I had manjaro installed, but the fact I couldn’t full screen a window on my second monitor really bothered me. I just reinstalled and my second monitor still has this issue.
If I fullscreen a video on my second monitor (whichever monitor isn’t set to primary in nvidia-settings), I can get out, audio continues to play and my cursor can still move around, but the screen just shows black.
It happens in firefox and discord (so I’m assuming everything else) The two fixes I have are to disable full-screen-api.ignore-widgets in firefox (only helps firefox naturally) or not maximize the window before fullscreening (which is pretty annoying).
What I’ve tried so far:
-Nouveu drivers DO work (but don’t work with the android studio emulator or have cuda, so I can’t use them)
-disabling KDE full screen animations does not help
-I tried installing the nvidia drivers from the official website, but this was giving me a lot of issues.
-I tried shifting to kernel 5.14 from 13, but the problem is still there.
Most solutions I’ve found online center around nvidia hybrid graphics (which I’m not using), so if anyone has any solutions, I’d appreciate it!
Thanks.
System specs:
Kernel: 5.14.2-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.14-x86_64
root=UUID=5713985e-a16d-4540-860f-464cd0f30ae7 rw quiet apparmor=1
Desktop: KDE Plasma 5.22.5 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop Mobo: ASUSTeK model: PRIME A320M-K v: Rev X.0x
serial: <filter> UEFI: American Megatrends v: 5406 date: 11/13/2019
RAM: total: 31.29 GiB used: 3.36 GiB (10.7%)
Info: 8-Core model: AMD Ryzen 7 2700X bits: 64 type: MT MCP arch: Zen+
family: 17 (23) model-id: 8 stepping: 2 microcode: 800820D cache: L2: 4 MiB
bogomips: 118202
Speed: 2425 MHz min/max: 2200/3700 MHz boost: enabled Core speeds (MHz):
1: 2425 2: 2069 3: 1796 4: 2038 5: 1877 6: 3367 7: 1993 8: 1957 9: 2087
10: 2083 11: 1927 12: 3373 13: 1994 14: 1993 15: 2523 16: 1782
bmi2 bpext clflush clflushopt clzero cmov cmp_legacy constant_tsc cpb cpuid
fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb irperf lahf_lm lbrv lm mca
mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx nonstop_tsc nopl
npt nrip_save nx osvw overflow_recov pae pat pausefilter pclmulqdq pdpe1gb
perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni popcnt pse pse36
rapl rdrand rdseed rdtscp rep_good sep sev sev_es sha_ni skinit smap smca
sme smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 succor svm svm_lock syscall
tce topoext tsc tsc_scale v_vmsave_vmload vgif vmcb_clean vme vmmcall wdt
disabled, RSB filling
Device-1: NVIDIA GM206 [GeForce GTX 960] vendor: Micro-Star MSI
driver: nvidia v: 470.63.01 alternate: nouveau,nvidia_drm bus-ID: 08:00.0
chip-ID: 10de:1401 class-ID: 0300
Device-2: ARC Camera type: USB driver: snd-usb-audio,uvcvideo bus-ID: 1-9:4
chip-ID: 05a3:9331 class-ID: 0102 serial: <filter>
Screen-1: 0 s-res: 3360x1080 s-dpi: 89 s-size: 959x315mm (37.8x12.4")
s-diag: 1009mm (39.7")
Monitor-1: DVI-I-0 res: 1440x900 hz: 60 dpi: 90 size: 408x255mm (16.1x10.0")
diag: 481mm (18.9")
Monitor-2: HDMI-0 res: 1920x1080 hz: 60 dpi: 92 size: 531x299mm (20.9x11.8")
diag: 609mm (24")
OpenGL: renderer: NVIDIA GeForce GTX 960/PCIe/SSE2 v: 4.6.0 NVIDIA 470.63.01
direct render: Yes
Device-1: NVIDIA GM206 High Definition Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus-ID: 08:00.1 chip-ID: 10de:0fba
class-ID: 0403
Device-2: AMD Family 17h HD Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel bus-ID: 0a:00.3 chip-ID: 1022:1457 class-ID: 0403
Device-3: ARC Camera type: USB driver: snd-usb-audio,uvcvideo bus-ID: 1-9:4
Sound Server-1: ALSA v: k5.14.2-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.35 running: yes
vendor: ASUSTeK PRIME B450M-A driver: r8169 v: kernel port: f000
bus-ID: 06:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp6s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
driver: btusb v: 0.8 bus-ID: 1-3:2 chip-ID: 0a12:0001 class-ID: e001
Local Storage: total: 1.61 TiB used: 186.82 GiB (11.3%)
model: WDS256G1X0C-00ENX0 size: 238.47 GiB block-size: physical: 512 B
rev: B35500WD temp: 70.8 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000LX015-1U7172
type: HDD rpm: 5400 serial: <filter> rev: SDM1 scheme: MBR
ID-3: /dev/sdb maj-min: 8:16 type: USB model: MILAN II 512G size: 476.91 GiB
block-size: physical: 4096 B logical: 512 B type: SSD serial: <filter>
rev: 1012 scheme: GPT
Optical-1: /dev/sr0 vendor: ATAPI model: iHAS124 F rev: CL07
dev-links: cdrom
ID-1: / raw-size: 238.17 GiB size: 233.38 GiB (97.99%)
used: 41.17 GiB (17.6%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: 5713985e-a16d-4540-860f-464cd0f30ae7
label: NO_LABEL uuid: 46D5-D9AE
ID-3: /run/media/noahr/Initial raw-size: 931.51 GiB
size: 931.51 GiB (100.00%) used: 105.84 GiB (11.4%) fs: exfat dev: /dev/sda1
maj-min: 8:1 label: Initial uuid: A9E8-44FA
ID-4: /run/media/noahr/external_hardrive raw-size: 426.9 GiB
size: 426.9 GiB (100.00%) used: 15.04 GiB (3.5%) fs: btrfs dev: /dev/sdb2
maj-min: 8:18 label: external_hardrive
uuid: 47ecfea9-b457-4d3c-b6ba-f2976de37ecb
ID-5: /run/timeshift/backup raw-size: 50 GiB size: 48.91 GiB (97.83%)
used: 24.76 GiB (50.6%) fs: ext4 dev: /dev/sdb1 maj-min: 8:17 label: Backups
uuid: 1c05555e-1b7e-4ee3-8f40-56b52d20f639
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 9 rev: 2.0
Device-1: 1-3:2 info: Cambridge Silicon Radio Bluetooth Dongle (HCI mode)
type: Bluetooth driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 0a12:0001 class-ID: e001
Device-2: 1-5:3 info: Sony WF-SP800N type: HID driver: hid-generic,usbhid
interfaces: 1 rev: 2.0 speed: 12 Mb/s power: 500mA chip-ID: 054c:0d52
class-ID: 0300
Device-3: 1-9:4 info: ARC Camera type: Video,Audio
power: 200mA chip-ID: 05a3:9331 class-ID: 0102 serial: <filter>
Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 3 rev: 3.1 speed: 10 Gb/s
Hub-3: 3-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
Device-1: 3-3:2 info: Cooler Master MK750 type: Keyboard,HID
driver: hid-generic,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 2516:0067 class-ID: 0300
Device-2: 3-4:3 info: Razer USA DeathAdder Essential type: Mouse,Keyboard
power: 500mA chip-ID: 1532:006e class-ID: 0300
Hub-4: 4-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.0 speed: 5 Gb/s
Device-1: 4-1:2 info: Western Digital My Passport SSD (WDBK3E)
type: Mass Storage driver: uas interfaces: 1 rev: 3.1 speed: 5 Gb/s
power: 896mA chip-ID: 1058:25f3 class-ID: 0806 serial: <filter>
System Temperatures: cpu: 45.0 C mobo: N/A gpu: nvidia temp: 43 C
Processes: 353 Uptime: 2h 49m wakeups: 0 Init: systemd v: 249
tool: systemctl Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: 1392
pacman: 1379 lib: 353 flatpak: 0 snap: 13 Shell: Zsh v: 5.8 default: Bash
v: 5.1.8 running-in: yakuake inxi: 3.3.06
xrandr, if it helps
xrandr ✔ 3s
Screen 0: minimum 8 x 8, current 3360 x 1080, maximum 16384 x 16384
DVI-I-0 connected 1440x900+0+90 (normal left inverted right x axis y axis) 408mm x 255mm
1440x900 59.89*+ 74.98
1280x1024 75.02 60.02
1280x960 60.00
1152x864 75.00
1024x768 75.03 70.07 60.00
800x600 75.00 60.32 56.25
640x480 75.00 59.94
DVI-I-1 disconnected (normal left inverted right x axis y axis)
HDMI-0 connected primary 1920x1080+1440+0 (normal left inverted right x axis y axis) 531mm x 299mm
1920x1080 60.00*+ 59.94 50.00 60.05 60.00 50.04
1680x1050 59.95
1600x900 60.00
1280x800 59.81
1280x720 60.00 59.94 50.00
1024x768 75.03 60.00
800x600 75.00 60.32
720x576 50.00
720x480 59.94
640x480 75.00 59.94 59.93
DP-0 disconnected (normal left inverted right x axis y axis)
DP-1 disconnected (normal left inverted right x axis y axis)
DP-2 disconnected (normal left inverted right x axis y axis)
DP-3 disconnected (normal left inverted right x axis y axis)
DP-4 disconnected (normal left inverted right x axis y axis)
DP-5 disconnected (normal left inverted right x axis y axis)
