Hello!
I just setup Manjaro in dualboot with Windows, and I have a problem with my secondary monitor:
When I run “xrandr” the monitor are disconnected, and when I run “nvidia-settings” it shows the secondary monitor but its marked as “disabled”, and unable to change it for “New X screen”
Here my xrandr:
Screen 0: minimum 8 x 8, current 2560 x 1440, maximum 32767 x 32767
DP-1 disconnected (normal left inverted right x axis y axis)
DP-2 connected 2560x1440+0+0 (normal left inverted right x axis y axis) 698mm x 393mm
2560x1440 144.00*+ 239.96 120.00 59.95
1920x1080 239.76 143.98 119.88 60.00 59.94 50.00
1680x1050 59.95
1600x900 60.00
1440x900 59.89
1280x1024 75.02 60.02
1280x800 59.81
1280x720 60.00 59.94 50.00
1152x864 75.00
1024x768 75.03 70.07 60.00
800x600 75.00 72.19 60.32 56.25
720x576 50.00
720x480 59.94
640x480 75.00 72.81 59.94
DP-3 disconnected (normal left inverted right x axis y axis)
HDMI-0 disconnected (normal left inverted right x axis y axis)
HDMI-1 disconnected (normal left inverted right x axis y axis)
HDMI-2 disconnected (normal left inverted right x axis y axis)
DP-5 disconnected (normal left inverted right x axis y axis)
EDIT: Here my nvidia-settings file:
# nvidia-settings: X configuration file generated by nvidia-settings
# nvidia-settings: version 510.54
# nvidia-xconfig: X configuration file generated by nvidia-xconfig
# nvidia-xconfig: version 510.54
Section "ServerLayout"
Identifier "Layout0"
Screen 0 "Screen0" 0 0
InputDevice "Keyboard0" "CoreKeyboard"
InputDevice "Mouse0" "CorePointer"
Option "Xinerama" "0"
EndSection
Section "Files"
EndSection
Section "InputDevice"
# generated from default
Identifier "Mouse0"
Driver "mouse"
Option "Protocol" "auto"
Option "Device" "/dev/psaux"
Option "Emulate3Buttons" "no"
Option "ZAxisMapping" "4 5"
EndSection
Identifier "Keyboard0"
Driver "kbd"
EndSection
Section "Monitor"
# HorizSync source: edid, VertRefresh source: edid
Identifier "Monitor0"
VendorName "Unknown"
ModelName "Samsung LC32G7xT"
HorizSync 358.0 - 358.0
VertRefresh 60.0 - 240.0
Option "DPMS"
EndSection
Section "Monitor"
Identifier "Monitor1"
ModelName "DELL U2415"
HorizSync 30.0 - 83.0
VertRefresh 49.0 - 61.0
EndSection
Section "Device"
Identifier "Device0"
Driver "nvidia"
VendorName "NVIDIA Corporation"
BoardName "NVIDIA GeForce RTX 3080"
BusID "PCI:11:0:0"
EndSection
Section "Device"
Identifier "Device1"
Driver "nvidia"
BusID "PCI:11:0:0"
Screen 1
EndSection
Section "Screen"
# Removed Option "metamodes" "DP-4: nvidia-auto-select +1920+0, DP-2: nvidia-auto-select +0+0; DP-4: 2560x1440_240 +1920+0, DP-2: nvidia-auto-select +0+0; DP-4: 2560x1440_120 +1920+0, DP-2: nvidia-auto-select +0+0; DP-4: 2560x1440_60 +1920+0, DP-2: nvidia-auto-select +0+0; DP-4: 1920x1080 +1920+0, DP-2: nvidia-auto-select +0+0; DP-4: 1920x1080_144 +1920+0, DP-2: nvidia-auto-select +0+0; DP-4: 1920x1080_120 +1920+0, DP-2: nvidia-auto-select +0+0; DP-4: 1920x1080_60 +1920+0, DP-2: nvidia-auto-select +0+0; DP-4: 1920x1080_60_0 +1920+0, DP-2: nvidia-auto-select +0+0; DP-4: 1920x1080_50 +1920+0, DP-2: nvidia-auto-select +0+0; DP-4: 1680x1050 +1920+0, DP-2: nvidia-auto-select +0+0; DP-4: 1600x900 +1920+0, DP-2: nvidia-auto-select +0+0; DP-4: 1440x900 +1920+0, DP-2: nvidia-auto-select +0+0; DP-4: 1280x1024 +1920+0, DP-2: nvidia-auto-select +0+0; DP-4: 1280x1024_60 +1920+0, DP-2: nvidia-auto-select +0+0; DP-4: 1280x800 +1920+0, DP-2: nvidia-auto-select +0+0; DP-4: 1280x720 +1920+0, DP-2: nvidia-auto-select +0+0; DP-4: 1280x720_60_0 +1920+0, DP-2: nvidia-auto-select +0+0; DP-4: 1280x720_50 +1920+0, DP-2: nvidia-auto-select +0+0; DP-4: 1152x864 +1920+0, DP-2: nvidia-auto-select +0+0; DP-4: 1024x768 +1920+0, DP-2: nvidia-auto-select +0+0; DP-4: 1024x768_70 +1920+0, DP-2: nvidia-auto-select +0+0; DP-4: 1024x768_60 +1920+0, DP-2: nvidia-auto-select +0+0; DP-4: 800x600 +1920+0, DP-2: nvidia-auto-select +0+0; DP-4: 800x600_72 +1920+0, DP-2: nvidia-auto-select +0+0; DP-4: 800x600_60 +1920+0, DP-2: nvidia-auto-select +0+0; DP-4: 800x600_56 +1920+0, DP-2: nvidia-auto-select +0+0; DP-4: 720x576 +1920+0, DP-2: nvidia-auto-select +0+0; DP-4: 720x480 +1920+0, DP-2: nvidia-auto-select +0+0; DP-4: 640x480 +1920+0, DP-2: nvidia-auto-select +0+0; DP-4: 640x480_72 +1920+0, DP-2: nvidia-auto-select +0+0; DP-4: 640x480_60 +1920+0, DP-2: nvidia-auto-select +0+0; DP-4: nvidia-auto-select +1920+0 {viewportin=1920x1200, viewportout=2304x1440+128+0}, DP-2: nvidia-auto-select +0+0; DP-4: nvidia-auto-select +1920+0 {viewportin=1600x1200, viewportout=1920x1440+320+0}, DP-2: nvidia-auto-select +0+0; DP-4: nvidia-auto-select +1920+0 {viewportin=1366x768, viewportout=2560x1439+0+0}, DP-2: nvidia-auto-select +0+0"
# Removed Option "metamodes" "DP-4: nvidia-auto-select +1920+0, DP-2: nvidia-auto-select +0+0"
# Removed Option "metamodes" "DP-4: nvidia-auto-select +0+0"
# Removed Option "metamodes" "DP-2: nvidia-auto-select +0+0"
Identifier "Screen0"
Device "Device0"
Monitor "Monitor0"
DefaultDepth 24
Option "nvidiaXineramaInfoOrder" "DFP-7"
Option "Stereo" "0"
Option "metamodes" "DP-2: nvidia-auto-select +0+0 {ForceCompositionPipeline=On}"
Option "SLI" "Off"
Option "MultiGPU" "Off"
Option "BaseMosaic" "off"
SubSection "Display"
Depth 24
EndSubSection
EndSection
Section "Screen"
Identifier "Screen1"
Device "Device1"
Monitor "Monitor1"
DefaultDepth 24
Option "Stereo" "0"
Option "metamodes" "DP-4: nvidia-auto-select +0+0 {AllowGSYNC=Off} {ForceCompositionPipeline=On}"
Option "SLI" "Off"
Depth 24
EndSubSection
EndSection
Anyone has the solution?
Thanks!
PS: Sorry for my bad english, I’m french
