I have seen similar issues pop up on other posts but didn’t understand the solution (Plus I use different hardware and didn’t want to mess up stuff).
I recently installed manjaro (used pop os before without facing this issue) and realized that my second monitor is not working. Both xrandr and kde settings seem to acknowledge the monitor exists but the monitor still doesn’t get any input. I am fairly new to linux (have done some troubleshooting before, but I’m far from an expert) and I haven’t posted in these forums before, so let me know if I need to give more information or if I accidentaly leave out key details.
xrandr information:
Screen 0: minimum 320 x 200, current 3839 x 1080, maximum 16384 x 16384
eDP connected primary 1920x1080+0+0 (normal left inverted right x axis y axis) 344mm x 194mm
1920x1080 120.04*+ 60.01
1680x1050 120.04
1280x1024 120.04
1440x900 120.04
1280x800 120.04
1280x720 120.04
1024x768 120.04
800x600 120.04
640x480 120.04
DisplayPort-0 disconnected (normal left inverted right x axis y axis)
HDMI-1-0 connected (normal left inverted right x axis y axis)
1920x1080 60.00 + 59.94 50.00
1600x900 60.00
1280x1024 75.02 60.02
1280x720 60.00 59.94 50.00
1152x864 75.00
1024x768 75.03 60.00
800x600 75.00 60.32
720x576 50.00
720x480 59.94
640x480 75.00 59.94 59.93
inxi information:
Kernel: 5.16.7-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.16-x86_64
root=UUID=d2b4d794-2d75-4789-bdc0-52584d8e2e63 rw quiet apparmor=1
Desktop: KDE Plasma 5.23.5 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: Dell product: Dell G15 5515 v: 1.4.0
serial: <superuser required> Chassis: type: 10 v: 1.4.0
Mobo: Dell model: 00VT1V v: A00 serial: <superuser required> UEFI: Dell
v: 1.4.0 date: 07/20/2021
ID-1: BAT1 charge: 79.4 Wh (94.3%) condition: 84.2/86.0 Wh (98.0%)
volts: 13.3 min: 11.4 model: Simplo 0x46,0x39,0x35,0x41,0x0B,0x0A,0x000E
type: Li-ion serial: <filter> status: Charging
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse M325
status: Discharging
RAM: total: 15.05 GiB used: 3.9 GiB (25.9%)
RAM Report:
Info: model: AMD Ryzen 7 5800H with Radeon Graphics bits: 64 type: MT MCP
arch: Zen 3 family: 0x19 (25) model-id: 0x50 (80) stepping: 0
microcode: 0xA50000C
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 3564 high: 4270 min/max: 1200/3200 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3838 2: 3058
3: 3407 4: 3593 5: 3453 6: 3374 7: 3378 8: 3370 9: 3533 10: 4270 11: 2793
12: 3875 13: 3196 14: 3680 15: 4039 16: 4174 bogomips: 102241
cqm_occup_llc cr8_legacy cx16 cx8 de decodeassists erms extapic
extd_apicid f16c flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt ht
hw_pstate ibpb ibrs ibs invpcid irperf lahf_lm lbrv lm mba mca mce
pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pku pni popcnt
pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni
skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor
svm svm_lock syscall tce topoext tsc tsc_scale umip v_spec_ctrl
v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall vpclmulqdq wbnoinvd wdt
Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional,
IBRS_FW, STIBP: always-on, RSB filling
Device-1: NVIDIA GA107M [GeForce RTX 3050 Ti Mobile] vendor: Dell
driver: nvidia v: 510.47.03 alternate: nouveau,nvidia_drm bus-ID: 01:00.0
chip-ID: 10de:25a0 class-ID: 0300
Device-2: AMD Cezanne vendor: Dell driver: amdgpu v: kernel
bus-ID: 05:00.0 chip-ID: 1002:1638 class-ID: 0300
Device-3: Microdia Integrated_Webcam_HD type: USB driver: uvcvideo
bus-ID: 1-4:3 chip-ID: 0c45:6a09 class-ID: 0e02
Display: x11 server: X.org 1.21.1.3 compositor: kwin_x11 driver:
loaded: amdgpu,ati,nvidia unloaded: modesetting,nouveau
alternate: fbdev,nv,vesa resolution: <missing: xdpyinfo>
OpenGL: renderer: AMD RENOIR (DRM 3.44.0 5.16.7-1-MANJARO LLVM 13.0.0)
v: 4.6 Mesa 21.3.5 direct render: Yes
Device-1: NVIDIA driver: snd_hda_intel v: kernel bus-ID: 01:00.1
chip-ID: 10de:2291 class-ID: 0403
Device-2: AMD Renoir Radeon High Definition Audio vendor: Dell
driver: snd_hda_intel v: kernel bus-ID: 05:00.1 chip-ID: 1002:1637
class-ID: 0403
Device-3: AMD Raven/Raven2/FireFlight/Renoir Audio Processor vendor: Dell
driver: snd_rn_pci_acp3x v: kernel alternate: snd_pci_acp3x,snd_pci_acp5x
bus-ID: 05:00.5 chip-ID: 1022:15e2 class-ID: 0480
Device-4: AMD Family 17h HD Audio vendor: Dell driver: snd_hda_intel
v: kernel bus-ID: 05:00.6 chip-ID: 1022:15e3 class-ID: 0403
Sound Server-1: ALSA v: k5.16.7-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.45 running: yes
Device-1: Realtek RTL8125 2.5GbE vendor: Dell driver: r8169 v: kernel
port: 2000 bus-ID: 03:00.0 chip-ID: 10ec:8125 class-ID: 0200
Device-2: Intel Wi-Fi 6 AX200 vendor: Rivet Networks Killer™
driver: iwlwifi v: kernel bus-ID: 04:00.0 chip-ID: 8086:2723 class-ID: 0280
IF: wlp4s0 state: up mac: <filter>
IF-ID-1: ipv6leakintrf0 state: unknown speed: N/A duplex: N/A
mac: <filter>
IP v6: <filter> type: noprefixroute scope: global
IF-ID-2: proton0 state: unknown speed: 10 Mbps duplex: full mac: N/A
IP v6: <filter> virtual: stable-privacy scope: link
Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 1-3:2
Local Storage: total: 476.94 GiB used: 74.22 GiB (15.6%)
ID-1: /dev/nvme0n1 maj-min: 259:0 model: OM3PDP3-AD NVMe KDI 512GB
lanes: 4 type: SSD serial: <filter> rev: 10100000 temp: 43.9 C scheme: GPT
ID-1: / raw-size: 476.64 GiB size: 468.09 GiB (98.21%)
used: 74.22 GiB (15.9%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: d2b4d794-2d75-4789-bdc0-52584d8e2e63
used: 300 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
label: NO_LABEL uuid: E2C1-3461
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 1-2:4 info: MacAlly USB Wired PC Keyboard type: Keyboard,HID
power: 98mA chip-ID: 2222:0067 class-ID: 0300
Device-2: 1-3:2 info: Intel AX200 Bluetooth type: Bluetooth driver: btusb
class-ID: e001
Device-3: 1-4:3 info: Microdia Integrated_Webcam_HD type: Video
Hub-2: 2-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 3-1:2 info: Logitech Unifying Receiver type: Keyboard,Mouse,HID
power: 98mA chip-ID: 046d:c52b class-ID: 0300
Hub-4: 4-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: N/A mobo: N/A gpu: amdgpu temp: 48.0 C
Processes: 397 Uptime: 5h 14m wakeups: 3470 Init: systemd v: 250
tool: systemctl Compilers: gcc: 11.1.0 clang: 13.0.1 Packages: 1428
pacman: 1413 lib: 450 flatpak: 15 Shell: Zsh v: 5.8 default: Bash v: 5.1.16
running-in: konsole inxi: 3.3.12
