Second monitor recognized but no signal
Hi
I use Manjaro and KDE. I have an nvidia GPU and use the proprietary drivers. After some updates my second display connected via HDMI stopped working. The display itself says, it doesn’t get any signal. The display is connected and recognized in the system settings, by xrandr and the nvidia settings.
In the login screen both monitors work fine.
The monitor works fine with windows. I dual boot with Manjaro and Windows, they’re on separate ssds tho.
xrandr gives me that output:
Screen 0: minimum 16 x 16, current 3840 x 1080, maximum 32767 x 32767
HDMI-A-1 connected primary 1920x1080+1920+0 (normal left inverted right x axis y axis) 543mm x 302mm
   1920x1080    164.83*+
   1440x1080    164.85
   1400x1050    164.77
   1280x1024    164.81
   1280x960     164.80
   1152x864     164.77
   1024x768     164.99
   800x600      164.72
   640x480      164.26
   320x240      163.69
   1680x1050    164.82
   1440x900     164.74
   1280x800     164.81
   1152x720     164.77
   960x600      164.72
   928x580      164.51
   800x500      164.66
   768x480      164.47
   720x480      164.67
   640x400      164.67
   320x200      161.83
   1600x900     164.77
   1368x768     164.98
   1280x720     164.71
   1024x576     164.94
   864x486      164.71
   720x400      164.23
   640x350      164.46
eDP-1 connected 1920x1080+0+0 (normal left inverted right x axis y axis) 381mm x 214mm
   1920x1080    143.88*+
   1440x1080    143.80
   1400x1050    143.89
   1280x1024    143.79
   1280x960     143.86
   1152x864     143.92
   1024x768     143.87
   800x600      143.83
   640x480      143.85
   320x240      142.05
   1680x1050    143.88
   1440x900     143.86
   1280x800     143.84
   1152x720     143.77
   960x600      143.72
   928x580      143.50
   800x500      143.68
   768x480      143.69
   720x480      143.85
   640x400      143.37
   320x200      141.40
   1600x900     143.93
   1368x768     143.77
   1280x720     143.85
   1024x576     143.91
   864x486      143.63
   720x400      143.88
   640x350      143.57
Do you have any ideas on what I could do? Thank you
Hi @dreamAviator,
Have you tried Wayland?
Also, please provide the output to:
inxi --filter --verbosity=8
I have not yet tried Wayland but let me test that real quick
also outputs:
inxi:
CPU: 6-core AMD Ryzen 5 5600H with Radeon Graphics (-MT MCP-)
speed/min/max: 1108/400/4280 MHz Kernel: 6.12.20-2-MANJARO x86_64 Up: 1h 16m
Mem: 4.18/31.2 GiB (13.4%) Storage: 2.75 TiB (14.9% used) Procs: 286
Shell: Zsh inxi: 3.3.37
inxi --filter --verbosity=8:
  Kernel: 6.12.20-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    clocksource: hpet avail: acpi_pm
    root=UUID=23c19d16-1190-44fc-870f-f191010b97da rw quiet splash
    resume=UUID=568d55af-c4db-4bab-9f31-d7d3f5ac1a0a udev.log_priority=3
  Desktop: KDE Plasma v: 6.3.3 tk: Qt v: N/A info: frameworks v: 6.12.0
  Type: Laptop System: LENOVO product: 82JY v: Legion 5 17ACH6H
    serial: <superuser required> Chassis: type: 10 v: Legion 5 17ACH6H
  Mobo: LENOVO model: LNVNB161216 v: SDK0J40709 WIN
    serial: <superuser required> part-nu: LENOVO_MT_82JY_BU_idea_FM_Legion 5
    17ACH6H uuid: <superuser required> UEFI: LENOVO v: GKCN65WW
    date: 01/16/2024
  ID-1: BAT0 charge: 49.1 Wh (60.0%) condition: 81.8/80.0 Wh (102.2%)
    volts: 15.9 min: 15.4 model: Celxpert L20C4PC2 type: Li-poly
    serial: <filter> status: not charging cycles: 24
  System RAM: total: 32 GiB available: 31.2 GiB used: 4.18 GiB (13.4%)
    (unregistered) size: 16 GiB speed: 3200 MT/s volts: note: check curr: 1
    min: 1 max: 1 width (bits): data: 64 total: 64 manufacturer: G.Skill
    part-no: F4-3200C22-16GRS serial: <filter>
  Info: model: AMD Ryzen 5 5600H with Radeon Graphics bits: 64 type: MT MCP
    arch: Zen 3 gen: 3 level: v3 note: check built: 2021-22
    microcode: 0xA500011
    desc: 6x512 KiB L3: 16 MiB desc: 1x16 MiB
  Speed (MHz): avg: 1108 min/max: 400/4280 boost: enabled scaling:
    driver: amd-pstate-epp governor: performance cores: 1: 1108 2: 1108 3: 1108
    4: 1108 5: 1108 6: 1108 7: 1108 8: 1108 9: 1108 10: 1108 11: 1108 12: 1108
    bogomips: 79090
    vpclmulqdq wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
    xtopology
    affected
  Device-1: NVIDIA GA106M [GeForce RTX 3060 Mobile / Max-Q] vendor: Lenovo
    driver: nvidia v: 570.133.07 alternate: nouveau,nvidia_drm
    non-free: 550/565.xx+ status: current (as of 2025-01; EOL~2026-12-xx)
    arch: Ampere code: GAxxx process: TSMC n7 (7nm) built: 2020-2023 pcie:
    gen: 2 speed: 5 GT/s lanes: 8 link-max: gen: 4 speed: 16 GT/s lanes: 16
    ports: active: none off: HDMI-A-1,eDP-1 empty: DP-1,DP-2 bus-ID: 01:00.0
    chip-ID: 10de:2560 class-ID: 0300
  Device-2: Bison Integrated Camera driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-3:4 chip-ID: 5986:212b
    class-ID: 0e02
    compositor: kwin_wayland driver: X: loaded: nvidia
    gpu: nvidia,nvidia-nvswitch d-rect: 3840x1080 display-ID: 0
  Monitor-1: HDMI-A-1 pos: right model: MSI G251F serial: <filter>
    built: 2022 res: mode: 1920x1080 hz: 165 scale: 100% (1) dpi: 90 gamma: 1.2
    chroma: red: x: 0.651 y: 0.341 green: x: 0.310 y: 0.631 blue: x: 0.145
    y: 0.051 white: x: 0.314 y: 0.329 size: 543x302mm (21.38x11.89")
    diag: 621mm (24.5") ratio: 16:9 modes: 1920x1080, 1680x1050, 1280x1024,
    1440x900, 1280x960, 1152x864, 1280x720, 1440x576, 1024x768, 1440x480,
    800x600, 720x576, 720x480, 640x480
  Monitor-2: eDP-1 pos: primary,left model: ChiMei InnoLux 0x175c
    built: 2018 res: mode: 1920x1080 hz: 144 scale: 100% (1) dpi: 128 gamma: 1.2
    chroma: red: x: 0.639 y: 0.329 green: x: 0.298 y: 0.600 blue: x: 0.149
    y: 0.059 white: x: 0.314 y: 0.329 size: 381x214mm (15x8.43")
    diag: 437mm (17.2") ratio: 16:9 modes: 1920x1080
  API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0 drv: nvidia gbm:
    drv: nvidia surfaceless: drv: nvidia wayland: drv: nvidia x11: drv: nvidia
  API: OpenGL v: 4.6.0 vendor: nvidia v: 570.133.07 glx-v: 1.4
    direct-render: yes renderer: NVIDIA GeForce RTX 3060 Laptop GPU/PCIe/SSE2
    memory: 5.86 GiB display-ID: :1.0
  API: Vulkan v: 1.4.309 layers: 5 device: 0 type: discrete-gpu name: NVIDIA
    GeForce RTX 3060 Laptop GPU driver: N/A device-ID: 10de:2560
    surfaces: xcb,xlib,wayland
  Device-1: NVIDIA GA106 High Definition Audio driver: snd_hda_intel v: kernel
    pcie: gen: 3 speed: 8 GT/s lanes: 8 link-max: gen: 4 speed: 16 GT/s
    lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:228e class-ID: 0403
  Device-2: Advanced Micro Devices [AMD] ACP/ACP3X/ACP6x Audio Coprocessor
    vendor: Lenovo driver: N/A alternate: snd_pci_acp3x, snd_rn_pci_acp3x,
    snd_pci_acp5x, snd_pci_acp6x, snd_acp_pci, snd_rpl_pci_acp6x, snd_pci_ps,
    snd_sof_amd_renoir, snd_sof_amd_rembrandt, snd_sof_amd_vangogh,
    snd_sof_amd_acp63, snd_sof_amd_acp70 pcie: gen: 3 speed: 8 GT/s lanes: 16
    link-max: gen: 4 speed: 16 GT/s bus-ID: 06:00.5 chip-ID: 1022:15e2
    class-ID: 0480
    vendor: Lenovo driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s
    lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 06:00.6
    chip-ID: 1022:15e3 class-ID: 0403
  Device-4: Realtek TONOR TC40 Audio Device driver: snd-usb-audio type: USB
    rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-2.2:5
    chip-ID: 0bda:49e3 class-ID: 0102
  API: ALSA v: k6.12.20-2-MANJARO status: kernel-api with: aoss
  Server-3: PipeWire v: 1.4.1 status: active with: 1: pipewire-pulse
    vendor: Lenovo driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
    port: 2000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
  Device-2: Realtek RTL8852AE 802.11ax PCIe Wireless Network Adapter
    vendor: Lenovo driver: rtw89_8852ae v: kernel pcie: gen: 1 speed: 2.5 GT/s
    lanes: 1 port: 1000 bus-ID: 04:00.0 chip-ID: 10ec:8852 class-ID: 0280
  IF: wlp4s0 state: up mac: <filter>
  Device-1: Realtek Bluetooth Radio driver: btusb v: 0.8 type: USB rev: 1.0
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-4:3 chip-ID: 0bda:4852
  Report: btmgmt ID: hci0 rfk-id: 2 state: up address: <filter> bt-v: 5.2
    lmp-v: 11 status: discoverable: no pairing: no class-ID: 6c010c
  Local Storage: total: 2.75 TiB used: 419.51 GiB (14.9%)
  ID-1: /dev/nvme0n1 maj-min: 259:4 vendor: Samsung
    model: MZVLB1T0HBLR-000L2 size: 953.87 GiB block-size: physical: 512 B
    fw-rev: 3L1QEXF7 temp: 25.9 C scheme: GPT
  ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Samsung
    model: SSD 970 EVO Plus 2TB size: 1.82 TiB block-size: physical: 512 B
    fw-rev: 4B2QEXM7 temp: 35.9 C scheme: GPT
  ID-1: / raw-size: 1.79 TiB size: 1.76 TiB (98.37%) used: 419.51 GiB (23.3%)
    fs: ext4 dev: /dev/nvme1n1p2 maj-min: 259:2 label: N/A
    uuid: 23c19d16-1190-44fc-870f-f191010b97da
    used: 292 KiB (0.1%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:1 label: N/A
    uuid: E20C-6A3A
  ID-1: swap-1 type: partition size: 34.32 GiB used: 0 KiB (0.0%)
    priority: -2 dev: /dev/nvme1n1p3 maj-min: 259:3 label: swap
    uuid: 568d55af-c4db-4bab-9f31-d7d3f5ac1a0a
  ID-1: /dev/nvme0n1p1 maj-min: 259:5 size: 260 MiB fs: vfat label: SYSTEM_DRV
    uuid: 76F1-674B
  ID-2: /dev/nvme0n1p2 maj-min: 259:6 size: 16 MiB fs: <superuser required>
    label: N/A uuid: N/A
  ID-3: /dev/nvme0n1p3 maj-min: 259:7 size: 952.62 GiB fs: ntfs
    label: Windows-SSD uuid: BC1AF2311AF1E7F2
  ID-4: /dev/nvme0n1p4 maj-min: 259:8 size: 1000 MiB fs: ntfs
    label: WINRE_DRV uuid: EE84F2AA84F27485
  Hub-2: 1-1:2 info: Terminus USB 2.0 Hub ports: 4 rev: 2.0
    chip-ID: 1a40:0801 class-ID: 0900
  Hub-3: 1-2:3 info: Genesys Logic Hub ports: 3 rev: 2.1
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 05e3:0610
  Device-1: 1-2.2:5 info: Realtek TONOR TC40 Audio Device type: audio
    driver: snd-usb-audio interfaces: 3 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
    lanes: 1 mode: 2.0 power: 100mA chip-ID: 0bda:49e3 class-ID: 0102
  Device-2: 1-2.3:7 info: Logitech G213 Prodigy Gaming Keyboard
    type: keyboard,HID driver: hid-generic,usbhid interfaces: 2 rev: 2.0
    chip-ID: 046d:c336 class-ID: 0300 serial: <filter>
  Device-3: 1-3:4 info: Bison Integrated Camera type: video driver: uvcvideo
    interfaces: 2 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0
    power: 500mA chip-ID: 5986:212b class-ID: 0e02
  Device-4: 1-4:6 info: Integrated Express ITE Device(8910) type: keyboard
    lanes: 1 mode: 1.1 power: 100mA chip-ID: 048d:c101 class-ID: 0301
  Hub-4: 2-0:1 info: super-speed hub ports: 2 rev: 3.1
  Hub-5: 2-2:2 info: Genesys Logic GL3523 Hub ports: 3 rev: 3.2
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 05e3:0620
  Hub-6: 3-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
  Hub-7: 3-2:2 info: Genesys Logic Hub ports: 2 rev: 2.1
  Device-1: 3-2.1:4 info: Logitech G402 Gaming Mouse type: mouse,HID
    lanes: 1 mode: 1.1 power: 300mA chip-ID: 046d:c07e class-ID: 0300
    serial: <filter>
  Device-2: 3-4:3 info: Realtek Bluetooth Radio type: bluetooth
    driver: btusb interfaces: 2 rev: 1.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
    mode: 1.1 power: 500mA chip-ID: 0bda:4852 class-ID: e001 serial: <filter>
  Hub-8: 4-0:1 info: super-speed hub ports: 2 rev: 3.1
  Hub-9: 4-2:2 info: Genesys Logic GL3523 Hub ports: 2 rev: 3.2
  System Temperatures: cpu: 61.1 C mobo: N/A
  Fan Speeds (rpm): N/A
  Packages: 1972 pm: pacman pkgs: 1901 libs: 515 tools: pamac pm: flatpak
    pkgs: 71
    1: https://mirror.easyname.at/manjaro/stable/$repo/$arch
    2: https://forksystems.mm.fcix.net/manjaro/stable/$repo/$arch
    3: https://coresite.mm.fcix.net/manjaro/stable/$repo/$arch
    4: https://mirror.math.princeton.edu/pub/manjaro/stable/$repo/$arch
    5: https://volico.mm.fcix.net/manjaro/stable/$repo/$arch
    6: https://irltoolkit.mm.fcix.net/manjaro/stable/$repo/$arch
    7: https://repo.ialab.dsu.edu/manjaro/stable/$repo/$arch
    8: https://ridgewireless.mm.fcix.net/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 286
  1: cpu: 13.1% command: firefox pid: 2046 mem: 958.4 MiB (3.0%)
  2: cpu: 7.4% command: firefox pid: 5967 mem: 426.0 MiB (1.3%)
  3: cpu: 6.1% command: kwin_wayland pid: 790 mem: 299.8 MiB (0.9%)
  4: cpu: 1.8% command: firefox pid: 2139 mem: 752.3 MiB (2.3%)
  5: cpu: 1.6% command: firefox pid: 3409 mem: 270.0 MiB (0.8%)
  Memory top: 5 of 286
  1: mem: 958.4 MiB (3.0%) command: firefox pid: 2046 cpu: 13.1%
  2: mem: 752.3 MiB (2.3%) command: firefox pid: 2139 cpu: 1.8%
  3: mem: 564.6 MiB (1.7%) command: plasmashell pid: 935 cpu: 0.9%
  4: mem: 426.0 MiB (1.3%) command: firefox pid: 5967 cpu: 7.4%
  5: mem: 360.1 MiB (1.1%) command: systemsettings pid: 1990 cpu: 0.3%
  Processes: 286 Power: uptime: 1h 16m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 12.45 GiB services: org_kde_powerdevil,
    tool: systemctl
  Compilers: clang: 19.1.7 gcc: 14.2.1 alt: 13 Shell: Zsh v: 5.9
    default: Bash v: 5.2.37 running-in: konsole inxi: 3.3.37
I will try Wayland now
Okay so turns out I was using Wayland. I now switched to X11 and I have the same problem.
Also everything is a bit laggy and slow
I don’t know what to do then so this is me, taking a wild guess.
Seeing as you’re using Plasma:
…please provide the output of:
kscreen-doctor --outputs
output:
Output: 1 HDMI-A-1
        enabled
        connected
        priority 1
        HDMI
        Modes:  1:1920x1080@60!  2:1920x1080@165*  3:1920x1080@144  4:1920x1080@120  5:1920x1080@120  6:1920x1080@100  7:1920x1080@85  8:1920x1080@60  9:1920x1080@50  10:1680x1050@60  11:1280x1024@75  12:1280x1024@60  13:1440x900@75  14:1440x900@60  15:1280x960@60  16:1152x864@75  17:1280x720@60  18:1280x720@60  19:1280x720@50  20:1440x576@50  21:1024x768@75  22:1024x768@70  23:1024x768@60  24:1440x480@60  25:800x600@75  26:800x600@72  27:800x600@60  28:800x600@56  29:720x576@50  30:720x480@60  31:640x480@75  32:640x480@73  33:640x480@60  34:640x480@60
        Geometry: 1920,0 1920x1080
        Scale: 1
        Rotation: 1
        Overscan: 0
        Vrr: incapable
        RgbRange: unknown
        HDR: disabled
        Wide Color Gamut: disabled
        ICC profile: none
        Color profile source: sRGB
        Color power preference: prefer efficiency and performance
        Brightness control: supported, set to 45% and dimming to 100%
Output: 2 eDP-1
        enabled
        connected
        priority 2
        Panel
        Modes:  35:1920x1080@144*!
        Geometry: 0,0 1920x1080
        Scale: 1
        Rotation: 1
        Overscan: 0
        Vrr: Automatic
        RgbRange: unknown
        HDR: incapable
        Wide Color Gamut: incapable
        ICC profile: none
        Brightness control: supported, set to 79% and dimming to 100%
Even if u don’t have a fix thank you for your help.
I just have to think about what doing then
Do you think the issue is KDE Plasma or Manjaro?
Neither. Both connected and seems to be enabled:
So to me this is looking more and more like a faulty monitor…
The thing is, with windows everything works fine. Stopped working after some updates, don’t know which. And also the login screen and the console view (when you press control + alt + f3)
So I don’t really get how the monitor should be at fault.
Me neither. But stranger things have happened, I think. Try this, maybe it helps:
https://www.reddit.com/r/kde/comments/o9kjpn/comment/jgf86qx/?utm_source=share&utm_medium=web3x&utm_name=web3xcss&utm_term=1&utm_content=share_button
Edit:
Deleting the $HOME/.local/share/kscreen is, apparently, like a reset of your display settings. So you could try that:
mv $HOME/.local/share/kscreen $HOME/.local/share/kscreen.backup
…and see if you can just reconfigure it.
The symptoms you’re having seem remarkably similar to another recent topic;
The user’s issue was solved by addressing a related issue regarding the new Nvidia 570 drivers and the Plymouth (the three dots) boot screen. Disabling Plymouth actually solved their issue.
Perhaps you can have a look at the respective solution linked from that topic, and see if it brings any joy.
I did that but nothing changed
I tried changing the resolution now
I just set it to a random value (800×600) and now it works somehow
I will see what I can do with the resolution
Alright
I now changed it back to 1920×1080 and it works
Thank you for your help and time
Why didn’t I think of trying this earlier…
Anyway thank you!
Okay noy take that back
Somehow it stops working if I set the refresh rate to 165
120 hz works, 144 and 165 doesn’t
Weird
But it’s not that big of an issue rn
I think I will try display port later tho and see if the issue persists
Well, as you haven’t even acknowleged any of my posts, I’ll remove them. I’m glad you found a resolution.
Oh
I’m sorry I didn’t reply to any of your posts. I definitely read them.
And I would like to know what your last suggestion was?
Thank you for trying to help me though, I hope I didn’t come off as unfriendly, sorry :c
Not unfriendly, but clearly focussed. :smile_cat:
It’s not needed now, anyway, but I’ve restored it (scroll up). It was a longshot at best, if nothing else worked.
Oh okay
Thank you nonetheless
I will try to see if I can get 165hz working again
If not 120 is not that bad
At least I don’t have to use Windows for my daily use anymore :sweat_smile:
Actually, that just triggered a memory from a topic a few months ago. I recall mentioned that each monitor is best having a resolution that’s supported by both monitors.
So, in your case I might translate that as; if the laptop screen and the external monitor suppoer 120Hz - all good; but if the external monitor supports 165Hz and the laptop doesn’t - not so good.
Of course, this is conjecture, at best.
Hm
Interestingly my internal monitor has 144hz, it’s a value I can’t change
So now I have 144 and 120
And 144hz on my external screen didn’t work :woman_shrugging:
But do you mean buggy with not so good? Or just unstable in general?
