Hello,
I have new installation of Manjaro and I have two monitors connected to my GPU. Primary one throught DP and works fine, but second one connected through DVI-D act as if it was properly connected and working (can drag windows on it an stuff), but the actuall screen is black.
I have dual boot with Win10 where both monitors work fine. The secondary one works even on Manjaro’s UEFI screen while booting up.
I had same problem on Ubuntu where I fixed it by accident and I don’t know how to reproduce it… Also I’m beginner so idk what I’m doing.
Any help would be appreciated, thanks for any advice
inxi -Fza
System: Kernel: 5.10.42-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.10-x86_64 root=UUID=b6663b10-1166-4611-bf0a-e58a9048d682 rw quiet apparmor=1
Desktop: KDE Plasma 5.21.5 tk: Qt 5.15.2 wm: kwin_x11 vt: 7 dm: LightDM 1.30.0 Distro: Manjaro Linux
base: Arch Linux
Machine: Type: Desktop System: MSI product: MS-7978 v: 2.0 serial: <filter>
Mobo: MSI model: B150 GAMING M3 (MS-7978) v: 2.0 serial: <filter> UEFI: American Megatrends v: B.10
date: 09/06/2015
Battery: Device-1: hidpp_battery_0 model: Logitech Wireless Mouse MX Master 3 serial: <filter>
charge: 55% (should be ignored) rechargeable: yes status: Discharging
CPU: Info: Quad Core model: Intel Core i5-6500 bits: 64 type: MCP arch: Skylake-S family: 6 model-id: 5E (94)
stepping: 3 microcode: E2 cache: L2: 6 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 25610
Speed: 800 MHz min/max: 800/3600 MHz Core speeds (MHz): 1: 800 2: 800 3: 800 4: 800
Type: l1tf mitigation: PTE Inversion; VMX: conditional cache flushes, SMT disabled
Type: spectre_v2 mitigation: Full generic retpoline, IBPB: conditional, IBRS_FW, STIBP: disabled, RSB filling
Type: tsx_async_abort mitigation: Clear CPU buffers; SMT disabled
Graphics: Device-1: Advanced Micro Devices [AMD/ATI] Tonga PRO [Radeon R9 285/380] vendor: PC Partner Limited driver: amdgpu
v: kernel bus-ID: 01:00.0 chip-ID: 1002:6939 class-ID: 0300
Device-2: Z-Star Micro ZC0303 Webcam type: USB driver: gspca_zc3xx bus-ID: 1-2:2 chip-ID: 0ac8:303b class-ID: ff00
Display: x11 server: X.Org 1.20.11 compositor: kwin_x11 driver: loaded: ati,modesetting unloaded: amdgpu
alternate: fbdev,vesa display-ID: :0 screens: 1
Screen-1: 0 s-res: 4480x1440 s-dpi: 96 s-size: 1185x381mm (46.7x15.0") s-diag: 1245mm (49")
Monitor-1: DP-1 res: 2560x1440 hz: 60 dpi: 109 size: 597x336mm (23.5x13.2") diag: 685mm (27")
Monitor-2: DVI-D-2 res: 1920x1080 hz: 60 dpi: 102 size: 477x268mm (18.8x10.6") diag: 547mm (21.5")
OpenGL: renderer: AMD Radeon R9 380 Series (TONGA DRM 3.40.0 5.10.42-1-MANJARO LLVM 12.0.0) v: 4.6 Mesa 21.1.2
direct render: Yes
Audio: Device-1: Intel 100 Series/C230 Series Family HD Audio vendor: Micro-Star MSI driver: snd_hda_intel v: kernel
bus-ID: 00:1f.3 chip-ID: 8086:a170 class-ID: 0403
Device-2: Advanced Micro Devices [AMD/ATI] Tonga HDMI Audio [Radeon R9 285/380] vendor: PC Partner Limited
driver: snd_hda_intel v: kernel bus-ID: 01:00.1 chip-ID: 1002:aad8 class-ID: 0403
Sound Server-1: ALSA v: k5.10.42-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.30 running: no
Network: Device-1: Qualcomm Atheros Killer E2400 Gigabit Ethernet vendor: Micro-Star MSI driver: alx v: kernel port: d000
bus-ID: 05:00.0 chip-ID: 1969:e0a1 class-ID: 0200
IF: enp5s0 state: down mac: <filter>
Device-2: Edimax Edimax AC600 USB type: USB driver: rtl88XXau bus-ID: 1-5:3 chip-ID: 7392:a812 class-ID: 0000
serial: <filter>
IF: wlp0s20f0u5 state: up mac: <filter>
Bluetooth: Device-1: Realtek Bluetooth Radio type: USB driver: btusb v: 0.8 bus-ID: 1-11:5 chip-ID: 0bda:8771 class-ID: e001
serial: <filter>
Drives: Local Storage: total: 1.99 TiB used: 1.61 TiB (81.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000DM003-1ER162 size: 931.51 GiB block-size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s rotation: 7200 rpm serial: <filter> rev: CC45 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Samsung model: HD642JJ size: 596.17 GiB block-size: physical: 512 B
logical: 512 B speed: 3.0 Gb/s serial: <filter> rev: 1113 scheme: MBR
ID-3: /dev/sdc maj-min: 8:32 vendor: Kingston model: SKC600512G size: 476.94 GiB block-size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s rotation: SSD serial: <filter> rev: 0102 scheme: GPT
ID-4: /dev/sdd maj-min: 8:48 type: USB vendor: Kingston model: DataTraveler 3.0 size: 28.91 GiB block-size:
physical: 512 B logical: 512 B serial: <filter> rev: PMAP scheme: MBR
Partition: ID-1: / raw-size: 49.38 GiB size: 48.3 GiB (97.82%) used: 8.55 GiB (17.7%) fs: ext4 dev: /dev/sdc4 maj-min: 8:36
ID-2: /boot/efi raw-size: 100 MiB size: 96 MiB (96.00%) used: 27.6 MiB (28.8%) fs: vfat dev: /dev/sdc1
maj-min: 8:33
Swap: Alert: No swap data was found.
Sensors: System Temperatures: cpu: 43.5 C mobo: 29.8 C gpu: amdgpu temp: 62.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 650
Info: Processes: 206 Uptime: 45m wakeups: 5 Memory: 31.3 GiB used: 2.61 GiB (8.4%) Init: systemd v: 248 tool: systemctl
Compilers: gcc: 11.1.0 Packages: pacman: 1201 lib: 323 flatpak: 0 Shell: Bash v: 5.1.8 running-in: konsole
inxi: 3.3.04
xrandr --verbose
Screen 0: minimum 320 x 200, current 4480 x 1440, maximum 16384 x 16384
DP-1 connected primary 2560x1440+0+0 (0x4a) normal (normal left inverted right x axis y axis) 597mm x 336mm
Identifier: 0x45
Timestamp: 2589738
Subpixel: unknown
Gamma: 1.0:1.0:1.0
Brightness: 1.0
Clones:
CRTC: 0
CRTCs: 1 0 2 3 4 5
Transform: 1.000000 0.000000 0.000000
0.000000 1.000000 0.000000
0.000000 0.000000 1.000000
filter:
EDID:
00ffffffffffff0006b3052701010101
1c1e0104b53c22783b9325ad4f44a926
0d5054bfef00714f81809500d1c00101
010101010101565e00a0a0a029503020
350055502100001c000000fd003090df
df3b010a202020202020000000fc0056
47323741514c31410a202020000000ff
004c374c4d51533032313331320a015f
020327f14c90111213040e0f1d1e1f40
3f2309070783010000e305e001e60607
01737300e2006a9ee80078a0a0675008
20980455502100001a6fc200a0a0a055
503020350055502100001a5aa000a0a0
a046503020350055502100001a000000
00000000000000000000000000000000
000000000000000000000000000000a1
subconnector: Native
supported: Unknown, VGA, DVI-D, HDMI, DP, Wireless, Native
vrr_capable: 1
range: (0, 1)
max bpc: 8
range: (8, 16)
underscan vborder: 0
range: (0, 128)
underscan hborder: 0
range: (0, 128)
underscan: off
supported: off, on, auto
scaling mode: None
supported: None, Full, Center, Full aspect
link-status: Good
supported: Good, Bad
CONNECTOR_ID: 71
supported: 71
non-desktop: 0
range: (0, 1)
2560x1440 (0x4a) 241.500MHz -HSync +VSync *current +preferred
h: width 2560 start 2608 end 2640 total 2720 skew 0 clock 88.79KHz
v: height 1440 start 1443 end 1448 total 1481 clock 59.95Hz
2560x1440 (0x4b) 595.500MHz +HSync -VSync
h: width 2560 start 2568 end 2600 total 2680 skew 0 clock 222.20KHz
v: height 1440 start 1465 end 1473 total 1543 clock 144.01Hz
2560x1440 (0x4c) 497.750MHz +HSync -VSync
h: width 2560 start 2608 end 2640 total 2720 skew 0 clock 183.00KHz
v: height 1440 start 1443 end 1448 total 1525 clock 120.00Hz
2560x1440 (0x4d) 410.500MHz +HSync -VSync
h: width 2560 start 2608 end 2640 total 2720 skew 0 clock 150.92KHz
v: height 1440 start 1443 end 1448 total 1510 clock 99.95Hz
1920x1440 (0x4e) 341.350MHz -HSync +VSync
h: width 1920 start 2072 end 2288 total 2656 skew 0 clock 128.52KHz
v: height 1440 start 1441 end 1444 total 1512 clock 85.00Hz
1920x1440 (0x4f) 297.000MHz -HSync +VSync
h: width 1920 start 2064 end 2288 total 2640 skew 0 clock 112.50KHz
v: height 1440 start 1441 end 1444 total 1500 clock 75.00Hz
1920x1440 (0x50) 234.000MHz -HSync +VSync
h: width 1920 start 2048 end 2256 total 2600 skew 0 clock 90.00KHz
v: height 1440 start 1441 end 1444 total 1500 clock 60.00Hz
1856x1392 (0x51) 288.000MHz -HSync +VSync
h: width 1856 start 1984 end 2208 total 2560 skew 0 clock 112.50KHz
v: height 1392 start 1393 end 1396 total 1500 clock 75.00Hz
1856x1392 (0x52) 218.300MHz -HSync +VSync
h: width 1856 start 1952 end 2176 total 2528 skew 0 clock 86.35KHz
v: height 1392 start 1393 end 1396 total 1439 clock 60.01Hz
1792x1344 (0x53) 261.000MHz -HSync +VSync
h: width 1792 start 1888 end 2104 total 2456 skew 0 clock 106.27KHz
v: height 1344 start 1345 end 1348 total 1417 clock 75.00Hz
1792x1344 (0x54) 204.800MHz -HSync +VSync
h: width 1792 start 1920 end 2120 total 2448 skew 0 clock 83.66KHz
v: height 1344 start 1345 end 1348 total 1394 clock 60.01Hz
2048x1152 (0x55) 406.500MHz -HSync +VSync DoubleScan
h: width 2048 start 2220 end 2444 total 2840 skew 0 clock 143.13KHz
v: height 1152 start 1153 end 1156 total 1193 clock 59.99Hz
2048x1152 (0x56) 302.500MHz +HSync -VSync DoubleScan
h: width 2048 start 2072 end 2088 total 2128 skew 0 clock 142.15KHz
v: height 1152 start 1153 end 1156 total 1185 clock 59.98Hz
2048x1152 (0x57) 197.000MHz -HSync +VSync
h: width 2048 start 2184 end 2400 total 2752 skew 0 clock 71.58KHz
v: height 1152 start 1155 end 1160 total 1195 clock 59.90Hz
2048x1152 (0x58) 156.750MHz +HSync -VSync
h: width 2048 start 2096 end 2128 total 2208 skew 0 clock 70.99KHz
v: height 1152 start 1155 end 1160 total 1185 clock 59.91Hz
1920x1200 (0x59) 241.500MHz -HSync +VSync
h: width 1920 start 2608 end 2640 total 2720 skew 0 clock 88.79KHz
v: height 1200 start 1443 end 1448 total 1481 clock 59.95Hz
1920x1200 (0x5a) 193.250MHz -HSync +VSync
h: width 1920 start 2056 end 2256 total 2592 skew 0 clock 74.56KHz
v: height 1200 start 1203 end 1209 total 1245 clock 59.88Hz
1920x1200 (0x5b) 154.000MHz +HSync -VSync
h: width 1920 start 1968 end 2000 total 2080 skew 0 clock 74.04KHz
v: height 1200 start 1203 end 1209 total 1235 clock 59.95Hz
1920x1080 (0x5c) 356.375MHz -HSync +VSync DoubleScan
h: width 1920 start 2080 end 2288 total 2656 skew 0 clock 134.18KHz
v: height 1080 start 1081 end 1084 total 1118 clock 60.01Hz
1920x1080 (0x5d) 297.000MHz +HSync +VSync
h: width 1920 start 2008 end 2052 total 2200 skew 0 clock 135.00KHz
v: height 1080 start 1084 end 1089 total 1125 clock 120.00Hz
1920x1080 (0x5e) 297.000MHz +HSync +VSync
h: width 1920 start 2448 end 2492 total 2640 skew 0 clock 112.50KHz
v: height 1080 start 1084 end 1089 total 1125 clock 100.00Hz
1920x1080 (0x5f) 296.703MHz +HSync +VSync
h: width 1920 start 2008 end 2052 total 2200 skew 0 clock 134.87KHz
v: height 1080 start 1084 end 1089 total 1125 clock 119.88Hz
1920x1080 (0x60) 266.500MHz +HSync -VSync DoubleScan
h: width 1920 start 1944 end 1960 total 2000 skew 0 clock 133.25KHz
v: height 1080 start 1081 end 1084 total 1111 clock 59.97Hz
1920x1080 (0x61) 173.000MHz -HSync +VSync
h: width 1920 start 2048 end 2248 total 2576 skew 0 clock 67.16KHz
v: height 1080 start 1083 end 1088 total 1120 clock 59.96Hz
1920x1080 (0x62) 148.500MHz -HSync -VSync
h: width 1920 start 2008 end 2052 total 2200 skew 0 clock 67.50KHz
v: height 1080 start 1084 end 1089 total 1125 clock 60.00Hz
1920x1080 (0x63) 148.500MHz +HSync +VSync
1920x1080 (0x64) 148.500MHz +HSync +VSync
h: width 1920 start 2448 end 2492 total 2640 skew 0 clock 56.25KHz
v: height 1080 start 1084 end 1089 total 1125 clock 50.00Hz
1920x1080 (0x65) 148.352MHz +HSync +VSync
h: width 1920 start 2008 end 2052 total 2200 skew 0 clock 67.43KHz
v: height 1080 start 1084 end 1089 total 1125 clock 59.94Hz
1920x1080 (0x66) 138.500MHz +HSync -VSync
h: width 1920 start 1968 end 2000 total 2080 skew 0 clock 66.59KHz
v: height 1080 start 1083 end 1088 total 1111 clock 59.93Hz
1600x1200 (0x67) 241.500MHz -HSync +VSync
h: width 1600 start 2608 end 2640 total 2720 skew 0 clock 88.79KHz
1600x1200 (0x68) 229.500MHz +HSync +VSync
h: width 1600 start 1664 end 1856 total 2160 skew 0 clock 106.25KHz
v: height 1200 start 1201 end 1204 total 1250 clock 85.00Hz
1600x1200 (0x69) 202.500MHz +HSync +VSync
h: width 1600 start 1664 end 1856 total 2160 skew 0 clock 93.75KHz
v: height 1200 start 1201 end 1204 total 1250 clock 75.00Hz
1600x1200 (0x6a) 189.000MHz +HSync +VSync
h: width 1600 start 1664 end 1856 total 2160 skew 0 clock 87.50KHz
v: height 1200 start 1201 end 1204 total 1250 clock 70.00Hz
1600x1200 (0x6b) 175.500MHz +HSync +VSync
h: width 1600 start 1664 end 1856 total 2160 skew 0 clock 81.25KHz
v: height 1200 start 1201 end 1204 total 1250 clock 65.00Hz
1600x1200 (0x6c) 162.000MHz +HSync +VSync
h: width 1600 start 1664 end 1856 total 2160 skew 0 clock 75.00KHz
v: height 1200 start 1201 end 1204 total 1250 clock 60.00Hz
1680x1050 (0x6d) 241.500MHz -HSync +VSync
h: width 1680 start 2608 end 2640 total 2720 skew 0 clock 88.79KHz
v: height 1050 start 1443 end 1448 total 1481 clock 59.95Hz
1680x1050 (0x6e) 146.250MHz -HSync +VSync
h: width 1680 start 1784 end 1960 total 2240 skew 0 clock 65.29KHz
v: height 1050 start 1053 end 1059 total 1089 clock 59.95Hz
1680x1050 (0x6f) 119.000MHz +HSync -VSync
h: width 1680 start 1728 end 1760 total 1840 skew 0 clock 64.67KHz
v: height 1050 start 1053 end 1059 total 1080 clock 59.88Hz
1400x1050 (0x70) 155.800MHz +HSync +VSync
h: width 1400 start 1464 end 1784 total 1912 skew 0 clock 81.49KHz
v: height 1050 start 1052 end 1064 total 1090 clock 74.76Hz
1400x1050 (0x71) 122.000MHz +HSync +VSync
h: width 1400 start 1488 end 1640 total 1880 skew 0 clock 64.89KHz
v: height 1050 start 1052 end 1064 total 1082 clock 59.98Hz
1600x900 (0x72) 246.000MHz -HSync +VSync DoubleScan
h: width 1600 start 1728 end 1900 total 2200 skew 0 clock 111.82KHz
v: height 900 start 901 end 904 total 932 clock 59.99Hz
1600x900 (0x73) 186.500MHz +HSync -VSync DoubleScan
h: width 1600 start 1624 end 1640 total 1680 skew 0 clock 111.01KHz
v: height 900 start 901 end 904 total 926 clock 59.94Hz
1600x900 (0x74) 118.250MHz -HSync +VSync
h: width 1600 start 1696 end 1856 total 2112 skew 0 clock 55.99KHz
v: height 900 start 903 end 908 total 934 clock 59.95Hz
1600x900 (0x75) 97.500MHz +HSync -VSync
h: width 1600 start 1648 end 1680 total 1760 skew 0 clock 55.40KHz
v: height 900 start 903 end 908 total 926 clock 59.82Hz
1280x1024 (0x76) 157.500MHz +HSync +VSync
h: width 1280 start 1344 end 1504 total 1728 skew 0 clock 91.15KHz
v: height 1024 start 1025 end 1028 total 1072 clock 85.02Hz
1280x1024 (0x77) 135.000MHz +HSync +VSync
h: width 1280 start 1296 end 1440 total 1688 skew 0 clock 79.98KHz
v: height 1024 start 1025 end 1028 total 1066 clock 75.02Hz
1280x1024 (0x78) 108.000MHz +HSync +VSync
h: width 1280 start 1328 end 1440 total 1688 skew 0 clock 63.98KHz
v: height 1024 start 1025 end 1028 total 1066 clock 60.02Hz
1440x900 (0x79) 106.500MHz -HSync +VSync
h: width 1440 start 1520 end 1672 total 1904 skew 0 clock 55.93KHz
v: height 900 start 903 end 909 total 934 clock 59.89Hz
1400x900 (0x7a) 103.500MHz -HSync +VSync
h: width 1400 start 1480 end 1624 total 1848 skew 0 clock 56.01KHz
v: height 900 start 903 end 913 total 934 clock 59.96Hz
1400x900 (0x7b) 86.500MHz +HSync -VSync
h: width 1400 start 1448 end 1480 total 1560 skew 0 clock 55.45KHz
v: height 900 start 903 end 913 total 926 clock 59.88Hz
1280x960 (0x7c) 148.500MHz +HSync +VSync
h: width 1280 start 1344 end 1504 total 1728 skew 0 clock 85.94KHz
v: height 960 start 961 end 964 total 1011 clock 85.00Hz
1280x960 (0x7d) 108.000MHz +HSync +VSync
h: width 1280 start 1376 end 1488 total 1800 skew 0 clock 60.00KHz
v: height 960 start 961 end 964 total 1000 clock 60.00Hz
1440x810 (0x7e) 198.125MHz -HSync +VSync DoubleScan
h: width 1440 start 1548 end 1704 total 1968 skew 0 clock 100.67KHz
v: height 810 start 811 end 814 total 839 clock 60.00Hz
1440x810 (0x7f) 151.875MHz +HSync -VSync DoubleScan
h: width 1440 start 1464 end 1480 total 1520 skew 0 clock 99.92KHz
v: height 810 start 811 end 814 total 833 clock 59.97Hz
1368x768 (0x80) 85.250MHz -HSync +VSync
h: width 1368 start 1440 end 1576 total 1784 skew 0 clock 47.79KHz
v: height 768 start 771 end 781 total 798 clock 59.88Hz
1368x768 (0x81) 72.250MHz +HSync -VSync
h: width 1368 start 1416 end 1448 total 1528 skew 0 clock 47.28KHz
v: height 768 start 771 end 781 total 790 clock 59.85Hz
1280x800 (0x82) 241.500MHz -HSync +VSync
h: width 1280 start 2608 end 2640 total 2720 skew 0 clock 88.79KHz
v: height 800 start 1443 end 1448 total 1481 clock 59.95Hz
1280x800 (0x83) 174.250MHz -HSync +VSync DoubleScan
h: width 1280 start 1380 end 1516 total 1752 skew 0 clock 99.46KHz
v: height 800 start 801 end 804 total 829 clock 59.99Hz
1280x800 (0x84) 134.250MHz +HSync -VSync DoubleScan
h: width 1280 start 1304 end 1320 total 1360 skew 0 clock 98.71KHz
v: height 800 start 801 end 804 total 823 clock 59.97Hz
1280x800 (0x85) 83.500MHz -HSync +VSync
h: width 1280 start 1352 end 1480 total 1680 skew 0 clock 49.70KHz
v: height 800 start 803 end 809 total 831 clock 59.81Hz
1280x800 (0x86) 71.000MHz +HSync -VSync
h: width 1280 start 1328 end 1360 total 1440 skew 0 clock 49.31KHz
v: height 800 start 803 end 809 total 823 clock 59.91Hz
1152x864 (0x87) 108.000MHz +HSync +VSync
h: width 1152 start 1216 end 1344 total 1600 skew 0 clock 67.50KHz
v: height 864 start 865 end 868 total 900 clock 75.00Hz
1280x720 (0x88) 156.125MHz -HSync +VSync DoubleScan
h: width 1280 start 1376 end 1512 total 1744 skew 0 clock 89.52KHz
v: height 720 start 721 end 724 total 746 clock 60.00Hz
1280x720 (0x89) 120.750MHz +HSync -VSync DoubleScan
h: width 1280 start 1304 end 1320 total 1360 skew 0 clock 88.79KHz
v: height 720 start 721 end 724 total 740 clock 59.99Hz
1280x720 (0x8a) 74.500MHz -HSync +VSync
h: width 1280 start 1344 end 1472 total 1664 skew 0 clock 44.77KHz
v: height 720 start 723 end 728 total 748 clock 59.86Hz
1280x720 (0x8b) 74.250MHz +HSync +VSync
h: width 1280 start 1390 end 1430 total 1650 skew 0 clock 45.00KHz
v: height 720 start 725 end 730 total 750 clock 60.00Hz
1280x720 (0x8c) 74.250MHz +HSync +VSync
h: width 1280 start 1720 end 1760 total 1980 skew 0 clock 37.50KHz
v: height 720 start 725 end 730 total 750 clock 50.00Hz
1280x720 (0x8d) 74.176MHz +HSync +VSync
h: width 1280 start 1390 end 1430 total 1650 skew 0 clock 44.96KHz
v: height 720 start 725 end 730 total 750 clock 59.94Hz
1280x720 (0x8e) 63.750MHz +HSync -VSync
h: width 1280 start 1328 end 1360 total 1440 skew 0 clock 44.27KHz
v: height 720 start 723 end 728 total 741 clock 59.74Hz
1440x576 (0x8f) 54.000MHz -HSync -VSync
h: width 1440 start 1464 end 1592 total 1728 skew 0 clock 31.25KHz
v: height 576 start 581 end 586 total 625 clock 50.00Hz
1024x768 (0x90) 194.020MHz -HSync +VSync DoubleScan
h: width 1024 start 1108 end 1220 total 1416 skew 0 clock 137.02KHz
v: height 768 start 768 end 770 total 806 clock 85.00Hz
1024x768 (0x91) 170.240MHz -HSync +VSync DoubleScan
h: width 1024 start 1108 end 1220 total 1416 skew 0 clock 120.23KHz
v: height 768 start 768 end 770 total 801 clock 75.05Hz
1024x768 (0x92) 133.475MHz -HSync +VSync DoubleScan
h: width 1024 start 1100 end 1212 total 1400 skew 0 clock 95.34KHz
v: height 768 start 768 end 770 total 794 clock 60.04Hz
1024x768 (0x93) 94.500MHz +HSync +VSync
h: width 1024 start 1072 end 1168 total 1376 skew 0 clock 68.68KHz
v: height 768 start 769 end 772 total 808 clock 85.00Hz
1024x768 (0x94) 78.750MHz +HSync +VSync
h: width 1024 start 1040 end 1136 total 1312 skew 0 clock 60.02KHz
v: height 768 start 769 end 772 total 800 clock 75.03Hz
1024x768 (0x95) 75.000MHz -HSync -VSync
h: width 1024 start 1048 end 1184 total 1328 skew 0 clock 56.48KHz
v: height 768 start 771 end 777 total 806 clock 70.07Hz
1024x768 (0x96) 65.000MHz -HSync -VSync
h: width 1024 start 1048 end 1184 total 1344 skew 0 clock 48.36KHz
v: height 768 start 771 end 777 total 806 clock 60.00Hz
1024x768i (0x97) 44.900MHz +HSync +VSync Interlace
h: width 1024 start 1032 end 1208 total 1264 skew 0 clock 35.52KHz
v: height 768 start 768 end 776 total 817 clock 86.96Hz
960x720 (0x98) 170.675MHz -HSync +VSync DoubleScan
h: width 960 start 1036 end 1144 total 1328 skew 0 clock 128.52KHz
v: height 720 start 720 end 722 total 756 clock 85.00Hz
960x720 (0x99) 148.500MHz -HSync +VSync DoubleScan
h: width 960 start 1032 end 1144 total 1320 skew 0 clock 112.50KHz
v: height 720 start 720 end 722 total 750 clock 75.00Hz
960x720 (0x9a) 117.000MHz -HSync +VSync DoubleScan
h: width 960 start 1024 end 1128 total 1300 skew 0 clock 90.00KHz
v: height 720 start 720 end 722 total 750 clock 60.00Hz
1440x480 (0x9b) 54.054MHz -HSync -VSync
h: width 1440 start 1472 end 1596 total 1716 skew 0 clock 31.50KHz
v: height 480 start 489 end 495 total 525 clock 60.00Hz
1440x480 (0x9c) 54.000MHz -HSync -VSync
h: width 1440 start 1472 end 1596 total 1716 skew 0 clock 31.47KHz
v: height 480 start 489 end 495 total 525 clock 59.94Hz
928x696 (0x9d) 144.000MHz -HSync +VSync DoubleScan
h: width 928 start 992 end 1104 total 1280 skew 0 clock 112.50KHz
v: height 696 start 696 end 698 total 750 clock 75.00Hz
928x696 (0x9e) 109.150MHz -HSync +VSync DoubleScan
h: width 928 start 976 end 1088 total 1264 skew 0 clock 86.35KHz
v: height 696 start 696 end 698 total 719 clock 60.05Hz
896x672 (0x9f) 130.500MHz -HSync +VSync DoubleScan
h: width 896 start 944 end 1052 total 1228 skew 0 clock 106.27KHz
v: height 672 start 672 end 674 total 708 clock 75.05Hz
896x672 (0xa0) 102.400MHz -HSync +VSync DoubleScan
h: width 896 start 960 end 1060 total 1224 skew 0 clock 83.66KHz
v: height 672 start 672 end 674 total 697 clock 60.01Hz
1024x576 (0xa1) 98.500MHz -HSync +VSync DoubleScan
h: width 1024 start 1092 end 1200 total 1376 skew 0 clock 71.58KHz
v: height 576 start 577 end 580 total 597 clock 59.95Hz
1024x576 (0xa2) 78.375MHz +HSync -VSync DoubleScan
h: width 1024 start 1048 end 1064 total 1104 skew 0 clock 70.99KHz
v: height 576 start 577 end 580 total 592 clock 59.96Hz
1024x576 (0xa3) 46.500MHz -HSync +VSync
h: width 1024 start 1064 end 1160 total 1296 skew 0 clock 35.88KHz
v: height 576 start 579 end 584 total 599 clock 59.90Hz
1024x576 (0xa4) 42.000MHz +HSync -VSync
h: width 1024 start 1072 end 1104 total 1184 skew 0 clock 35.47KHz
v: height 576 start 579 end 584 total 593 clock 59.82Hz
960x600 (0xa5) 96.625MHz -HSync +VSync DoubleScan
h: width 960 start 1028 end 1128 total 1296 skew 0 clock 74.56KHz
v: height 600 start 601 end 604 total 622 clock 59.93Hz
960x600 (0xa6) 77.000MHz +HSync -VSync DoubleScan
h: width 960 start 984 end 1000 total 1040 skew 0 clock 74.04KHz
v: height 600 start 601 end 604 total 617 clock 60.00Hz
832x624 (0xa7) 57.284MHz -HSync -VSync
h: width 832 start 864 end 928 total 1152 skew 0 clock 49.73KHz
v: height 624 start 625 end 628 total 667 clock 74.55Hz
960x540 (0xa8) 86.500MHz -HSync +VSync DoubleScan
h: width 960 start 1024 end 1124 total 1288 skew 0 clock 67.16KHz
v: height 540 start 541 end 544 total 560 clock 59.96Hz
960x540 (0xa9) 69.250MHz +HSync -VSync DoubleScan
h: width 960 start 984 end 1000 total 1040 skew 0 clock 66.59KHz
v: height 540 start 541 end 544 total 555 clock 59.99Hz
960x540 (0xaa) 40.750MHz -HSync +VSync
h: width 960 start 992 end 1088 total 1216 skew 0 clock 33.51KHz
v: height 540 start 543 end 548 total 562 clock 59.63Hz
960x540 (0xab) 37.250MHz +HSync -VSync
h: width 960 start 1008 end 1040 total 1120 skew 0 clock 33.26KHz
v: height 540 start 543 end 548 total 556 clock 59.82Hz
800x600 (0xac) 114.750MHz +HSync +VSync DoubleScan
h: width 800 start 832 end 928 total 1080 skew 0 clock 106.25KHz
v: height 600 start 600 end 602 total 625 clock 85.00Hz
800x600 (0xad) 101.250MHz +HSync +VSync DoubleScan
h: width 800 start 832 end 928 total 1080 skew 0 clock 93.75KHz
v: height 600 start 600 end 602 total 625 clock 75.00Hz
800x600 (0xae) 94.500MHz +HSync +VSync DoubleScan
h: width 800 start 832 end 928 total 1080 skew 0 clock 87.50KHz
v: height 600 start 600 end 602 total 625 clock 70.00Hz
800x600 (0xaf) 87.750MHz +HSync +VSync DoubleScan
h: width 800 start 832 end 928 total 1080 skew 0 clock 81.25KHz
v: height 600 start 600 end 602 total 625 clock 65.00Hz
800x600 (0xb0) 81.000MHz +HSync +VSync DoubleScan
h: width 800 start 832 end 928 total 1080 skew 0 clock 75.00KHz
v: height 600 start 600 end 602 total 625 clock 60.00Hz
800x600 (0xb1) 56.300MHz +HSync +VSync
h: width 800 start 832 end 896 total 1048 skew 0 clock 53.72KHz
v: height 600 start 601 end 604 total 631 clock 85.14Hz
800x600 (0xb2) 50.000MHz +HSync +VSync
h: width 800 start 856 end 976 total 1040 skew 0 clock 48.08KHz
v: height 600 start 637 end 643 total 666 clock 72.19Hz
800x600 (0xb3) 49.500MHz +HSync +VSync
h: width 800 start 816 end 896 total 1056 skew 0 clock 46.88KHz
v: height 600 start 601 end 604 total 625 clock 75.00Hz
800x600 (0xb4) 40.000MHz +HSync +VSync
h: width 800 start 840 end 968 total 1056 skew 0 clock 37.88KHz
v: height 600 start 601 end 605 total 628 clock 60.32Hz
800x600 (0xb5) 36.000MHz +HSync +VSync
h: width 800 start 824 end 896 total 1024 skew 0 clock 35.16KHz
v: height 600 start 601 end 603 total 625 clock 56.25Hz
840x525 (0xb6) 73.125MHz -HSync +VSync DoubleScan
h: width 840 start 892 end 980 total 1120 skew 0 clock 65.29KHz
v: height 525 start 526 end 529 total 544 clock 60.01Hz
840x525 (0xb7) 59.500MHz +HSync -VSync DoubleScan
h: width 840 start 864 end 880 total 920 skew 0 clock 64.67KHz
v: height 525 start 526 end 529 total 540 clock 59.88Hz
864x486 (0xb8) 32.500MHz -HSync +VSync
h: width 864 start 888 end 968 total 1072 skew 0 clock 30.32KHz
v: height 486 start 489 end 494 total 506 clock 59.92Hz
864x486 (0xb9) 30.500MHz +HSync -VSync
h: width 864 start 912 end 944 total 1024 skew 0 clock 29.79KHz
v: height 486 start 489 end 494 total 500 clock 59.57Hz
720x576 (0xba) 27.000MHz -HSync -VSync
h: width 720 start 732 end 796 total 864 skew 0 clock 31.25KHz
700x525 (0xbb) 77.900MHz +HSync +VSync DoubleScan
h: width 700 start 732 end 892 total 956 skew 0 clock 81.49KHz
v: height 525 start 526 end 532 total 545 clock 74.76Hz
700x525 (0xbc) 61.000MHz +HSync +VSync DoubleScan
h: width 700 start 744 end 820 total 940 skew 0 clock 64.89KHz
v: height 525 start 526 end 532 total 541 clock 59.98Hz
800x450 (0xbd) 59.125MHz -HSync +VSync DoubleScan
h: width 800 start 848 end 928 total 1056 skew 0 clock 55.99KHz
v: height 450 start 451 end 454 total 467 clock 59.95Hz
800x450 (0xbe) 48.750MHz +HSync -VSync DoubleScan
h: width 800 start 824 end 840 total 880 skew 0 clock 55.40KHz
v: height 450 start 451 end 454 total 463 clock 59.82Hz
640x512 (0xbf) 78.750MHz +HSync +VSync DoubleScan
h: width 640 start 672 end 752 total 864 skew 0 clock 91.15KHz
v: height 512 start 512 end 514 total 536 clock 85.02Hz
640x512 (0xc0) 67.500MHz +HSync +VSync DoubleScan
h: width 640 start 648 end 720 total 844 skew 0 clock 79.98KHz
v: height 512 start 512 end 514 total 533 clock 75.02Hz
640x512 (0xc1) 54.000MHz +HSync +VSync DoubleScan
h: width 640 start 664 end 720 total 844 skew 0 clock 63.98KHz
v: height 512 start 512 end 514 total 533 clock 60.02Hz
700x450 (0xc2) 51.750MHz -HSync +VSync DoubleScan
h: width 700 start 740 end 812 total 924 skew 0 clock 56.01KHz
v: height 450 start 451 end 456 total 467 clock 59.96Hz
700x450 (0xc3) 43.250MHz +HSync -VSync DoubleScan
h: width 700 start 724 end 740 total 780 skew 0 clock 55.45KHz
v: height 450 start 451 end 456 total 463 clock 59.88Hz
640x480 (0xc4) 74.250MHz +HSync +VSync DoubleScan
h: width 640 start 672 end 752 total 864 skew 0 clock 85.94KHz
v: height 480 start 480 end 482 total 505 clock 85.09Hz
640x480 (0xc5) 54.000MHz +HSync +VSync DoubleScan
h: width 640 start 688 end 744 total 900 skew 0 clock 60.00KHz
v: height 480 start 480 end 482 total 500 clock 60.00Hz
640x480 (0xc6) 36.000MHz -HSync -VSync
h: width 640 start 696 end 752 total 832 skew 0 clock 43.27KHz
v: height 480 start 481 end 484 total 509 clock 85.01Hz
640x480 (0xc7) 31.500MHz -HSync -VSync
h: width 640 start 656 end 720 total 840 skew 0 clock 37.50KHz
v: height 480 start 481 end 484 total 500 clock 75.00Hz
640x480 (0xc8) 31.500MHz -HSync -VSync
h: width 640 start 664 end 704 total 832 skew 0 clock 37.86KHz
v: height 480 start 489 end 492 total 520 clock 72.81Hz
640x480 (0xc9) 30.240MHz -HSync -VSync
h: width 640 start 704 end 768 total 864 skew 0 clock 35.00KHz
v: height 480 start 483 end 486 total 525 clock 66.67Hz
640x480 (0xca) 25.200MHz -HSync -VSync
h: width 640 start 656 end 752 total 800 skew 0 clock 31.50KHz
v: height 480 start 490 end 492 total 525 clock 60.00Hz
640x480 (0xcb) 25.175MHz -HSync -VSync
h: width 640 start 656 end 752 total 800 skew 0 clock 31.47KHz
v: height 480 start 490 end 492 total 525 clock 59.94Hz
720x405 (0xcc) 22.500MHz -HSync +VSync
h: width 720 start 744 end 808 total 896 skew 0 clock 25.11KHz
v: height 405 start 408 end 413 total 422 clock 59.51Hz
720x405 (0xcd) 21.750MHz +HSync -VSync
h: width 720 start 768 end 800 total 880 skew 0 clock 24.72KHz
v: height 405 start 408 end 413 total 419 clock 58.99Hz
720x400 (0xce) 35.500MHz -HSync +VSync
h: width 720 start 756 end 828 total 936 skew 0 clock 37.93KHz
v: height 400 start 401 end 404 total 446 clock 85.04Hz
720x400 (0xcf) 28.320MHz -HSync +VSync
h: width 720 start 738 end 846 total 900 skew 0 clock 31.47KHz
v: height 400 start 412 end 414 total 449 clock 70.08Hz
684x384 (0xd0) 42.625MHz -HSync +VSync DoubleScan
h: width 684 start 720 end 788 total 892 skew 0 clock 47.79KHz
v: height 384 start 385 end 390 total 399 clock 59.88Hz
684x384 (0xd1) 36.125MHz +HSync -VSync DoubleScan
h: width 684 start 708 end 724 total 764 skew 0 clock 47.28KHz
v: height 384 start 385 end 390 total 395 clock 59.85Hz
640x400 (0xd2) 41.750MHz -HSync +VSync DoubleScan
h: width 640 start 676 end 740 total 840 skew 0 clock 49.70KHz
v: height 400 start 401 end 404 total 415 clock 59.88Hz
640x400 (0xd3) 35.500MHz +HSync -VSync DoubleScan
h: width 640 start 664 end 680 total 720 skew 0 clock 49.31KHz
v: height 400 start 401 end 404 total 411 clock 59.98Hz
640x400 (0xd4) 31.500MHz -HSync +VSync
h: width 640 start 672 end 736 total 832 skew 0 clock 37.86KHz
v: height 400 start 401 end 404 total 445 clock 85.08Hz
576x432 (0xd5) 54.000MHz +HSync +VSync DoubleScan
h: width 576 start 608 end 672 total 800 skew 0 clock 67.50KHz
v: height 432 start 432 end 434 total 450 clock 75.00Hz
640x360 (0xd6) 37.250MHz -HSync +VSync DoubleScan
h: width 640 start 672 end 736 total 832 skew 0 clock 44.77KHz
v: height 360 start 361 end 364 total 374 clock 59.86Hz
640x360 (0xd7) 31.875MHz +HSync -VSync DoubleScan
h: width 640 start 664 end 680 total 720 skew 0 clock 44.27KHz
v: height 360 start 361 end 364 total 370 clock 59.83Hz
640x360 (0xd8) 18.000MHz -HSync +VSync
h: width 640 start 664 end 720 total 800 skew 0 clock 22.50KHz
v: height 360 start 363 end 368 total 376 clock 59.84Hz
640x360 (0xd9) 17.750MHz +HSync -VSync
h: width 640 start 688 end 720 total 800 skew 0 clock 22.19KHz
v: height 360 start 363 end 368 total 374 clock 59.32Hz
640x350 (0xda) 31.500MHz +HSync -VSync
v: height 350 start 382 end 385 total 445 clock 85.08Hz
512x384 (0xdb) 47.250MHz +HSync +VSync DoubleScan
h: width 512 start 536 end 584 total 688 skew 0 clock 68.68KHz
v: height 384 start 384 end 386 total 404 clock 85.00Hz
512x384 (0xdc) 39.375MHz +HSync +VSync DoubleScan
h: width 512 start 520 end 568 total 656 skew 0 clock 60.02KHz
v: height 384 start 384 end 386 total 400 clock 75.03Hz
512x384 (0xdd) 37.500MHz -HSync -VSync DoubleScan
h: width 512 start 524 end 592 total 664 skew 0 clock 56.48KHz
v: height 384 start 385 end 388 total 403 clock 70.07Hz
512x384 (0xde) 32.500MHz -HSync -VSync DoubleScan
h: width 512 start 524 end 592 total 672 skew 0 clock 48.36KHz
v: height 384 start 385 end 388 total 403 clock 60.00Hz
512x384i (0xdf) 22.450MHz +HSync +VSync Interlace DoubleScan
h: width 512 start 516 end 604 total 632 skew 0 clock 35.52KHz
v: height 384 start 384 end 388 total 408 clock 87.06Hz
512x288 (0xe0) 23.250MHz -HSync +VSync DoubleScan
h: width 512 start 532 end 580 total 648 skew 0 clock 35.88KHz
v: height 288 start 289 end 292 total 299 clock 60.00Hz
512x288 (0xe1) 21.000MHz +HSync -VSync DoubleScan
h: width 512 start 536 end 552 total 592 skew 0 clock 35.47KHz
v: height 288 start 289 end 292 total 296 clock 59.92Hz
416x312 (0xe2) 28.642MHz -HSync -VSync DoubleScan
h: width 416 start 432 end 464 total 576 skew 0 clock 49.73KHz
v: height 312 start 312 end 314 total 333 clock 74.66Hz
480x270 (0xe3) 20.375MHz -HSync +VSync DoubleScan
h: width 480 start 496 end 544 total 608 skew 0 clock 33.51KHz
v: height 270 start 271 end 274 total 281 clock 59.63Hz
480x270 (0xe4) 18.625MHz +HSync -VSync DoubleScan
h: width 480 start 504 end 520 total 560 skew 0 clock 33.26KHz
v: height 270 start 271 end 274 total 278 clock 59.82Hz
400x300 (0xe5) 28.150MHz +HSync +VSync DoubleScan
h: width 400 start 416 end 448 total 524 skew 0 clock 53.72KHz
v: height 300 start 300 end 302 total 315 clock 85.27Hz
400x300 (0xe6) 25.000MHz +HSync +VSync DoubleScan
h: width 400 start 428 end 488 total 520 skew 0 clock 48.08KHz
v: height 300 start 318 end 321 total 333 clock 72.19Hz
400x300 (0xe7) 24.750MHz +HSync +VSync DoubleScan
h: width 400 start 408 end 448 total 528 skew 0 clock 46.88KHz
v: height 300 start 300 end 302 total 312 clock 75.12Hz
400x300 (0xe8) 20.000MHz +HSync +VSync DoubleScan
h: width 400 start 420 end 484 total 528 skew 0 clock 37.88KHz
v: height 300 start 300 end 302 total 314 clock 60.32Hz
400x300 (0xe9) 18.000MHz +HSync +VSync DoubleScan
h: width 400 start 412 end 448 total 512 skew 0 clock 35.16KHz
v: height 300 start 300 end 301 total 312 clock 56.34Hz
432x243 (0xea) 16.250MHz -HSync +VSync DoubleScan
h: width 432 start 444 end 484 total 536 skew 0 clock 30.32KHz
v: height 243 start 244 end 247 total 253 clock 59.92Hz
432x243 (0xeb) 15.250MHz +HSync -VSync DoubleScan
h: width 432 start 456 end 472 total 512 skew 0 clock 29.79KHz
v: height 243 start 244 end 247 total 250 clock 59.57Hz
320x240 (0xec) 18.000MHz -HSync -VSync DoubleScan
h: width 320 start 348 end 376 total 416 skew 0 clock 43.27KHz
v: height 240 start 240 end 242 total 254 clock 85.18Hz
320x240 (0xed) 15.750MHz -HSync -VSync DoubleScan
h: width 320 start 332 end 352 total 416 skew 0 clock 37.86KHz
v: height 240 start 244 end 246 total 260 clock 72.81Hz
320x240 (0xee) 15.750MHz -HSync -VSync DoubleScan
h: width 320 start 328 end 360 total 420 skew 0 clock 37.50KHz
v: height 240 start 240 end 242 total 250 clock 75.00Hz
320x240 (0xef) 12.587MHz -HSync -VSync DoubleScan
h: width 320 start 328 end 376 total 400 skew 0 clock 31.47KHz
v: height 240 start 245 end 246 total 262 clock 60.05Hz
360x202 (0xf0) 11.250MHz -HSync +VSync DoubleScan
h: width 360 start 372 end 404 total 448 skew 0 clock 25.11KHz
v: height 202 start 204 end 206 total 211 clock 59.51Hz
360x202 (0xf1) 10.875MHz +HSync -VSync DoubleScan
h: width 360 start 384 end 400 total 440 skew 0 clock 24.72KHz
v: height 202 start 204 end 206 total 209 clock 59.13Hz
360x200 (0xf2) 17.750MHz -HSync +VSync DoubleScan
h: width 360 start 378 end 414 total 468 skew 0 clock 37.93KHz
v: height 200 start 200 end 202 total 223 clock 85.04Hz
320x200 (0xf3) 15.750MHz -HSync +VSync DoubleScan
h: width 320 start 336 end 368 total 416 skew 0 clock 37.86KHz
v: height 200 start 200 end 202 total 222 clock 85.27Hz
320x180 (0xf4) 9.000MHz -HSync +VSync DoubleScan
h: width 320 start 332 end 360 total 400 skew 0 clock 22.50KHz
v: height 180 start 181 end 184 total 188 clock 59.84Hz
320x180 (0xf5) 8.875MHz +HSync -VSync DoubleScan
h: width 320 start 344 end 360 total 400 skew 0 clock 22.19KHz
v: height 180 start 181 end 184 total 187 clock 59.32Hz
320x175 (0xf6) 15.750MHz +HSync -VSync DoubleScan
v: height 175 start 191 end 192 total 222 clock 85.27Hz
HDMI-1 disconnected (normal left inverted right x axis y axis)
Identifier: 0x46
Timestamp: 2589738
Subpixel: unknown
Clones:
CRTCs: 1 0 2 3 4 5
filter:
vrr_capable: 0
range: (0, 1)
max bpc: 8
range: (8, 16)
range: (0, 128)
range: (0, 128)
underscan: off
scaling mode: None
link-status: Good
CONNECTOR_ID: 77
supported: 77
non-desktop: 0
range: (0, 1)
DVI-D-1 disconnected (normal left inverted right x axis y axis)
Identifier: 0x47
Timestamp: 2589738
Subpixel: unknown
Clones:
CRTCs: 1 0 2 3 4 5
filter:
max bpc: 8
range: (8, 16)
range: (0, 128)
range: (0, 128)
underscan: off
scaling mode: None
link-status: Good
CONNECTOR_ID: 81
supported: 81
non-desktop: 0
range: (0, 1)
DVI-D-2 connected 1920x1080+2560+180 (0x63) normal (normal left inverted right x axis y axis) 477mm x 268mm
Identifier: 0x48
Timestamp: 2589738
Subpixel: unknown
Gamma: 1.0:1.0:1.0
Brightness: 1.0
Clones:
CRTC: 1
CRTCs: 1 0 2 3 4 5
filter:
EDID:
00ffffffffffff001e6d1858965a0200
041501036c301b78ea9535a159579f27
0e5054a54b00714f8180818fb3000101
010101010101023a801871382d40582c
4500dd0c1100001e000000fd00384b1e
530f000a202020202020000000fc0045
323234310a20202020202020000000ff
003130345450534c344a3236320a0052
max bpc: 8
range: (8, 16)
range: (0, 128)
range: (0, 128)
underscan: off
scaling mode: None
link-status: Good
CONNECTOR_ID: 84
supported: 84
non-desktop: 0
range: (0, 1)
1920x1080 (0x63) 148.500MHz +HSync +VSync *current +preferred
1440x900 (0xf7) 148.500MHz +HSync +VSync
h: width 1440 start 2008 end 2052 total 2200 skew 0 clock 67.50KHz
v: height 900 start 1084 end 1089 total 1125 clock 60.00Hz
1280x800 (0xf8) 148.500MHz +HSync +VSync
h: width 1280 start 2008 end 2052 total 2200 skew 0 clock 67.50KHz
v: height 800 start 1084 end 1089 total 1125 clock 60.00Hz
1280x720 (0xf9) 148.500MHz +HSync +VSync
v: height 720 start 1084 end 1089 total 1125 clock 60.00Hz
