[ 2.466] (--) PCI:*(2@0:0:0) 10de:2206:1462:3897 rev 161, Mem @ 0x90000000/16777216, 0x6000000000/268435456, 0x6010000000/33554432, I/O @ 0x00003000/128, BIOS @ 0x????????/524288
[ 2.466] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[ 2.466] (II) LoadModule: "glx"
[ 2.467] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 2.471] (II) Module glx: vendor="X.Org Foundation"
[ 2.471] compiled for 1.20.10, module version = 1.0.0
[ 2.471] ABI class: X.Org Server Extension, version 10.0
[ 2.471] (II) Applying OutputClass "nvidia" to /dev/dri/card0
[ 2.471] loading driver: nvidia
[ 2.471] (II) Applying OutputClass "intel" to /dev/dri/card1
[ 2.471] loading driver: modesetting
[ 2.471] (==) Matched nvidia as autoconfigured driver 0
[ 2.471] (==) Matched nouveau as autoconfigured driver 1
[ 2.471] (==) Matched nv as autoconfigured driver 2
[ 2.471] (==) Matched modesetting as autoconfigured driver 3
[ 2.471] (==) Matched intel as autoconfigured driver 4
[ 2.471] (==) Matched fbdev as autoconfigured driver 5
[ 2.471] (==) Matched vesa as autoconfigured driver 6
[ 2.471] (==) Assigned the driver to the xf86ConfigLayout
[ 2.471] (II) LoadModule: "nvidia"
[ 2.471] (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
[ 2.473] (II) Module nvidia: vendor="NVIDIA Corporation"
[ 2.473] compiled for 1.6.99.901, module version = 1.0.0
[ 2.473] Module class: X.Org Video Driver
[ 2.473] (II) LoadModule: "nouveau"
[ 2.473] (WW) Warning, couldn't open module nouveau
[ 2.473] (EE) Failed to load module "nouveau" (module does not exist, 0)
[ 2.473] (II) LoadModule: "nv"
[ 2.474] (WW) Warning, couldn't open module nv
[ 2.474] (EE) Failed to load module "nv" (module does not exist, 0)
[ 2.474] (II) LoadModule: "modesetting"
[ 2.474] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[ 2.475] (II) Module modesetting: vendor="X.Org Foundation"
[ 2.475] compiled for 1.20.10, module version = 1.20.10
[ 2.475] Module class: X.Org Video Driver
[ 2.475] ABI class: X.Org Video Driver, version 24.1
[ 2.475] (II) LoadModule: "intel"
[ 2.475] (WW) Warning, couldn't open module intel
[ 2.475] (EE) Failed to load module "intel" (module does not exist, 0)
[ 2.475] (II) LoadModule: "fbdev"
[ 2.475] (WW) Warning, couldn't open module fbdev
[ 2.475] (EE) Failed to load module "fbdev" (module does not exist, 0)
[ 2.475] (II) LoadModule: "vesa"
[ 2.475] (WW) Warning, couldn't open module vesa
[ 2.475] (EE) Failed to load module "vesa" (module does not exist, 0)
[ 2.475] (II) NVIDIA dlloader X Driver 455.45.01 Thu Nov 5 23:01:05 UTC 2020
[ 2.476] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[ 2.476] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[ 2.476] (II) systemd-logind: releasing fd for 226:0
[ 2.476] (II) Loading sub module "fb"
[ 2.476] (II) LoadModule: "fb"
[ 2.476] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 2.477] (II) Module fb: vendor="X.Org Foundation"
[ 2.477] compiled for 1.20.10, module version = 1.0.0
[ 2.477] ABI class: X.Org ANSI C Emulation, version 0.4
[ 2.477] (II) Loading sub module "wfb"
[ 2.477] (II) LoadModule: "wfb"
[ 2.477] (II) Loading /usr/lib/xorg/modules/libwfb.so
[ 2.477] (II) Module wfb: vendor="X.Org Foundation"
[ 2.478] ABI class: X.Org ANSI C Emulation, version 0.4
[ 2.478] (II) Loading sub module "ramdac"
[ 2.478] (II) LoadModule: "ramdac"
[ 2.478] (II) Module "ramdac" already built-in
[ 2.618] (WW) Falling back to old probe method for modesetting
[ 2.618] (II) modeset(G0): using drv /dev/dri/card1
[ 2.619] (II) NVIDIA(0): Creating default Display subsection in Screen section
"Default Screen Section" for depth/fbbpp 24/32
[ 2.619] (==) NVIDIA(0): Depth 24, (==) framebuffer bpp 32
[ 2.619] (==) NVIDIA(0): RGB weight 888
[ 2.619] (==) NVIDIA(0): Default visual is TrueColor
[ 2.619] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[ 2.619] (**) Option "AllowNVIDIAGpuScreens"
[ 2.619] (II) Applying OutputClass "nvidia" options to /dev/dri/card0
[ 2.619] (**) NVIDIA(0): Option "AllowEmptyInitialConfiguration"
[ 2.620] (**) NVIDIA(0): Enabling 2D acceleration
[ 2.620] (II) Loading sub module "glxserver_nvidia"
[ 2.620] (II) LoadModule: "glxserver_nvidia"
[ 2.620] (II) Loading /usr/lib/nvidia/xorg/libglxserver_nvidia.so
[ 2.652] (II) Module glxserver_nvidia: vendor="NVIDIA Corporation"
[ 2.652] compiled for 1.6.99.901, module version = 1.0.0
[ 2.652] Module class: X.Org Server Extension
[ 2.652] (II) NVIDIA GLX Module 455.45.01 Thu Nov 5 22:58:18 UTC 2020
[ 2.653] (II) NVIDIA: The X server supports PRIME Render Offload.
[ 3.543] (--) NVIDIA(0): Valid display device(s) on GPU-0 at PCI:2:0:0
[ 3.543] (--) NVIDIA(0): DFP-0
[ 3.543] (--) NVIDIA(0): DFP-1
[ 3.543] (--) NVIDIA(0): DFP-2
[ 3.543] (--) NVIDIA(0): DFP-3
[ 3.543] (--) NVIDIA(0): DFP-4
[ 3.543] (--) NVIDIA(0): DFP-5 (boot)
[ 3.543] (--) NVIDIA(0): DFP-6
[ 3.544] (II) NVIDIA(0): NVIDIA GPU GeForce RTX 3080 (GA102-A) at PCI:2:0:0 (GPU-0)
[ 3.544] (--) NVIDIA(0): Memory: 10485760 kBytes
[ 3.544] (--) NVIDIA(0): VideoBIOS: 94.02.26.88.0d
[ 3.544] (II) NVIDIA(0): Detected PCI Express Link width: 16X
[ 3.544] (--) NVIDIA(GPU-0): DFP-0: disconnected
[ 3.544] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[ 3.544] (--) NVIDIA(GPU-0): DFP-0: 165.0 MHz maximum pixel clock
[ 3.544] (--) NVIDIA(GPU-0): DFP-1: disconnected
[ 3.544] (--) NVIDIA(GPU-0): DFP-1: Internal DisplayPort
[ 3.544] (--) NVIDIA(GPU-0): DFP-1: 2670.0 MHz maximum pixel clock
[ 3.544] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 3.544] (--) NVIDIA(GPU-0): DFP-2: Internal TMDS
[ 3.544] (--) NVIDIA(GPU-0): DFP-2: 165.0 MHz maximum pixel clock
[ 3.544] (--) NVIDIA(GPU-0): Acer XB273K GP (DFP-3): connected
[ 3.544] (--) NVIDIA(GPU-0): Acer XB273K GP (DFP-3): Internal DisplayPort
[ 3.544] (--) NVIDIA(GPU-0): Acer XB273K GP (DFP-3): 2670.0 MHz maximum pixel clock
[ 3.547] (--) NVIDIA(GPU-0): DFP-4: disconnected
[ 3.547] (--) NVIDIA(GPU-0): DFP-4: Internal TMDS
[ 3.547] (--) NVIDIA(GPU-0): DFP-4: 165.0 MHz maximum pixel clock
[ 3.704] (--) NVIDIA(GPU-0): AOC G2460 (DFP-5): connected
[ 3.704] (--) NVIDIA(GPU-0): AOC G2460 (DFP-5): Internal DisplayPort
[ 3.704] (--) NVIDIA(GPU-0): AOC G2460 (DFP-5): 2670.0 MHz maximum pixel clock
[ 3.704] (--) NVIDIA(GPU-0): AOC G2460 (DFP-5): supports NVIDIA 3D Vision stereo.
[ 3.705] (--) NVIDIA(GPU-0): DFP-6: disconnected
[ 3.705] (--) NVIDIA(GPU-0): DFP-6: Internal TMDS
[ 3.705] (--) NVIDIA(GPU-0): DFP-6: 165.0 MHz maximum pixel clock
[ 3.777] (==) NVIDIA(0):
[ 3.777] (==) NVIDIA(0): No modes were requested; the default mode "nvidia-auto-select"
[ 3.777] (==) NVIDIA(0): will be used as the requested mode.
[ 3.778] (II) NVIDIA(0): Validated MetaModes:
[ 3.778] (II) NVIDIA(0): "DFP-5:nvidia-auto-select,DFP-3:nvidia-auto-select"
[ 3.778] (II) NVIDIA(0): Virtual screen size determined to be 5760 x 2160
[ 3.799] (--) NVIDIA(0): DPI set to (92, 91); computed from "UseEdidDpi" X config
[ 3.799] (--) NVIDIA(0): option
[ 3.799] (==) modeset(G0): Depth 24, (==) framebuffer bpp 32
[ 3.799] (==) modeset(G0): RGB weight 888
[ 3.799] (==) modeset(G0): Default visual is TrueColor
[ 3.799] (II) Loading sub module "glamoregl"
[ 3.799] (II) LoadModule: "glamoregl"
[ 3.799] (II) Loading /usr/lib/xorg/modules/libglamoregl.so
[ 3.807] (II) Module glamoregl: vendor="X.Org Foundation"
[ 3.807] compiled for 1.20.10, module version = 1.0.1
[ 3.807] ABI class: X.Org ANSI C Emulation, version 0.4
[ 3.924] (II) modeset(G0): glamor X acceleration enabled on Mesa Intel(R) UHD Graphics 630 (CML GT2)
[ 3.924] (II) modeset(G0): glamor initialized
[ 3.924] (II) modeset(G0): Output DP-1-1 has no monitor section
[ 3.936] (II) modeset(G0): Output HDMI-1-1 has no monitor section
[ 3.947] (II) modeset(G0): Output HDMI-1-2 has no monitor section
[ 3.947] (II) modeset(G0): EDID for output DP-1-1
[ 3.957] (II) modeset(G0): EDID for output HDMI-1-1
[ 3.968] (II) modeset(G0): EDID for output HDMI-1-2
[ 3.968] (==) modeset(G0): Using gamma correction (1.0, 1.0, 1.0)
[ 3.968] (==) modeset(G0): DPI set to (96, 96)
[ 3.968] (II) Loading sub module "fb"
[ 3.968] (II) LoadModule: "fb"
[ 3.968] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 3.968] (II) Module fb: vendor="X.Org Foundation"
[ 3.968] compiled for 1.20.10, module version = 1.0.0
[ 3.968] ABI class: X.Org ANSI C Emulation, version 0.4
[ 3.969] (II) NVIDIA: Using 24576.00 MB of virtual memory for indirect memory
[ 3.969] (II) NVIDIA: access.
[ 3.971] (II) NVIDIA(0): ACPI: failed to connect to the ACPI event daemon; the daemon
[ 3.971] (II) NVIDIA(0): may not be running or the "AcpidSocketPath" X
[ 3.971] (II) NVIDIA(0): configuration option may not be set correctly. When the
[ 3.971] (II) NVIDIA(0): ACPI event daemon is available, the NVIDIA X driver will
[ 3.971] (II) NVIDIA(0): try to use it to receive ACPI event notifications. For
[ 3.971] (II) NVIDIA(0): details, please see the "ConnectToAcpid" and
[ 3.971] (II) NVIDIA(0): "AcpidSocketPath" X configuration options in Appendix B: X
[ 3.971] (II) NVIDIA(0): Config Options in the README.
[ 3.982] (II) NVIDIA(0): Setting mode "DFP-5:nvidia-auto-select,DFP-3:nvidia-auto-select"
[ 4.108] (==) NVIDIA(0): Disabling shared memory pixmaps
[ 4.108] (==) NVIDIA(0): Backing store enabled
[ 4.108] (==) NVIDIA(0): Silken mouse disabled
[ 4.108] (==) NVIDIA(0): DPMS enabled
[ 4.108] (II) Loading sub module "dri2"
[ 4.108] (II) LoadModule: "dri2"
[ 4.108] (II) Module "dri2" already built-in
[ 4.108] (II) NVIDIA(0): [DRI2] Setup complete
[ 4.108] (II) NVIDIA(0): [DRI2] VDPAU driver: nvidia
[ 4.127] (==) modeset(G0): Backing store enabled
[ 4.127] (==) modeset(G0): Silken mouse disabled
[ 4.128] (II) modeset(G0): Initializing kms color map for depth 24, 8 bpc.
[ 4.128] (==) modeset(G0): DPMS enabled
[ 4.128] (II) modeset(G0): [DRI2] Setup complete
[ 4.128] (II) modeset(G0): [DRI2] DRI driver: iris
[ 4.128] (II) modeset(G0): [DRI2] VDPAU driver: va_gl
[ 4.128] (II) Initializing extension Generic Event Extension
[ 4.128] (II) Initializing extension SHAPE
[ 4.128] (II) Initializing extension MIT-SHM
[ 4.128] (II) Initializing extension XInputExtension
[ 4.128] (II) Initializing extension XTEST
[ 4.128] (II) Initializing extension BIG-REQUESTS
[ 4.128] (II) Initializing extension SYNC
[ 4.128] (II) Initializing extension XKEYBOARD
[ 4.128] (II) Initializing extension XC-MISC
[ 4.128] (II) Initializing extension SECURITY
[ 4.128] (II) Initializing extension XFIXES
[ 4.128] (II) Initializing extension RENDER
[ 4.128] (II) Initializing extension RANDR
[ 4.128] (II) Initializing extension COMPOSITE
[ 4.128] (II) Initializing extension DAMAGE
[ 4.128] (II) Initializing extension MIT-SCREEN-SAVER
[ 4.128] (II) Initializing extension DOUBLE-BUFFER
[ 4.128] (II) Initializing extension RECORD
[ 4.128] (II) Initializing extension DPMS
[ 4.128] (II) Initializing extension Present
[ 4.128] (II) Initializing extension DRI3
[ 4.128] (II) Initializing extension X-Resource
[ 4.128] (II) Initializing extension XVideo
[ 4.128] (II) Initializing extension XVideo-MotionCompensation
[ 4.128] (II) Initializing extension GLX
[ 4.128] (II) Indirect GLX disabled.
[ 4.128] (II) GLX: Another vendor is already registered for screen 0
[ 4.128] (II) Initializing extension XFree86-VidModeExtension
[ 4.128] (II) Initializing extension XFree86-DGA
[ 4.128] (II) Initializing extension XFree86-DRI
[ 4.128] (II) Initializing extension DRI2
[ 4.128] (II) Initializing extension NV-GLX
[ 4.128] (II) Initializing extension NV-CONTROL
[ 4.128] (II) Initializing extension XINERAMA
[ 4.129] (II) modeset(G0): Damage tracking initialized
[ 4.201] (II) config/udev: Adding input device Power Button (/dev/input/event2)
[ 4.201] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 4.201] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[ 4.201] (**) Power Button: Applying InputClass "system-keyboard"
[ 4.201] (II) LoadModule: "libinput"
[ 4.201] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[ 4.204] (II) Module libinput: vendor="X.Org Foundation"
[ 4.204] compiled for 1.20.8, module version = 0.30.0
[ 4.204] Module class: X.Org XInput Driver
[ 4.204] ABI class: X.Org XInput driver, version 24.1
[ 4.204] (II) Using input driver 'libinput' for 'Power Button'
[ 4.204] (II) systemd-logind: got fd for /dev/input/event2 13:66 fd 40 paused 0
[ 4.204] (**) Power Button: always reports core events
[ 4.204] (**) Option "Device" "/dev/input/event2"
[ 4.204] (**) Option "_source" "server/udev"
[ 4.208] (II) event2 - Power Button: is tagged by udev as: Keyboard
[ 4.208] (II) event2 - Power Button: device is a keyboard
[ 4.208] (II) event2 - Power Button: device removed
[ 4.208] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input2/event2"
[ 4.208] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[ 4.208] (**) Option "xkb_layout" "de"
[ 4.217] (II) event2 - Power Button: is tagged by udev as: Keyboard
[ 4.217] (II) event2 - Power Button: device is a keyboard
[ 4.218] (II) config/udev: Adding input device Video Bus (/dev/input/event5)
[ 4.218] (**) Video Bus: Applying InputClass "evdev keyboard catchall"
[ 4.218] (**) Video Bus: Applying InputClass "libinput keyboard catchall"
[ 4.218] (**) Video Bus: Applying InputClass "system-keyboard"
[ 4.218] (II) Using input driver 'libinput' for 'Video Bus'
[ 4.218] (II) systemd-logind: got fd for /dev/input/event5 13:69 fd 43 paused 0
[ 4.218] (**) Video Bus: always reports core events
[ 4.218] (**) Option "Device" "/dev/input/event5"
[ 4.218] (**) Option "_source" "server/udev"
[ 4.219] (II) event5 - Video Bus: is tagged by udev as: Keyboard
[ 4.219] (II) event5 - Video Bus: device is a keyboard
[ 4.219] (II) event5 - Video Bus: device removed
[ 4.219] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input5/event5"
[ 4.219] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 7)
[ 4.219] (**) Option "xkb_layout" "de"
[ 4.219] (II) config/udev: Adding input device Power Button (/dev/input/event1)
[ 4.219] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 4.219] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[ 4.219] (**) Power Button: Applying InputClass "system-keyboard"
[ 4.219] (II) Using input driver 'libinput' for 'Power Button'
[ 4.220] (II) systemd-logind: got fd for /dev/input/event1 13:65 fd 44 paused 0
[ 4.220] (**) Power Button: always reports core events
[ 4.220] (**) Option "Device" "/dev/input/event1"
[ 4.220] (**) Option "_source" "server/udev"
[ 4.220] (II) event1 - Power Button: is tagged by udev as: Keyboard
[ 4.220] (II) event1 - Power Button: device is a keyboard
[ 4.220] (II) event1 - Power Button: device removed
[ 4.220] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input1/event1"
[ 4.220] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 8)
[ 4.220] (**) Option "xkb_layout" "de"
[ 4.221] (II) event1 - Power Button: is tagged by udev as: Keyboard
[ 4.221] (II) event1 - Power Button: device is a keyboard
[ 4.221] (II) config/udev: Adding input device Sleep Button (/dev/input/event0)
[ 4.221] (**) Sleep Button: Applying InputClass "evdev keyboard catchall"
[ 4.221] (**) Sleep Button: Applying InputClass "libinput keyboard catchall"
[ 4.221] (**) Sleep Button: Applying InputClass "system-keyboard"
[ 4.221] (II) Using input driver 'libinput' for 'Sleep Button'
[ 4.222] (II) systemd-logind: got fd for /dev/input/event0 13:64 fd 45 paused 0
[ 4.222] (**) Sleep Button: always reports core events
[ 4.222] (**) Option "Device" "/dev/input/event0"
[ 4.222] (**) Option "_source" "server/udev"
[ 4.222] (II) event0 - Sleep Button: is tagged by udev as: Keyboard
[ 4.222] (II) event0 - Sleep Button: device is a keyboard
[ 4.222] (II) event0 - Sleep Button: device removed
[ 4.222] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input0/event0"
[ 4.222] (II) XINPUT: Adding extended input device "Sleep Button" (type: KEYBOARD, id 9)
[ 4.222] (**) Option "xkb_layout" "de"
[ 4.223] (II) event0 - Sleep Button: is tagged by udev as: Keyboard
[ 4.223] (II) event0 - Sleep Button: device is a keyboard
[ 4.223] (II) config/udev: Adding input device HDA Intel PCH Line Out Surround (/dev/input/event10)
[ 4.223] (II) No input driver specified, ignoring this device.
[ 4.223] (II) This device may have been added with another device file.
[ 4.223] (II) config/udev: Adding input device HDA Intel PCH Line Out CLFE (/dev/input/event11)
[ 4.224] (II) config/udev: Adding input device HDA Intel PCH Front Headphone (/dev/input/event12)
[ 4.224] (II) No input driver specified, ignoring this device.
[ 4.224] (II) This device may have been added with another device file.
[ 4.224] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=3 (/dev/input/event13)
[ 4.224] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=7 (/dev/input/event14)
[ 4.224] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=8 (/dev/input/event15)
[ 4.224] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=9 (/dev/input/event16)
[ 4.224] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=10 (/dev/input/event17)
[ 4.225] (II) config/udev: Adding input device HDA Intel PCH Front Mic (/dev/input/event6)
[ 4.225] (II) No input driver specified, ignoring this device.
[ 4.225] (II) This device may have been added with another device file.
[ 4.225] (II) config/udev: Adding input device HDA Intel PCH Rear Mic (/dev/input/event7)
[ 4.225] (II) config/udev: Adding input device HDA Intel PCH Line (/dev/input/event8)
[ 4.225] (II) config/udev: Adding input device HDA Intel PCH Line Out Front (/dev/input/event9)
[ 4.225] (II) config/udev: Adding input device Eee PC WMI hotkeys (/dev/input/event4)
[ 4.225] (**) Eee PC WMI hotkeys: Applying InputClass "evdev keyboard catchall"
[ 4.225] (**) Eee PC WMI hotkeys: Applying InputClass "libinput keyboard catchall"
[ 4.225] (**) Eee PC WMI hotkeys: Applying InputClass "system-keyboard"
[ 4.225] (II) Using input driver 'libinput' for 'Eee PC WMI hotkeys'
[ 4.226] (II) systemd-logind: got fd for /dev/input/event4 13:68 fd 46 paused 0
[ 4.226] (**) Eee PC WMI hotkeys: always reports core events
[ 4.226] (**) Option "Device" "/dev/input/event4"
[ 4.226] (**) Option "_source" "server/udev"
[ 4.226] (II) event4 - Eee PC WMI hotkeys: is tagged by udev as: Keyboard
[ 4.226] (II) event4 - Eee PC WMI hotkeys: device is a keyboard
[ 4.226] (II) event4 - Eee PC WMI hotkeys: device removed
[ 4.226] (**) Option "config_info" "udev:/sys/devices/platform/eeepc-wmi/input/input4/event4"
[ 4.226] (II) XINPUT: Adding extended input device "Eee PC WMI hotkeys" (type: KEYBOARD, id 10)
[ 4.226] (**) Option "xkb_layout" "de"
[ 4.227] (II) event4 - Eee PC WMI hotkeys: is tagged by udev as: Keyboard
[ 4.227] (II) event4 - Eee PC WMI hotkeys: device is a keyboard
[ 4.227] (II) config/udev: Adding input device PC Speaker (/dev/input/event3)
[ 4.227] (II) No input driver specified, ignoring this device.
[ 4.227] (II) This device may have been added with another device file.
[ 4.229] (--) NVIDIA(GPU-0): Acer XB273K GP (DFP-3): connected
[ 4.229] (--) NVIDIA(GPU-0): Acer XB273K GP (DFP-3): Internal DisplayPort
[ 4.229] (--) NVIDIA(GPU-0): Acer XB273K GP (DFP-3): 2670.0 MHz maximum pixel clock
[ 4.229] (--) NVIDIA(GPU-0): AOC G2460 (DFP-5): connected
[ 4.229] (--) NVIDIA(GPU-0): AOC G2460 (DFP-5): Internal DisplayPort
[ 4.229] (--) NVIDIA(GPU-0): AOC G2460 (DFP-5): 2670.0 MHz maximum pixel clock
[ 4.229] (--) NVIDIA(GPU-0): AOC G2460 (DFP-5): supports NVIDIA 3D Vision stereo.
[ 4.229] (II) config/udev: Adding input device HDA Intel PCH Line Out Surround (/dev/input/event10)
[ 4.229] (II) No input driver specified, ignoring this device.
[ 4.229] (II) This device may have been added with another device file.
[ 4.230] (II) config/udev: Adding input device HDA Intel PCH Line (/dev/input/event8)
[ 4.230] (II) No input driver specified, ignoring this device.
[ 4.230] (II) This device may have been added with another device file.
[ 4.230] (II) config/udev: Adding input device HDA Intel PCH Line Out Front (/dev/input/event9)
[ 4.230] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=7 (/dev/input/event14)
[ 4.230] (II) config/udev: Adding input device HDA Intel PCH Front Headphone (/dev/input/event12)
[ 4.230] (II) config/udev: Adding input device HDA Intel PCH Rear Mic (/dev/input/event7)
[ 4.230] (II) config/udev: Adding input device HDA Intel PCH Front Mic (/dev/input/event6)
[ 4.230] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=3 (/dev/input/event13)
[ 4.230] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=9 (/dev/input/event16)
[ 4.231] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=10 (/dev/input/event17)
[ 4.231] (II) No input driver specified, ignoring this device.
[ 4.231] (II) This device may have been added with another device file.
[ 4.231] (II) config/udev: Adding input device HDA Intel PCH Line Out CLFE (/dev/input/event11)
[ 4.231] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=8 (/dev/input/event15)
[ 4.511] (--) NVIDIA(GPU-0): DFP-0: disconnected
[ 4.511] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[ 4.511] (--) NVIDIA(GPU-0): DFP-0: 165.0 MHz maximum pixel clock
[ 4.511] (--) NVIDIA(GPU-0): DFP-1: disconnected
[ 4.511] (--) NVIDIA(GPU-0): DFP-1: Internal DisplayPort
[ 4.511] (--) NVIDIA(GPU-0): DFP-1: 2670.0 MHz maximum pixel clock
[ 4.511] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 4.511] (--) NVIDIA(GPU-0): DFP-2: Internal TMDS
[ 4.511] (--) NVIDIA(GPU-0): DFP-2: 165.0 MHz maximum pixel clock
[ 4.511] (--) NVIDIA(GPU-0): Acer XB273K GP (DFP-3): connected
[ 4.511] (--) NVIDIA(GPU-0): Acer XB273K GP (DFP-3): Internal DisplayPort
[ 4.511] (--) NVIDIA(GPU-0): Acer XB273K GP (DFP-3): 2670.0 MHz maximum pixel clock
[ 4.514] (--) NVIDIA(GPU-0): DFP-4: disconnected
[ 4.514] (--) NVIDIA(GPU-0): DFP-4: Internal TMDS
[ 4.514] (--) NVIDIA(GPU-0): DFP-4: 165.0 MHz maximum pixel clock
[ 4.514] (--) NVIDIA(GPU-0): AOC G2460 (DFP-5): connected
[ 4.514] (--) NVIDIA(GPU-0): AOC G2460 (DFP-5): Internal DisplayPort
[ 4.514] (--) NVIDIA(GPU-0): AOC G2460 (DFP-5): 2670.0 MHz maximum pixel clock
[ 4.514] (--) NVIDIA(GPU-0): AOC G2460 (DFP-5): supports NVIDIA 3D Vision stereo.
[ 4.515] (--) NVIDIA(GPU-0): DFP-6: disconnected
[ 4.515] (--) NVIDIA(GPU-0): DFP-6: Internal TMDS
[ 4.515] (--) NVIDIA(GPU-0): DFP-6: 165.0 MHz maximum pixel clock
[ 4.516] (--) NVIDIA(GPU-0): DFP-0: disconnected
[ 4.516] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[ 4.516] (--) NVIDIA(GPU-0): DFP-0: 165.0 MHz maximum pixel clock
[ 4.516] (--) NVIDIA(GPU-0): DFP-1: disconnected
[ 4.516] (--) NVIDIA(GPU-0): DFP-1: Internal DisplayPort
[ 4.516] (--) NVIDIA(GPU-0): DFP-1: 2670.0 MHz maximum pixel clock
[ 4.516] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 4.516] (--) NVIDIA(GPU-0): DFP-2: Internal TMDS
[ 4.516] (--) NVIDIA(GPU-0): DFP-2: 165.0 MHz maximum pixel clock
[ 4.516] (--) NVIDIA(GPU-0): Acer XB273K GP (DFP-3): connected
[ 4.516] (--) NVIDIA(GPU-0): Acer XB273K GP (DFP-3): Internal DisplayPort
[ 4.516] (--) NVIDIA(GPU-0): Acer XB273K GP (DFP-3): 2670.0 MHz maximum pixel clock
[ 4.518] (--) NVIDIA(GPU-0): DFP-4: disconnected
[ 4.518] (--) NVIDIA(GPU-0): DFP-4: Internal TMDS
[ 4.518] (--) NVIDIA(GPU-0): DFP-4: 165.0 MHz maximum pixel clock
[ 4.518] (--) NVIDIA(GPU-0): AOC G2460 (DFP-5): connected
[ 4.518] (--) NVIDIA(GPU-0): AOC G2460 (DFP-5): Internal DisplayPort
[ 4.518] (--) NVIDIA(GPU-0): AOC G2460 (DFP-5): 2670.0 MHz maximum pixel clock
[ 4.518] (--) NVIDIA(GPU-0): AOC G2460 (DFP-5): supports NVIDIA 3D Vision stereo.
[ 4.520] (--) NVIDIA(GPU-0): DFP-6: disconnected
[ 4.520] (--) NVIDIA(GPU-0): DFP-6: Internal TMDS
[ 4.520] (--) NVIDIA(GPU-0): DFP-6: 165.0 MHz maximum pixel clock
[ 4.588] (II) NVIDIA(0): Setting mode "DP-4: nvidia-auto-select @1920x1080 +0+0 {ViewPortIn=1920x1080, ViewPortOut=1920x1080+0+0}"
[ 4.916] (II) config/udev: Adding input device SteelSeries SteelSeries Apex Raw Gaming Keyboard (/dev/input/event22)
[ 4.916] (**) SteelSeries SteelSeries Apex Raw Gaming Keyboard: Applying InputClass "evdev keyboard catchall"
[ 4.916] (**) SteelSeries SteelSeries Apex Raw Gaming Keyboard: Applying InputClass "libinput keyboard catchall"
[ 4.916] (**) SteelSeries SteelSeries Apex Raw Gaming Keyboard: Applying InputClass "system-keyboard"
[ 4.916] (II) Using input driver 'libinput' for 'SteelSeries SteelSeries Apex Raw Gaming Keyboard'
[ 4.917] (II) systemd-logind: got fd for /dev/input/event22 13:86 fd 48 paused 0
[ 4.917] (**) SteelSeries SteelSeries Apex Raw Gaming Keyboard: always reports core events
[ 4.917] (**) Option "Device" "/dev/input/event22"
[ 4.917] (**) Option "_source" "server/udev"
[ 4.918] (II) event22 - SteelSeries SteelSeries Apex Raw Gaming Keyboard: is tagged by udev as: Keyboard
[ 4.918] (II) event22 - SteelSeries SteelSeries Apex Raw Gaming Keyboard: device is a keyboard
[ 4.918] (II) event22 - SteelSeries SteelSeries Apex Raw Gaming Keyboard: device removed
[ 4.918] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-2/1-2:1.1/0003:1038:1200.0004/input/input24/event22"
[ 4.918] (II) XINPUT: Adding extended input device "SteelSeries SteelSeries Apex Raw Gaming Keyboard" (type: KEYBOARD, id 11)
[ 4.918] (**) Option "xkb_layout" "de"
[ 4.919] (II) event22 - SteelSeries SteelSeries Apex Raw Gaming Keyboard: is tagged by udev as: Keyboard
[ 4.919] (II) event22 - SteelSeries SteelSeries Apex Raw Gaming Keyboard: device is a keyboard
[ 4.924] (II) config/udev: Adding input device SteelSeries SteelSeries Apex Raw Gaming Keyboard (/dev/input/event23)
[ 4.924] (**) SteelSeries SteelSeries Apex Raw Gaming Keyboard: Applying InputClass "evdev keyboard catchall"
[ 4.924] (**) SteelSeries SteelSeries Apex Raw Gaming Keyboard: Applying InputClass "libinput keyboard catchall"
[ 4.924] (**) SteelSeries SteelSeries Apex Raw Gaming Keyboard: Applying InputClass "system-keyboard"
[ 4.924] (II) Using input driver 'libinput' for 'SteelSeries SteelSeries Apex Raw Gaming Keyboard'
[ 4.925] (II) systemd-logind: got fd for /dev/input/event23 13:87 fd 49 paused 0
[ 4.925] (**) SteelSeries SteelSeries Apex Raw Gaming Keyboard: always reports core events
[ 4.925] (**) Option "Device" "/dev/input/event23"
[ 4.925] (**) Option "_source" "server/udev"
[ 4.925] (II) event23 - SteelSeries SteelSeries Apex Raw Gaming Keyboard: is tagged by udev as: Keyboard
[ 4.925] (II) event23 - SteelSeries SteelSeries Apex Raw Gaming Keyboard: device is a keyboard
[ 4.926] (II) event23 - SteelSeries SteelSeries Apex Raw Gaming Keyboard: device removed
[ 4.926] (II) libinput: SteelSeries SteelSeries Apex Raw Gaming Keyboard: needs a virtual subdevice
[ 4.926] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-2/1-2:1.2/0003:1038:1200.0005/input/input25/event23"
[ 4.926] (II) XINPUT: Adding extended input device "SteelSeries SteelSeries Apex Raw Gaming Keyboard" (type: MOUSE, id 12)
[ 4.926] (**) Option "AccelerationScheme" "none"
[ 4.926] (**) SteelSeries SteelSeries Apex Raw Gaming Keyboard: (accel) selected scheme none/0
[ 4.926] (**) SteelSeries SteelSeries Apex Raw Gaming Keyboard: (accel) acceleration factor: 2.000
[ 4.926] (**) SteelSeries SteelSeries Apex Raw Gaming Keyboard: (accel) acceleration threshold: 4
[ 4.926] (II) event23 - SteelSeries SteelSeries Apex Raw Gaming Keyboard: is tagged by udev as: Keyboard
[ 4.926] (II) event23 - SteelSeries SteelSeries Apex Raw Gaming Keyboard: device is a keyboard
[ 4.926] (**) SteelSeries SteelSeries Apex Raw Gaming Keyboard: Applying InputClass "evdev keyboard catchall"
[ 4.926] (**) SteelSeries SteelSeries Apex Raw Gaming Keyboard: Applying InputClass "libinput keyboard catchall"
[ 4.926] (**) SteelSeries SteelSeries Apex Raw Gaming Keyboard: Applying InputClass "system-keyboard"
[ 4.926] (II) Using input driver 'libinput' for 'SteelSeries SteelSeries Apex Raw Gaming Keyboard'
[ 4.926] (II) systemd-logind: returning pre-existing fd for /dev/input/event23 13:87
[ 4.926] (**) SteelSeries SteelSeries Apex Raw Gaming Keyboard: always reports core events
[ 4.926] (**) Option "Device" "/dev/input/event23"
[ 4.926] (**) Option "_source" "_driver/libinput"
[ 4.926] (II) libinput: SteelSeries SteelSeries Apex Raw Gaming Keyboard: is a virtual subdevice
[ 4.927] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-2/1-2:1.2/0003:1038:1200.0005/input/input25/event23"
[ 4.927] (II) XINPUT: Adding extended input device "SteelSeries SteelSeries Apex Raw Gaming Keyboard" (type: KEYBOARD, id 13)
[ 4.927] (**) Option "xkb_layout" "de"
[ 4.934] (II) config/udev: Adding input device Logitech Gaming Mouse G302 Consumer Control (/dev/input/event20)
[ 4.934] (**) Logitech Gaming Mouse G302 Consumer Control: Applying InputClass "evdev keyboard catchall"
[ 4.934] (**) Logitech Gaming Mouse G302 Consumer Control: Applying InputClass "libinput keyboard catchall"
[ 4.934] (**) Logitech Gaming Mouse G302 Consumer Control: Applying InputClass "system-keyboard"
[ 4.934] (II) Using input driver 'libinput' for 'Logitech Gaming Mouse G302 Consumer Control'
[ 4.935] (II) systemd-logind: got fd for /dev/input/event20 13:84 fd 50 paused 0
[ 4.935] (**) Logitech Gaming Mouse G302 Consumer Control: always reports core events
[ 4.935] (**) Option "Device" "/dev/input/event20"
[ 4.935] (**) Option "_source" "server/udev"
[ 4.936] (II) event20 - Logitech Gaming Mouse G302 Consumer Control: is tagged by udev as: Keyboard
[ 4.936] (II) event20 - Logitech Gaming Mouse G302 Consumer Control: device is a keyboard
[ 4.937] (II) event20 - Logitech Gaming Mouse G302 Consumer Control: device removed
[ 4.937] (II) libinput: Logitech Gaming Mouse G302 Consumer Control: needs a virtual subdevice
[ 4.937] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1:1.1/0003:046D:C07F.0002/input/input20/event20"
[ 4.937] (II) XINPUT: Adding extended input device "Logitech Gaming Mouse G302 Consumer Control" (type: MOUSE, id 14)
[ 4.937] (**) Option "AccelerationScheme" "none"
[ 4.937] (**) Logitech Gaming Mouse G302 Consumer Control: (accel) selected scheme none/0
[ 4.937] (**) Logitech Gaming Mouse G302 Consumer Control: (accel) acceleration factor: 2.000
[ 4.937] (**) Logitech Gaming Mouse G302 Consumer Control: (accel) acceleration threshold: 4
[ 4.937] (II) event20 - Logitech Gaming Mouse G302 Consumer Control: is tagged by udev as: Keyboard
[ 4.937] (II) event20 - Logitech Gaming Mouse G302 Consumer Control: device is a keyboard
[ 4.937] (**) Logitech Gaming Mouse G302 Consumer Control: Applying InputClass "evdev keyboard catchall"
[ 4.937] (**) Logitech Gaming Mouse G302 Consumer Control: Applying InputClass "libinput keyboard catchall"
[ 4.937] (**) Logitech Gaming Mouse G302 Consumer Control: Applying InputClass "system-keyboard"
[ 4.937] (II) Using input driver 'libinput' for 'Logitech Gaming Mouse G302 Consumer Control'
[ 4.938] (II) systemd-logind: returning pre-existing fd for /dev/input/event20 13:84
[ 4.938] (**) Logitech Gaming Mouse G302 Consumer Control: always reports core events
[ 4.938] (**) Option "Device" "/dev/input/event20"
[ 4.938] (**) Option "_source" "_driver/libinput"
[ 4.938] (II) libinput: Logitech Gaming Mouse G302 Consumer Control: is a virtual subdevice
[ 4.938] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1:1.1/0003:046D:C07F.0002/input/input20/event20"
[ 4.938] (II) XINPUT: Adding extended input device "Logitech Gaming Mouse G302 Consumer Control" (type: KEYBOARD, id 15)
[ 4.938] (**) Option "xkb_layout" "de"
[ 4.938] (II) config/udev: Adding input device Logitech Gaming Mouse G302 Keyboard (/dev/input/event19)
[ 4.938] (**) Logitech Gaming Mouse G302 Keyboard: Applying InputClass "evdev keyboard catchall"
[ 4.938] (**) Logitech Gaming Mouse G302 Keyboard: Applying InputClass "libinput keyboard catchall"
[ 4.938] (**) Logitech Gaming Mouse G302 Keyboard: Applying InputClass "system-keyboard"
[ 4.938] (II) Using input driver 'libinput' for 'Logitech Gaming Mouse G302 Keyboard'
[ 4.938] (II) systemd-logind: got fd for /dev/input/event19 13:83 fd 51 paused 0
[ 4.938] (**) Logitech Gaming Mouse G302 Keyboard: always reports core events
[ 4.938] (**) Option "Device" "/dev/input/event19"
[ 4.938] (**) Option "_source" "server/udev"
[ 4.939] (II) event19 - Logitech Gaming Mouse G302 Keyboard: is tagged by udev as: Keyboard
[ 4.939] (II) event19 - Logitech Gaming Mouse G302 Keyboard: device is a keyboard
[ 4.939] (II) event19 - Logitech Gaming Mouse G302 Keyboard: device removed
[ 4.939] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1:1.1/0003:046D:C07F.0002/input/input19/event19"
[ 4.939] (II) XINPUT: Adding extended input device "Logitech Gaming Mouse G302 Keyboard" (type: KEYBOARD, id 16)
[ 4.939] (**) Option "xkb_layout" "de"
[ 4.940] (II) event19 - Logitech Gaming Mouse G302 Keyboard: is tagged by udev as: Keyboard
[ 4.940] (II) event19 - Logitech Gaming Mouse G302 Keyboard: device is a keyboard
[ 4.940] (II) config/udev: Adding input device Logitech Gaming Mouse G302 System Control (/dev/input/event21)
[ 4.940] (**) Logitech Gaming Mouse G302 System Control: Applying InputClass "evdev keyboard catchall"
[ 4.940] (**) Logitech Gaming Mouse G302 System Control: Applying InputClass "libinput keyboard catchall"
[ 4.940] (**) Logitech Gaming Mouse G302 System Control: Applying InputClass "system-keyboard"
[ 4.940] (II) Using input driver 'libinput' for 'Logitech Gaming Mouse G302 System Control'
[ 4.941] (II) systemd-logind: got fd for /dev/input/event21 13:85 fd 52 paused 0
[ 4.941] (**) Logitech Gaming Mouse G302 System Control: always reports core events
[ 4.941] (**) Option "Device" "/dev/input/event21"
[ 4.941] (**) Option "_source" "server/udev"
[ 4.941] (II) event21 - Logitech Gaming Mouse G302 System Control: is tagged by udev as: Keyboard
[ 4.942] (II) event21 - Logitech Gaming Mouse G302 System Control: device is a keyboard
[ 4.942] (II) event21 - Logitech Gaming Mouse G302 System Control: device removed
[ 4.942] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1:1.1/0003:046D:C07F.0002/input/input21/event21"
[ 4.942] (II) XINPUT: Adding extended input device "Logitech Gaming Mouse G302 System Control" (type: KEYBOARD, id 17)
[ 4.942] (**) Option "xkb_layout" "de"
[ 4.942] (II) event21 - Logitech Gaming Mouse G302 System Control: is tagged by udev as: Keyboard
[ 5.031] (II) config/udev: Adding input device Logitech Gaming Mouse G302 (/dev/input/event18)
[ 5.031] (**) Logitech Gaming Mouse G302: Applying InputClass "evdev pointer catchall"
[ 5.031] (**) Logitech Gaming Mouse G302: Applying InputClass "libinput pointer catchall"
[ 5.031] (II) Using input driver 'libinput' for 'Logitech Gaming Mouse G302'
[ 5.085] (II) systemd-logind: got fd for /dev/input/event18 13:82 fd 55 paused 0
[ 5.085] (**) Logitech Gaming Mouse G302: always reports core events
[ 5.085] (**) Option "Device" "/dev/input/event18"
[ 5.085] (**) Option "_source" "server/udev"
[ 5.086] (II) event18 - Logitech Gaming Mouse G302: is tagged by udev as: Mouse
[ 5.086] (II) event18 - Logitech Gaming Mouse G302: device is a pointer
[ 5.086] (II) event18 - Logitech Gaming Mouse G302: device removed
[ 5.086] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1:1.0/0003:046D:C07F.0001/input/input18/event18"
[ 5.086] (II) XINPUT: Adding extended input device "Logitech Gaming Mouse G302" (type: MOUSE, id 18)
[ 5.086] (**) Option "AccelerationScheme" "none"
[ 5.086] (**) Logitech Gaming Mouse G302: (accel) selected scheme none/0
[ 5.086] (**) Logitech Gaming Mouse G302: (accel) acceleration factor: 2.000
[ 5.086] (**) Logitech Gaming Mouse G302: (accel) acceleration threshold: 4
[ 5.087] (II) event18 - Logitech Gaming Mouse G302: is tagged by udev as: Mouse
[ 5.087] (II) event18 - Logitech Gaming Mouse G302: device is a pointer
[ 5.087] (II) config/udev: Adding input device Logitech Gaming Mouse G302 (/dev/input/mouse0)
[ 5.087] (II) No input driver specified, ignoring this device.
[ 5.087] (II) This device may have been added with another device file.
[ 5.226] (--) NVIDIA(GPU-0): DFP-0: disconnected
[ 5.226] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[ 5.226] (--) NVIDIA(GPU-0): DFP-0: 165.0 MHz maximum pixel clock
[ 5.226] (--) NVIDIA(GPU-0): DFP-1: disconnected
[ 5.226] (--) NVIDIA(GPU-0): DFP-1: Internal DisplayPort
[ 5.226] (--) NVIDIA(GPU-0): DFP-1: 2670.0 MHz maximum pixel clock
[ 5.226] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 5.226] (--) NVIDIA(GPU-0): DFP-2: Internal TMDS
[ 5.226] (--) NVIDIA(GPU-0): DFP-2: 165.0 MHz maximum pixel clock
[ 5.227] (--) NVIDIA(GPU-0): Acer XB273K GP (DFP-3): connected
[ 5.227] (--) NVIDIA(GPU-0): Acer XB273K GP (DFP-3): Internal DisplayPort
[ 5.227] (--) NVIDIA(GPU-0): Acer XB273K GP (DFP-3): 2670.0 MHz maximum pixel clock
[ 5.229] (--) NVIDIA(GPU-0): DFP-4: disconnected
[ 5.229] (--) NVIDIA(GPU-0): DFP-4: Internal TMDS
[ 5.229] (--) NVIDIA(GPU-0): DFP-4: 165.0 MHz maximum pixel clock
[ 5.229] (--) NVIDIA(GPU-0): AOC G2460 (DFP-5): connected
[ 5.229] (--) NVIDIA(GPU-0): AOC G2460 (DFP-5): Internal DisplayPort
[ 5.229] (--) NVIDIA(GPU-0): AOC G2460 (DFP-5): 2670.0 MHz maximum pixel clock
[ 5.229] (--) NVIDIA(GPU-0): AOC G2460 (DFP-5): supports NVIDIA 3D Vision stereo.
[ 5.231] (--) NVIDIA(GPU-0): DFP-6: disconnected
[ 5.231] (--) NVIDIA(GPU-0): DFP-6: Internal TMDS
[ 5.231] (--) NVIDIA(GPU-0): DFP-6: 165.0 MHz maximum pixel clock
[ 5.231] (--) NVIDIA(GPU-0): DFP-0: disconnected
[ 5.231] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[ 5.231] (--) NVIDIA(GPU-0): DFP-0: 165.0 MHz maximum pixel clock
[ 5.231] (--) NVIDIA(GPU-0): DFP-1: disconnected
[ 5.231] (--) NVIDIA(GPU-0): DFP-1: Internal DisplayPort
[ 5.231] (--) NVIDIA(GPU-0): DFP-1: 2670.0 MHz maximum pixel clock
[ 5.231] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 5.231] (--) NVIDIA(GPU-0): DFP-2: Internal TMDS
[ 5.231] (--) NVIDIA(GPU-0): DFP-2: 165.0 MHz maximum pixel clock
[ 5.231] (--) NVIDIA(GPU-0): Acer XB273K GP (DFP-3): connected
[ 5.231] (--) NVIDIA(GPU-0): Acer XB273K GP (DFP-3): Internal DisplayPort
[ 5.231] (--) NVIDIA(GPU-0): Acer XB273K GP (DFP-3): 2670.0 MHz maximum pixel clock
[ 5.233] (--) NVIDIA(GPU-0): DFP-4: disconnected
[ 5.233] (--) NVIDIA(GPU-0): DFP-4: Internal TMDS
[ 5.233] (--) NVIDIA(GPU-0): DFP-4: 165.0 MHz maximum pixel clock
[ 5.234] (--) NVIDIA(GPU-0): AOC G2460 (DFP-5): connected
[ 5.234] (--) NVIDIA(GPU-0): AOC G2460 (DFP-5): Internal DisplayPort
[ 5.234] (--) NVIDIA(GPU-0): AOC G2460 (DFP-5): 2670.0 MHz maximum pixel clock
[ 5.234] (--) NVIDIA(GPU-0): AOC G2460 (DFP-5): supports NVIDIA 3D Vision stereo.
[ 5.235] (--) NVIDIA(GPU-0): DFP-6: disconnected
[ 5.235] (--) NVIDIA(GPU-0): DFP-6: Internal TMDS
[ 5.235] (--) NVIDIA(GPU-0): DFP-6: 165.0 MHz maximum pixel clock
[ 7.018] (II) config/udev: Adding input device C505 HD Webcam (/dev/input/event24)
[ 7.018] (**) C505 HD Webcam: Applying InputClass "evdev keyboard catchall"
[ 7.018] (**) C505 HD Webcam: Applying InputClass "libinput keyboard catchall"
[ 7.018] (**) C505 HD Webcam: Applying InputClass "system-keyboard"
[ 7.018] (II) Using input driver 'libinput' for 'C505 HD Webcam'
[ 7.018] (II) systemd-logind: got fd for /dev/input/event24 13:88 fd 62 paused 0
[ 7.018] (**) C505 HD Webcam: always reports core events
[ 7.018] (**) Option "Device" "/dev/input/event24"
[ 7.018] (**) Option "_source" "server/udev"
[ 7.019] (II) event24 - C505 HD Webcam: is tagged by udev as: Keyboard
[ 7.019] (II) event24 - C505 HD Webcam: device is a keyboard
[ 7.019] (II) event24 - C505 HD Webcam: device removed
[ 7.019] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-3/1-3:1.0/input/input26/event24"
[ 7.019] (II) XINPUT: Adding extended input device "C505 HD Webcam" (type: KEYBOARD, id 19)
[ 7.019] (**) Option "xkb_layout" "de"
[ 7.020] (II) event24 - C505 HD Webcam: is tagged by udev as: Keyboard
[ 7.020] (II) event24 - C505 HD Webcam: device is a keyboard
[ 40.824] (**) Option "fd" "40"
[ 40.824] (II) event2 - Power Button: device removed
[ 40.824] (**) Option "fd" "43"
[ 40.824] (II) event5 - Video Bus: device removed
[ 40.824] (**) Option "fd" "44"
[ 40.824] (II) event1 - Power Button: device removed
[ 40.825] (**) Option "fd" "45"
[ 40.825] (II) event0 - Sleep Button: device removed
[ 40.825] (**) Option "fd" "46"
[ 40.825] (II) event4 - Eee PC WMI hotkeys: device removed
[ 40.825] (**) Option "fd" "48"
[ 40.825] (II) event22 - SteelSeries SteelSeries Apex Raw Gaming Keyboard: device removed
[ 40.825] (**) Option "fd" "49"
[ 40.825] (II) event23 - SteelSeries SteelSeries Apex Raw Gaming Keyboard: device removed
[ 40.825] (**) Option "fd" "50"
[ 40.825] (II) event20 - Logitech Gaming Mouse G302 Consumer Control: device removed
[ 40.825] (**) Option "fd" "51"
[ 40.825] (II) event19 - Logitech Gaming Mouse G302 Keyboard: device removed
[ 40.825] (**) Option "fd" "52"
[ 40.825] (II) event21 - Logitech Gaming Mouse G302 System Control: device removed
[ 40.825] (**) Option "fd" "55"
[ 40.825] (II) event18 - Logitech Gaming Mouse G302: device removed
[ 40.825] (**) Option "fd" "62"
[ 40.825] (II) event24 - C505 HD Webcam: device removed
[ 40.954] (II) systemd-logind: got pause for 13:87
[ 40.954] (II) systemd-logind: got pause for 13:64
[ 40.954] (II) systemd-logind: got pause for 13:85
[ 40.954] (II) systemd-logind: got pause for 13:65
[ 40.954] (II) systemd-logind: got pause for 13:86
[ 40.954] (II) systemd-logind: got pause for 13:68
[ 40.954] (II) systemd-logind: got pause for 226:1
[ 40.954] (II) systemd-logind: got pause for 13:82
[ 40.954] (II) systemd-logind: got pause for 13:66
[ 40.955] (II) systemd-logind: got pause for 13:88
[ 40.955] (II) systemd-logind: got pause for 13:83
[ 40.955] (II) systemd-logind: got pause for 13:84
[ 40.955] (II) systemd-logind: got pause for 13:69
[ 43.470] (II) UnloadModule: "libinput"
[ 43.470] (II) systemd-logind: releasing fd for 13:88
[ 43.492] (II) UnloadModule: "libinput"
[ 43.492] (II) systemd-logind: releasing fd for 13:82
[ 43.509] (II) UnloadModule: "libinput"
[ 43.509] (II) systemd-logind: releasing fd for 13:85
[ 43.549] (II) UnloadModule: "libinput"
[ 43.549] (II) systemd-logind: releasing fd for 13:83
[ 43.589] (II) UnloadModule: "libinput"
[ 43.589] (II) systemd-logind: not releasing fd for 13:84, still in use
[ 43.589] (II) systemd-logind: releasing fd for 13:84
[ 43.625] (II) UnloadModule: "libinput"
[ 43.625] (II) systemd-logind: not releasing fd for 13:87, still in use
[ 43.625] (II) systemd-logind: releasing fd for 13:87
[ 43.656] (II) UnloadModule: "libinput"
[ 43.656] (II) systemd-logind: releasing fd for 13:86
[ 43.695] (II) UnloadModule: "libinput"
[ 43.695] (II) systemd-logind: releasing fd for 13:68
[ 43.735] (II) UnloadModule: "libinput"
[ 43.736] (II) systemd-logind: releasing fd for 13:64
[ 43.788] (II) UnloadModule: "libinput"
[ 43.788] (II) systemd-logind: releasing fd for 13:65
[ 43.846] (II) UnloadModule: "libinput"
[ 43.846] (II) systemd-logind: releasing fd for 13:69
[ 43.886] (II) UnloadModule: "libinput"
[ 43.886] (II) systemd-logind: releasing fd for 13:66
[ 43.952] (II) NVIDIA(GPU-0): Deleting GPU-0
[ 43.953] (II) Server terminated successfully (0). Closing log file.
