Secondary monitor don't wake-up after resume
Hello, I installed my system from zero last week, I removed the Nvidia prime video driver with this command sudo mhwd -r pci video-hybrid-amd-nvidia-prime and install the Nvidia drivers with this command sudo mhwd -i pci video-nvidia and then my secondary monitor doesn’t wake up after resuming sleep mode, the monitor only wake up if I change the monitor resolution and revert form display configuration or disable and reenable de monitor.
I tried install Linux drivers, and reinstall the nvidia drivers. I used the command sudo mhwd-gpu --setmod nvidia --setxorg /etc/X11/mhwd.d/nvidia.conf to set de xOrg configuration but nothing solves the problem
Can someone help me?.
The system info is
  Kernel: 6.1.31-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
    root=UUID=ccce4068-7b7b-47ed-baa7-862cc12a3809 rw quiet
    cryptdevice=UUID=9d67d35f-9627-4ff1-90a8-cd24e07cf9e6:luks-9d67d35f-9627-4ff1-90a8-cd24e07cf9e6
    root=/dev/mapper/luks-9d67d35f-9627-4ff1-90a8-cd24e07cf9e6 splash
    resume=/dev/mapper/luks-e8257d07-8e9f-443f-8934-f19fed1baa98
    udev.log_priority=3
  Desktop: KDE Plasma v: 5.27.5 tk: Qt v: 5.15.9 wm: kwin_x11 dm: SDDM
  Type: Desktop Mobo: Gigabyte model: B650 AORUS ELITE AX v: x.x serial: N/A
    UEFI: American Megatrends LLC. v: F3 date: 01/18/2023
  System RAM: available: 62.54 GiB used: 16.59 GiB (26.5%)
  Array-1: capacity: 128 GiB slots: 4 EC: None max-module-size: 32 GiB
    note: est.
  Device-1: DIMM 0 type: no module installed
  Device-2: DIMM 1 type: DDR5 detail: synchronous unbuffered (unregistered)
    size: 32 GiB speed: 6000 MT/s volts: curr: 1.1 min: 1.1 max: 1.1
    width (bits): data: 64 total: 64 manufacturer: N/A
    part-no: F5-6000J3040G32G serial: N/A
  Device-3: DIMM 0 type: no module installed
  Device-4: DIMM 1 type: DDR5 detail: synchronous unbuffered (unregistered)
  Info: model: AMD Ryzen 9 7900X socket: AM5 bits: 64 type: MT MCP arch: Zen 4
    gen: 5 level: v4 note: check built: 2022+ process: TSMC n5 (5nm)
    family: 0x19 (25) model-id: 0x61 (97) stepping: 2 microcode: 0xA601203
  Topology: cpus: 1x cores: 12 tpc: 2 threads: 24 smt: enabled cache:
    L1: 768 KiB desc: d-12x32 KiB; i-12x32 KiB L2: 12 MiB desc: 12x1024 KiB
    L3: 64 MiB desc: 2x32 MiB
  Speed (MHz): avg: 3212 high: 4700 min/max: 3000/5733 boost: enabled
    base/boost: 4700/5700 scaling: driver: acpi-cpufreq governor: schedutil
    volts: 1.3 V ext-clock: 100 MHz cores: 1: 4700 2: 3000 3: 3000 4: 3000
    5: 3000 6: 3000 7: 3000 8: 3000 9: 3000 10: 4700 11: 3000 12: 3000 13: 4700
    14: 3000 15: 3000 16: 3000 17: 3000 18: 3000 19: 3000 20: 3000 21: 3000
    22: 3000 23: 3000 24: 3000 bogomips: 225260
  Flags: 3dnowprefetch abm adx aes amd_lbr_v2 aperfmperf apic arat avic avx
    avx2 avx512_bf16 avx512_bitalg avx512_vbmi2 avx512_vnni avx512_vpopcntdq
    avx512bw avx512cd avx512dq avx512f avx512ifma avx512vbmi avx512vl bmi1
    cqm_occup_llc cr8_legacy cx16 cx8 de decodeassists erms extapic
    extd_apicid f16c flush_l1d flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt
    gfni ht hw_pstate ibpb ibrs ibs invpcid irperf lahf_lm lbrv lm mba mca mce
    pdpe1gb perfctr_core perfctr_llc perfctr_nb perfmon_v2 pfthreshold pge pku
    pni popcnt pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good
    sep sha_ni skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3
    v_spec_ctrl v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall vpclmulqdq
    wbnoinvd wdt x2apic x2avic xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
    STIBP: always-on, RSB filling, PBRSB-eIBRS: Not affected
  Device-1: NVIDIA AD104 [GeForce RTX 4070 Ti] vendor: ASUSTeK driver: nvidia
    v: 530.41.03 alternate: nouveau,nvidia_drm non-free: 530.xx+
    status: current (as of 2023-05) arch: Lovelace code: AD1xx
    process: TSMC n4 (5nm) built: 2022-23+ pcie: gen: 2 speed: 5 GT/s lanes: 16
    link-max: gen: 4 speed: 16 GT/s bus-ID: 01:00.0 chip-ID: 10de:2782
    class-ID: 0300
  Device-2: Logitech C920 HD Pro Webcam driver: snd-usb-audio,uvcvideo
    type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-3.2.4:11
    chip-ID: 046d:0892 class-ID: 0102 serial: <filter>
  Display: x11 server: X.Org v: 21.1.8 with: Xwayland v: 23.1.1
    compositor: kwin_x11 driver: X: loaded: nvidia gpu: nvidia display-ID: :0
    screens: 1
  Screen-1: 0 s-res: 5120x1440 s-dpi: 96 s-size: 1354x381mm (53.31x15.00")
    s-diag: 1407mm (55.38")
  Monitor-1: HDMI-0 pos: primary,left res: 2560x1440 hz: 60 dpi: 108
    size: 600x340mm (23.62x13.39") diag: 690mm (27.15") modes: N/A
  Monitor-2: HDMI-1 pos: right res: 2560x1440 hz: 60 dpi: 108
  API: OpenGL v: 4.6.0 NVIDIA 530.41.03 renderer: NVIDIA GeForce RTX 4070
    Ti/PCIe/SSE2 direct-render: Yes
  Device-1: NVIDIA vendor: ASUSTeK driver: snd_hda_intel v: kernel pcie: gen: 4
    speed: 16 GT/s lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:22bc class-ID: 0403
  Device-2: AMD Family 17h/19h HD Audio vendor: Gigabyte
    bus-ID: 10:00.6 chip-ID: 1022:15e3 class-ID: 0403
  Device-3: DCMT USB Condenser Microphone
    driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 1.1 speed: 12 Mb/s
    lanes: 1 mode: 1.1 bus-ID: 1-3.2.2:10 chip-ID: 31b2:0011 class-ID: 0300
    serial: <filter>
  Device-4: Logitech C920 HD Pro Webcam driver: snd-usb-audio,uvcvideo
  API: ALSA v: k6.1.31-2-MANJARO status: kernel-api with: aoss
  Server-3: PipeWire v: 0.3.70 status: off with: wireplumber status: off
    tools: pw-cat,pw-cli,wpctl
  Server-4: PulseAudio v: 16.1 status: active (root, process) with:
    tools: pacat,pactl
  Device-1: Realtek RTL8125 2.5GbE vendor: Gigabyte driver: r8169 v: kernel
    pcie: gen: 2 speed: 5 GT/s lanes: 1 port: e000 bus-ID: 0c:00.0
  IF: enp12s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Device-2: MEDIATEK MT7922 802.11ax PCI Express Wireless Network Adapter
    driver: mt7921e v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 0d:00.0
    chip-ID: 14c3:0616 class-ID: 0280
  IF: wlp13s0 state: down mac: <filter>
  IF-ID-1: br-fca6cd6d5c37 state: up speed: 10000 Mbps duplex: unknown
    mac: <filter>
  IP v6: <filter> scope: link
  IF-ID-2: docker0 state: down mac: <filter>
  Message: Output throttled. IPs: 1; Limit: 10; Override: --limit [1-x;-1
    all]
  IF-ID-3: veth45cc76b state: up speed: 10000 Mbps duplex: full mac: <filter>
  IF-ID-4: veth745504a state: up speed: 10000 Mbps duplex: full mac: <filter>
  IF-ID-5: vethcf2c08c state: up speed: 10000 Mbps duplex: full mac: <filter>
  IF-ID-6: vethe119193 state: up speed: 10000 Mbps duplex: full mac: <filter>
  Device-1: MediaTek Wireless_Device driver: btusb v: 0.8 type: USB rev: 2.1
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-9:8 chip-ID: 0e8d:0616
  Report: rfkill ID: hci0 rfk-id: 3 state: up address: see --recommends
  Device-1: luks-9d67d35f-9627-4ff1-90a8-cd24e07cf9e6 maj-min: 254:0
    type: LUKS dm: dm-0 size: 1.75 TiB
  Components:
  p-1: nvme0n1p2 maj-min: 259:2 size: 1.75 TiB
  Device-2: luks-e8257d07-8e9f-443f-8934-f19fed1baa98 maj-min: 254:1
    type: LUKS dm: dm-1 size: 68.15 GiB
  Components:
  p-1: nvme0n1p3 maj-min: 259:3 size: 68.15 GiB
  Local Storage: total: 5.46 TiB used: 307.98 GiB (5.5%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 980 PRO 2TB
    lanes: 4 tech: SSD serial: <filter> fw-rev: 5B2QGXA7 temp: 31.9 C
    scheme: GPT
  SMART: yes health: PASSED on: 9 hrs cycles: 63 read-units: 377,408 [193 GB]
    written-units: 1,230,141 [629 GB]
  ID-2: /dev/sda maj-min: 8:0 vendor: Toshiba model: DT01ACA200 family: 3.5"
    DT01ACA... Desktop HDD size: 1.82 TiB block-size: physical: 4096 B
    logical: 512 B sata: 3.0 speed: 6.0 Gb/s tech: HDD rpm: 7200
    serial: <filter> fw-rev: ABB0 temp: 27 C scheme: MBR
  SMART: yes state: enabled health: PASSED on: 3y 47d 23h cycles: 6588
    Pre-Fail: reallocated sector: 100 threshold: 5
  ID-3: /dev/sdb maj-min: 8:16 vendor: Toshiba model: DT01ACA200 family: 3.5"
  SMART: yes state: enabled health: PASSED on: 3y 173d 1h cycles: 7205
  ID-1: / raw-size: 1.75 TiB size: 1.72 TiB (98.37%) used: 307.98 GiB (17.4%)
    fs: ext4 block-size: 4096 B dev: /dev/dm-0 maj-min: 254:0
    mapped: luks-9d67d35f-9627-4ff1-90a8-cd24e07cf9e6 label: N/A
    uuid: ccce4068-7b7b-47ed-baa7-862cc12a3809
    used: 448 KiB (0.1%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
    maj-min: 259:1 label: N/A uuid: 1AD2-287C
  ID-1: swap-1 type: partition size: 68.15 GiB used: 0 KiB (0.0%)
    priority: -2 dev: /dev/dm-1 maj-min: 254:1
    mapped: luks-e8257d07-8e9f-443f-8934-f19fed1baa98 label: swap
    uuid: 864ecc85-e692-436a-860c-22a43d72c036
  ID-1: /dev/sda1 maj-min: 8:1 size: 1.82 TiB fs: ntfs label: MY_DATA
    uuid: 2600979808741D81
  ID-2: /dev/sdb3 maj-min: 8:19 size: 976.56 GiB fs: ntfs label: DATOS
    uuid: 5CA0B706A0B6E5A4
  ID-3: /dev/sdb4 maj-min: 8:20 size: 1 KiB fs: N/A label: N/A uuid: N/A
  ID-4: /dev/sdb5 maj-min: 8:21 size: 93.13 GiB fs: btrfs label: manjaro
    uuid: a3878f83-9a6a-4cc5-95c9-1693880e9307
  ID-5: /dev/sdb6 maj-min: 8:22 size: 793.32 GiB fs: btrfs label: home
    uuid: b8c3db1b-b9fd-4ae4-89c8-c8d4a8f40fe1
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
  Hub-2: 1-3:2 info: Realtek RTS5411 Hub ports: 4 rev: 2.1
    chip-ID: 0bda:5411 class-ID: 0900
  Hub-3: 1-3.1:4 info: Genesys Logic Hub ports: 4 rev: 2.1
  Device-1: 1-3.1.4:7 info: Yubicom Yubikey 4/5 OTP+U2F+CCID
    type: keyboard,HID,smart card driver: hid-generic,usbhid interfaces: 3
    rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 30mA
    chip-ID: 1050:0407 class-ID: 0b00
  Hub-4: 1-3.2:6 info: Hitachi ports: 4 rev: 2.1 speed: 480 Mb/s (57.2 MiB/s)
    lanes: 1 mode: 2.0 chip-ID: 045b:0209 class-ID: 0900
  Hub-5: 1-3.2.1:9 info: Hitachi ports: 4 rev: 2.1
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 045b:0209
  Device-1: 1-3.2.2:10 info: DCMT USB Condenser Microphone type: audio,HID
    driver: hid-generic,snd-usb-audio,usbhid interfaces: 3 rev: 1.1
    chip-ID: 31b2:0011 class-ID: 0300 serial: <filter>
  Device-2: 1-3.2.4:11 info: Logitech C920 HD Pro Webcam type: video,audio
  Device-3: 1-6:3 info: Integrated Express RGB LED Controller type: HID
    lanes: 1 mode: 1.1 power: 100mA chip-ID: 048d:5702 class-ID: 0300
  Device-4: 1-7:5 info: Cooler Master ARGB GEN-2 type: HID
    lanes: 1 mode: 1.1 power: 100mA chip-ID: 2516:01c9 class-ID: 0300
  Device-5: 1-9:8 info: MediaTek Wireless_Device type: bluetooth
    mode: 2.0 power: 100mA chip-ID: 0e8d:0616 class-ID: e001 serial: <filter>
  Hub-6: 2-0:1 info: super-speed hub ports: 5 rev: 3.1
  Hub-7: 2-3:2 info: Realtek Hub ports: 4 rev: 3.2
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 power: 96mA
    chip-ID: 0bda:0411 class-ID: 0900
  Hub-8: 2-3.1:3 info: Genesys Logic Hub ports: 4 rev: 3.1
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 05e3:0612
  Hub-9: 2-3.2:4 info: Hitachi ports: 4 rev: 3.0 speed: 5 Gb/s (596.0 MiB/s)
    lanes: 1 mode: 3.2 gen-1x1 chip-ID: 045b:0210 class-ID: 0900
  Hub-10: 2-3.2.1:5 info: Hitachi ports: 4 rev: 3.0
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 045b:0210
  Hub-11: 3-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
  Hub-12: 4-0:1 info: super-speed hub ports: 2 rev: 3.1
  Hub-13: 5-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
  Hub-14: 6-0:1 info: super-speed hub ports: 2 rev: 3.1
  Hub-15: 7-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
  Hub-16: 7-1:2 info: Genesys Logic Hub ports: 4 rev: 2.0
  Device-1: 7-1.1:3 info: Corsair K70 RGB MK.2 Mechanical Gaming Keyboard
    type: keyboard,HID driver: usbfs interfaces: 2 rev: 2.0
    chip-ID: 1b1c:1b49 class-ID: 0300 serial: <filter>
  Device-2: 7-1.3:4 info: Corsair Gaming M65 Pro RGB Mouse type: mouse,HID
    driver: usbfs interfaces: 2 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
    mode: 1.1 power: 300mA chip-ID: 1b1c:1b2e class-ID: 0300 serial: <filter>
  Hub-17: 8-0:1 info: Linux Foundation 3.0 root hub ports: N/A rev: 3.0
  System Temperatures: cpu: 63.4 C mobo: 25.0 C gpu: nvidia temp: 33 C
  Processes: 528 Uptime: 23h 9m wakeups: 6 Init: systemd v: 253
  default: graphical tool: systemctl Compilers: gcc: 13.1.1 alt: 12
  clang: 15.0.7 Packages: pm: pacman pkgs: 2015 libs: 514 tools: pamac,yay
  pm: appimage pkgs: 0 pm: flatpak pkgs: 0 Shell: Zsh (sudo) v: 5.9
  default: Bash v: 5.1.16 running-in: tilix inxi: 3.3.27
journalctl --boot=-1 --priority=3 --catalog --no-pager
jul 04 21:10:36 gollum23PC kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.GPP7._PRW], AE_ALREADY_EXISTS (20220331/dswload2-326)
jul 04 21:10:36 gollum23PC kernel: ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20220331/psobject-220)
jul 04 21:10:36 gollum23PC kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.GPP2._PRW], AE_ALREADY_EXISTS (20220331/dswload2-326)
jul 04 21:10:36 gollum23PC kernel: ACPI BIOS Error (bug): Failure creating named object [\_GPE._L08], AE_ALREADY_EXISTS (20220331/dswload2-326)
jul 04 21:10:36 gollum23PC kernel: hub 8-0:1.0: config failed, hub doesn't have any ports! (err -19)
jul 04 21:10:36 gollum23PC systemd-udevd[576]: /usr/lib/udev/rules.d/51-trezor.rules:11 Unknown group 'trezord', ignoring
jul 04 21:10:36 gollum23PC systemd-udevd[576]: /usr/lib/udev/rules.d/51-trezor.rules:12 Unknown group 'trezord', ignoring
jul 04 21:10:36 gollum23PC systemd-udevd[576]: /usr/lib/udev/rules.d/51-trezor.rules:15 Unknown group 'trezord', ignoring
jul 04 21:10:36 gollum23PC systemd-udevd[576]: /usr/lib/udev/rules.d/51-trezor.rules:16 Unknown group 'trezord', ignoring
jul 04 21:10:36 gollum23PC systemd-udevd[576]: /usr/lib/udev/rules.d/51-trezor.rules:17 Unknown group 'trezord', ignoring
jul 04 21:10:37 gollum23PC kernel: gspca_vc032x: reg_r err -32
jul 04 21:10:37 gollum23PC bluetoothd[813]: src/plugin.c:plugin_init() Failed to init vcp plugin
jul 04 21:10:37 gollum23PC bluetoothd[813]: src/plugin.c:plugin_init() Failed to init mcp plugin
jul 04 21:10:37 gollum23PC bluetoothd[813]: src/plugin.c:plugin_init() Failed to init bap plugin
jul 04 21:10:46 gollum23PC systemd[1264]: /run/user/1000/systemd/generator.late/app-rescuetime@autostart.service:18: WorkingDirectory= path is not absolute, ignoring:
jul 04 21:10:47 gollum23PC systemd[1264]: /run/user/1000/systemd/generator.late/app-rescuetime@autostart.service:18: WorkingDirectory= path is not absolute, ignoring:
jul 04 21:10:51 gollum23PC akonadiserver[1782]: org.kde.pim.akonadiserver: DATABASE ERROR:
jul 04 21:10:51 gollum23PC akonadiserver[1782]: org.kde.pim.akonadiserver:   Error code: "1062"
jul 04 21:10:51 gollum23PC akonadiserver[1782]: org.kde.pim.akonadiserver:   DB error:  "Duplicate entry '26-None' for key 'CollectionTable_parentAndNameIndex'"
jul 04 21:10:51 gollum23PC akonadiserver[1782]: org.kde.pim.akonadiserver:   Error text: "Duplicate entry '26-None' for key 'CollectionTable_parentAndNameIndex' QMYSQL3: Unable to execute statement"
jul 04 21:10:51 gollum23PC akonadiserver[1782]: org.kde.pim.akonadiserver:   Values: QMap((":0", QVariant(QString, "contactGroups/6d0fc450f30a99a"))(":1", QVariant(QString, "kFtdrqoBL0U="))(":10", QVariant(int, -1))(":11", QVariant(int, -1))(":12", QVariant(bool, false))(":13", QVariant(QString, ""))(":14", QVariant(bool, true))(":2", QVariant(QString, "None"))(":3", QVariant(qlonglong, 26))(":4", QVariant(qlonglong, 12))(":5", QVariant(bool, true))(":6", QVariant(int, 2))(":7", QVariant(int, 2))(":8", QVariant(int, 2))(":9", QVariant(bool, true)))
jul 04 21:10:51 gollum23PC akonadiserver[1782]: org.kde.pim.akonadiserver:   Query: "INSERT INTO CollectionTable (remoteId, remoteRevision, name, parentId, resourceId, enabled, syncPref, displayPref, indexPref, cachePolicyInherit, cachePolicyCheckInterval, cachePolicyCacheTimeout, cachePolicySyncOnDemand, cachePolicyLocalParts, isVirtual) VALUES (:0, :1, :2, :3, :4, :5, :6, :7, :8, :9, :10, :11, :12, :13, :14)"
jul 05 04:13:03 gollum23PC systemd[1]: Failed to start pkgfile database update.
░░ Subject: A start job for unit pkgfile-update.service has failed
░░ Defined-By: systemd
░░ A start job for unit pkgfile-update.service has finished with a failure.
░░ The job identifier is 2298 and the job result is failed.
jul 05 04:13:05 gollum23PC kernel: usb 1-3.1-port1: Cannot enable. Maybe the USB cable is bad?
jul 05 04:14:18 gollum23PC systemd-coredump[42421]: [🡕] Process 1791 (plasmashell) of user 1000 dumped core.
                                                    Stack trace of thread 2665:
                                                    #0  0x00007fe002fb6700 _ZN16QSGAreaAllocator16deallocateInNodeERK6QPointP20QSGAreaAllocatorNode (libQt5Quick.so.5 + 0x1b6700)
                                                    #1  0x00007fe002fb677b _ZN16QSGAreaAllocator10deallocateERK5QRect (libQt5Quick.so.5 + 0x1b677b)
                                                    #2  0x00007fe002fbc91c n/a (libQt5Quick.so.5 + 0x1bc91c)
                                                    #3  0x00007fe002fbc99d n/a (libQt5Quick.so.5 + 0x1bc99d)
                                                    #4  0x00007fdff816d291 n/a (libcorebindingsplugin.so + 0x1b291)
                                                    #5  0x00007fe003054ae0 _ZN19QQuickWindowPrivate15runAndClearJobsEP5QListIP9QRunnableE (libQt5Quick.so.5 + 0x254ae0)
                                                    #6  0x00007fe002ff8518 n/a (libQt5Quick.so.5 + 0x1f8518)
                                                    #7  0x00007fe002ffcbe4 n/a (libQt5Quick.so.5 + 0x1fcbe4)
                                                    #8  0x00007fe0012e424a n/a (libQt5Core.so.5 + 0xe424a)
                                                    #9  0x00007fe000c9d44b n/a (libc.so.6 + 0x8744b)
                                                    #10 0x00007fe000d20e40 n/a (libc.so.6 + 0x10ae40)
                                                    Stack trace of thread 1902:
                                                    #0  0x00007fe000d13c0f __poll (libc.so.6 + 0xfdc0f)
                                                    #1  0x00007fe0037d826b n/a (libxcb.so.1 + 0xd26b)
                                                    #2  0x00007fe0037d9d1d xcb_wait_for_event (libxcb.so.1 + 0xed1d)
                                                    #3  0x00007fdffbf2c242 n/a (libQt5XcbQpa.so.5 + 0x62242)
                                                    #4  0x00007fe0012e424a n/a (libQt5Core.so.5 + 0xe424a)
                                                    #5  0x00007fe000c9d44b n/a (libc.so.6 + 0x8744b)
                                                    #6  0x00007fe000d20e40 n/a (libc.so.6 + 0x10ae40)
                                                    Stack trace of thread 2224:
                                                    #1  0x00007fe00022017f n/a (libglib-2.0.so.0 + 0xb717f)
                                                    #2  0x00007fe0001c21a2 g_main_context_iteration (libglib-2.0.so.0 + 0x591a2)
                                                    #3  0x00007fe0014d8d3c _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt5Core.so.5 + 0x2d8d3c)
                                                    #4  0x00007fe00148668c _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt5Core.so.5 + 0x28668c)
                                                    #5  0x00007fe0012e771f _ZN7QThread4execEv (libQt5Core.so.5 + 0xe771f)
                                                    #6  0x00007fe002ac2410 n/a (libQt5Qml.so.5 + 0x2c2410)
                                                    #7  0x00007fe0012e424a n/a (libQt5Core.so.5 + 0xe424a)
                                                    #8  0x00007fe000c9d44b n/a (libc.so.6 + 0x8744b)
                                                    #9  0x00007fe000d20e40 n/a (libc.so.6 + 0x10ae40)
                                                    Stack trace of thread 2440:
                                                    #0  0x00007fe000c99f0e n/a (libc.so.6 + 0x83f0e)
                                                    #1  0x00007fe000c9c7a0 pthread_cond_wait (libc.so.6 + 0x867a0)
                                                    #2  0x00007fe0012eb6f4 _ZN14QWaitCondition4waitEP6QMutex14QDeadlineTimer (libQt5Core.so.5 + 0xeb6f4)
                                                    #3  0x00007fe002ffcfc2 n/a (libQt5Quick.so.5 + 0x1fcfc2)
                                                    Stack trace of thread 37725:
                                                    Stack trace of thread 37702:
                                                    Stack trace of thread 2658:
                                                    #6  0x00007fdfb405ec8e _ZN15KCupsConnection3runEv (libkcupslib.so + 0x1fc8e)
                                                    Stack trace of thread 1791:
                                                    #3  0x00007fe003001300 n/a (libQt5Quick.so.5 + 0x201300)
                                                    #4  0x00007fe003052643 _ZN12QQuickWindow5eventEP6QEvent (libQt5Quick.so.5 + 0x252643)
                                                    #5  0x00007fe002178b5c _ZN19QApplicationPrivate13notify_helperEP7QObjectP6QEvent (libQt5Widgets.so.5 + 0x178b5c)
                                                    #6  0x00007fe00148e028 _ZN16QCoreApplication15notifyInternal2EP7QObjectP6QEvent (libQt5Core.so.5 + 0x28e028)
                                                    #7  0x00007fe0019344e8 _ZN15QPlatformWindow11windowEventEP6QEvent (libQt5Gui.so.5 + 0x1344e8)
                                                    #8  0x00007fe00217d041 _ZN12QApplication6notifyEP7QObjectP6QEvent (libQt5Widgets.so.5 + 0x17d041)
                                                    #9  0x00007fe00148e028 _ZN16QCoreApplication15notifyInternal2EP7QObjectP6QEvent (libQt5Core.so.5 + 0x28e028)
                                                    #10 0x00007fe0014d8583 _ZN14QTimerInfoList14activateTimersEv (libQt5Core.so.5 + 0x2d8583)
                                                    #11 0x00007fe0014d8bc2 n/a (libQt5Core.so.5 + 0x2d8bc2)
                                                    #12 0x00007fe0001c353b g_main_context_dispatch (libglib-2.0.so.0 + 0x5a53b)
                                                    #13 0x00007fe000220219 n/a (libglib-2.0.so.0 + 0xb7219)
                                                    #14 0x00007fe0001c21a2 g_main_context_iteration (libglib-2.0.so.0 + 0x591a2)
                                                    #15 0x00007fe0014d8d3c _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt5Core.so.5 + 0x2d8d3c)
                                                    #16 0x00007fe00148668c _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt5Core.so.5 + 0x28668c)
                                                    #17 0x00007fe0014912f9 _ZN16QCoreApplication4execEv (libQt5Core.so.5 + 0x2912f9)
                                                    #18 0x00005580c77f216c n/a (plasmashell + 0x2416c)
                                                    #19 0x00007fe000c39850 n/a (libc.so.6 + 0x23850)
                                                    #20 0x00007fe000c3990a __libc_start_main (libc.so.6 + 0x2390a)
                                                    #21 0x00005580c77f2515 n/a (plasmashell + 0x24515)
                                                    Stack trace of thread 2465:
                                                    Stack trace of thread 2490:
                                                    #6  0x00007fe002f5613f n/a (libQt5Quick.so.5 + 0x15613f)
                                                    Stack trace of thread 41824:
                                                    Stack trace of thread 2644:
                                                    #0  0x00007fe000d16571 pselect (libc.so.6 + 0x100571)
                                                    #1  0x00007fdfff4b36f9 n/a (libusbmuxd-2.0.so.6 + 0x36f9)
                                                    #2  0x00007fdfff4b43cc n/a (libusbmuxd-2.0.so.6 + 0x43cc)
                                                    #3  0x00007fe000c9d44b n/a (libc.so.6 + 0x8744b)
                                                    #4  0x00007fe000d20e40 n/a (libc.so.6 + 0x10ae40)
                                                    Stack trace of thread 2462:
                                                    #1  0x00007fdff2913d47 n/a (libnvidia-glcore.so.530.41.03 + 0x1513d47)
                                                    #2  0x00007fdff291162a n/a (libnvidia-glcore.so.530.41.03 + 0x151162a)
                                                    Stack trace of thread 1842:
                                                    #6  0x00007fe0026edcba n/a (libQt5DBus.so.5 + 0x23cba)
░░ Subject: Process 1791 (plasmashell) dumped core
░░ Documentation: man:core(5)
░░ Process 1791 (plasmashell) crashed and dumped core.
░░ This usually indicates a programming error in the crashing program and
░░ should be reported to its vendor as a bug.
jul 05 05:45:27 gollum23PC sudo[345665]: pam_unix(sudo:auth): conversation failed
jul 05 05:45:27 gollum23PC sudo[345665]: pam_unix(sudo:auth): auth could not identify password for [gollum23]
jul 05 05:50:35 gollum23PC systemd-coredump[359590]: [🡕] Process 340300 (postgres) of user 999 dumped core.
                                                     Stack trace of thread 26:
                                                     #0  0x00007f807d412ce1 n/a (/lib/x86_64-linux-gnu/libc-2.31.so + 0x3bce1)
                                                     #1  0x00005572faf9356a n/a (/usr/lib/postgresql/14/bin/postgres + 0x14956a)
                                                     #2  0x00005572fb02c18b n/a (/usr/lib/postgresql/14/bin/postgres + 0x1e218b)
                                                     #3  0x00005572fb20ccd5 n/a (/usr/lib/postgresql/14/bin/postgres + 0x3c2cd5)
                                                     #4  0x00005572fb20ce74 n/a (/usr/lib/postgresql/14/bin/postgres + 0x3c2e74)
                                                     #5  0x00005572fb03c559 n/a (/usr/lib/postgresql/14/bin/postgres + 0x1f2559)
                                                     #6  0x00005572fb217cbf n/a (/usr/lib/postgresql/14/bin/postgres + 0x3cdcbf)
                                                     #7  0x00005572fb21909a n/a (/usr/lib/postgresql/14/bin/postgres + 0x3cf09a)
                                                     #8  0x00007f807dd01140 n/a (/lib/x86_64-linux-gnu/libpthread-2.31.so + 0x14140)
                                                     #9  0x00005572fb21b484 n/a (/usr/lib/postgresql/14/bin/postgres + 0x3d1484)
                                                     #10 0x00005572faf940d9 n/a (/usr/lib/postgresql/14/bin/postgres + 0x14a0d9)
                                                     #11 0x00007f807d3fdd0a n/a (/lib/x86_64-linux-gnu/libc-2.31.so + 0x26d0a)
░░ Subject: Process 340300 (postgres) dumped core
░░ Process 340300 (postgres) crashed and dumped core.
jul 05 06:52:22 gollum23PC kernel: ntfs3: Unknown parameter 'windows_names'
jul 05 09:11:07 gollum23PC kernel: usb 1-3.1-port1: Cannot enable. Maybe the USB cable is bad?
jul 05 09:11:08 gollum23PC kernel: usb 1-3.1-port1: Cannot enable. Maybe the USB cable is bad?
jul 05 10:42:33 gollum23PC bluetoothd[813]: src/profile.c:ext_io_disconnected() Unable to get io data for Hands-Free Voice gateway: getpeername: Transport endpoint is not connected (107)
jul 05 11:27:05 gollum23PC bluetoothd[813]: src/profile.c:ext_io_disconnected() Unable to get io data for Hands-Free Voice gateway: getpeername: Transport endpoint is not connected (107)
jul 05 13:57:00 gollum23PC kernel: usb 1-3.1-port1: Cannot enable. Maybe the USB cable is bad?
jul 05 13:57:01 gollum23PC kernel: usb 1-3.1-port1: Cannot enable. Maybe the USB cable is bad?
jul 05 15:40:51 gollum23PC bluetoothd[813]: src/profile.c:ext_io_disconnected() Unable to get io data for Hands-Free Voice gateway: getpeername: Transport endpoint is not connected (107)
jul 05 16:49:51 gollum23PC akonadiserver[1782]: org.kde.pim.akonadiserver: Control process died, exiting!
jul 05 16:49:52 gollum23PC pulseaudio[2640]: Lost I/O connection in module "module-gsettings"
jul 05 16:50:02 gollum23PC systemd-cryptsetup[2201515]: Device luks-9d67d35f-9627-4ff1-90a8-cd24e07cf9e6 is still in use.
jul 05 16:50:02 gollum23PC systemd-cryptsetup[2201515]: Failed to deactivate: Device or resource busy
jul 05 16:50:03 gollum23PC systemd-cryptsetup[2201533]: device-mapper: remove ioctl on luks-e8257d07-8e9f-443f-8934-f19fed1baa98  failed: Device or resource busy
Hello,
Is early KMS set on your system? I guess not, maybe worth a try
Maybe also share the content of your system’s /etc/X11/mhwd.d/nvidia.conf
This is the content of my nvidia.conf
# nvidia-xconfig: X configuration file generated by nvidia-xconfig
# nvidia-xconfig:  version 530.41.03
# nvidia-settings: X configuration file generated by nvidia-settings
# nvidia-settings:  version 530.41.03
Section "ServerLayout"
    Identifier     "Layout0"
    Screen      0  "Screen0" 0 0
    InputDevice    "Keyboard0" "CoreKeyboard"
    InputDevice    "Mouse0" "CorePointer"
    Option         "Xinerama" "0"
EndSection
Section "Files"
EndSection
Section "InputDevice"
    # generated from default
    Identifier     "Mouse0"
    Driver         "mouse"
    Option         "Protocol" "auto"
    Option         "Device" "/dev/psaux"
    Option         "Emulate3Buttons" "no"
    Option         "ZAxisMapping" "4 5"
EndSection
    Identifier     "Keyboard0"
    Driver         "kbd"
EndSection
Section "Monitor"
    # HorizSync source: edid, VertRefresh source: edid
    Identifier     "Monitor0"
    VendorName     "Unknown"
    ModelName      "LG Electronics LG HDR 4K"
    HorizSync       30.0 - 135.0
    VertRefresh     56.0 - 61.0
    Option         "DPMS"
EndSection
Section "Device"
    Identifier     "Device0"
    Driver         "nvidia"
    VendorName     "NVIDIA Corporation"
    BoardName      "NVIDIA GeForce RTX 4070 Ti"
	Option "NoLogo" "1"
EndSection
Section "Screen"
# Removed Option "nvidiaXineramaInfoOrder" "DFP-3"
# Removed Option "metamodes" "HDMI-0: 2560x1440 +2560+0, HDMI-1: 2560x1440 +0+0"
    Identifier     "Screen0"
    Device         "Device0"
    Monitor        "Monitor0"
    DefaultDepth    24
    Option         "Stereo" "0"
    Option         "nvidiaXineramaInfoOrder" "DFP-0"
    Option         "metamodes" "HDMI-0: 2560x1440 +0+0, HDMI-1: 2560x1440 +2560+0"
    Option         "SLI" "Off"
    Option         "MultiGPU" "Off"
    Option         "BaseMosaic" "off"
    SubSection     "Display"
        Depth       24
    EndSubSection
EndSection
Section "Extensions"
    Option         "COMPOSITE" "Enable"
EndSection
Section "InputClass"
    Identifier          "Keyboard Defaults"
    MatchIsKeyboard        "yes"
    Option              "XkbOptions" "terminate:ctrl_alt_bksp"
EndSection
I will check the post and try the solution.
Please try this config, but also make sure you enable the early KMS by one of the methods pointed out in my previous link.
EndSection
Section "Files"
EndSection
    Identifier     "Mouse0"
    Driver         "mouse"
EndSection
    Driver         "kbd"
EndSection
Section "Monitor"
    VendorName     "LG Electronics"
    Option         "DPMS"
EndSection
Section "Device"
    Driver         "nvidia"
    Option  "ConnectToAcpid"    "Off"
EndSection
Section "Screen"
    Device         "Device0"
    Monitor        "Monitor0"
    DefaultDepth    24
    Option         "Stereo" "0"
    Option         "metamodes" "HDMI-0: 2560x1440_60 +0+0 {ForceCompositionPipeline=On}, HDMI-1: 2560x1440_60 +2560+0 {ForceCompositionPipeline=On}"
    Option         "SLI" "Off"
        Depth       24
    EndSubSection
EndSection
EndSection
EndSection
Once you modified it, run again this command
Reboot and see if things are still funky.
The solutions don’t work, I’m still with the issue.
If the proposals don’t work, nor help, then those are not solutions.
What happens if you swap the cables/ports between the monitors, is the issue happening to the other monitor too?
Have you tried this ? NVIDIA/Tips and tricks - ArchWiki
Thanks for your help @anon89812132, I try to change cables and ports with the same results, but the secondary monitor doesn’t wake up. I reinstall again the system and now all works well, both monitors wake up after resuming.
I run the same commands to see the difference with my previous installation and found that plasmashell not crash in new installation
jul 08 16:38:12 Gollum23-PC kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.GPP7._PRW], AE_ALREADY_EXISTS (20220331/dswload2-326)
jul 08 16:38:12 Gollum23-PC kernel: ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20220331/psobject-220)
jul 08 16:38:12 Gollum23-PC kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.GPP2._PRW], AE_ALREADY_EXISTS (20220331/dswload2-326)
jul 08 16:38:12 Gollum23-PC kernel: ACPI BIOS Error (bug): Failure creating named object [\_GPE._L08], AE_ALREADY_EXISTS (20220331/dswload2-326)
jul 08 16:38:12 Gollum23-PC kernel: hub 8-0:1.0: config failed, hub doesn't have any ports! (err -19)
jul 08 16:38:12 Gollum23-PC systemd-udevd[568]: /usr/lib/udev/rules.d/51-trezor.rules:11 Unknown group 'trezord', ignoring
jul 08 16:38:12 Gollum23-PC systemd-udevd[568]: /usr/lib/udev/rules.d/51-trezor.rules:12 Unknown group 'trezord', ignoring
jul 08 16:38:12 Gollum23-PC systemd-udevd[568]: /usr/lib/udev/rules.d/51-trezor.rules:15 Unknown group 'trezord', ignoring
jul 08 16:38:12 Gollum23-PC systemd-udevd[568]: /usr/lib/udev/rules.d/51-trezor.rules:16 Unknown group 'trezord', ignoring
jul 08 16:38:12 Gollum23-PC systemd-udevd[568]: /usr/lib/udev/rules.d/51-trezor.rules:17 Unknown group 'trezord', ignoring
jul 08 16:38:12 Gollum23-PC kernel: gspca_vc032x: reg_r err -32
jul 08 16:38:13 Gollum23-PC bluetoothd[810]: src/plugin.c:plugin_init() Failed to init vcp plugin
jul 08 16:38:13 Gollum23-PC bluetoothd[810]: src/plugin.c:plugin_init() Failed to init mcp plugin
jul 08 16:38:13 Gollum23-PC bluetoothd[810]: src/plugin.c:plugin_init() Failed to init bap plugin
jul 08 16:38:26 Gollum23-PC systemd[952]: /run/user/1000/systemd/generator.late/app-rescuetime@autostart.service:18: WorkingDirectory= path is not absolute, ignoring:
jul 08 16:38:28 Gollum23-PC kernel: ntfs3: Unknown parameter 'windows_names'
jul 08 16:53:43 Gollum23-PC dolphin[41936]: inotify_add_watch(/lost+found) failed: (Permission denied)
jul 08 16:53:43 Gollum23-PC dolphin[41936]: inotify_add_watch(/root) failed: (Permission denied)
jul 08 17:16:55 Gollum23-PC pulseaudio[1756]: Lost I/O connection in module "module-gsettings"
jul 08 17:16:58 Gollum23-PC systemd-cryptsetup[126482]: Device luks-b2bd79f4-47f1-4c34-8f24-7d3a3005865f is still in use.
jul 08 17:16:58 Gollum23-PC systemd-cryptsetup[126482]: Failed to deactivate: Device or resource busy
jul 08 17:17:00 Gollum23-PC systemd-cryptsetup[126497]: device-mapper: remove ioctl on luks-9c62862b-db38-4657-9ea8-74898591bdc7  failed: Device or resource busy
jul 08 17:17:00 Gollum23-PC kernel: watchdog: watchdog0: watchdog did not stop!
For me, the only solution was to reinstall the entire system, and now all works as expected.
