as described the quick search function of the application launcher is not working anymore. i hope someone can help.
Is Baloo running?
System Settings → Workspace → Search
File Search
KRunner
no it’s deactivated
Try activating it, but be aware that it’ll take some time (and CPU cycles) to populate. You don’t necessarily need to index file content ─ which is very CPU-intensive ─ but indexing filenames is something I myself would recommend.
thanks for your help but if the search function does only work with active balloo than i give a shit to it and will not use it anymore.
