I have a dual boot system with Manjaro-i3wm and Windows 10. The second monitor doesn’t work with Manjaro, works with windows. It is not detecting the HDMI connection. Can someone please help.
Here is the the output of some commands: xrandr
kramer ~ `xrandr`
Screen 0: minimum 8 x 8, current 1920 x 1080, maximum 32767 x 32767
eDP1 connected primary 1920x1080+0+0 (normal left inverted right x axis y axis) 340mm x 190mm
1920x1080 60.02*+ 59.93
1680x1050 59.88
1400x1050 59.98
1600x900 60.00 59.95 59.82
1280x1024 60.02
1400x900 59.96 59.88
1280x960 60.00
1368x768 60.00 59.88 59.85
1280x800 59.81 59.91
1280x720 59.86 60.00 59.74
1024x768 60.00
1024x576 60.00 59.90 59.82
960x540 60.00 59.63 59.82
800x600 60.32 56.25
864x486 60.00 59.92 59.57
640x480 59.94
720x405 59.51 60.00 58.99
640x360 59.84 59.32 60.00
VIRTUAL1 disconnected (normal left inverted right x axis y axis)
lspci
kramer ~ `lspci`
00:00.0 Host bridge: Intel Corporation 8th Gen Core Processor Host Bridge/DRAM Registers (rev 07)
00:01.0 PCI bridge: Intel Corporation 6th-10th Gen Core Processor PCIe Controller (x16) (rev 07)
00:02.0 VGA compatible controller: Intel Corporation CoffeeLake-H GT2 [UHD Graphics 630]
00:08.0 System peripheral: Intel Corporation Xeon E3-1200 v5/v6 / E3-1500 v5 / 6th/7th/8th Gen Core Processor Gaussian Mixture Model
00:12.0 Signal processing controller: Intel Corporation Cannon Lake PCH Thermal Controller (rev 10)
00:14.0 USB controller: Intel Corporation Cannon Lake PCH USB 3.1 xHCI Host Controller (rev 10)
00:14.2 RAM memory: Intel Corporation Cannon Lake PCH Shared SRAM (rev 10)
00:14.3 Network controller: Intel Corporation Cannon Lake PCH CNVi WiFi (rev 10)
00:15.0 Serial bus controller: Intel Corporation Cannon Lake PCH Serial IO I2C Controller #0 (rev 10)
00:15.1 Serial bus controller: Intel Corporation Cannon Lake PCH Serial IO I2C Controller #1 (rev 10)
00:16.0 Communication controller: Intel Corporation Cannon Lake PCH HECI Controller (rev 10)
00:17.0 RAID bus controller: Intel Corporation 82801 Mobile SATA Controller [RAID mode] (rev 10)
00:1d.0 PCI bridge: Intel Corporation Cannon Lake PCH PCI Express Root Port #14 (rev f0)
00:1e.0 Communication controller: Intel Corporation Cannon Lake PCH Serial IO UART Host Controller (rev 10)
00:1f.0 ISA bridge: Intel Corporation HM470 Chipset LPC/eSPI Controller (rev 10)
00:1f.3 Audio device: Intel Corporation Cannon Lake PCH cAVS (rev 10)
00:1f.4 SMBus: Intel Corporation Cannon Lake PCH SMBus Controller (rev 10)
00:1f.5 Serial bus controller: Intel Corporation Cannon Lake PCH SPI Controller (rev 10)
01:00.0 VGA compatible controller: NVIDIA Corporation GP107M [GeForce GTX 1050 Ti Mobile] (rev a1)
01:00.1 Audio device: NVIDIA Corporation GP107GL High Definition Audio Controller (rev a1)
06:00.0 Unassigned class [ff00]: Realtek Semiconductor Co., Ltd. RTL8411B PCI Express Card Reader (rev 01)
06:00.1 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 12)
@mithrial Maybe, because lshw -C video outputs one unclaimed. However, I have installed nvidia drivers, not sure what’s wrong.
I installed from the GUI utility provided in Settings manager, also using sudo mhwd -a pci nonfree 0300.
No /dev/i2c devices exist.
ddcutil requires module i2c-dev.
Strange. You have not installed ddcutil either you 'll get an output like this one (but for one monitor for the moment). Install i2c-devices and try again.
I suspect an issue/conflict with intel/nvidia drivers. That really strange that we only see one DP port.
To my mind, I think that your second monitor is on the nvidia card and like it is intel the master it is normal to see only monitor. The solution is to desactivate intel.
Perhaps with Prime ?
Another question: are you using a displaylink device (the second monitor) ?
I am having errors installing i2cdev. When I try to make the files, I get make[1]: *** [Makefile:709: install-am] Error 2 . Not sure why.
I do think it is some problem with drivers. I will try shifting to only NVIDIA drivers using optimus prime or prime as you suggested.
Optimus Prime says nvidia module does not seem to be available for the current kernel.
I added the line i2c_dev to /etc/modules-load.d/modules.conf, and when I now do sudo ddcutil detect
I get:
sudo ddcutil detect
Unable to open directory /sys/bus/i2c/devices/i2c--1: No such file or directory
Device /dev/i2c-255 does not exist. Error = ENOENT(2): No such file or directory
/sys/bus/i2c buses without /dev/i2c-N devices: /sys/bus/i2c/devices/i2c-255
Driver i2c_dev must be loaded or builtin
See https://www.ddcutil.com/kernel_module
Invalid display
I2C bus: /dev/i2c-7
DRM connector: card0-eDP-1
EDID synopsis:
Mfg id: LGD - UNK
Model:
Product code: 1496 (0x05d8)
Serial number:
Binary serial number: 0 (0x00000000)
Manufacture year: 2018, Week: 0
DDC communication failed
This is an eDP laptop display. Laptop displays do not support DDC/CI.
are you able to edit a textfile with sudo-rights ? if not we’ll help you.
what i really recommend to you is to switch to nvidia permanently. in this case i’m 100% sure it will work. it seem’s that acer really uses some electrical engineers that don’t know their job and that causes always trouble with this hybrid-mode-acer-BS.
if you want please install optimus-manager from the package-manager, but only installing this packet, do not switch anything that eventually will break your system. let me know if you want to try this.
I tried switching to NVIDIA using optimus. However, I get nvidia module does not seem to be available for the current kernel. when switching. i tried trying a new kernel(not real time), but still nothing changes.
On top of that, when I switch to NVIDIA, it starts the session but optimus manager is not able to open when NVIDIA is selected. I did the mistake of starting optimus on NVIDIA on boot, so now I am not able to even open optimus.
optimus-manager
ERROR: the latest GPU setup attempt failed at Xorg pre-start hook.
Log at /var/log/optimus-manager/switch/switch-20220820T120049.log
Cannot execute command because of previous error
well optimus-manager is active, that’s fine. now you check with
echo $XDG_SESSION_TYPE
that it is x11. it is, but you should know that nvidia and wayland is a mess, always use x11.
after you checked this you will edit /etc/default grub . you will find a entry
GRUB_CMDLINE_LINUX_DEFAULT="
you will add to the existing entries the following two one’s
