Hello guys,
I installed manjaro and i got stuck on this problem. My second monitor is not recognized. I already updated de kernel that I was using and installed the nvidea-graphics provided by sudo mhwd -a pci nonfree 0300
which is video-hybrid-amd-nvidia-prime -but it seems not to work. Can someone help me ?
PC: Omen 15
GPU: Nvidia 1650-Ti
CPU: AMD-Ryzen 4800H
Kernel: linux515
Olli
22 October 2022 15:24
2
I got this from it
Kernel: 5.15.74-3-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=7bd429e4-2c78-4e4e-bed0-e58bf9759cc6 rw quiet apparmor=1
Desktop: KDE Plasma v: 5.25.5 tk: Qt v: 5.15.6 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: HP product: OMEN Laptop 15-en0002np v: N/A
Mobo: HP model: 8788 v: 22.58 serial: <superuser required> UEFI: AMI
v: F.13 date: 03/04/2021
ID-1: BAT0 charge: 41.8 Wh (95.0%) condition: 44.0/44.0 Wh (100.0%)
volts: 12.9 min: 11.6 model: Hewlett-Packard Primary type: Li-ion
serial: N/A status: charging cycles: 395
ID-2: hidpp_battery_0 charge: 88% condition: N/A volts: 4.1 min: N/A
model: Logitech G703 LIGHTSPEED Wireless Gaming Mouse w/ HERO type: N/A
serial: <filter> status: discharging
RAM: total: 14.99 GiB used: 3.28 GiB (21.9%)
RAM Report: permissions: Unable to run dmidecode. Root privileges
required.
Info: model: AMD Ryzen 7 4800H with Radeon Graphics bits: 64 type: MT MCP
arch: Zen 2 gen: 3 level: v3 note: check built: 2020-22 process: TSMC n7
(7nm) family: 0x17 (23) model-id: 0x60 (96) stepping: 1
microcode: 0x8600106
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB L3: 8 MiB
desc: 2x4 MiB
Speed (MHz): avg: 1599 high: 2475 min/max: 1400/2900 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1397 2: 1843
3: 1713 4: 1416 5: 1743 6: 2019 7: 1447 8: 1457 9: 1406 10: 2475 11: 1397
12: 1397 13: 1397 14: 1614 15: 1460 16: 1411 bogomips: 92664
f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibrs ibs
pfthreshold pge pni popcnt pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a
rdtscp rep_good sep sha_ni skinit smap smca smep ssbd sse sse2 sse4_1
sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce topoext tsc
tsc_scale umip v_spec_ctrl v_vmsave_vmload vgif vmcb_clean vme vmmcall
wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
Type: retbleed mitigation: untrained return thunk; SMT enabled with STIBP
protection
prctl and seccomp
Type: spectre_v2 mitigation: Retpolines, IBPB: conditional, STIBP:
always-on, RSB filling, PBRSB-eIBRS: Not affected
Device-1: NVIDIA TU117M [GeForce GTX 1650 Ti Mobile] vendor: Hewlett-Packard
driver: nvidia v: 520.56.06 alternate: nouveau,nvidia_drm non-free: 515.xx+
status: current (as of 2022-10) arch: Turing code: TUxxx
process: TSMC 12nm built: 2018-22 pcie: gen: 1 speed: 2.5 GT/s lanes: 8
link-max: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 01:00.0
chip-ID: 10de:1f95 class-ID: 0300
Device-2: AMD Renoir vendor: Hewlett-Packard driver: amdgpu v: kernel
arch: GCN-5.1 code: Vega-2 process: TSMC n7 (7nm) built: 2018-21 pcie:
gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s ports:
active: eDP-1 empty: none bus-ID: 06:00.0 chip-ID: 1002:1636
class-ID: 0300 temp: 49.0 C
Device-3: Chicony HP Wide Vision HD Camera type: USB driver: uvcvideo
bus-ID: 1-3:2 chip-ID: 04f2:b6bb class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org v: 21.1.4 compositor: kwin_x11 driver: X:
loaded: modesetting dri: radeonsi gpu: amdgpu display-ID: :0 screens: 1
s-diag: 582mm (22.93")
Monitor-1: eDP-1 model: LG Display 0x05fe built: 2018 res: 1920x1080
hz: 144 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64")
diag: 395mm (15.5") ratio: 16:9 modes: max: 1920x1080 min: 640x480
OpenGL: renderer: AMD RENOIR (LLVM 14.0.6 DRM 3.42 5.15.74-3-MANJARO) v: 4.6
Mesa 22.1.7 direct render: Yes
Device-1: NVIDIA vendor: Hewlett-Packard driver: snd_hda_intel v: kernel
pcie: gen: 1 speed: 2.5 GT/s lanes: 8 link-max: gen: 3 speed: 8 GT/s
lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:10fa class-ID: 0403
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Hewlett-Packard
driver: snd_rn_pci_acp3x v: kernel alternate: snd_pci_acp3x,snd_pci_acp5x
pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s
bus-ID: 06:00.5 chip-ID: 1022:15e2 class-ID: 0480
Device-3: AMD Family 17h/19h HD Audio vendor: Hewlett-Packard
link-max: gen: 4 speed: 16 GT/s bus-ID: 06:00.6 chip-ID: 1022:15e3
class-ID: 0403
Sound API: ALSA v: k5.15.74-3-MANJARO running: yes
Sound Server-3: PipeWire v: 0.3.58 running: yes
vendor: Hewlett-Packard driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: e000 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 1 bus-ID: 03:00.0 chip-ID: 8086:2723 class-ID: 0280
IF: wlo1 state: down mac: <filter>
Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 1-4:3
Local Storage: total: 476.94 GiB used: 55.09 GiB (11.6%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: PC SN730
SDBPNTY-512G-1006 size: 476.94 GiB block-size: physical: 512 B
rev: HPS2 temp: 33.9 C scheme: GPT
ID-1: / raw-size: 68.61 GiB size: 66.98 GiB (97.63%) used: 55.01 GiB (82.1%)
fs: ext4 dev: /dev/nvme0n1p4 maj-min: 259:4 label: N/A
uuid: 7bd429e4-2c78-4e4e-bed0-e58bf9759cc6
ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%) used: 82.1 MiB
(32.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: SYSTEM
uuid: 7EAC-A740
ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-2: /dev/nvme0n1p3 maj-min: 259:3 size: 407.47 GiB fs: ntfs
label: Windows uuid: B22636D1263695F7
ID-3: /dev/nvme0n1p5 maj-min: 259:5 size: 600 MiB fs: ntfs label: N/A
uuid: C278566A78565CEB
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 1-3:2 info: Chicony HP Wide Vision HD Camera type: Video
Device-2: 1-4:3 info: Intel AX200 Bluetooth type: Bluetooth driver: btusb
class-ID: e001
Hub-2: 2-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 3-1:2 info: Microdia USB DEVICE type: Keyboard,Mouse
power: 400mA chip-ID: 0c45:7664 class-ID: 0301
Device-2: 3-2:3 info: Logitech Cordless Mouse Receiver
type: Keyboard,Mouse,HID driver: logitech-djreceiver,usbhid interfaces: 3
rev: 2.0 speed: 12 Mb/s power: 98mA chip-ID: 046d:c539 class-ID: 0300
Hub-4: 4-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 66.5 C mobo: N/A gpu: amdgpu temp: 51.0 C
Processes: 377 Uptime: 17m wakeups: 3 Init: systemd v: 251
default: graphical tool: systemctl Compilers: gcc: 12.2.0 Packages: 1398
pm: pacman pkgs: 1378 libs: 348 tools: pamac,yay pm: flatpak pkgs: 5
pm: snap pkgs: 15 Shell: Zsh v: 5.9 default: Bash v: 5.1.16
running-in: konsole inxi: 3.3.22
Olli
22 October 2022 15:31
4
run
glxinfo | grep server
and you’ll see that you’re using the internal graphics. to use the external port of your laptop you have to switch to nvidia
note: if glxinfo isn’t avaiable you’ll need to install the package mesa-utils (but it should be installed)
i got this:
server glx vendor string: SGI
server glx version string: 1.4
server glx extensions:
How can I switch to N-vidia ?
Olli
22 October 2022 15:34
6
install optimus-manager from package-manager and follow the linked instructions:
Olli
22 October 2022 15:35
7
Quintela:
i got this:
in fact SGI is the internal GPU
I guess I already swapped to Nvidia GPU but the monitor is not recognized as well.
I used optimus-manager --switch nvidia
and it warned me that I was swapping to Nvidia and then my computer kinda rebooted.
also runned xrandr --listproviders
and got:
Providers: number : 1
Provider 0: id: 0x43 cap: 0xf, Source Output, Sink Output, Source Offload, Sink Offload crtcs: 4 outputs: 1 associated providers: 0 name:modesetting
Also ran prime-run glxinfo | grep OpenGL
and got:
OpenGL vendor string: NVIDIA Corporation
OpenGL renderer string: NVIDIA GeForce GTX 1650 Ti/PCIe/SSE2
OpenGL core profile version string: 4.6.0 NVIDIA 520.56.06
OpenGL core profile shading language version string: 4.60 NVIDIA
OpenGL core profile profile mask: core profile
OpenGL core profile extensions:
OpenGL version string: 4.6.0 NVIDIA 520.56.06
OpenGL shading language version string: 4.60 NVIDIA
OpenGL context flags: (none)
OpenGL profile mask: (none)
OpenGL extensions:
OpenGL ES profile version string: OpenGL ES 3.2 NVIDIA 520.56.06
OpenGL ES profile shading language version string: OpenGL ES GLSL ES 3.20
OpenGL ES profile extensions:
Olli
22 October 2022 15:58
9
again
nvidia or SGI
check which state with glxinfo
SGI idk what I’ve done wrong
Olli
22 October 2022 16:01
11
first thing what is the status:
systemctl status optimus-manager.service
systemctl status optimus-manager.service  ✔
â—Ź optimus-manager.service - Optimus Manager Commands Daemon
Loaded: loaded (/usr/lib/systemd/system/optimus-manager.service; enabled; preset: disabled)
Active: active (running) since Sat 2022-10-22 17:54:26 WEST; 7min ago
Process: 691 ExecStartPre=/usr/bin/python3 -u -m optimus_manager.hooks.pre_daemon_start (code=>
Process: 775 ExecStartPre=/usr/bin/python3 -u -m optimus_manager.hooks.pre_xorg_start (code=ex>
Main PID: 831 (python3)
Tasks: 1 (limit: 18406)
Memory: 15.4M
CPU: 215ms
CGroup: /system.slice/optimus-manager.service
└─831 /usr/bin/python3 -u -m optimus_manager.daemon
out 22 17:54:26 manjaroquintela python3[775]: [81] INFO: Writing to /etc/X11/xorg.conf.d/10-optimu>
out 22 17:54:26 manjaroquintela python3[775]: [81] INFO: Writing state {'type': 'pending_post_xorg>
out 22 17:54:26 manjaroquintela python3[775]: [81] INFO: Xorg pre-start hook completed successfull>
out 22 17:54:26 manjaroquintela systemd[1]: Started Optimus Manager Commands Daemon.
out 22 17:54:26 manjaroquintela python3[831]: [1] INFO: # Commands daemon
out 22 17:54:26 manjaroquintela python3[831]: [1] INFO: Opening UNIX socket
out 22 17:54:26 manjaroquintela python3[831]: [1] INFO: Awaiting commands
out 22 18:00:55 manjaroquintela python3[831]: [389038] INFO: Received command : {"type": "switch",>
out 22 18:00:55 manjaroquintela python3[831]: [389038] INFO: Writing requested GPU mode nvidia
Actually now the 2nd monitor started working, I executed the optimus-manager --switch nvidia
command again and it worked
Olli
22 October 2022 16:05
14
pay attention and check also the /etc/sddm.conf file and do the “#” as described here:
Manjaro ships with a default configuration for SDDM (the default login manager for KDE) which overrides some keys needed by optimus-manager. To use optimus-manager, you need to edit the file /etc/sddm.conf and simply put a # before the line starting with DisplayCommandand the one starting with DisplayStopCommand.
it should look like this
Wayland]
EnableHiDPI=false
SessionCommand=/usr/share/sddm/scripts/wayland-session
SessionDir=/usr/share/wayland-sessions
SessionLogFile=.local/share/sddm/wayland-session.log
[X11]
#DisplayCommand=/usr/share/sddm/scripts/Xsetup
#DisplayStopCommand=/usr/share/sddm/scripts/Xstop
EnableHiDPI=false
MinimumVT=1
ServerArguments=-nolisten tcp
ServerPath=/usr/bin/X
SessionCommand=/usr/share/sddm/scripts/Xsession
SessionDir=/usr/share/xsessions
SessionLogFile=.local/share/sddm/xorg-session.log
UserAuthFile=.Xauthority
XauthPath=/usr/bin/xauth
XephyrPath=/usr/bin/Xephyr
after this everything should be fine.
Already done that, I saw that on the github repo that you sent. Thank you very much man!
system
Closed
25 October 2022 06:10
16
