Hello everyone, I just installed Manjaro KDE Plasma and I have a weird issue with the log in screen.
Setup
Hardware
- CPU: AMD Ryzen 7 5700G
- GPU: Integrated graphics
- Motherboard: Asus ROG Strix B550-E Gaming
- Monitors (Dual): Dell P2719HC and P2719H
Software
inxi --admin --verbosity=7 --filter --width
Kernel: 5.13.19-2-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-5.13-x86_64
root=UUID=86d39de0-ed1a-4e6a-9552-faad7eadead8 rw rootflags=subvol=@ quiet
Desktop: KDE Plasma 5.23.3 tk: Qt 5.15.2 wm: kwin_x11 vt: 2 dm: SDDM
Mobo: ASUSTeK model: ROG STRIX B550-E GAMING v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 2423
date: 08/09/2021
RAM: total: 14.93 GiB used: 2.73 GiB (18.3%)
Info: 8-Core model: AMD Ryzen 7 5700G with Radeon Graphics bits: 64
type: MT MCP arch: Zen 3 family: 19 (25) model-id: 50 (80) stepping: 0
microcode: A50000C cache: L1: 512 KiB L2: 4 MiB L3: 16 MiB bogomips: 137654
Speed: 4279 MHz min/max: 1400/4300 MHz boost: enabled Core speeds (MHz):
1: 4279 2: 4292 3: 4300 4: 4270 5: 4295 6: 4296 7: 4299 8: 4299 9: 4292
10: 4300 11: 4299 12: 4284 13: 4217 14: 4268 15: 4293 16: 4299
cr8_legacy cx16 cx8 de decodeassists erms extapic extd_apicid f16c
flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt ht hw_pstate ibpb ibrs ibs
invpcid irperf lahf_lm lbrv lm mba mca mce misalignsse mmx mmxext monitor
movbe msr mtrr mwaitx nonstop_tsc nopl npt nrip_save nx ospke osvw
overflow_recov pae pat pausefilter pclmulqdq pdpe1gb perfctr_core
perfctr_llc perfctr_nb pfthreshold pge pku pni popcnt pse pse36 rdpid rdpru
rdrand rdseed rdt_a rdtscp rep_good sep sha_ni skinit smap smca smep ssbd
sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce
topoext tsc tsc_scale umip v_spec_ctrl v_vmsave_vmload vaes vgif vmcb_clean
vme vmmcall vpclmulqdq wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt
xsaves
Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional, IBRS_FW,
STIBP: always-on, RSB filling
Device-1: AMD Cezanne vendor: ASUSTeK driver: amdgpu v: kernel
bus-ID: 07:00.0 chip-ID: 1002:1638 class-ID: 0300
Display: server: X.Org 1.21.1.1 compositor: kwin_x11 driver:
loaded: amdgpu,ati unloaded: modesetting,radeon alternate: fbdev,vesa
display-ID: :1 screens: 1
Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1016x285mm (40.0x11.2")
s-diag: 1055mm (41.5")
Monitor-1: DisplayPort-1 res: 1920x1080 hz: 60 dpi: 82
size: 598x336mm (23.5x13.2") diag: 686mm (27")
Monitor-2: DisplayPort-2 res: 1920x1080 hz: 60 dpi: 82
OpenGL: renderer: AMD RENOIR (DRM 3.41.0 5.13.19-2-MANJARO LLVM 13.0.0)
v: 4.6 Mesa 21.2.5 direct render: Yes
Device-1: AMD vendor: ASUSTeK driver: snd_hda_intel v: kernel
bus-ID: 07:00.1 chip-ID: 1002:1637 class-ID: 0403
Device-2: AMD Family 17h HD Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel bus-ID: 07:00.6 chip-ID: 1022:15e3 class-ID: 0403
Sound Server-1: ALSA v: k5.13.19-2-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.40 running: yes
Device-1: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel bus-ID: 04:00.0
chip-ID: 8086:2723 class-ID: 0280
IF: wlp4s0 state: up mac: <filter>
Device-2: Intel Ethernet I225-V vendor: ASUSTeK driver: igc v: kernel
port: N/A bus-ID: 05:00.0 chip-ID: 8086:15f3 class-ID: 0200
IF: enp5s0 state: down mac: <filter>
Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 1-5:2
Local Storage: total: 465.76 GiB used: 12.45 GiB (2.7%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: SKC2500M8500G
size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 type: SSD serial: <filter> rev: S7780101 temp: 26.9 C scheme: GPT
ID-1: / raw-size: 457.47 GiB size: 457.47 GiB (100.00%)
used: 12.45 GiB (2.7%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
label: root uuid: 86d39de0-ed1a-4e6a-9552-faad7eadead8
used: 568 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: EFI
uuid: 73AB-35AA
ID-3: /home raw-size: 457.47 GiB size: 457.47 GiB (100.00%)
ID-4: /var/cache raw-size: 457.47 GiB size: 457.47 GiB (100.00%)
ID-5: /var/log raw-size: 457.47 GiB size: 457.47 GiB (100.00%)
ID-1: swap-1 type: partition size: 8 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p3 maj-min: 259:3 label: swap
uuid: ebb14d16-53be-404e-943f-f1cdcbf5f1bb
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 10 rev: 2.0
Device-1: 1-5:2 info: Intel AX200 Bluetooth type: Bluetooth driver: btusb
class-ID: e001
Device-2: 1-6:3 info: ASUSTek AURA LED Controller type: HID
driver: hid-generic,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 16mA
chip-ID: 0b05:18f3 class-ID: 0300 serial: <filter>
Hub-2: 1-7:4 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
Hub-3: 1-9:5 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
Hub-4: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-5: 3-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Hub-6: 4-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
Hub-7: 5-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Hub-8: 5-1:2 info: Texas Instruments ports: 6 rev: 2.1 speed: 480 Mb/s
chip-ID: 0451:8442 class-ID: 0900
Hub-9: 5-1.3:3 info: Microchip (formerly SMSC) Hub ports: 4 rev: 2.1
speed: 480 Mb/s chip-ID: 0424:2744 class-ID: 0900
Device-1: 5-1.3.3:5 info: Razer USA Ornata Chroma type: Keyboard,Mouse
driver: hid-generic,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s
power: 500mA chip-ID: 1532:021e class-ID: 0300
Device-2: 5-1.4:4 info: Logitech G502 SE HERO Gaming Mouse type: Mouse,HID
power: 300mA chip-ID: 046d:c08b class-ID: 0300 serial: <filter>
Device-3: 5-1.5:6 info: Texas Instruments type: HID
driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 480 Mb/s
chip-ID: 0451:82ff class-ID: 0300 serial: <filter>
Device-4: 5-1.6:7 info: Texas Instruments type: Billboard driver: N/A
interfaces: 1 rev: 2.0 speed: 480 Mb/s chip-ID: 0451:82ee class-ID: 1100
serial: <filter>
Hub-10: 6-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
Hub-11: 6-1:2 info: Texas Instruments ports: 2 rev: 3.1 speed: 5 Gb/s
chip-ID: 0451:8440 class-ID: 0900
Message: No sensor data found. Is lm-sensors configured?
Processes: 375 Uptime: 1h 5m wakeups: 0 Init: systemd v: 249 tool: systemctl
Compilers: gcc: N/A Packages: pacman: 1206 lib: 333 flatpak: 0 Shell: Zsh
v: 5.8 default: Bash v: 5.1.8 running-in: konsole inxi: 3.3.09
The motherboard has two display outputs one Display Port
and one HDMI
both monitors are connected to the single DP and via MST I have picture on both of them.
The problem
The PC starts booting normally I see the ROG splash screen and the prompt to get in the bios but once it comes the time to load the Log in screen everything goes black and both monitors start looking for signal.
What did I try
- Update the system using a workaround (see bellow)
- Disconnect and reconnect the monitors at the Login screen
- Use only one monitor (MST off)
Up to this point none of the above worked but the magic moment was:
- Connect monitor to HDMI
Now as soon as I connect to HDMI the display comes up and I can Login so I can afterwards connect back to the Display port at which point the desktop environment comes up and everything works perfectly even monitor extension via MST.
I also discovered a workaround so that I don’t need to change from DP to HDMI and back to DP. If I press CTRL + ALT + F2
to get to the tty2
the terminal appears over Display Port, I can Login and after running startx
the desktop loads normally but us a very tedious solution.
How can I setup sddm so that is defaults to the Display Port output instead of the HDMI?
PS
I apologize as I am relatively new Linux user and this is my first time installing Manjaro or any Arch distribution so I do not know what more information might be required. My Linux background is Ubuntu VMs so I never had to worry about drivers or hardware. So feel free to ask for anything that might be useful. Just tell me what to run .
