Second monitor sometimes works
Hi all,
I’ve got quite a weird problem with my second monitor. I’m one of the lucky souls on a laptop with a hybrid GPU (AMD Cezanne/NVIDIA GA106M). Let me try to explain it as best as i can.
I switched to Manjaro (KDE) recently and everything seemed to work fine. At the end of the day went to bed, next day i boot up my system and my second monitor is gone. Tried everything i could think of (switching cables, rebooting, reinstalling drivers, trying kernels, using envycontrol, you name it…) to get it working. Nothing worked and i gave up. Next day, i just wanted to try again just to be sure. Hook up my monitor and it works. No problems at all.
Next day i come back and guess what? My second monitor stopped working again.
After a lot of trying i came to the following conclusions.
  • If i boot (cold/warm boot) my laptop with the monitor connected to the HDMI and i turn the monitor on, it “disconnects”. The screen freezes and i can do whatever i want, but i won’t get it back on. Rebooting doesn’t help, it gives a no signal.
  • If i boot (cold boot) and the HDMI is NOT connected and i plug it in later the second monitor will work without any problem.
  • If the monitor doesn’t work a reboot won’t fix it. I even tried to shutdown the system and try it an hour later, same result.
  • If the monitor doesn’t work and i unplug the HDMI cable and try it the next day, it will work.
Anyone got a clue on where to start? inxi in next post.
Current state: HDMI connected, monitor not working.
  Kernel: 7.0.3-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
    parameters: BOOT_IMAGE=/@/boot/vmlinuz-7.0-x86_64
    root=UUID=** rw rootflags=subvol=@
  Desktop: KDE Plasma v: 6.6.4 tk: Qt v: N/A info: frameworks v: 6.25.0
  Type: Laptop System: HP product: Victus by HP Laptop 16-e0xxx v: N/A
  Mobo: HP model: 88EE v: 80.74 serial: <superuser required>
    part-nu: 6E1F9EA#ABH uuid: <superuser required> Firmware: UEFI vendor: AMI
    v: F.26 date: 12/18/2025
  ID-1: BAT0 charge: 54.7 Wh (100%) condition: 54.7/54.7 Wh (100%)
    volts: 17.24 min: 15.4 model: HP Primary type: Li-ion serial: <filter>
    charging: status: full cycles: 187
  System RAM: total: 32 GiB available: 30.68 GiB used: 4.7 GiB (15.3%)
  Device-1: Bottom - Slot 1 (left) type: DDR4 detail: synchronous
    unbuffered (unregistered) size: 16 GiB speed: 3200 MT/s volts: note: check
    curr: 1 min: 1 max: 1 width (bits): data: 64 total: 64
    manufacturer: Kingston part-no: KF3200C20S4/16G serial: <filter>
  Device-2: Bottom - Slot 2 (right) type: DDR4 detail: synchronous
  Info: model: AMD Ryzen 5 5600H with Radeon Graphics bits: 64 type: MT MCP
    arch: Zen 3 gen: 3 level: v3 note: check built: 2021-22
    microcode: 0xA500014
    desc: 6x512 KiB L3: 16 MiB desc: 1x16 MiB
  Speed (MHz): avg: 3323 min/max: 413/4281 boost: enabled scaling:
    driver: amd-pstate-epp governor: performance cores: 1: 3323 2: 3323 3: 3323
    4: 3323 5: 3323 6: 3323 7: 3323 8: 3323 9: 3323 10: 3323 11: 3323 12: 3323
    bogomips: 79055
    stibp succor svm_lock syscall tce topoext tsc tsc_scale umip user_shstk
    v_spec_ctrl v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall vpclmulqdq
    wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves xtopology
    affected
  Device-1: NVIDIA GA106M [GeForce RTX 3060 Mobile / Max-Q]
    vendor: Hewlett-Packard driver: nvidia v: 595.71.05
    alternate: nouveau,nvidia_drm non-free: 550-580.xx+ status: current (as
    of 2025-11; EOL~2026-12-xx) arch: Ampere code: GAxxx
    process: TSMC n7 (7nm) built: 2020-2023 pcie: gen: 1 speed: 2.5 GT/s
    lanes: 8 link-max: gen: 4 speed: 16 GT/s lanes: 16 ports: active: none
    empty: DP-2,HDMI-A-1 bus-ID: 01:00.0 chip-ID: 10de:2520 class-ID: 0300
  Device-2: Advanced Micro Devices [AMD/ATI] Cezanne [Radeon Vega Series /
    Radeon Mobile Series] vendor: Hewlett-Packard driver: amdgpu v: kernel
    arch: GCN-5 code: Vega process: GF 14nm built: 2017-20 pcie: gen: 3
    speed: 8 GT/s lanes: 16 ports: active: eDP-1 empty: DP-1 bus-ID: 07:00.0
    chip-ID: 1002:1638 class-ID: 0300 temp: 48.0 C
  Device-3: Quanta HP Wide Vision HD Camera driver: uvcvideo type: USB
    rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-3:2 chip-ID: 0408:5425
    compositor: kwin_wayland driver: X: loaded: amdgpu,nvidia dri: radeonsi
    gpu: amdgpu display-ID: 0
  Monitor-1: eDP-1 model: BOE Display 0x09f1 built: 2020 res:
    mode: 1920x1080 hz: 60 scale: 100% (1) dpi: 137 gamma: 1.2 chroma: red:
    x: 0.592 y: 0.349 green: x: 0.341 y: 0.557 blue: x: 0.161 y: 0.118 white:
    x: 0.314 y: 0.329 size: 355x200mm (13.98x7.87") diag: 407mm (16")
    ratio: 16:9 modes: 1920x1080, 1680x1050, 1280x1024, 1440x900, 1280x800,
    1280x720, 1024x768, 800x600, 640x480
  EDID-Warnings: 1: parse_edid: unknown flag 2
  API: EGL v: 1.5 hw: drv: nvidia drv: amd radeonsi platforms: device: 0
    drv: nvidia device: 2 drv: radeonsi device: 3 drv: swrast gbm: drv: nvidia
    surfaceless: drv: nvidia wayland: drv: radeonsi x11: drv: radeonsi
    inactive: device-1
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: amd mesa v: 26.0.6-arch1.1
    renoir ACO DRM 3.64 7.0.3-1-MANJARO) device-ID: 1002:1638 memory: 500 MiB
    unified: yes display-ID: :1.0
  API: Vulkan v: 1.4.341 layers: 8 device: 0 type: integrated-gpu name: AMD
    Radeon Graphics (RADV RENOIR) driver: mesa radv v: 26.0.6-arch1.1
    device-ID: 1002:1638 surfaces: N/A device: 1 type: discrete-gpu
    name: NVIDIA GeForce RTX 3060 Laptop GPU driver: nvidia v: 595.71.05
    device-ID: 10de:2520 surfaces: N/A
  Device-1: NVIDIA GA106 High Definition Audio vendor: Hewlett-Packard
    driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 8
    link-max: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 01:00.1
    chip-ID: 10de:228e class-ID: 0403
  Device-2: Advanced Micro Devices [AMD] Audio Coprocessor
    vendor: Hewlett-Packard driver: snd_rn_pci_acp3x v: kernel
    alternate: snd_pci_acp3x, snd_pci_acp5x, snd_pci_acp6x, snd_acp_pci,
    snd_rpl_pci_acp6x, snd_pci_ps, snd_sof_amd_renoir, snd_sof_amd_rembrandt,
    snd_sof_amd_vangogh, snd_sof_amd_acp63, snd_sof_amd_acp70 pcie: gen: 3
    speed: 8 GT/s lanes: 16 bus-ID: 07:00.5 chip-ID: 1022:15e2 class-ID: 0480
  Device-3: Advanced Micro Devices [AMD] Ryzen HD Audio
    vendor: Hewlett-Packard driver: snd_hda_intel v: kernel pcie: gen: 3
    speed: 8 GT/s lanes: 16 bus-ID: 07:00.6 chip-ID: 1022:15e3 class-ID: 0403
  API: ALSA v: k7.0.3-1-MANJARO status: kernel-api with: aoss
  Server-3: PipeWire v: 1.6.4 status: active with: 1: pipewire-pulse
    vendor: Hewlett-Packard driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
    lanes: 1 port: e000 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
  Device-2: Realtek RTL8852AE 802.11ax PCIe Wireless Network Adapter
    vendor: Hewlett-Packard driver: rtw89_8852ae v: kernel pcie: gen: 1
    speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 03:00.0 chip-ID: 10ec:8852
    class-ID: 0280
  IF: wlo1 state: down mac: <filter>
  Device-1: Realtek Bluetooth Radio driver: btusb v: 0.8 type: USB rev: 1.0
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-4:3 chip-ID: 0bda:2852
  Local Storage: total: 1.38 TiB used: 159.58 GiB (11.3%)
  ID-1: /dev/nvme0n1 maj-min: 259:2 vendor: Samsung
    model: MZVLB512HBJQ-000H1 size: 476.94 GiB block-size: physical: 512 B
    fw-rev: HPS0NEXF temp: 33.9 C scheme: GPT
  ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Samsung
    model: SSD 970 EVO Plus 1TB size: 931.51 GiB block-size: physical: 512 B
    fw-rev: 4B2QEXM7 temp: 33.9 C scheme: GPT
  ID-1: / raw-size: 475.89 GiB size: 475.89 GiB (100.00%)
    used: 11.82 GiB (2.5%) fs: btrfs dev: /dev/nvme0n1p1 maj-min: 259:3
    label: N/A uuid: 42f317ee-845a-4f51-92ef-46d43c55bb1a
  ID-2: /boot/efi raw-size: 1.05 GiB size: 1.05 GiB (99.80%)
    used: 5.9 MiB (0.5%) fs: vfat dev: /dev/nvme0n1p2 maj-min: 259:4 label: N/A
    uuid: A11D-592E
  ID-3: /home raw-size: 931.51 GiB size: 931.51 GiB (100.00%)
    used: 147.75 GiB (15.9%) fs: btrfs dev: /dev/nvme1n1p1 maj-min: 259:1
    label: N/A uuid: f50390af-8c74-4719-8cf3-13d26575def6
  ID-4: /var/cache raw-size: 475.89 GiB size: 475.89 GiB (100.00%)
  ID-5: /var/log raw-size: 475.89 GiB size: 475.89 GiB (100.00%)
  Device-1: 1-3:2 info: Quanta HP Wide Vision HD Camera type: video
    driver: uvcvideo interfaces: 3 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
    lanes: 1 mode: 2.0 power: 500mA chip-ID: 0408:5425 class-ID: fe01
    serial: <filter>
  Device-2: 1-4:3 info: Realtek Bluetooth Radio type: bluetooth
    driver: btusb interfaces: 2 rev: 1.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
    mode: 1.1 power: 500mA chip-ID: 0bda:2852 class-ID: e001 serial: <filter>
  Device-1: 3-2:2 info: Corsair KATAR PRO Wireless Gaming Dongle
    type: mouse,HID,keyboard driver: hid-generic,usbhid interfaces: 5 rev: 2.0
    chip-ID: 1b1c:1b94 class-ID: 0301 serial: <filter>
  System Temperatures: cpu: 61.9 C mobo: N/A gpu: amdgpu temp: 50.0 C
  Fan Speeds (rpm): fan-1: 0 fan-2: 0
  Packages: pm: pacman pkgs: 1325 libs: 384 tools: pamac pm: flatpak pkgs: 0
    1: https://ftp.snt.utwente.nl/pub/linux/manjaro/stable/$repo/$arch
    2: https://mirror.netcologne.de/manjaro/stable/$repo/$arch
    3: https://mirror.math.princeton.edu/pub/manjaro/stable/$repo/$arch
    4: https://mirror.xenyth.net/manjaro/stable/$repo/$arch
    5: https://mirror.truenetwork.ru/manjaro/stable/$repo/$arch
    6: https://mirror.csclub.uwaterloo.ca/manjaro/stable/$repo/$arch
    7: https://mirror.2degrees.nz/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 344
  1: cpu: 5.7% command: firefox pid: 3168 mem: 539.1 MiB (1.7%)
  2: cpu: 5.6% command: firefox pid: 2752 mem: 664.7 MiB (2.1%)
  3: cpu: 5.4% command: kwin_wayland pid: 951 mem: 249.9 MiB (0.7%)
  4: cpu: 1.0% command: steam pid: 1709 mem: 207.2 MiB (0.6%)
  5: cpu: 0.7% command: ./steamwebhelper pid: 1952 mem: 343.1 MiB (1.0%)
  Memory top: 5 of 344
  1: mem: 664.7 MiB (2.1%) command: firefox pid: 2752 cpu: 5.6%
  2: mem: 556.1 MiB (1.7%) command: thunderbird pid: 3458 cpu: 0.3%
  3: mem: 539.1 MiB (1.7%) command: firefox pid: 3168 cpu: 5.7%
  4: mem: 463.8 MiB (1.4%) command: steamwebhelper pid: 2082 cpu: 0.1%
  5: mem: 383.8 MiB (1.2%) command: plasmashell pid: 1182 cpu: 0.2%
  Processes: 344 Power: uptime: 45m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 12.18 GiB services: org_kde_powerdevil,
    power-profiles-daemon, upowerd Init: systemd v: 260 default: graphical
    tool: systemctl
  Compilers: gcc: 15.2.1 Shell: Zsh v: 5.9 running-in: konsole inxi: 3.3.40
Hi @Ronster
I am not running KDE.
Correct me if I am wrong. But it looks like your monitor settings in kde settings are not saved for next boot.
I think it is simpler to find the solution in the kde gui.
Probably when hdmi connected after boot works. kde maybe uses auto find and connect the hdmi.
Not at boot, because it does not save the settings.
A kde user can guide you if needed.
Hello @Ronster and welcome to the Manjaro Community! :vulcan_salute:
No expert here, but this could be a clue:
It looks to me like the monitor isn’t (properly) sending its EDID, so Wayland doesn’t know what to do with it.
Maybe the outputs of these commands will help others:
sudo dmesg | grep -Ei 'edid|drm'
and
journalctl -b | grep -Ei 'edid|drm|dp|hdmi'
… I don’t suppose you have another monitor you could try? (It could be a cable issue to).
It’s also worth checking in (U)EFI settings for anything monitor-related.
Hi, thanks for the replies.
dmesg:
[    0.959396] ACPI: bus type drm_connector registered
[    0.965139] simple-framebuffer simple-framebuffer.0: [drm] Registered 1 planes with drm panic
[    0.965156] [drm] Initialized simpledrm 1.0.0 for simple-framebuffer.0 on minor 0
[    0.966107] simple-framebuffer simple-framebuffer.0: [drm] fb0: simpledrmdrmfb frame buffer device
[    3.876850] amdgpu 0000:06:00.0: [drm] ATOM BIOS: 113-CEZANNE-018
[    3.930666] amdgpu 0000:06:00.0: [drm] Detected VRAM RAM=512M, BAR=512M
[    3.930671] amdgpu 0000:06:00.0: [drm] RAM width 128bits DDR4
[    3.931152] amdgpu 0000:06:00.0: [drm] GART: num cpu pages 262144, num gpu pages 262144
[    3.931323] amdgpu 0000:06:00.0: [drm] PCIE GART of 1024M enabled.
[    3.931345] amdgpu 0000:06:00.0: [drm] PTB located at 0x000000F41FC00000
[    3.932132] amdgpu 0000:06:00.0: [drm] Loading DMUB firmware via PSP: version=0x0101002B
[    4.035076] amdgpu 0000:06:00.0: [drm] Display Core v3.2.369 initialized on DCN 2.1
[    4.035082] amdgpu 0000:06:00.0: [drm] DP-HDMI FRL PCON supported
[    4.035635] amdgpu 0000:06:00.0: [drm] DMUB hardware initialized: version=0x0101002B
[    4.454218] amdgpu 0000:06:00.0: [drm] Using custom brightness curve
[    4.455062] amdgpu 0000:06:00.0: [drm] Registered 4 planes with drm panic
[    4.458431] [drm] Initialized amdgpu 3.64.0 for 0000:06:00.0 on minor 1
[    4.465979] fbcon: amdgpudrmfb (fb0) is primary device
[    4.465986] amdgpu 0000:06:00.0: [drm] fb0: amdgpudrmfb frame buffer device
[    4.533421] [drm] pre_validate_dsc:1667 MST_DSC dsc precompute is not needed
[    5.606905] systemd[1]: Load Kernel Module drm skipped, unmet condition check ConditionKernelModuleLoaded=!drm
[    5.899596] [drm] [nvidia-drm] [GPU ID 0x00000100] Loading driver
[    8.202930] [drm] Initialized nvidia-drm 0.0.0 for 0000:01:00.0 on minor 0
[    8.203558] nvidia 0000:01:00.0: [drm] Cannot find any crtc or sizes
[   12.260991] [drm:__nv_drm_nvkms_gem_obj_init [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to get memory pages for NvKmsKapiMemory 0x00000000c6e24513
journalctl:
 15 20:07:05 laptop kernel: ACPI: RSDP 0x00000000B6B82014 000024 (v02 HPQOEM)
 15 20:07:05 laptop kernel: acpi PNP0A08:00: _OSC: platform does not support [SHPCHotplug LTR DPC]
 15 20:07:05 laptop kernel: pci 0000:00:00.0: [1022:1630] type 00 class 0x060000 conventional PCI endpoint
 15 20:07:05 laptop kernel: pci 0000:00:00.2: [1022:1631] type 00 class 0x080600 conventional PCI endpoint
 15 20:07:05 laptop kernel: pci 0000:00:01.0: [1022:1632] type 00 class 0x060000 conventional PCI endpoint
 15 20:07:05 laptop kernel: pci 0000:00:02.0: [1022:1632] type 00 class 0x060000 conventional PCI endpoint
 15 20:07:05 laptop kernel: pci 0000:00:08.0: [1022:1632] type 00 class 0x060000 conventional PCI endpoint
 15 20:07:05 laptop kernel: pci 0000:00:14.0: [1022:790b] type 00 class 0x0c0500 conventional PCI endpoint
 15 20:07:05 laptop kernel: pci 0000:00:14.3: [1022:790e] type 00 class 0x060100 conventional PCI endpoint
 15 20:07:05 laptop kernel: pci 0000:00:18.0: [1022:166a] type 00 class 0x060000 conventional PCI endpoint
 15 20:07:05 laptop kernel: pci 0000:00:18.1: [1022:166b] type 00 class 0x060000 conventional PCI endpoint
 15 20:07:05 laptop kernel: pci 0000:00:18.2: [1022:166c] type 00 class 0x060000 conventional PCI endpoint
 15 20:07:05 laptop kernel: pci 0000:00:18.3: [1022:166d] type 00 class 0x060000 conventional PCI endpoint
 15 20:07:05 laptop kernel: pci 0000:00:18.4: [1022:166e] type 00 class 0x060000 conventional PCI endpoint
 15 20:07:05 laptop kernel: pci 0000:00:18.5: [1022:166f] type 00 class 0x060000 conventional PCI endpoint
 15 20:07:05 laptop kernel: pci 0000:00:18.6: [1022:1670] type 00 class 0x060000 conventional PCI endpoint
 15 20:07:05 laptop kernel: pci 0000:00:18.7: [1022:1671] type 00 class 0x060000 conventional PCI endpoint
 15 20:07:05 laptop kernel: pci 0000:01:00.0: [10de:2520] type 00 class 0x030000 PCIe Legacy Endpoint
 15 20:07:05 laptop kernel: pci 0000:01:00.1: [10de:228e] type 00 class 0x040300 PCIe Endpoint
 15 20:07:05 laptop kernel: pci 0000:02:00.0: [10ec:8168] type 00 class 0x020000 PCIe Endpoint
 15 20:07:05 laptop kernel: pci 0000:03:00.0: [17a0:9750] type 00 class 0x080501 PCIe Endpoint
 15 20:07:05 laptop kernel: pci 0000:04:00.0: [144d:a808] type 00 class 0x010802 PCIe Endpoint
 15 20:07:05 laptop kernel: pci 0000:05:00.0: [144d:a808] type 00 class 0x010802 PCIe Endpoint
 15 20:07:05 laptop kernel: pci 0000:06:00.0: [1002:1638] type 00 class 0x030000 PCIe Legacy Endpoint
 15 20:07:05 laptop kernel: pci 0000:06:00.2: [1022:15df] type 00 class 0x108000 PCIe Endpoint
 15 20:07:05 laptop kernel: pci 0000:06:00.3: [1022:1639] type 00 class 0x0c0330 PCIe Endpoint
 15 20:07:05 laptop kernel: pci 0000:06:00.4: [1022:1639] type 00 class 0x0c0330 PCIe Endpoint
 15 20:07:05 laptop kernel: pci 0000:06:00.5: [1022:15e2] type 00 class 0x048000 PCIe Endpoint
 15 20:07:05 laptop kernel: pci 0000:06:00.6: [1022:15e3] type 00 class 0x040300 PCIe Endpoint
 15 20:07:05 laptop kernel: UDP hash table entries: 16384 (order: 8, 1048576 bytes, linear)
 15 20:07:05 laptop kernel: UDP-Lite hash table entries: 16384 (order: 8, 1048576 bytes, linear)
 15 20:07:05 laptop kernel: NET: Registered PF_XDP protocol family
 15 20:07:05 laptop kernel: ACPI: bus type drm_connector registered
 15 20:07:05 laptop kernel: usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 7.00
 15 20:07:05 laptop kernel: usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 7.00
 15 20:07:05 laptop kernel: usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 7.00
 15 20:07:05 laptop kernel: usb usb4: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 7.00
 15 20:07:05 laptop kernel: simple-framebuffer simple-framebuffer.0: [drm] Registered 1 planes with drm panic
 15 20:07:05 laptop kernel: [drm] Initialized simpledrm 1.0.0 for simple-framebuffer.0 on minor 0
 15 20:07:05 laptop kernel: simple-framebuffer simple-framebuffer.0: [drm] fb0: simpledrmdrmfb frame buffer device
 15 20:07:05 laptop kernel: usb 1-3: New USB device found, idVendor=0408, idProduct=5425, bcdDevice= 0.05
 15 20:07:05 laptop kernel: usb 3-2: New USB device found, idVendor=1b1c, idProduct=1b94, bcdDevice= 2.03
 15 20:07:05 laptop kernel: usb 1-4: New USB device found, idVendor=0bda, idProduct=2852, bcdDevice= 0.00
 15 20:07:05 laptop kernel: amdgpu 0000:06:00.0: [drm] ATOM BIOS: 113-CEZANNE-018
 15 20:07:05 laptop kernel: amdgpu 0000:06:00.0: [drm] Detected VRAM RAM=512M, BAR=512M
 15 20:07:05 laptop kernel: amdgpu 0000:06:00.0: [drm] RAM width 128bits DDR4
 15 20:07:05 laptop kernel: amdgpu 0000:06:00.0: [drm] GART: num cpu pages 262144, num gpu pages 262144
 15 20:07:05 laptop kernel: amdgpu 0000:06:00.0: [drm] PCIE GART of 1024M enabled.
 15 20:07:05 laptop kernel: amdgpu 0000:06:00.0: [drm] PTB located at 0x000000F41FC00000
 15 20:07:05 laptop kernel: amdgpu 0000:06:00.0: [drm] Loading DMUB firmware via PSP: version=0x0101002B
 15 20:07:05 laptop kernel: amdgpu 0000:06:00.0: [drm] Display Core v3.2.369 initialized on DCN 2.1
 15 20:07:05 laptop kernel: amdgpu 0000:06:00.0: [drm] DP-HDMI FRL PCON supported
 15 20:07:05 laptop kernel: amdgpu 0000:06:00.0: [drm] DMUB hardware initialized: version=0x0101002B
 15 20:07:05 laptop kernel: amdgpu 0000:06:00.0: [drm] Using custom brightness curve
 15 20:07:05 laptop kernel: amdgpu 0000:06:00.0: [drm] Registered 4 planes with drm panic
 15 20:07:05 laptop kernel: [drm] Initialized amdgpu 3.64.0 for 0000:06:00.0 on minor 1
 15 20:07:05 laptop kernel: fbcon: amdgpudrmfb (fb0) is primary device
 15 20:07:05 laptop kernel: amdgpu 0000:06:00.0: [drm] fb0: amdgpudrmfb frame buffer device
 15 20:07:05 laptop kernel: [drm] pre_validate_dsc:1667 MST_DSC dsc precompute is not needed
 15 20:07:05 laptop systemd[1]: Created slice Slice /system/modprobe.
 15 20:07:05 laptop systemd[1]: Load Kernel Module drm skipped, unmet condition check ConditionKernelModuleLoaded=!drm
 15 20:07:05 laptop systemd[1]: Starting Coldplug All udev Devices...
 15 20:07:05 laptop kernel: [drm] [nvidia-drm] [GPU ID 0x00000100] Loading driver
 15 20:07:05 laptop systemd[1]: Finished Coldplug All udev Devices.
 15 20:07:06 laptop kernel: input: HDA NVidia HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:01.1/0000:01:00.1/sound/card0/input18
 15 20:07:06 laptop kernel: input: HDA NVidia HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:01.1/0000:01:00.1/sound/card0/input19
 15 20:07:06 laptop kernel: input: HDA NVidia HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:01.1/0000:01:00.1/sound/card0/input20
 15 20:07:06 laptop kernel: input: HDA NVidia HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:01.1/0000:01:00.1/sound/card0/input21
 15 20:07:06 laptop kernel: input: HD-Audio Generic Headphone as /devices/pci0000:00/0000:00:08.1/0000:06:00.6/sound/card1/input23
 15 20:07:07 laptop kernel: [drm] Initialized nvidia-drm 0.0.0 for 0000:01:00.0 on minor 0
 15 20:07:07 laptop systemd-modules-load[386]: Inserted module 'nvidia_drm'
 15 20:07:07 laptop kernel: nvidia 0000:01:00.0: [drm] Cannot find any crtc or sizes
 15 20:07:08 laptop bluetoothd[682]: Starting SDP server
 15 20:07:11 laptop kernel: [drm:__nv_drm_nvkms_gem_obj_init [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to get memory pages for NvKmsKapiMemory 0x00000000c6e24513
 15 20:07:12 laptop sddm-greeter-qt6[832]: High-DPI autoscaling Enabled
 15 20:07:13 laptop sddm-greeter-qt6[832]: Adding view for "eDP-1-0" QRect(0,0 1920x1080)
 15 20:07:18 laptop kwin_wayland[943]: No backend specified, automatically choosing drm
 15 20:07:18 laptop bluetoothd[682]: Endpoint registered: sender=:1.32 path=/MediaEndpoint/A2DPSource/ldac
 15 20:07:18 laptop bluetoothd[682]: Endpoint registered: sender=:1.32 path=/MediaEndpoint/A2DPSink/aptx_hd
 15 20:07:18 laptop bluetoothd[682]: Endpoint registered: sender=:1.32 path=/MediaEndpoint/A2DPSource/aptx_hd
 15 20:07:18 laptop bluetoothd[682]: Endpoint registered: sender=:1.32 path=/MediaEndpoint/A2DPSink/aac
 15 20:07:18 laptop bluetoothd[682]: Endpoint registered: sender=:1.32 path=/MediaEndpoint/A2DPSource/aac
 15 20:07:18 laptop bluetoothd[682]: Endpoint registered: sender=:1.32 path=/MediaEndpoint/A2DPSink/opus_g
 15 20:07:18 laptop bluetoothd[682]: Endpoint registered: sender=:1.32 path=/MediaEndpoint/A2DPSource/opus_g
 15 20:07:18 laptop bluetoothd[682]: Endpoint registered: sender=:1.32 path=/MediaEndpoint/A2DPSink/sbc
 15 20:07:18 laptop bluetoothd[682]: Endpoint registered: sender=:1.32 path=/MediaEndpoint/A2DPSource/sbc
 15 20:07:18 laptop bluetoothd[682]: Endpoint registered: sender=:1.32 path=/MediaEndpoint/A2DPSource/aptx_ll_1
 15 20:07:18 laptop bluetoothd[682]: Endpoint registered: sender=:1.32 path=/MediaEndpoint/A2DPSource/aptx_ll_0
 15 20:07:18 laptop bluetoothd[682]: Endpoint registered: sender=:1.32 path=/MediaEndpoint/A2DPSource/aptx_ll_duplex_1
 15 20:07:18 laptop bluetoothd[682]: Endpoint registered: sender=:1.32 path=/MediaEndpoint/A2DPSource/aptx_ll_duplex_0
 15 20:07:18 laptop bluetoothd[682]: Endpoint registered: sender=:1.32 path=/MediaEndpoint/A2DPSource/faststream
 15 20:07:18 laptop bluetoothd[682]: Endpoint registered: sender=:1.32 path=/MediaEndpoint/A2DPSource/faststream_duplex
 15 20:07:18 laptop bluetoothd[682]: Endpoint registered: sender=:1.32 path=/MediaEndpoint/A2DPSink/opus_05
 15 20:07:18 laptop bluetoothd[682]: Endpoint registered: sender=:1.32 path=/MediaEndpoint/A2DPSource/opus_05
 15 20:07:18 laptop bluetoothd[682]: Endpoint registered: sender=:1.32 path=/MediaEndpoint/A2DPSink/opus_05_duplex
 15 20:07:18 laptop bluetoothd[682]: Endpoint registered: sender=:1.32 path=/MediaEndpoint/A2DPSource/opus_05_duplex
 15 20:07:20 laptop org_kde_powerdevil[1218]: Watching for DPMS state changes unimplemented
 15 20:07:20 laptop org_kde_powerdevil[1218]: [  1218] Watching for DPMS state changes unimplemented
 15 20:08:01 laptop kernel: [UFW BLOCK] IN=eno1 OUT= MAC=a8:b1:3b:82:e6:36:d4:1a:d1:68:d4:c8:08:00 SRC=162.159.61.4 DST=192.168.1.189 LEN=91 TOS=0x00 PREC=0x00 TTL=58 ID=60702 DF PROTO=TCP SPT=443 DPT=41492 WINDOW=16 RES=0x00 ACK PSH URGP=0
Both give an error for retrieving memory pages, but this started since i’m using kernel 7.0. On 6.19 i didn’t see this error, but i had the issue with the second monitor.
I hooked it up to my tv and that worked fine. Could be monitor related as it is quite old. One of the earlier 1080p devices with hdmi. On the other hand, i only ran into this using Manjaro.
What i did notice was this error message, which i also only had on Manjaro. Could this be related?
ACPI BIOS Error (bug): AE_AML_BUFFER_LIMIT, Index (0x000000032) is beyond end of object (length 0x32) (20251212/exoparg2-393)
As far as I can tell, this does tie in with an EDID issue. I do (or did) have a TV/monitor which KDE wouldn’t recognize.
There is a way of reading the EDID (I’ll need to refresh my memory on that) and at least with x11, IIRC also a way of incorporating that with xrandr. Not sure what Wayland would involve in that regard. :thinking: I’ll try to get back to you a bit later on that.
I’m not sure about that last ACPI BIOS error. :man_shrugging:
Well, it turns out the the ACPI bug is a HP thing. Could be related to the issue i’m having, but i’m not sure.
What I did find out is that the issue i have is 100% monitor related. Even after hooking it up to another system it didn’t work. The monitor gets into a state it won’t get out of. The only solution is to remove power (unplug the cable) on the monitor. I gave my monitor and laptop a dedicated power strip, which basically solves the problem.
Still a lot of thanks for your support!
