Hi guys
Recently I have installed hyprland in my environment. I occur a problem that sddm is loadded, but not showing the logging page after I boot into my manjaro linux. My computer is asus laptop so in my case it is that it will boot into a asus logo page, and I can blindly type my password, and then it will loggin into my hyprland desktop environment. I want to solve such problem and make loggin page show, as well as able to switch back to kde plasma not by wayland. (I can actually have access to my kde by running startplasma-wayland in hyprland env, but I want pure one)
anyone can help me?
output of inxi -Fayz:
β― inxi -Fazy
Kernel: 6.6.46-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=672b5c5b-d92a-4d7d-90e7-9b1b11661aaf rw quiet splash
udev.log_priority=3 nvidia_drm.modeset=1
Desktop: Hyprland v: 0.42.0 with: waybar tools: avail: swaylock vt: 1
dm: SDDM Distro: Manjaro base: Arch Linux
Type: Laptop System: ASUSTeK product: ASUS TUF Gaming F15 FX507VV_FX507VV
v: 1.0 serial: <superuser required>
Mobo: ASUSTeK model: FX507VV v: 1.0 serial: <superuser required>
uuid: <superuser required> UEFI: American Megatrends LLC. v: FX507VV.320
date: 07/05/2023
ID-1: BAT0 charge: 17.2 Wh (22.0%) condition: 78.1/90.0 Wh (86.8%)
power: 81.2 W volts: 16.1 min: 15.9 model: AS3GWYF3KC GA50358 type: Unknown
serial: <filter> status: charging
Info: model: 13th Gen Intel Core i9-13900H bits: 64 type: MST AMCP
arch: Raptor Lake gen: core 13 level: v3 note: check built: 2022+
process: Intel 7 (10nm) family: 6 model-id: 0xBA (186) stepping: 2
microcode: 0x4121
Topology: cpus: 1x cores: 14 mt: 6 tpc: 2 st: 8 threads: 20 smt: enabled
cache: L1: 1.2 MiB desc: d-8x32 KiB, 6x48 KiB; i-6x32 KiB, 8x64 KiB
L2: 11.5 MiB desc: 6x1.2 MiB, 2x2 MiB L3: 24 MiB desc: 1x24 MiB
Speed (MHz): avg: 516 high: 1046 min/max: 400/5200:5400:4100 scaling:
driver: intel_pstate governor: powersave cores: 1: 1013 2: 400 3: 400 4: 400
5: 1046 6: 1017 7: 400 8: 400 9: 400 10: 400 11: 400 12: 863 13: 400
14: 400 15: 400 16: 400 17: 400 18: 400 19: 400 20: 400 bogomips: 119840
Type: spectre_v2 mitigation: Enhanced / Automatic IBRS; IBPB: conditional;
RSB filling; PBRSB-eIBRS: SW sequence; BHI: BHI_DIS_S
Device-1: Intel Raptor Lake-P [Iris Xe Graphics] vendor: ASUSTeK driver: i915
v: kernel arch: Gen-13 process: Intel 7 (10nm) built: 2022+ ports:
active: eDP-2 empty: DP-2,DP-3 bus-ID: 0000:00:02.0 chip-ID: 8086:a7a0
class-ID: 0300
Device-2: NVIDIA AD107M [GeForce RTX 4060 Max-Q / Mobile] vendor: ASUSTeK
driver: nvidia v: 550.107.02 alternate: nouveau,nvidia_drm non-free: 550.xx+
status: current (as of 2024-06) arch: Lovelace code: AD1xx
process: TSMC n4 (5nm) built: 2022+ ports: active: none
empty: DP-1,HDMI-A-1,eDP-1 bus-ID: 0000:01:00.0 chip-ID: 10de:28e0
class-ID: 0300
Device-3: IMC Networks USB2.0 HD UVC WebCam driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-7:2 chip-ID: 13d3:56a2
Display: wayland server: X.org v: 1.21.1.13 with: Xwayland v: 24.1.2
compositor: Hyprland v: 0.42.0 driver: X: loaded: nvidia gpu: i915,nvidia
display-ID: 1
Monitor-1: eDP-2 res: 1600x900 size: N/A modes: N/A
drv: nvidia device: 2 drv: iris device: 3 drv: swrast gbm: drv: nvidia
surfaceless: drv: nvidia wayland: drv: iris x11: drv: iris
inactive: device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 550.107.02
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 4060 Laptop
GPU/PCIe/SSE2 memory: 7.81 GiB
API: Vulkan v: 1.3.279 layers: 2 device: 0 type: discrete-gpu name: NVIDIA
GeForce RTX 4060 Laptop GPU driver: nvidia v: 550.107.02
device-ID: 10de:28e0 surfaces: xcb,xlib,wayland device: 1
type: integrated-gpu name: Intel Graphics (RPL-P) driver: mesa intel
v: 24.1.6-arch1.1 device-ID: 8086:a7a0 surfaces: xcb,xlib,wayland
Device-1: Intel Raptor Lake-P/U/H cAVS vendor: ASUSTeK driver: snd_hda_intel
v: kernel alternate: snd_sof_pci_intel_tgl bus-ID: 0000:00:1f.3
chip-ID: 8086:51ca class-ID: 0403
Device-2: NVIDIA vendor: ASUSTeK driver: snd_hda_intel v: kernel
bus-ID: 0000:01:00.1 chip-ID: 10de:22be class-ID: 0403
API: ALSA v: k6.6.46-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.2.2 status: active with: 1: pipewire-pulse
4: pw-jack type: plugin tools: pactl,pw-cat,pw-cli,wpctl
Device-1: Intel Raptor Lake PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 0000:00:14.3 chip-ID: 8086:51f1 class-ID: 0280
vendor: ASUSTeK driver: r8169 v: kernel port: 3000 bus-ID: 0000:37:00.0
IF: enp55s0 state: down mac: <filter>
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-10:3 chip-ID: 8087:0026
class-ID: e001
Report: btmgmt ID: hci0 rfk-id: 0 state: down bt-service: enabled,running
rfk-block: hardware: no software: no address: <filter> bt-v: 5.2 lmp-v: 11
status: discoverable: no pairing: no
Hardware-1: Intel Volume Management Device NVMe RAID Controller Intel
driver: vmd v: 0.6 port: N/A bus-ID: 0000:00:0e.0 chip-ID: 8086:a77f rev:
class-ID: 0104
Local Storage: total: 953.87 GiB used: 88.12 GiB (9.2%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: WD PC
SN560 SDDPNQE-1T00-1002 size: 953.87 GiB block-size: physical: 512 B
fw-rev: 74104000 temp: 48.9 C scheme: GPT
ID-1: / raw-size: 156.25 GiB size: 152.73 GiB (97.75%)
used: 88.06 GiB (57.7%) fs: ext4 dev: /dev/nvme0n1p9 maj-min: 259:9
ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%)
used: 64.5 MiB (25.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
System Temperatures: cpu: 48.0 C mobo: N/A
Fan Speeds (rpm): cpu: 0
Memory: total: 16 GiB available: 15.25 GiB used: 3.83 GiB (25.1%)
Processes: 368 Power: uptime: 25m states: freeze,mem,disk suspend: s2idle
avail: deep wakeups: 0 hibernate: platform avail: shutdown, reboot, suspend,
test_resume image: 6.05 GiB services: power-profiles-daemon,upowerd
Init: systemd v: 256 default: graphical tool: systemctl
Packages: 2222 pm: pacman pkgs: 2210 libs: 417 tools: pamac,yay pm: flatpak
pkgs: 12 Compilers: clang: 18.1.8 gcc: 14.2.1 Shell: Zsh v: 5.9
running-in: kitty inxi: 3.3.35
output of systemctl status sddm.service
β― systemctl status sddm.service
β sddm.service - Simple Desktop Display Manager
Loaded: loaded (/usr/lib/systemd/system/sddm.service; enabled; preset: disabled)
Active: active (running) since Fri 2024-08-23 16:51:04 CST; 28min ago
Invocation: dbb15d6c62ff4b8ea5989557cd495300
Docs: man:sddm(1)
man:sddm.conf(5)
Main PID: 775 (sddm)
Tasks: 4 (limit: 18600)
Memory: 104.8M (peak: 116M)
CPU: 378ms
CGroup: /system.slice/sddm.service
ββ775 /usr/bin/sddm
ββ778 /usr/lib/Xorg -nolisten tcp -background none -seat seat0 vt2 -auth /run/sddm/xauth_GydcsM -noreset -displayfd 16
Aug 23 16:51:08 TryHard sddm-helper[831]: [PAM] returning.
Aug 23 16:51:08 TryHard sddm[775]: Authentication for user "jonathan" successful
Aug 23 16:51:08 TryHard sddm-helper[831]: pam_kwallet5(sddm:setcred): pam_kwallet5: pam_sm_setcred
Aug 23 16:51:08 TryHard sddm-helper[831]: pam_unix(sddm:session): session opened for user jonathan(uid=1000) by jonathan(uid=0)
Aug 23 16:51:08 TryHard sddm-helper[831]: pam_systemd(sddm:session): New sd-bus connection (system-bus-pam-systemd-831) opened.
Aug 23 16:51:08 TryHard sddm[775]: Auth: sddm-helper exited successfully
Aug 23 16:51:08 TryHard sddm[775]: Greeter stopped. SDDM::Auth::HELPER_SUCCESS
Aug 23 16:51:08 TryHard sddm-helper[831]: pam_kwallet5(sddm:session): pam_kwallet5: pam_sm_open_session
Aug 23 16:51:08 TryHard sddm-helper[831]: Starting Wayland user session: "/usr/share/sddm/scripts/wayland-session" "Hyprland"
Aug 23 16:51:09 TryHard sddm[775]: Session started true
Some more output:
β― systemctl status default.target
β graphical.target - Graphical Interface
Loaded: loaded (/usr/lib/systemd/system/graphical.target; static)
Active: active since Fri 2024-08-23 16:51:04 CST; 45min ago
Invocation: 9b59e436112744f585dd276660ad97f7
Docs: man:systemd.special(7)
Aug 23 16:51:04 TryHard systemd[1]: Reached target Graphical Interface.
β― cat /proc/cmdline
BOOT_IMAGE=/boot/vmlinuz-6.6-x86_64 root=UUID=672b5c5b-d92a-4d7d-90e7-9b1b11661aaf rw quiet splash udev.log_priority=3 nvidia_drm.modeset=1
β― journalctl -b 0 | grep sddm
8ζ 23 16:51:04 TryHard sddm[775]: Initializing...
8ζ 23 16:51:04 TryHard sddm[775]: Starting...
8ζ 23 16:51:04 TryHard sddm[775]: Logind interface found
8ζ 23 16:51:04 TryHard sddm[775]: Adding new display...
8ζ 23 16:51:04 TryHard sddm[775]: Loaded empty theme configuration
8ζ 23 16:51:04 TryHard sddm[775]: Xauthority path: "/run/sddm/xauth_GydcsM"
8ζ 23 16:51:04 TryHard sddm[775]: Using VT 2
8ζ 23 16:51:04 TryHard sddm[775]: Display server starting...
8ζ 23 16:51:04 TryHard sddm[775]: Writing cookie to "/run/sddm/xauth_GydcsM"
8ζ 23 16:51:04 TryHard sddm[775]: Running: /usr/bin/X -nolisten tcp -background none -seat seat0 vt2 -auth /run/sddm/xauth_GydcsM -noreset -displayfd 16
8ζ 23 16:51:05 TryHard sddm[775]: Setting default cursor
8ζ 23 16:51:05 TryHard sddm[775]: Running display setup script "/usr/share/sddm/scripts/Xsetup"
8ζ 23 16:51:05 TryHard sddm[775]: Display server started.
8ζ 23 16:51:05 TryHard sddm[775]: Socket server starting...
8ζ 23 16:51:05 TryHard sddm[775]: Socket server started.
8ζ 23 16:51:05 TryHard sddm[775]: Loading theme configuration from "/usr/share/sddm/themes/Candy/theme.conf"
8ζ 23 16:51:05 TryHard sddm[775]: Greeter starting...
8ζ 23 16:51:05 TryHard sddm-helper[787]: [PAM] Starting...
8ζ 23 16:51:05 TryHard sddm-helper[787]: [PAM] Authenticating...
8ζ 23 16:51:05 TryHard sddm-helper[787]: [PAM] returning.
8ζ 23 16:51:05 TryHard sddm-helper[787]: pam_unix(sddm-greeter:session): session opened for user sddm(uid=959) by (uid=0)
8ζ 23 16:51:05 TryHard sddm-helper[787]: pam_systemd(sddm-greeter:session): New sd-bus connection (system-bus-pam-systemd-787) opened.
8ζ 23 16:51:05 TryHard systemd-logind[686]: New session c1 of user sddm.
8ζ 23 16:51:05 TryHard (systemd)[793]: pam_warn(systemd-user:setcred): function=[pam_sm_setcred] flags=0x8002 service=[systemd-user] terminal=[] user=[sddm] ruser=[<unknown>] rhost=[<unknown>]
8ζ 23 16:51:05 TryHard (systemd)[793]: pam_unix(systemd-user:session): session opened for user sddm(uid=959) by sddm(uid=0)
8ζ 23 16:51:05 TryHard systemd-logind[686]: New session 1 of user sddm.
8ζ 23 16:51:06 TryHard systemd[793]: Cleanup lingering KCrash metadata was skipped because of an unmet condition check (ConditionPathExistsGlob=/var/lib/sddm/.cache/kcrash-metadata/*.ini).
8ζ 23 16:51:06 TryHard systemd[793]: Submitting pending crash events was skipped because of an unmet condition check (ConditionPathExistsGlob=/var/lib/sddm/.cache/drkonqi/sentry-envelopes/*).
8ζ 23 16:51:06 TryHard systemd[1]: Started Session c1 of User sddm.
8ζ 23 16:51:06 TryHard sddm-helper[787]: Writing cookie to "/tmp/xauth_tfNoVX"
8ζ 23 16:51:06 TryHard sddm-helper[787]: Starting X11 session: "" "/usr/bin/sddm-greeter --socket /tmp/sddm-:0-YBYIXL --theme /usr/share/sddm/themes/Candy"
8ζ 23 16:51:06 TryHard sddm[775]: Greeter session started successfully
8ζ 23 16:51:06 TryHard sddm-greeter[807]: High-DPI autoscaling not Enabled
8ζ 23 16:51:06 TryHard sddm-greeter[807]: Reading from "/usr/share/wayland-sessions/hyprland.desktop"
8ζ 23 16:51:06 TryHard sddm-greeter[807]: Reading from "/usr/share/wayland-sessions/plasmawayland.desktop"
8ζ 23 16:51:06 TryHard sddm-greeter[807]: Reading from "/usr/share/xsessions/hyprland.desktop"
8ζ 23 16:51:06 TryHard sddm-greeter[807]: Reading from "/usr/share/xsessions/plasma.desktop"
8ζ 23 16:51:06 TryHard sddm-greeter[807]: Loading theme configuration from "/usr/share/sddm/themes/Candy/theme.conf"
8ζ 23 16:51:06 TryHard sddm-greeter[807]: Connected to the daemon.
8ζ 23 16:51:06 TryHard sddm[775]: Message received from greeter: Connect
8ζ 23 16:51:06 TryHard sddm-greeter[807]: Loading file:///usr/share/sddm/themes/Candy/Main.qml...
8ζ 23 16:51:06 TryHard sddm-greeter[807]: file:///usr/share/sddm/themes/Candy/Components/VirtualKeyboard.qml:28:1: Type InputPanel unavailable
8ζ 23 16:51:06 TryHard sddm-greeter[807]: qrc:/QtQuick/VirtualKeyboard/content/InputPanel.qml:138:5: Type Keyboard unavailable
8ζ 23 16:51:06 TryHard sddm-greeter[807]: qrc:/QtQuick/VirtualKeyboard/content/components/Keyboard.qml:38:1: module "QtQuick.VirtualKeyboard.Plugins" is not installed
8ζ 23 16:51:06 TryHard sddm-greeter[807]: file:///usr/share/sddm/themes/Candy/Components/Input.qml:561:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
8ζ 23 16:51:06 TryHard sddm-greeter[807]: file:///usr/share/sddm/themes/Candy/Components/SystemButtons.qml:70:13: Unable to assign [undefined] to QQuickItem*
8ζ 23 16:51:06 TryHard sddm-greeter[807]: file:///usr/share/sddm/themes/Candy/Components/SessionButton.qml:38:5: Unable to assign ComboBox_QMLTYPE_6 to Control_QMLTYPE_3
8ζ 23 16:51:06 TryHard sddm-greeter[807]: Adding view for ":0.0" QRect(0,0 640x480)
8ζ 23 16:51:06 TryHard sddm-greeter[807]: Message received from daemon: Capabilities
8ζ 23 16:51:06 TryHard sddm-greeter[807]: Message received from daemon: HostName
8ζ 23 16:51:08 TryHard sddm-greeter[807]: Reading from "/usr/share/wayland-sessions/hyprland.desktop"
8ζ 23 16:51:08 TryHard sddm[775]: Message received from greeter: Login
8ζ 23 16:51:08 TryHard sddm[775]: Reading from "/usr/share/wayland-sessions/hyprland.desktop"
8ζ 23 16:51:08 TryHard sddm[775]: Session "/usr/share/wayland-sessions/hyprland.desktop" selected, command: "Hyprland" for VT 1
8ζ 23 16:51:08 TryHard sddm-helper[831]: [PAM] Starting...
8ζ 23 16:51:08 TryHard sddm-helper[831]: [PAM] Authenticating...
8ζ 23 16:51:08 TryHard sddm-helper[831]: pam_systemd_home(sddm:auth): New sd-bus connection (system-bus-pam-systemd-home-831) opened.
8ζ 23 16:51:08 TryHard sddm-helper[831]: [PAM] Preparing to converse...
8ζ 23 16:51:08 TryHard sddm-helper[831]: [PAM] Conversation with 1 messages
8ζ 23 16:51:08 TryHard sddm-helper[831]: pam_kwallet5(sddm:auth): pam_kwallet5: pam_sm_authenticate
8ζ 23 16:51:08 TryHard sddm-helper[831]: [PAM] returning.
8ζ 23 16:51:08 TryHard sddm[775]: Authentication for user "jonathan" successful
8ζ 23 16:51:08 TryHard sddm-greeter[807]: Message received from daemon: LoginSucceeded
8ζ 23 16:51:08 TryHard sddm-helper[831]: pam_kwallet5(sddm:setcred): pam_kwallet5: pam_sm_setcred
8ζ 23 16:51:08 TryHard sddm-helper[831]: pam_unix(sddm:session): session opened for user jonathan(uid=1000) by jonathan(uid=0)
8ζ 23 16:51:08 TryHard sddm-helper[831]: pam_systemd(sddm:session): New sd-bus connection (system-bus-pam-systemd-831) opened.
8ζ 23 16:51:08 TryHard sddm-helper[787]: [PAM] Closing session
8ζ 23 16:51:08 TryHard sddm-helper[787]: pam_unix(sddm-greeter:session): session closed for user sddm
8ζ 23 16:51:08 TryHard sddm-helper[787]: pam_systemd(sddm-greeter:session): New sd-bus connection (system-bus-pam-systemd-787) opened.
8ζ 23 16:51:08 TryHard sddm-helper[787]: [PAM] Ended.
8ζ 23 16:51:08 TryHard sddm[775]: Auth: sddm-helper exited successfully
8ζ 23 16:51:08 TryHard sddm[775]: Greeter stopped. SDDM::Auth::HELPER_SUCCESS
8ζ 23 16:51:08 TryHard sddm-helper[831]: pam_kwallet5(sddm:session): pam_kwallet5: pam_sm_open_session
8ζ 23 16:51:08 TryHard sddm-helper[854]: pam_kwallet5: final socket path: /run/user/1000/kwallet5.socket
8ζ 23 16:51:08 TryHard sddm-helper[831]: Starting Wayland user session: "/usr/share/sddm/scripts/wayland-session" "Hyprland"
8ζ 23 16:51:08 TryHard sddm-helper[856]: Jumping to VT 1
8ζ 23 16:51:08 TryHard sddm-helper[856]: VT mode didn't need to be fixed
8ζ 23 16:51:09 TryHard sddm[775]: Session started true
8ζ 23 16:51:18 TryHard (sd-pam)[795]: pam_unix(systemd-user:session): session closed for user sddm
As Nvidia user you will have to wait until plasma 6.1 arrives at stable branch before experimenting with hyprland.
Or if you are hypr and cannot wait - switch to unstable branch - one member report, the newly arrived Nvidia 560 driver provides a better experience.
See β Switching Branches - Manjaro for more info
how is it relate to stable or unstable branch? I thought it may some configuration problem and can be forced?
I tried some changes on the configuration files of sddm, no changes
, maybe I can directly use AUTOLOGIN to avoid such things?
maybe
maybe not
why would or should that make a difference?
if there is a problem - it canβt be forced
because:
there is a problem β¦ it will remain a problem
whether you are βforcing itβ or not ![]()
The (perhaps uncomfortable) truth is:
you have no idea what you ended up with after having run that script.
Nor do you seem to have an idea about what a βnormalβ system would look like
to compare the current state to.
There is no official Hyprland support for Nvidia hardware.
If you need more info check the wiki, first:
Have checked that, all nvidia stuff properly set up.
just little uncomfortable stuff
I just leave it. It wonβt affect too much on my daily usage.
yeah, but we have a demo⦠Have to be careful in the future, leaving timeshift from time to time.
