Hello,
I’m new to Manjaro but not so new to Linux. I’m having an issue where my second monitor periodically (anywhere from 30 seconds to 10 minutes) turns off for about 2 seconds and turns back on.
The only log output that I can find that could be related to this is the output from /var/log/Xorg.1.log:
My primary monitor does not do this and I’m not sure what the issue could be given that I haven’t noticed this behavior on any other Linux distro I’ve tried on this PC (PopOS, Elementary OS, Debian).
Here are some common log outputs from random posts on this forum but involved Nvidia and monitors. Please let me know if you’d like to see anything else.
Conf / Log Output
/var/log/Xorg.1.log
This doesn’t tell me much because the frequency of the monitor turning off/on is much faster than 2500 seconds.
[ 2024.358] (--) NVIDIA(GPU-0): Acer XF270HU (DFP-2): connected
[ 2024.358] (--) NVIDIA(GPU-0): Acer XF270HU (DFP-2): Internal TMDS
[ 2024.358] (--) NVIDIA(GPU-0): Acer XF270HU (DFP-2): 600.0 MHz maximum pixel clock
[ 2024.404] (--) NVIDIA(GPU-0): Acer XF270HU (DFP-2): connected
[ 2024.404] (--) NVIDIA(GPU-0): Acer XF270HU (DFP-2): Internal TMDS
[ 2024.404] (--) NVIDIA(GPU-0): Acer XF270HU (DFP-2): 600.0 MHz maximum pixel clock
[ 4522.444] (--) NVIDIA(GPU-0): DFP-0: disconnected
[ 4522.444] (--) NVIDIA(GPU-0): DFP-0: Internal DisplayPort
[ 4522.444] (--) NVIDIA(GPU-0): DFP-0: 2660.0 MHz maximum pixel clock
[ 4522.444] (--) NVIDIA(GPU-0): DFP-1: disconnected
[ 4522.445] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[ 4522.445] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[ 4522.491] (--) NVIDIA(GPU-0): Acer XF270HU (DFP-2): connected
[ 4522.491] (--) NVIDIA(GPU-0): Acer XF270HU (DFP-2): Internal TMDS
[ 4522.491] (--) NVIDIA(GPU-0): Acer XF270HU (DFP-2): 600.0 MHz maximum pixel clock
[ 4522.491] (--) NVIDIA(GPU-0): HKC 27E1QA (DFP-3): connected
[ 4522.491] (--) NVIDIA(GPU-0): HKC 27E1QA (DFP-3): Internal DisplayPort
[ 4522.491] (--) NVIDIA(GPU-0): HKC 27E1QA (DFP-3): 2660.0 MHz maximum pixel clock
[ 4522.493] (--) NVIDIA(GPU-0): DFP-4: disconnected
[ 4522.493] (--) NVIDIA(GPU-0): DFP-4: Internal TMDS
[ 4522.493] (--) NVIDIA(GPU-0): DFP-4: 165.0 MHz maximum pixel clock
[ 4522.493] (--) NVIDIA(GPU-0): DFP-5: disconnected
[ 4522.493] (--) NVIDIA(GPU-0): DFP-5: Internal DisplayPort
[ 4522.493] (--) NVIDIA(GPU-0): DFP-5: 2660.0 MHz maximum pixel clock
[ 4522.493] (--) NVIDIA(GPU-0): DFP-6: disconnected
[ 4522.493] (--) NVIDIA(GPU-0): DFP-6: Internal TMDS
[ 4522.493] (--) NVIDIA(GPU-0): DFP-6: 165.0 MHz maximum pixel clock
[ 4522.493] (--) NVIDIA(GPU-0): DFP-7: disconnected
[ 4522.493] (--) NVIDIA(GPU-0): DFP-7: Internal DisplayPort
[ 4522.493] (--) NVIDIA(GPU-0): DFP-7: 2660.0 MHz maximum pixel clock
nvidia-smi
Fri Mar 10 08:40:23 2023
| NVIDIA-SMI 525.89.02 Driver Version: 525.89.02 CUDA Version: 12.0 |
| GPU Name Persistence-M| Bus-Id Disp.A | Volatile Uncorr. ECC |
| Fan Temp Perf Pwr:Usage/Cap| Memory-Usage | GPU-Util Compute M. |
| | | MIG M. |
| 0 NVIDIA GeForce ... Off | 00000000:01:00.0 On | N/A |
| 25% 44C P0 56W / 215W | 554MiB / 8192MiB | 23% Default |
| | | N/A |
| Processes: |
| GPU GI CI PID Type Process name GPU Memory |
| ID ID Usage |
| 0 N/A N/A 1038 G /usr/lib/Xorg 34MiB |
| 0 N/A N/A 1119 G /usr/lib/Xorg 252MiB |
| 0 N/A N/A 1320 G budgie-wm 70MiB |
| 0 N/A N/A 1866 G /usr/lib/firefox/firefox 176MiB |
| 0 N/A N/A 3814 G ...RendererForSitePerProcess 16MiB |
inxi --admin --verbosity=7 --filter --width
Kernel: 6.1.12-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=002bf6d6-6ead-4965-80bc-3f10162fbaa2 rw quiet apparmor=1
security=apparmor resume=UUID=03f27fee-f86b-4885-8dab-3aa0e856b7a7
udev.log_priority=3
Desktop: Budgie v: 10.7 info: budgie-panel wm: budgie-wm vt: 2 dm: LightDM
v: 1.32.0 Distro: Manjaro Linux base: Arch Linux
Type: Desktop System: Gigabyte product: Z370P D3 v: N/A
serial: <superuser required>
Mobo: Gigabyte model: Z370P D3-CF serial: <superuser required>
UEFI: American Megatrends v: F15 date: 11/13/2021
Device-1: hidpp_battery_0 model: Logitech G604 Wireless Gaming Mouse
serial: <filter> charge: 100% (should be ignored) rechargeable: yes
status: discharging
RAM: total: 31.28 GiB used: 3.76 GiB (12.0%)
Info: model: Intel Core i7-8700K bits: 64 type: MT MCP arch: Coffee Lake
gen: core 8 level: v3 note: check built: 2018 process: Intel 14nm family: 6
model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xF0
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 1.5 MiB desc: 6x256 KiB
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 1525 high: 3700 min/max: 800/4700 scaling:
driver: intel_pstate governor: powersave cores: 1: 800 2: 800 3: 3700 4: 800
5: 800 6: 800 7: 800 8: 3700 9: 800 10: 3700 11: 800 12: 801
bogomips: 88824
dtherm dts ept ept_ad erms est f16c flexpriority flush_l1d fma fpu
intel_pt invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor
movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm
pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand rdseed rdtscp
rep_good sdbg sep smap smep smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp
vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
vulnerable
Type: spectre_v2 mitigation: IBRS, IBPB: conditional, RSB filling,
PBRSB-eIBRS: Not affected
Device-1: NVIDIA TU104 [GeForce RTX 2080] vendor: Micro-Star MSI
driver: nvidia v: 525.89.02 alternate: nouveau,nvidia_drm non-free: 525.xx+
status: current (as of 2023-02) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-22 pcie: gen: 3 speed: 8 GT/s lanes: 16
bus-ID: 01:00.0 chip-ID: 10de:1e82 class-ID: 0300
Display: server: X.org v: 1.21.1.7 with: Xwayland v: 22.1.8
compositor: budgie-wm driver: X: loaded: nvidia gpu: nvidia display-ID: :1
screens: 1
Screen-1: 0 s-res: 5120x1440 s-size: <missing: xdpyinfo>
Monitor-1: DP-2 pos: primary,left res: 2560x1440 dpi: 93
size: 698x393mm (27.48x15.47") diag: 801mm (31.54") modes: N/A
Monitor-2: HDMI-0 pos: right res: 2560x1440 dpi: 109
size: 597x336mm (23.5x13.23") diag: 685mm (26.97") modes: N/A
API: OpenGL Message: Unable to show GL data. Required tool glxinfo missing.
Device-1: Intel 200 Series PCH HD Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel bus-ID: 00:1f.3 chip-ID: 8086:a2f0
class-ID: 0403
Device-2: NVIDIA TU104 HD Audio vendor: Micro-Star MSI
bus-ID: 01:00.1 chip-ID: 10de:10f8 class-ID: 0403
Sound API: ALSA v: k6.1.12-1-MANJARO running: yes
Sound Server-1: JACK v: 1.9.22 running: no
Sound Server-3: PipeWire v: 0.3.65 running: no
lanes: 1 port: d000 bus-ID: 07:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp7s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-2: Realtek RTL8812AE 802.11ac PCIe Wireless Network Adapter
driver: rtl8821ae v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: c000
bus-ID: 08:00.0 chip-ID: 10ec:8812 class-ID: 0280
IF: wlp8s0 state: down mac: <filter>
driver: btusb v: 0.8 bus-ID: 1-2:3 chip-ID: 0a12:0001 class-ID: e001
Local Storage: total: 4.47 TiB used: 15.17 GiB (0.3%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Smart Modular Tech.
model: SHGP31-1000GM-2 size: 931.51 GiB block-size: physical: 512 B
rev: 41060C20 temp: 44.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Crucial model: CT250MX500SSD1
size: 232.89 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 023 scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST2000DM006-2DM164
type: HDD rpm: 7200 serial: <filter> rev: CC26 scheme: GPT
ID-4: /dev/sdc maj-min: 8:32 vendor: Vaseky model: V800 500GB
size: 476.94 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: KR scheme: GPT
ID-5: /dev/sdd maj-min: 8:48 vendor: SanDisk model: SDSSDH3 1T02
size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 1000 scheme: GPT
ID-6: /dev/sde maj-min: 8:64 type: USB vendor: SanDisk model: USB 3.2Gen1
size: 114.61 GiB block-size: physical: 512 B logical: 512 B type: N/A
serial: <filter> rev: 1.00 scheme: GPT
ID-1: / raw-size: 765.5 GiB size: 752.41 GiB (98.29%) used: 14.86 GiB (2.0%)
fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
uuid: 002bf6d6-6ead-4965-80bc-3f10162fbaa2
ID-2: /boot/efi raw-size: 1.95 GiB size: 1.95 GiB (99.80%)
used: 312.7 MiB (15.7%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
label: BOOTEFI uuid: 48C3-EC11
ID-1: swap-1 type: partition size: 16.41 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:3 label: N/A
uuid: 03f27fee-f86b-4885-8dab-3aa0e856b7a7
ID-1: /dev/sda1 maj-min: 8:1 size: 232.88 GiB fs: ext4 label: LinuxExtra
uuid: 9c31c548-308d-47bb-9362-09f9b56fa32a
ID-2: /dev/sdb1 maj-min: 8:17 size: 1.82 TiB fs: ntfs label: Barracuda1
uuid: D8E4CB99E4CB77F0
ID-3: /dev/sdc1 maj-min: 8:33 size: 100 GiB fs: ntfs label: N/A
uuid: 4CB14CDD7171AF68
ID-4: /dev/sdc2 maj-min: 8:34 size: 376.94 GiB fs: ntfs label: N/A
uuid: 5F289D5E2E021386
ID-5: /dev/sdd1 maj-min: 8:49 size: 953.27 GiB fs: ntfs label: N/A
uuid: C6A8F2C8A8F2B651
ID-6: /dev/sdd2 maj-min: 8:50 size: 600 MiB fs: ntfs label: N/A
uuid: 62A6094EA609245F
ID-7: /dev/sde1 maj-min: 8:65 size: 256 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-8: /dev/sde10 maj-min: 8:74 size: 3.5 GiB fs: iso9660
ID-9: /dev/sde11 maj-min: 8:75 size: 4.2 GiB fs: iso9660
ID-10: /dev/sde2 maj-min: 8:66 size: 1024 MiB fs: iso9660
ID-11: /dev/sde3 maj-min: 8:67 size: 3 GiB fs: ext4 label: Kali-Install
uuid: 04e1bddd-a9e9-421b-9bb5-84f7e556e767
ID-12: /dev/sde4 maj-min: 8:68 size: 1024 MiB fs: iso9660
ID-13: /dev/sde5 maj-min: 8:69 size: 3 GiB fs: iso9660
ID-14: /dev/sde7 maj-min: 8:71 size: 23.84 GiB fs: ext4
label: USB-Shared-Files uuid: dbad7b79-8e86-4871-8864-7e892c061818
ID-15: /dev/sde8 maj-min: 8:72 size: 2 GiB fs: <superuser required>
ID-16: /dev/sde9 maj-min: 8:73 size: 3 GiB fs: iso9660
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 16 rev: 2.0
Hub-2: 1-1:2 info: Genesys Logic Hub ports: 4 rev: 2.1 speed: 480 Mb/s
power: 100mA chip-ID: 05e3:0610 class-ID: 0900
Hub-3: 1-1.2:4 info: Terminus Hub ports: 4 rev: 2.0 speed: 480 Mb/s
power: 100mA chip-ID: 1a40:0101 class-ID: 0900
Device-1: 1-1.2.3:6 info: SanDisk Ultra Flair type: Mass Storage
driver: usb-storage interfaces: 1 rev: 2.1 speed: 480 Mb/s power: 224mA
chip-ID: 0781:5591 class-ID: 0806 serial: <filter>
Device-2: 1-1.2.4:7 info: Logitech Cordless Mouse Receiver
type: Keyboard,Mouse,HID driver: logitech-djreceiver,usbhid interfaces: 3
rev: 2.0 speed: 12 Mb/s power: 98mA chip-ID: 046d:c539 class-ID: 0300
Device-3: 1-2:3 info: Cambridge Silicon Radio Bluetooth Dongle (HCI mode)
type: Bluetooth driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s
Device-4: 1-10:5 info: Logitech Unifying Receiver type: Keyboard,Mouse,HID
power: 98mA chip-ID: 046d:c52b class-ID: 0300
Hub-4: 2-0:1 info: Super-speed hub ports: 10 rev: 3.0 speed: 5 Gb/s
Hub-5: 2-1:2 info: Genesys Logic Hub ports: 4 rev: 3.0 speed: 5 Gb/s
chip-ID: 05e3:0612 class-ID: 0900
Hub-6: 3-0:1 info: Hi-speed hub with single TT ports: 2 rev: 2.0
Hub-7: 4-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 33.0 C mobo: N/A gpu: nvidia temp: 44 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 25%
Processes: 331 Uptime: 1h 15m wakeups: 11 Init: systemd v: 252
default: graphical tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7
Packages: pm: pacman pkgs: 1039 libs: 299 tools: pamac Shell: Bash v: 5.1.16
running-in: tilix inxi: 3.3.25
