I read the post I can get in the forum. not work for me.
I get two monitors work fine on windows(dual system). But one not work in linux.
Install the driver follow wiki
I am using 4060 nvidia. info in kde display configuration just show one monitor. I install the nvidia driver follow the arch wiki steps.
I use x11.
- install nvidia through pacman
sudo pacman -S nvidia - remove the kms flag then reboot.
- run command
mkinitcpio -P - reboot
Not work. (second monitor not detected)
Infomation
lspci -n -n -k | grep -A 2 -e VGA -e 3D
01:00.0 VGA compatible controller [0300]: NVIDIA Corporation AD107 [GeForce RTX 4060] [10de:2882] (rev a1)
Subsystem: ASUSTeK Computer Inc. Device [1043:8944]
Kernel modules: nouveau
echo $XDG_SESSION_TYPE && glxinfo | grep server
x11
server glx vendor string: SGI
server glx version string: 1.4
server glx extensions:
inxi -v8zy
Kernel: 6.6.47-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=75d363f8-9c23-45d6-abb5-0d263d2a7b11 rw quiet splash
udev.log_priority=3
Desktop: KDE Plasma v: 6.0.5 tk: Qt v: N/A info: frameworks v: 6.5.0
Mobo: ASUSTeK model: ROG STRIX Z690-A GAMING WIFI D4 v: Rev 1.xx
UEFI: American Megatrends v: 2802 date: 09/27/2023
Device-1: hidpp_battery_0 model: Logitech G304 Lightspeed Wireless Gaming
Mouse serial: <filter> charge: 100% (should be ignored) rechargeable: yes
status: discharging
System RAM: total: 32 GiB available: 31.09 GiB used: 5.63 GiB (18.1%)
Device-1: Controller0-ChannelA-DIMM0 type: no module installed
Device-2: Controller0-ChannelA-DIMM1 type: DDR4 detail: synchronous
size: 16 GiB speed: 2133 MT/s volts: curr: 1 min: 1 max: 1.35 width (bits):
data: 64 total: 64 manufacturer: Corsair part-no: CM4X16GC3200C16K2E
serial: N/A
Device-3: Controller1-ChannelA-DIMM0 type: no module installed
Device-4: Controller1-ChannelA-DIMM1 type: DDR4 detail: synchronous
serial: N/A
Info: model: 12th Gen Intel Core i7-12700K bits: 64 type: MST AMCP
arch: Alder Lake gen: core 12 level: v3 note: check built: 2021+
process: Intel 7 (10nm ESF) family: 6 model-id: 0x97 (151) stepping: 2
microcode: 0x35
Topology: cpus: 1x dies: 1 clusters: 9 cores: 12 threads: 20 mt: 8 tpc: 2
st: 4 smt: enabled cache: L1: 1024 KiB desc: d-4x32 KiB, 8x48 KiB; i-8x32
KiB, 4x64 KiB L2: 12 MiB desc: 8x1.2 MiB, 1x2 MiB L3: 25 MiB desc: 1x25 MiB
Speed (MHz): avg: 957 min/max: 800/4900:5000:3800 scaling:
driver: intel_pstate governor: powersave cores: 1: 957 2: 957 3: 957 4: 957
5: 957 6: 957 7: 957 8: 957 9: 957 10: 957 11: 957 12: 957 13: 957 14: 957
15: 957 16: 957 17: 957 18: 957 19: 957 20: 957 bogomips: 144440
de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
hwp_epp hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ibt ida intel_pt
msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq pconfig pdcm
rdtscp rep_good sdbg sep serialize sha_ni smap smep smx split_lock_detect
ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tme tpr_shadow
tsc tsc_adjust tsc_deadline_timer tsc_known_freq umip user_shstk vaes vme
vmx vnmi vpclmulqdq vpid waitpkg x2apic xgetbv1 xsave xsavec xsaveopt
xsaves xtopology xtpr
Type: spectre_v2 mitigation: Enhanced / Automatic IBRS; IBPB: conditional;
RSB filling; PBRSB-eIBRS: SW sequence; BHI: BHI_DIS_S
Device-1: NVIDIA AD107 [GeForce RTX 4060] vendor: ASUSTeK driver: N/A
alternate: nouveau non-free: 550.xx+ status: current (as of 2024-09)
arch: Lovelace code: AD1xx process: TSMC n4 (5nm) built: 2022+ pcie: gen: 4
speed: 16 GT/s lanes: 8 bus-ID: 01:00.0 chip-ID: 10de:2882 class-ID: 0300
Display: x11 server: X.Org v: 21.1.13 with: Xwayland v: 24.1.2
compositor: kwin_x11 driver: X: loaded: modesetting,nouveau
alternate: fbdev,nv,vesa gpu: N/A display-ID: :0 screens: 1
Screen-1: 0 s-res: 3840x2160 s-dpi: 96 s-size: 1016x571mm (40.00x22.48")
s-diag: 1165mm (45.88")
Monitor-1: Unknown-1 mapped: None-1 res: 3840x2160 hz: 60 size: N/A
modes: 3840x2160
API: EGL v: 1.5 platforms: device: 0 drv: swrast surfaceless: drv: swrast
x11: drv: swrast inactive: gbm,wayland
API: OpenGL v: 4.5 vendor: mesa v: 24.1.6-arch1.1 glx-v: 1.4
direct-render: yes renderer: llvmpipe (LLVM 18.1.8 256 bits)
device-ID: ffffffff:ffffffff memory: 30.36 GiB unified: yes
Device-1: Intel Alder Lake-S HD Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel alternate: snd_sof_pci_intel_tgl bus-ID: 00:1f.3 chip-ID: 8086:7ad0
class-ID: 0403
Device-2: NVIDIA vendor: ASUSTeK driver: snd_hda_intel v: kernel pcie:
gen: 4 speed: 16 GT/s lanes: 8 bus-ID: 01:00.1 chip-ID: 10de:22be
class-ID: 0403
Device-3: ASUSTek USB Audio driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-2:2
chip-ID: 0b05:1a16 class-ID: 0300
Device-4: Blue Microphones Yeti Stereo Microphone
driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 1.1 speed: 12 Mb/s
lanes: 1 mode: 1.1 bus-ID: 1-6.2:8 chip-ID: b58e:9e84 class-ID: 0300
serial: <filter>
API: ALSA v: k6.6.47-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.2.3 status: active with: 1: pipewire-pulse
Device-1: Intel Alder Lake-S PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:7af0 class-ID: 0280
IF: wlo1 state: down mac: <filter>
Device-2: Intel Ethernet I225-V vendor: ASUSTeK driver: igc v: kernel pcie:
gen: 2 speed: 5 GT/s lanes: 1 port: N/A bus-ID: 06:00.0 chip-ID: 8086:15f3
class-ID: 0200
IF: enp6s0 state: up speed: 100 Mbps duplex: full mac: <filter>
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:9 chip-ID: 8087:0026
class-ID: e001
Hardware-1: Intel Volume Management Device NVMe RAID Controller driver: vmd
v: 0.6 port: N/A bus-ID: 00:0e.0 chip-ID: 8086:467f rev: class-ID: 0104
Local Storage: total: 1.16 TiB used: 18.79 GiB (1.6%)
ID-1: /dev/nvme0n1 maj-min: 259:7 vendor: Samsung model: MZVLW256HEHP-00000
size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: CXB7201Q temp: 38.9 C
scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:0 model: Predator SSD GM7000 1TB
size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: 3.A.F.X temp: 46.9 C
scheme: GPT
ID-1: / raw-size: 238.17 GiB size: 233.38 GiB (97.99%) used: 18.79 GiB (8.1%)
fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:9 label: N/A
uuid: 75d363f8-9c23-45d6-abb5-0d263d2a7b11
used: 296 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:8 label: N/A
uuid: 4527-ECC0
ID-1: /dev/nvme1n1p1 maj-min: 259:1 size: 300 MiB fs: vfat label: N/A
uuid: 38E9-1CA4
ID-2: /dev/nvme1n1p2 maj-min: 259:2 size: 128 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-3: /dev/nvme1n1p3 maj-min: 259:3 size: 399.3 GiB fs: ntfs label: N/A
uuid: 36EEB1C9EEB18223
ID-4: /dev/nvme1n1p4 maj-min: 259:4 size: 721 MiB fs: ntfs label: N/A
uuid: 54843B7D843B6122
ID-5: /dev/nvme1n1p5 maj-min: 259:5 size: 277 GiB fs: ntfs
label: \xe8\xbd\xaf\xe4\xbb\xb6 uuid: 82F5CC661A7FB9E9
ID-6: /dev/nvme1n1p6 maj-min: 259:6 size: 276.45 GiB fs: ntfs
label: \xe6\x96\x87\xe6\xa1\xa3 uuid: CD068EC007AE2BEF
Device-1: 1-2:2 info: ASUSTek USB Audio type: audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 8 rev: 2.0
Device-2: 1-4:3 info: ASUSTek AURA LED Controller type: HID
lanes: 1 mode: 1.1 power: 16mA chip-ID: 0b05:19af class-ID: 0300
serial: <filter>
Hub-2: 1-6:4 info: Genesys Logic Hub ports: 4 rev: 2.1
Device-1: 1-6.1:6 info: Logitech USB Receiver type: keyboard,mouse,HID
driver: logitech-djreceiver,usbhid interfaces: 3 rev: 2.0
chip-ID: 046d:c53f class-ID: 0300
Device-2: 1-6.2:8 info: Blue Microphones Yeti Stereo Microphone
type: audio,HID driver: hid-generic,snd-usb-audio,usbhid interfaces: 4
rev: 1.1 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 100mA
chip-ID: b58e:9e84 class-ID: 0300 serial: <filter>
Device-3: 1-6.3:10 info: Logitech USB Receiver type: mouse,keyboard,HID
lanes: 1 mode: 1.1 power: 98mA chip-ID: 046d:c547 class-ID: 0300
Hub-3: 1-10:5 info: ASMedia ASM1074 High-Speed hub ports: 4 rev: 2.1
chip-ID: 174c:2074 class-ID: 0900
Hub-4: 1-13:7 info: Alcor Micro USB Hub ports: 4 rev: 2.0
chip-ID: 058f:6254 class-ID: 0900
Device-1: 1-14:9 info: Intel AX201 Bluetooth type: bluetooth driver: btusb
power: 100mA chip-ID: 8087:0026 class-ID: e001
Hub-5: 2-0:1 info: super-speed hub ports: 8 rev: 3.1
Hub-6: 2-4:2 info: Genesys Logic Hub ports: 4 rev: 3.1
speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 05e3:0626
Hub-7: 2-8:3 info: ASMedia ASM1074 SuperSpeed hub ports: 4 rev: 3.0
speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 power: 8mA
chip-ID: 174c:3074 class-ID: 0900
System Temperatures: cpu: 34.0 C mobo: N/A
Fan Speeds (rpm): N/A
Packages: pm: pacman pkgs: 1475 libs: 354 tools: pamac,yay pm: flatpak
pkgs: 0
1: https://mirrors.sjtug.sjtu.edu.cn/manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 394
1: cpu: 115% command: kwin_x11 pid: 1066 mem: 699.2 MiB (2.1%)
2: cpu: 35.1% command: alacritty pid: 5643 mem: 167.7 MiB (0.5%)
3: cpu: 17.0% command: Xorg pid: 822 mem: 605.7 MiB (1.9%)
4: cpu: 10.9% command: chrome pid: 4490 mem: 403.7 MiB (1.2%)
5: cpu: 9.1% command: plasmashell pid: 1173 mem: 1123.0 MiB (3.5%)
Memory top: 5 of 394
1: mem: 1123.0 MiB (3.5%) command: plasmashell pid: 1173 cpu: 9.1%
2: mem: 699.2 MiB (2.1%) command: kwin_x11 pid: 1066 cpu: 115%
3: mem: 605.7 MiB (1.9%) command: Xorg pid: 822 cpu: 17.0%
4: mem: 484.3 MiB (1.5%) command: chrome pid: 3914 cpu: 7.1%
5: mem: 426.9 MiB (1.3%) command: systemsettings pid: 20635 cpu: 2.3%
Processes: 394 Power: uptime: 33m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.42 GiB services: org_kde_powerdevil,
power-profiles-daemon, upowerd Init: systemd v: 256 default: graphical
tool: systemctl
Compilers: clang: 18.1.8 gcc: 14.2.1 Shell: fish v: 3.7.1 running-in: tmux:
inxi: 3.3.36
