rethus
1
Regarding to this answer: Unable to Change Logon Screen (SDDM) - #2 by Strit I wonder, that there is no “LoginScreen” Menu-Entry in my settings at all.
Any suggestion how to fix this? Is there a package that might be removed, so that it’s not available anymore?
Hi @rethus,
AFAIK, you’re looking for sddm-kcm from the extra repository:
$ pamac info sddm-kcm
Version : 5.27.8-2
Description : KDE Config Module for SDDM
URL : https://kde.org/plasma-desktop/
Licences : GPL
Repository : extra
Installed Size : 482.7 kB
Groups : plasma
Depends On : sddm knewstuff5 systemsettings
Optional Dependencies : --
Required By : --
Optional For : --
Provides : --
Replaces : --
Conflicts With : --
Packager : Antonio Rojas <arojas@archlinux.org>
Build Date : Sun 01 Oct 2023 01:32:50
Install Date : Tue 10 Oct 2023 08:52:00
Install Reason : Explicitly installed
Validated By : Signature
Backup files : --
If it’s not installed, install it with:
pamac install sddm-kcm
If it is installed, well then
Edit:
And me not understanding German, perhaps this helps you. This is where mine is located:
https://i.imgur.com/H4UGIpt.png
rethus
3
Perfect, thanks. That was it
