Hello fellow Penguins! I have a strange problem.
I recently reinstalled Manjaro on my Laptop. The Laptop has both an SSD (250GB) and an HDD (1TB) drive. I usually use the HDD as my /home partition.
once i updated the system i wanted to change my /home partition to the second hard dirve… only to see that it is completely missing
The drive is still inside the laptop. I also have not opened it up or done anything else to it. yet the drive is completely undetected!
blkid only sees the SSD:
The output of sudo blkid
is:
/dev/nvme0n1p1: LABEL_FATBOOT="NO_LABEL" LABEL="NO_LABEL" UUID="FAD2-6E88" BLOCK_SIZE="512" TYPE="vfat" PARTUUID="a7e94599-c508-5946-a33a-800de755a91c"
/dev/nvme0n1p2: UUID="e64e3ed9-a5bd-4fbb-8c49-535e24f3f752" BLOCK_SIZE="4096" TYPE="ext4" PARTLABEL="root" PARTUUID="e056c596-3416-d64f-aacc-153105019425"
The output to fsck -lu
is:
/dev/nvme0n1: 238,47 GiB, 256060514304 bytes, 500118192 sectors Disk model: SAMSUNG MZVLB256HAHQ-000H1
Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes Disklabel type: gpt Disk identifier: 88BE5CB9-C6BB-F447-95BA-7736890E0528
/dev/nvme0n1p1 4096 618495 614400 300M EFI System /dev/nvme0n1p2 618496 500103449 499484954 238,2G Linux filesystem
GParted also does not show the drive in its drop-down menu.
What happened? How do i get my drive back? The laptop is less than 2 years old. i don’t want to buy a new one!
