Second monitor connected to my laptop isn't working on manjaro
  Kernel: 5.15.60-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.1
    root=UUID=697ce6db-8d93-4205-8ae5-a1f89152fffc rw quiet splash apparmor=1
  Desktop: GNOME v: 42.4 tk: GTK v: 3.24.34 wm: gnome-shell dm: GDM v: 42.0
  Type: Laptop System: Micro-Star product: GF65 Thin 10UE v: REV:1.0
  Mobo: Micro-Star model: MS-16W2 v: REV:1.0 serial: <superuser required>
    UEFI: American Megatrends v: E16W2IMS.105 date: 05/14/2021
  ID-1: BAT1 charge: 24.5 Wh (100.0%) condition: 24.5/51.3 Wh (47.7%)
    volts: 12.8 min: 11.4 model: MSI BIF0_9 type: Li-ion serial: N/A
    status: full
  RAM: total: 15.45 GiB used: 3.95 GiB (25.6%)
  RAM Report: permissions: Unable to run dmidecode. Root privileges
    required.
  Info: model: Intel Core i7-10750H bits: 64 type: MT MCP arch: Comet Lake
    gen: core 10 level: v3 built: 2020 process: Intel 14nm family: 6
    model-id: 0xA5 (165) stepping: 2 microcode: 0xF0
    L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 1.5 MiB desc: 6x256 KiB
    L3: 12 MiB desc: 1x12 MiB
  Speed (MHz): avg: 800 min/max: 800/5000 scaling: driver: intel_pstate
    governor: powersave cores: 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800
    8: 800 9: 800 10: 800 11: 800 12: 800 bogomips: 62431
    fsgsbase fxsr ht hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs
    ibrs_enhanced ida intel_pt invpcid invpcid_single lahf_lm lm mca mce
    md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx ospke pae pat
    pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pku pln pni popcnt pse pse36 pts
    rdrand rdseed rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1
    xsaves xtopology xtpr
  Type: retbleed mitigation: Enhanced IBRS
    prctl and seccomp
  Type: spectre_v2 status: Vulnerable: eIBRS with unprivileged eBPF
  Device-1: Intel CometLake-H GT2 [UHD Graphics] vendor: Micro-Star MSI
    ports: active: eDP-1 empty: none bus-ID: 00:02.0 chip-ID: 8086:9bc4
    class-ID: 0300
  Device-2: NVIDIA GA106M [GeForce RTX 3060 Mobile / Max-Q]
    vendor: Micro-Star MSI driver: nvidia v: 515.65.01
    alternate: nouveau,nvidia_drm non-free: 515.xx+ status: current (as of
    2022-08) arch: Ampere code: GAxxx process: TSMC n7 (7nm) built: 2020-22
    pcie: speed: Unknown lanes: 63 link-max: gen: 6 speed: 64 GT/s
    bus-ID: 01:00.0 chip-ID: 10de:2520 class-ID: 0300
  Display: x11 server: X.org v: 1.21.1.4 with: Xwayland v: 22.1.3
    compositor: gnome-shell driver: X: loaded: modesetting unloaded: nvidia
    alternate: fbdev,nouveau,nv,vesa gpu: i915 display-ID: :1 screens: 1
  Screen-1: 0 s-res: 1920x1080 s-size: <missing: xdpyinfo>
  Monitor-1: eDP-1 model: ChiMei InnoLux 0x1521 built: 2020 res: 1920x1080
    hz: 144 dpi: 142 gamma: 1.2 size: 344x193mm (13.54x7.6") diag: 394mm (15.5")
    ratio: 16:9 modes: 1920x1080
  OpenGL: renderer: Mesa Intel UHD Graphics (CML GT2) v: 4.6 Mesa 22.1.6
    direct render: Yes
  Device-1: Intel Comet Lake PCH cAVS vendor: Micro-Star MSI
    driver: snd_hda_intel v: kernel alternate: snd_soc_skl,snd_sof_pci_intel_cnl
    bus-ID: 00:1f.3 chip-ID: 8086:06c8 class-ID: 0403
  Device-2: NVIDIA GA106 High Definition Audio vendor: Micro-Star MSI
    driver: snd_hda_intel v: kernel pcie: speed: Unknown lanes: 63 link-max:
    gen: 6 speed: 64 GT/s bus-ID: 01:00.1 chip-ID: 10de:228e class-ID: 0403
  Sound Server-1: ALSA v: k5.15.60-1-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.56 running: yes
  Device-1: Intel Comet Lake PCH CNVi WiFi driver: iwlwifi v: kernel
    bus-ID: 00:14.3 chip-ID: 8086:06f0 class-ID: 0280
  IP v6: <filter> type: noprefixroute scope: global
    vendor: Micro-Star MSI driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
    lanes: 1 port: 3000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
    bus-ID: 1-14:3 chip-ID: 8087:0026 class-ID: e001
  Local Storage: total: 1.38 TiB used: 327.69 GiB (23.3%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Micron model: 2210 MTFDHBA512QFD
    lanes: 4 type: SSD serial: <filter> rev: P6MA001 temp: 49.9 C scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 type: USB vendor: SanDisk model: SSD PLUS
    1000GB size: 931.52 GiB block-size: physical: 512 B logical: 512 B
    type: SSD serial: <filter> scheme: GPT
  ID-1: / raw-size: 76.34 GiB size: 74.59 GiB (97.71%) used: 34.1 GiB (45.7%)
    fs: ext4 dev: /dev/nvme0n1p3 maj-min: 259:3 label: N/A
    uuid: 697ce6db-8d93-4205-8ae5-a1f89152fffc
  ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 34.2 MiB
    (11.4%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: NO_LABEL
    uuid: F8C6-0A4C
  ID-3: /run/media/daniel/SSD-Linux raw-size: 186.26 GiB size: 182.28 GiB
    (97.86%) used: 6 MiB (0.0%) fs: ext4 dev: /dev/sda2 maj-min: 8:2
    label: SSD-Linux uuid: 7c405308-71af-4165-bfd9-9adca8ecdfc9
  ID-4: /run/media/daniel/SSD-WIN raw-size: 745.25 GiB size: 745.25 GiB
    (100.00%) used: 293.56 GiB (39.4%) fs: ntfs dev: /dev/sda1 maj-min: 8:1
    label: SSD-WIN uuid: B02243162242E148
  ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 400.29 GiB fs: ntfs label: N/A
    uuid: B04EB8F94EB8BA04
  Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 16 rev: 2.0
  Device-1: 1-3:2 info: Sunplus Innovation Optical Mouse type: Mouse
    driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 1.5 Mb/s
    power: 98mA chip-ID: 1bcf:0005 class-ID: 0301
  Device-2: 1-14:3 info: Intel AX201 Bluetooth type: Bluetooth driver: btusb
    interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 8087:0026
    class-ID: e001
  Hub-2: 2-0:1 info: Super-speed hub ports: 8 rev: 3.1 speed: 10 Gb/s
  Device-1: 2-5:2 info: ASMedia ASM1153 SATA 3Gb/s bridge type: Mass Storage
    driver: usb-storage interfaces: 1 rev: 3.0 speed: 5 Gb/s chip-ID: 174c:1153
    class-ID: 0806 serial: <filter>
  System Temperatures: cpu: 66.0 C pch: 68.0 C mobo: N/A
  Processes: 334 Uptime: 16m wakeups: 1 Init: systemd v: 251
  default: graphical tool: systemctl Compilers: gcc: 12.1.1 clang: 14.0.6
  Packages: pm: pacman pkgs: 1320 libs: 412 tools: gnome-software,pamac
  pm: flatpak pkgs: 0 Shell: Zsh v: 5.9 running-in: gnome-terminal
  inxi: 3.3.21
I have a second monitor hooked up to my laptop but it doesn’t work on Manjaro. Never had this problem with linux before.
Some laptops with NVIDIA dedicated graphic cards have external ports directly connected to the dedicated card and so you need to use prime or another offloader in order to use the external port.
