SDDM doesn't start when switching to nvidia mode in optimus-manager
When I try switching to the nvidia mode (sudo optimus-manager --switch nvidia), SDDM doesn’t start anymore, it stays in a black screen with flashing cursor. I still can log in from another tty and switch back to integrated graphics then restart SDDM from there
System info
GT 750M
Optimus Manager (Client) version 1.4
Kernel  5.4.159-1-MANJARO
Nvidia driver linux54-nvidia-418xx
Optimus Manager configuration
[amd]
DRI=3
driver=modesetting
tearfree=
[intel]
DRI=3
accel=
driver=modesetting
modeset=yes
tearfree=
[nvidia]
DPI=96
PAT=yes
allow_external_gpus=no
dynamic_power_management=no
dynamic_power_management_memory_threshold=
ignore_abi=no
modeset=no
options=overclocking
[optimus]
auto_logout=yes
pci_power_control=no
pci_remove=no
pci_reset=function_level
startup_auto_battery_mode=integrated
startup_auto_extpower_mode=nvidia
startup_mode=integrated
switching=bbswitch
`systemctl status sddm.service`
● sddm.service - Simple Desktop Display Manager
     Loaded: loaded (/usr/lib/systemd/system/sddm.service; enabled; vendor preset: disabled)
     Active: active (running) since Tue 2022-01-04 19:54:02 -03; 9s ago
       Docs: man:sddm(1)
             man:sddm.conf(5)
   Main PID: 6008 (sddm)
      Tasks: 2 (limit: 9415)
     Memory: 3.1M
        CPU: 126ms
     CGroup: /system.slice/sddm.service
             └─6008 /usr/bin/sddm
jan 04 19:54:05 inspiron-14r sddm[6008]: Failed to read display number from pipe
jan 04 19:54:05 inspiron-14r sddm[6008]: Display server stopping...
jan 04 19:54:05 inspiron-14r sddm[6008]: Attempt 2 starting the Display server on vt 1 failed
jan 04 19:54:07 inspiron-14r sddm[6008]: Display server starting...
jan 04 19:54:07 inspiron-14r sddm[6008]: Adding cookie to "/var/run/sddm/{a79b6a0c-4f60-4562-acad-061ae7a15e76}"
jan 04 19:54:07 inspiron-14r sddm[6008]: Running: /usr/bin/X -nolisten tcp -background none -seat seat0 vt1 -auth /var/run/sddm/{a79b6a0c-4f60-4562-acad-061ae7a15e76} -noreset -displayfd 17
jan 04 19:54:07 inspiron-14r sddm[6008]: Failed to read display number from pipe
jan 04 19:54:07 inspiron-14r sddm[6008]: Display server stopping...
jan 04 19:54:07 inspiron-14r sddm[6008]: Attempt 3 starting the Display server on vt 1 failed
jan 04 19:54:07 inspiron-14r sddm[6008]: Could not start Display server on vt 1
xorg log
[   425.050] (--) Log file renamed from "/var/log/Xorg.pid-6083.log" to "/var/log/Xorg.0.log"
[   425.050]
This is a pre-release version of the X server from The X.Org Foundation.
It is not supported in any way.
Bugs may be filed in the bugzilla at http://bugs.freedesktop.org/.
Select the "xorg" product for bugs you find in this release.
Before reporting bugs in pre-release versions please check the
latest version in the X.Org Foundation git repository.
See http://wiki.x.org/wiki/GitPage for git access instructions.
[   425.050]
X.Org X Server 1.21.1.1
[   425.050] Current Operating System: Linux inspiron-14r 5.4.159-1-MANJARO #1 SMP PREEMPT Fri Nov 12 20:25:49 UTC 2021 x86_64
[   425.050] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.4-x86_64 root=UUID=6ca29c61-e5de-4a22-8751-e34ee0eb6300 rw quiet apparmor=1 security=apparmor udev.log_priority=3
[   425.050]
[   425.050] Current version of pixman: 0.40.0
[   425.050] 	Before reporting problems, check http://wiki.x.org
[   425.050] Markers: (--) probed, (**) from config file, (==) default setting,
[   425.050] (==) Log file: "/var/log/Xorg.0.log", Time: Tue Jan  4 19:54:07 2022
[   425.050] (==) Using config directory: "/etc/X11/xorg.conf.d"
[   425.050] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[   425.051] (==) ServerLayout "layout"
[   425.051] (**) |-->Screen "nvidia" (0)
[   425.051] (**) |   |-->Monitor ""
[   425.051] (**) |   |-->Device "nvidia"
[   425.051] (**) |   |-->GPUDevice "integrated"
[   425.051] (==) No monitor specified for screen "nvidia".
[   425.051] (**) |-->Inactive Device "integrated"
[   425.051] (==) Automatically adding devices
[   425.051] (==) Automatically enabling devices
[   425.051] (==) Automatically adding GPU devices
[   425.051] (==) Automatically binding GPU devices
[   425.051] (==) Max clients allowed: 256, resource mask: 0x1fffff
[   425.051] (WW) The directory "/usr/share/fonts/OTF" does not exist.
[   425.051] 	Entry deleted from font path.
[   425.051] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[   425.051] (WW) The directory "/usr/share/fonts/100dpi" does not exist.
[   425.051] (WW) The directory "/usr/share/fonts/75dpi" does not exist.
[   425.051] (==) FontPath set to:
	/usr/share/fonts/misc,
	/usr/share/fonts/TTF
[   425.051] (**) ModulePath set to "/usr/lib/nvidia,/usr/lib32/nvidia,/usr/lib32/nvidia/xorg/modules,/usr/lib32/xorg/modules,/usr/lib64/nvidia/xorg/modules,/usr/lib64/nvidia/xorg,/usr/lib64/xorg/modules"
[   425.051] (II) The server relies on udev to provide the list of input devices.
[   425.051] (II) Module ABI versions:
[   425.051] 	X.Org ANSI C Emulation: 0.4
[   425.051] 	X.Org Video Driver: 25.2
[   425.051] 	X.Org XInput driver : 24.4
[   425.051] 	X.Org Server Extension : 10.0
[   425.052] (++) using VT number 1
[   425.052] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[   425.052] (II) xfree86: Adding drm device (/dev/dri/card0)
[   425.052] (II) Platform probe for /sys/devices/pci0000:00/0000:00:02.0/drm/card0
[   425.068] (II) xfree86: Adding drm device (/dev/dri/card1)
[   425.068] (II) Platform probe for /sys/devices/pci0000:00/0000:00:1c.4/0000:08:00.0/drm/card1
[   425.070] () OutputClass "nvidia" ModulePath extended to "/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/nvidia,/usr/lib32/nvidia,/usr/lib32/nvidia/xorg/modules,/usr/lib32/xorg/modules,/usr/lib64/nvidia/xorg/modules,/usr/lib64/nvidia/xorg,/usr/lib64/xorg/modules"
[   425.070] () OutputClass "nvidia" setting /dev/dri/card1 as PrimaryGPU
[   425.070] (--) PCI: (0@0:2:0) 8086:0a16:1028:05f6 rev 9, Mem @ 0xf7400000/4194304, 0xd0000000/268435456, I/O @ 0x0000f000/64, BIOS @ 0x????????/131072
[   425.070] (--) PCI:*(8@0:0:0) 10de:0fe4:1028:05f6 rev 161, Mem @ 0xf6000000/16777216, 0xe0000000/268435456, 0xf0000000/33554432, I/O @ 0x0000d000/128, BIOS @ 0x????????/524288
[   425.071] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[   425.071] (II) LoadModule: "glx"
[   425.071] (II) Loading /usr/lib/nvidia/xorg/libglx.so
[   425.077] (II) Module glx: vendor="NVIDIA Corporation"
[   425.077] 	compiled for 4.0.2, module version = 1.0.0
[   425.077] 	Module class: X.Org Server Extension
[   425.077] (II) NVIDIA GLX Module  418.113  Sun Oct 27 00:12:38 UTC 2019
[   425.077] (II) LoadModule: "nvidia"
[   425.077] (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
[   425.077] (II) Module nvidia: vendor="NVIDIA Corporation"
[   425.077] 	Module class: X.Org Video Driver
[   425.077] ================ WARNING WARNING WARNING WARNING ================
[   425.077] This server has a video driver ABI version of 25.2 that is not
supported by this NVIDIA driver.  Please check
http://www.nvidia.com/ for driver updates or downgrade to an X
server with a supported driver ABI.
[   425.077] =================================================================
[   425.077] (EE) NVIDIA: Use the -ignoreABI option to override this check.
[   425.077] (II) UnloadModule: "nvidia"
[   425.077] (II) Unloading nvidia
[   425.078] (EE) Failed to load module "nvidia" (unknown error, 0)
[   425.078] (II) LoadModule: "modesetting"
[   425.078] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[   425.078] (II) Module modesetting: vendor="X.Org Foundation"
[   425.078] 	compiled for 1.21.1.1, module version = 1.21.1
[   425.078] 	Module class: X.Org Video Driver
[   425.078] 	ABI class: X.Org Video Driver, version 25.2
[   425.078] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[   425.112] (II) modeset(G0): using drv /dev/dri/card0
[   425.112] (WW) Falling back to old probe method for modesetting
[   425.128] (II) modeset(G1): using drv /dev/dri/card1
[   425.128] (EE) No devices detected.
[   425.128] (EE)
Fatal server error:
[   425.128] (EE) no screens found(EE)
[   425.128] (EE)
Please consult the The X.Org Foundation support
at http://wiki.x.org
for help.
[   425.128] (EE) Please also check the log file at "/var/log/Xorg.0.log" for additional information.
[   425.128] (EE)
[   425.199] (EE) Server terminated with error (1). Closing log file.
Switch logs
Switching to Nvidia
[10] INFO: # Xorg pre-start hook
[10] INFO: Previous state was: {'type': 'pending_pre_xorg_start', 'requested_mode': 'nvidia', 'current_mode': 'integrated'}
[10] INFO: Requested mode is: nvidia
[768] INFO: Available modules: ['nouveau', 'bbswitch', 'acpi_call', 'nvidia', 'nvidia_drm', 'nvidia_modeset', 'nvidia_uvm']
[768] INFO: Unloading modules ['nouveau'] (if loaded)
[771] INFO: Loading module bbswitch
[775] INFO: Setting GPU power to ON via bbswitch
[1251] INFO: Resetting Nvidia PCI device
[1252] INFO: Unloading modules ['bbswitch'] (if loaded)
[1319] INFO: Performing function-level reset of Nvidia
[1338] INFO: Writing "1" to /sys/bus/pci/devices/0000:08:00.0/reset
[1819] ERROR: Nvidia PCI reset failed. Continuing anyways. Error is: Failed to perform PCI reset: Error writing to /sys/bus/pci/devices/0000:08:00.0/reset: [Errno 25] Inappropriate ioctl for device
[1843] INFO: Loading module nvidia
[2577] INFO: Loading module nvidia_drm
[3265] INFO: Writing to /etc/X11/xorg.conf.d/10-optimus-manager.conf
[3266] INFO: Writing state {'type': 'pending_post_xorg_start', 'switch_id': '20220104T195216', 'requested_mode': 'nvidia'}
[3266] INFO: Xorg pre-start hook completed successfully.
Switching to integrated
[10] INFO: Previous state was: {'type': 'pending_pre_xorg_start', 'requested_mode': 'integrated', 'current_mode': None}
[10] INFO: Requested mode is: integrated
[775] INFO: Available modules: ['nouveau', 'bbswitch', 'acpi_call', 'nvidia', 'nvidia_drm', 'nvidia_modeset', 'nvidia_uvm']
[775] INFO: Unloading modules ['nvidia_drm', 'nvidia_modeset', 'nvidia_uvm', 'nvidia'] (if loaded)
[911] INFO: Loading module bbswitch
[953] INFO: Setting GPU power to OFF via bbswitch
[978] INFO: Writing to /etc/X11/xorg.conf.d/10-optimus-manager.conf
[978] INFO: Writing state {'type': 'pending_post_xorg_start', 'switch_id': '20220104T195656', 'requested_mode': 'integrated'}
[979] INFO: Xorg pre-start hook completed successfully.
[9] INFO: # Xorg post-start hook
[22] INFO: Running /etc/optimus-manager/xsetup-integrated.sh
[30] INFO: Writing state {'type': 'done', 'switch_id': '20220104T195656', 'current_mode': 'integrated'}
[31] INFO: Xorg post-start hook completed successfully.
lspci
08:00.0 3D controller: NVIDIA Corporation GK107M [GeForce GT 750M] (rev ff)
08:00.1 Audio device: NVIDIA Corporation GK107 HDMI Audio Controller (rev ff)
when in nvidia mode, running lsmod | grep nvidia from the tty will show that the nvidia drivers (nvidia, nvidia-drm, nvidia-modeset) are running
You might want to make some changes to sddm’s configuration:
Already don’t have these lines
sddm.conf
[General]
InputMethod=
Numlock=none
[Theme]
CursorTheme=breeze_cursors
DisableAvatarsThreshold=7
EnableAvatars=true
FacesDir=/usr/share/sddm/faces
ThemeDir=/usr/share/sddm/themes
[Users]
DefaultPath=/usr/local/sbin:/usr/local/bin:/usr/bin
HideShells=
HideUsers=
RememberLastSession=true
RememberLastUser=true
ReuseSession=false
[Wayland]
EnableHiDPI=false
SessionCommand=/usr/share/sddm/scripts/wayland-session
SessionDir=/usr/share/wayland-sessions
SessionLogFile=.local/share/sddm/wayland-session.log
[X11]
EnableHiDPI=false
MinimumVT=1
ServerArguments=-nolisten tcp
ServerPath=/usr/bin/X
SessionCommand=/usr/share/sddm/scripts/Xsession
SessionDir=/usr/share/xsessions
SessionLogFile=.local/share/sddm/xorg-session.log
UserAuthFile=.Xauthority
XauthPath=/usr/bin/xauth
XephyrPath=/usr/bin/Xephyr
I’m not an expert at all but where did you get the nvidia drivers from ? Think its only 390 470 and 490 in the repos
Following the “[Support/How-To] Compile old/legacy Nvidia Proprietary Drivers [2020-12-30 Update Issue]” post in the forum. The 470+ drivers are too new for my graphics card, and the 390 has an issue running Vulkan programs (it puts the CPU usage to 100% and locks up the system)
That’s good, wanted to make sure you hadn’t downloaded from nvidia. Did/do the drivers work without optimus manager ? I know there was an issue with optimus manager and the latest update, there’s a thread on it
Outside of OM’s inherent hackiness and such … There isnt really … its just that someone added it to the repos a while back, and recently it was removed again. Its still in the AUR, but some folks complained.
But … only a handful … I think it had the overall effect of helping most folks running OM that they dont actually need to.
some update?
So I noticed that
in the xorg log, and tried adding the section
Section "ServerFlags"
  Option "IgnoreABI" "true"
EndSection
to the xorg config
It still doesn’t work, but it makes xorg ‘advance’ more in the initialization, the new log being
Xorg.0.log
[   130.472] (--) Log file renamed from "/var/log/Xorg.pid-2294.log" to "/var/log/Xorg.0.log"
[   130.472]
X.Org X Server 1.21.1.2
[   130.472] Current Operating System: Linux inspiron-14r 5.4.169-1-MANJARO #1 SMP PREEMPT Wed Dec 29 18:08:59 UTC 2021 x86_64
[   130.473] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.4-x86_64 root=UUID=6ca29c61-e5de-4a22-8751-e34ee0eb6300 rw quiet apparmor=1 security=apparmor udev.log_priority=3 nvidia-drm.modeset=1
[   130.473]
[   130.473] Current version of pixman: 0.40.0
[   130.473] 	Before reporting problems, check http://wiki.x.org
[   130.473] Markers: (--) probed, (**) from config file, (==) default setting,
[   130.473] (==) Log file: "/var/log/Xorg.0.log", Time: Sun Feb  6 10:08:25 2022
[   130.473] (==) Using config directory: "/etc/X11/xorg.conf.d"
[   130.473] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[   130.473] (==) ServerLayout "layout"
[   130.473] (**) |-->Screen "nvidia" (0)
[   130.473] (**) |   |-->Monitor ""
[   130.473] (**) |   |-->Device "nvidia"
[   130.473] (**) |   |-->GPUDevice "intel"
[   130.473] (==) No monitor specified for screen "nvidia".
[   130.473] (**) |-->Inactive Device "intel"
[   130.473] (**) Option "IgnoreABI" "true"
[   130.473] (**) Ignoring ABI Version
[   130.473] (==) Automatically adding devices
[   130.473] (==) Automatically enabling devices
[   130.473] (==) Automatically adding GPU devices
[   130.473] (==) Automatically binding GPU devices
[   130.473] (==) Max clients allowed: 256, resource mask: 0x1fffff
[   130.473] (WW) The directory "/usr/share/fonts/OTF" does not exist.
[   130.473] 	Entry deleted from font path.
[   130.473] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[   130.473] (WW) The directory "/usr/share/fonts/100dpi" does not exist.
[   130.473] (WW) The directory "/usr/share/fonts/75dpi" does not exist.
[   130.473] (==) FontPath set to:
[   130.473] (==) ModulePath set to "/usr/lib/xorg/modules"
[   130.473] (II) The server relies on udev to provide the list of input devices.
[   130.473] (II) Module ABI versions:
[   130.473] 	X.Org ANSI C Emulation: 0.4
[   130.473] 	X.Org Video Driver: 25.2
[   130.473] 	X.Org XInput driver : 24.4
[   130.473] 	X.Org Server Extension : 10.0
[   130.474] (++) using VT number 1
[ 130.474] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[ 130.475] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 130.475] (II) Platform probe for /sys/devices/pci0000:00/0000:00:02.0/drm/card0
[ 130.487] (–) PCI:*(0@0:2:0) 8086:0a16:1028:05f6 rev 9, Mem @ 0xf7400000/4194304, 0xd0000000/268435456, I/O @ 0x0000f000/64, BIOS @ 0x???/131072
[ 130.487] (–) PCI: (8@0:0:0) 10de:0fe4:1028:05f6 rev 161, Mem @ 0xf6000000/16777216, 0xe0000000/268435456, 0xf0000000/33554432, I/O @ 0x0000d000/128, BIOS @ 0x???/524288
[ 130.487] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[ 130.487] (II) LoadModule: “glx”
[ 130.487] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 130.488] (II) Module glx: vendor=“X.Org Foundation”
[ 130.488] compiled for 1.21.1.2, module version = 1.0.0
[ 130.488] ABI class: X.Org Server Extension, version 10.0
[ 130.488] (II) LoadModule: “nvidia”
[ 130.488] (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
[ 130.488] (II) Module nvidia: vendor=“NVIDIA Corporation”
[ 130.488] compiled for 4.0.2, module version = 1.0.0
[ 130.488] Module class: X.Org Video Driver
[ 130.488] ================ WARNING WARNING WARNING WARNING ================
[ 130.489] This server has a video driver ABI version of 25.2 that is not
[ 130.489] =================================================================
[ 130.489] (WW) NVIDIA: The driver will continue to load, but may behave strangely.
[ 130.489] (II) LoadModule: “modesetting”
[ 130.489] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[ 130.492] (II) Module modesetting: vendor=“X.Org Foundation”
[ 130.492] compiled for 1.21.1.2, module version = 1.21.1
[ 130.492] Module class: X.Org Video Driver
[ 130.492] ABI class: X.Org Video Driver, version 25.2
[ 130.492] (II) NVIDIA dlloader X Driver 418.113 Sun Oct 27 00:12:58 UTC 2019
[ 130.492] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[ 130.492] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[ 130.504] (II) Loading sub module “fb”
[ 130.504] (II) LoadModule: “fb”
[ 130.504] (II) Module “fb” already built-in
[ 130.504] (II) Loading sub module “wfb”
[ 130.504] (II) LoadModule: “wfb”
[ 130.504] (II) Loading /usr/lib/xorg/modules/libwfb.so
[ 130.504] (II) Module wfb: vendor=“X.Org Foundation”
[ 130.504] compiled for 1.21.1.2, module version = 1.0.0
[ 130.504] ABI class: X.Org ANSI C Emulation, version 0.4
[ 130.504] (II) Loading sub module “ramdac”
[ 130.504] (II) LoadModule: “ramdac”
[ 130.504] (II) Module “ramdac” already built-in
[ 130.517] (II) modeset(G0): using drv /dev/dri/card0
[ 130.517] (II) UnloadModule: “nvidia”
[ 130.517] (II) UnloadSubModule: “wfb”
[ 130.517] (II) modeset(G0): Creating default Display subsection in Screen section
“nvidia” for depth/fbbpp 24/32
[ 130.517] (==) modeset(G0): Depth 24, (==) framebuffer bpp 32
[ 130.518] (==) modeset(G0): RGB weight 888
[ 130.518] (==) modeset(G0): Default visual is TrueColor
[ 130.518] (II) Loading sub module “glamoregl”
[ 130.518] (II) LoadModule: “glamoregl”
[ 130.518] (II) Loading /usr/lib/xorg/modules/libglamoregl.so
[ 130.522] (II) Module glamoregl: vendor=“X.Org Foundation”
[ 130.522] compiled for 1.21.1.2, module version = 1.0.1
[ 130.522] ABI class: X.Org ANSI C Emulation, version 0.4
[ 130.685] (II) modeset(G0): glamor X acceleration enabled on Mesa DRI Intel(R) HD Graphics 4400 (HSW GT2)
[ 130.685] (II) modeset(G0): glamor initialized
[ 130.687] (II) modeset(G0): Output eDP-1-1 has no monitor section
[ 130.714] (II) modeset(G0): Output HDMI-1-1 has no monitor section
[ 130.716] (II) modeset(G0): EDID for output eDP-1-1
[ 130.716] (II) modeset(G0): Manufacturer: LGD Model: 3b7 Serial#: 0
[ 130.716] (II) modeset(G0): Year: 2012 Week: 0
[ 130.716] (II) modeset(G0): EDID Version: 1.4
[ 130.716] (II) modeset(G0): Digital Display Input
[ 130.716] (II) modeset(G0): 6 bits per channel
[ 130.716] (II) modeset(G0): Digital interface is undefined
[ 130.716] (II) modeset(G0): Max Image Size [cm]: horiz.: 31 vert.: 17
[ 130.716] (II) modeset(G0): Gamma: 2.20
[ 130.716] (II) modeset(G0): No DPMS capabilities specified
[ 130.716] (II) modeset(G0): Supported color encodings: RGB 4:4:4 YCrCb 4:4:4
[ 130.716] (II) modeset(G0): First detailed timing is preferred mode
[ 130.716] (II) modeset(G0): Preferred mode is native pixel format and refresh rate
[ 130.716] (II) modeset(G0): redX: 0.579 redY: 0.344 greenX: 0.338 greenY: 0.569
[ 130.716] (II) modeset(G0): blueX: 0.158 blueY: 0.124 whiteX: 0.313 whiteY: 0.329
[ 130.716] (II) modeset(G0): Manufacturer’s mask: 0
[ 130.716] (II) modeset(G0): Supported detailed timing:
[ 130.716] (II) modeset(G0): clock: 76.8 MHz Image Size: 309 x 174 mm
[ 130.716] (II) modeset(G0): h_active: 1366 h_sync: 1414 h_sync_end 1446 h_blank_end 1620 h_border: 0
[ 130.716] (II) modeset(G0): v_active: 768 v_sync: 771 v_sync_end 776 v_blanking: 790 v_border: 0
[ 130.716] (II) modeset(G0): clock: 51.2 MHz Image Size: 309 x 174 mm
[ 130.716] (II) modeset(G0): MV65P€140WH2
[ 130.716] (II) modeset(G0): Unknown vendor-specific block 0
[ 130.716] (II) modeset(G0): EDID (in hex):
[ 130.716] (II) modeset(G0): 00ffffffffffff0030e4b70300000000
[ 130.716] (II) modeset(G0): 00160104901f11780a4bb59458569128
[ 130.716] (II) modeset(G0): 1f505400000001010101010101010101
[ 130.716] (II) modeset(G0): 010101010101fb1d56fe500016303020
[ 130.716] (II) modeset(G0): 350035ae10000019fc1356fe50001630
[ 130.716] (II) modeset(G0): 3020350035ae10000019000000fe004d
[ 130.716] (II) modeset(G0): 56363550803134305748320a00000000
[ 130.716] (II) modeset(G0): 00000131940110000001010a20200081
[ 130.717] (II) modeset(G0): Printing probed modes for output eDP-1-1
[ 130.717] (II) modeset(G0): Modeline "1366x768"x60.0 76.75 1366 1414 1446 1620 768 771 776 790 -hsync -vsync (47.4 kHz eP)
[ 130.717] (II) modeset(G0): Modeline "1366x768"x40.0 51.16 1366 1414 1446 1620 768 771 776 790 -hsync -vsync (31.6 kHz e)
[ 130.717] (II) modeset(G0): Modeline "1280x720"x120.0 156.12 1280 1376 1512 1744 720 721 724 746 doublescan -hsync +vsync (89.5 kHz d)
[ 130.717] (II) modeset(G0): Modeline "1280x720"x120.0 120.75 1280 1304 1320 1360 720 721 724 740 doublescan +hsync -vsync (88.8 kHz d)
[ 130.717] (II) modeset(G0): Modeline "1280x720"x59.9 74.50 1280 1344 1472 1664 720 723 728 748 -hsync +vsync (44.8 kHz d)
[ 130.717] (II) modeset(G0): Modeline "1280x720"x59.7 63.75 1280 1328 1360 1440 720 723 728 741 +hsync -vsync (44.3 kHz d)
[ 130.717] (II) modeset(G0): Modeline "1024x768"x120.1 133.47 1024 1100 1212 1400 768 768 770 794 doublescan -hsync +vsync (95.3 kHz d)
[ 130.717] (II) modeset(G0): Modeline "1024x768"x60.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz d)
[ 130.717] (II) modeset(G0): Modeline "960x720"x120.0 117.00 960 1024 1128 1300 720 720 722 750 doublescan -hsync +vsync (90.0 kHz d)
[ 130.717] (II) modeset(G0): Modeline "928x696"x120.1 109.15 928 976 1088 1264 696 696 698 719 doublescan -hsync +vsync (86.4 kHz d)
[ 130.717] (II) modeset(G0): Modeline "896x672"x120.0 102.40 896 960 1060 1224 672 672 674 697 doublescan -hsync +vsync (83.7 kHz d)
[ 130.717] (II) modeset(G0): Modeline "1024x576"x119.9 98.50 1024 1092 1200 1376 576 577 580 597 doublescan -hsync +vsync (71.6 kHz d)
[ 130.717] (II) modeset(G0): Modeline "1024x576"x119.9 78.38 1024 1048 1064 1104 576 577 580 592 doublescan +hsync -vsync (71.0 kHz d)
[ 130.717] (II) modeset(G0): Modeline "1024x576"x59.9 46.50 1024 1064 1160 1296 576 579 584 599 -hsync +vsync (35.9 kHz d)
[ 130.717] (II) modeset(G0): Modeline "1024x576"x59.8 42.00 1024 1072 1104 1184 576 579 584 593 +hsync -vsync (35.5 kHz d)
[ 130.717] (II) modeset(G0): Modeline "960x600"x119.9 96.62 960 1028 1128 1296 600 601 604 622 doublescan -hsync +vsync (74.6 kHz d)
[ 130.717] (II) modeset(G0): Modeline "960x600"x120.0 77.00 960 984 1000 1040 600 601 604 617 doublescan +hsync -vsync (74.0 kHz d)
[ 130.717] (II) modeset(G0): Modeline "960x540"x119.9 86.50 960 1024 1124 1288 540 541 544 560 doublescan -hsync +vsync (67.2 kHz d)
[ 130.717] (II) modeset(G0): Modeline "960x540"x120.0 69.25 960 984 1000 1040 540 541 544 555 doublescan +hsync -vsync (66.6 kHz d)
[ 130.717] (II) modeset(G0): Modeline "960x540"x59.6 40.75 960 992 1088 1216 540 543 548 562 -hsync +vsync (33.5 kHz d)
[ 130.717] (II) modeset(G0): Modeline "960x540"x59.8 37.25 960 1008 1040 1120 540 543 548 556 +hsync -vsync (33.3 kHz d)
[ 130.717] (II) modeset(G0): Modeline "800x600"x120.0 81.00 800 832 928 1080 600 600 602 625 doublescan +hsync +vsync (75.0 kHz d)
[ 130.717] (II) modeset(G0): Modeline "800x600"x60.3 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz d)
[ 130.717] (II) modeset(G0): Modeline "800x600"x56.2 36.00 800 824 896 1024 600 601 603 625 +hsync +vsync (35.2 kHz d)
[ 130.717] (II) modeset(G0): Modeline "840x525"x120.0 73.12 840 892 980 1120 525 526 529 544 doublescan -hsync +vsync (65.3 kHz d)
[ 130.717] (II) modeset(G0): Modeline "840x525"x119.8 59.50 840 864 880 920 525 526 529 540 doublescan +hsync -vsync (64.7 kHz d)
[ 130.717] (II) modeset(G0): Modeline "864x486"x59.9 32.50 864 888 968 1072 486 489 494 506 -hsync +vsync (30.3 kHz d)
[ 130.717] (II) modeset(G0): Modeline "864x486"x59.6 30.50 864 912 944 1024 486 489 494 500 +hsync -vsync (29.8 kHz d)
[ 130.717] (II) modeset(G0): Modeline "700x525"x120.0 61.00 700 744 820 940 525 526 532 541 doublescan +hsync +vsync (64.9 kHz d)
[ 130.717] (II) modeset(G0): Modeline "800x450"x119.9 59.12 800 848 928 1056 450 451 454 467 doublescan -hsync +vsync (56.0 kHz d)
[ 130.717] (II) modeset(G0): Modeline "800x450"x119.6 48.75 800 824 840 880 450 451 454 463 doublescan +hsync -vsync (55.4 kHz d)
[ 130.717] (II) modeset(G0): Modeline "640x512"x120.0 54.00 640 664 720 844 512 512 514 533 doublescan +hsync +vsync (64.0 kHz d)
[ 130.717] (II) modeset(G0): Modeline "700x450"x119.9 51.75 700 740 812 924 450 451 456 467 doublescan -hsync +vsync (56.0 kHz d)
[ 130.717] (II) modeset(G0): Modeline "700x450"x119.8 43.25 700 724 740 780 450 451 456 463 doublescan +hsync -vsync (55.4 kHz d)
[ 130.717] (II) modeset(G0): Modeline "640x480"x120.0 54.00 640 688 744 900 480 480 482 500 doublescan +hsync +vsync (60.0 kHz d)
[ 130.717] (II) modeset(G0): Modeline "640x480"x59.9 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz d)
[ 130.717] (II) modeset(G0): Modeline "720x405"x59.5 22.50 720 744 808 896 405 408 413 422 -hsync +vsync (25.1 kHz d)
[ 130.717] (II) modeset(G0): Modeline "720x405"x59.0 21.75 720 768 800 880 405 408 413 419 +hsync -vsync (24.7 kHz d)
[ 130.717] (II) modeset(G0): Modeline "684x384"x119.8 42.62 684 720 788 892 384 385 390 399 doublescan -hsync +vsync (47.8 kHz d)
[ 130.717] (II) modeset(G0): Modeline "684x384"x119.7 36.12 684 708 724 764 384 385 390 395 doublescan +hsync -vsync (47.3 kHz d)
[ 130.717] (II) modeset(G0): Modeline "640x400"x119.8 41.75 640 676 740 840 400 401 404 415 doublescan -hsync +vsync (49.7 kHz d)
[ 130.717] (II) modeset(G0): Modeline "640x400"x120.0 35.50 640 664 680 720 400 401 404 411 doublescan +hsync -vsync (49.3 kHz d)
[ 130.717] (II) modeset(G0): Modeline "640x360"x119.7 37.25 640 672 736 832 360 361 364 374 doublescan -hsync +vsync (44.8 kHz d)
[ 130.717] (II) modeset(G0): Modeline "640x360"x119.7 31.88 640 664 680 720 360 361 364 370 doublescan +hsync -vsync (44.3 kHz d)
[ 130.717] (II) modeset(G0): Modeline "640x360"x59.8 18.00 640 664 720 800 360 363 368 376 -hsync +vsync (22.5 kHz d)
[ 130.717] (II) modeset(G0): Modeline "640x360"x59.3 17.75 640 688 720 800 360 363 368 374 +hsync -vsync (22.2 kHz d)
[ 130.717] (II) modeset(G0): Modeline "512x384"x120.0 32.50 512 524 592 672 384 385 388 403 doublescan -hsync -vsync (48.4 kHz d)
[ 130.717] (II) modeset(G0): Modeline "512x288"x120.0 23.25 512 532 580 648 288 289 292 299 doublescan -hsync +vsync (35.9 kHz d)
[ 130.717] (II) modeset(G0): Modeline "512x288"x119.8 21.00 512 536 552 592 288 289 292 296 doublescan +hsync -vsync (35.5 kHz d)
[ 130.717] (II) modeset(G0): Modeline "480x270"x119.3 20.38 480 496 544 608 270 271 274 281 doublescan -hsync +vsync (33.5 kHz d)
[ 130.717] (II) modeset(G0): Modeline "480x270"x119.6 18.62 480 504 520 560 270 271 274 278 doublescan +hsync -vsync (33.3 kHz d)
[ 130.717] (II) modeset(G0): Modeline "400x300"x120.6 20.00 400 420 484 528 300 300 302 314 doublescan +hsync +vsync (37.9 kHz d)
[ 130.717] (II) modeset(G0): Modeline "400x300"x112.7 18.00 400 412 448 512 300 300 301 312 doublescan +hsync +vsync (35.2 kHz d)
[ 130.717] (II) modeset(G0): Modeline "432x243"x119.8 16.25 432 444 484 536 243 244 247 253 doublescan -hsync +vsync (30.3 kHz d)
[ 130.717] (II) modeset(G0): Modeline "432x243"x119.1 15.25 432 456 472 512 243 244 247 250 doublescan +hsync -vsync (29.8 kHz d)
[ 130.717] (II) modeset(G0): Modeline "320x240"x120.1 12.59 320 328 376 400 240 245 246 262 doublescan -hsync -vsync (31.5 kHz d)
[ 130.717] (II) modeset(G0): Modeline "360x202"x119.0 11.25 360 372 404 448 202 204 206 211 doublescan -hsync +vsync (25.1 kHz d)
[ 130.717] (II) modeset(G0): Modeline "360x202"x118.3 10.88 360 384 400 440 202 204 206 209 doublescan +hsync -vsync (24.7 kHz d)
[ 130.717] (II) modeset(G0): Modeline "320x180"x119.7 9.00 320 332 360 400 180 181 184 188 doublescan -hsync +vsync (22.5 kHz d)
[ 130.717] (II) modeset(G0): Modeline "320x180"x118.6 8.88 320 344 360 400 180 181 184 187 doublescan +hsync -vsync (22.2 kHz d)
[ 130.744] (II) modeset(G0): EDID for output HDMI-1-1
[ 130.744] (II) modeset(G0): Manufacturer: GSM Model: 1 Serial#: 16843009
[ 130.744] (II) modeset(G0): Year: 2014 Week: 1
[ 130.744] (II) modeset(G0): EDID Version: 1.3
[ 130.744] (II) modeset(G0): Digital Display Input
[ 130.744] (II) modeset(G0): Max Image Size [cm]: horiz.: 160 vert.: 90
[ 130.744] (II) modeset(G0): Gamma: 2.20
[ 130.744] (II) modeset(G0): No DPMS capabilities specified
[ 130.744] (II) modeset(G0): Supported color encodings: RGB 4:4:4 YCrCb 4:4:4
[ 130.744] (II) modeset(G0): First detailed timing is preferred mode
[ 130.744] (II) modeset(G0): redX: 0.640 redY: 0.330 greenX: 0.300 greenY: 0.600
[ 130.744] (II) modeset(G0): blueX: 0.150 blueY: 0.060 whiteX: 0.312 whiteY: 0.329
[ 130.744] (II) modeset(G0): Supported established timings:
[ 130.744] (II) modeset(G0): 720x400@70Hz
[ 130.744] (II) modeset(G0): 640x480@60Hz
[ 130.744] (II) modeset(G0): 800x600@60Hz
[ 130.744] (II) modeset(G0): 1024x768@60Hz
[ 130.744] (II) modeset(G0): Manufacturer’s mask: 0
[ 130.744] (II) modeset(G0): Supported standard timings:
[ 130.744] (II) modeset(G0): #0: hsize: 640 vsize 480 refresh: 60 vid: 16433
[ 130.744] (II) modeset(G0): #1: hsize: 800 vsize 600 refresh: 60 vid: 16453
[ 130.744] (II) modeset(G0): #2: hsize: 1024 vsize 768 refresh: 60 vid: 16481
[ 130.744] (II) modeset(G0): #3: hsize: 1152 vsize 864 refresh: 60 vid: 16497
[ 130.744] (II) modeset(G0): Supported detailed timing:
[ 130.744] (II) modeset(G0): clock: 85.5 MHz Image Size: 1600 x 900 mm
[ 130.744] (II) modeset(G0): h_active: 1360 h_sync: 1424 h_sync_end 1536 h_blank_end 1792 h_border: 0
[ 130.744] (II) modeset(G0): v_active: 768 v_sync: 771 v_sync_end 777 v_blanking: 795 v_border: 0
[ 130.744] (II) modeset(G0): clock: 65.0 MHz Image Size: 1600 x 900 mm
[ 130.744] (II) modeset(G0): h_active: 1024 h_sync: 1048 h_sync_end 1184 h_blank_end 1344 h_border: 0
[ 130.744] (II) modeset(G0): v_active: 768 v_sync: 771 v_sync_end 777 v_blanking: 806 v_border: 0
[ 130.744] (II) modeset(G0): Ranges: V min: 58 V max: 62 Hz, H min: 30 H max: 83 kHz, PixClock max 165 MHz
[ 130.744] (II) modeset(G0): Monitor name: LG TV
[ 130.744] (II) modeset(G0): clock: 74.2 MHz Image Size: 160 x 90 mm
[ 130.744] (II) modeset(G0): h_active: 1920 h_sync: 2008 h_sync_end 2052 h_blank_end 2200 h_border: 0
[ 130.744] (II) modeset(G0): v_active: 540 v_sync: 542 v_sync_end 547 v_blanking: 562 v_border: 0
[ 130.744] (II) modeset(G0): clock: 74.2 MHz Image Size: 800 x 450 mm
[ 130.744] (II) modeset(G0): h_active: 1280 h_sync: 1390 h_sync_end 1430 h_blank_end 1650 h_border: 0
[ 130.744] (II) modeset(G0): v_active: 720 v_sync: 725 v_sync_end 730 v_blanking: 750 v_border: 0
[ 130.744] (II) modeset(G0): clock: 27.0 MHz Image Size: 160 x 90 mm
[ 130.744] (II) modeset(G0): h_active: 720 h_sync: 736 h_sync_end 798 h_blank_end 858 h_border: 0
[ 130.744] (II) modeset(G0): v_active: 480 v_sync: 489 v_sync_end 495 v_blanking: 525 v_border: 0
[ 130.744] (II) modeset(G0): clock: 148.5 MHz Image Size: 160 x 90 mm
[ 130.744] (II) modeset(G0): v_active: 1080 v_sync: 1084 v_sync_end 1089 v_blanking: 1125 v_border: 0
[ 130.744] (II) modeset(G0): Number of EDID sections to follow: 1
[ 130.744] (II) modeset(G0): EDID (in hex):
[ 130.744] (II) modeset(G0): 00ffffffffffff001e6d010001010101
[ 130.744] (II) modeset(G0): 0118010380a05a780aee91a3544c9926
[ 130.744] (II) modeset(G0): 0f5054a1080031404540614071400101
[ 130.744] (II) modeset(G0): 010101010101662150b051001b304070
[ 130.744] (II) modeset(G0): 360040846300001e6419004041002630
[ 130.744] (II) modeset(G0): 18883600408463000018000000fd003a
[ 130.744] (II) modeset(G0): 3e1e5310000a202020202020000000fc
[ 130.744] (II) modeset(G0): 004c472054560a202020202020200175
[ 130.744] (II) modeset(G0): 020322f14e101f049305140302122021
[ 130.744] (II) modeset(G0): 2215012615075009570767030c002000
[ 130.744] (II) modeset(G0): 801e011d8018711c1620582c2500a05a
[ 130.744] (II) modeset(G0): 0000009e011d007251d01e206e285500
[ 130.744] (II) modeset(G0): 20c23100001e8c0ad08a20e02d10103e
[ 130.744] (II) modeset(G0): 9600a05a00000018023a801871382d40
[ 130.744] (II) modeset(G0): 582c4500a05a0000001e000000000000
[ 130.744] (II) modeset(G0): 0000000000000000000000000000004b
[ 130.744] (–) modeset(G0): HDMI max TMDS frequency 150000KHz
[ 130.744] (II) modeset(G0): Printing probed modes for output HDMI-1-1
[ 130.744] (II) modeset(G0): Modeline "1360x768"x60.0 85.50 1360 1424 1536 1792 768 771 777 795 +hsync +vsync (47.7 kHz eP)
[ 130.744] (II) modeset(G0): Modeline "1920x1080"x60.0 148.50 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.5 kHz e)
[ 130.744] (II) modeset(G0): Modeline "1920x1080"x50.0 148.50 1920 2448 2492 2640 1080 1084 1089 1125 +hsync +vsync (56.2 kHz e)
[ 130.744] (II) modeset(G0): Modeline "1920x1080"x59.9 148.35 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.4 kHz e)
[ 130.744] (II) modeset(G0): Modeline "1920x1080i"x60.0 74.25 1920 2008 2052 2200 1080 1084 1094 1125 interlace +hsync +vsync (33.8 kHz e)
[ 130.744] (II) modeset(G0): Modeline "1920x1080i"x50.0 74.25 1920 2448 2492 2640 1080 1084 1094 1125 interlace +hsync +vsync (28.1 kHz e)
[ 130.744] (II) modeset(G0): Modeline "1920x1080"x30.0 74.25 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (33.8 kHz e)
[ 130.744] (II) modeset(G0): Modeline "1920x1080"x25.0 74.25 1920 2448 2492 2640 1080 1084 1089 1125 +hsync +vsync (28.1 kHz e)
[ 130.744] (II) modeset(G0): Modeline "1920x1080"x24.0 74.25 1920 2558 2602 2750 1080 1084 1089 1125 +hsync +vsync (27.0 kHz e)
[ 130.745] (II) modeset(G0): Modeline "1920x1080i"x59.9 74.18 1920 2008 2052 2200 1080 1084 1094 1125 interlace +hsync +vsync (33.7 kHz e)
[ 130.745] (II) modeset(G0): Modeline "1920x1080"x30.0 74.18 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (33.7 kHz e)
[ 130.745] (II) modeset(G0): Modeline "1920x1080"x24.0 74.18 1920 2558 2602 2750 1080 1084 1089 1125 +hsync +vsync (27.0 kHz e)
[ 130.745] (II) modeset(G0): Modeline "1152x864"x60.0 81.58 1152 1216 1336 1520 864 865 868 895 -hsync +vsync (53.7 kHz)
[ 130.745] (II) modeset(G0): Modeline "1280x720"x60.0 74.25 1280 1390 1430 1650 720 725 730 750 +hsync +vsync (45.0 kHz e)
[ 130.745] (II) modeset(G0): Modeline "1280x720"x50.0 74.25 1280 1720 1760 1980 720 725 730 750 +hsync +vsync (37.5 kHz e)
[ 130.745] (II) modeset(G0): Modeline "1280x720"x59.9 74.18 1280 1390 1430 1650 720 725 730 750 +hsync +vsync (45.0 kHz e)
[ 130.745] (II) modeset(G0): Modeline "1024x768"x60.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e)
[ 130.745] (II) modeset(G0): Modeline "800x600"x60.3 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e)
[ 130.745] (II) modeset(G0): Modeline "720x576"x50.0 27.00 720 732 796 864 576 581 586 625 -hsync -vsync (31.2 kHz e)
[ 130.745] (II) modeset(G0): Modeline "720x576i"x50.0 13.50 720 732 795 864 576 580 586 625 interlace -hsync -vsync (15.6 kHz e)
[ 130.745] (II) modeset(G0): Modeline "720x480"x60.0 27.03 720 736 798 858 480 489 495 525 -hsync -vsync (31.5 kHz e)
[ 130.745] (II) modeset(G0): Modeline "720x480"x59.9 27.00 720 736 798 858 480 489 495 525 -hsync -vsync (31.5 kHz e)
[ 130.745] (II) modeset(G0): Modeline "640x480"x60.0 25.20 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 130.745] (II) modeset(G0): Modeline "640x480"x59.9 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 130.745] (II) modeset(G0): Modeline "720x400"x70.1 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz e)
[ 130.745] (==) modeset(G0): Using gamma correction (1.0, 1.0, 1.0)
[ 130.745] (==) modeset(G0): DPI set to (96, 96)
[ 130.745] (II) Loading sub module “fb”
[ 130.745] (II) LoadModule: “fb”
[ 130.745] (II) Module “fb” already built-in
[ 130.745] (EE) Screen(s) found, but none have a usable configuration.
[ 130.745] (EE)
Fatal server error:
[ 130.745] (EE) no screens found(EE)
[ 130.745] (EE)
for help.
[ 130.745] (EE) Please also check the log file at “/var/log/Xorg.0.log” for additional information.
[ 130.745] (EE)
[ 130.758] (EE) Server terminated with error (1). Closing log file.
so, if this gives more info on what might be wrong
I forgot to mention … it also appears you are forcing some driver version outside of mhwd …
You are pretty beyond regular manjaro operation. So you might want to ask Optimus Manager or some other resource … because you are functionally unsupported at this point.
$ mhwd -la | grep nvidia
video-nvidia-390xx            2021.12.18               false            PCI
video-nvidia            2021.12.18               false            PCI
video-hybrid-amd-nvidia-470xx-prime            2021.12.18               false            PCI
video-hybrid-intel-nvidia-390xx-bumblebee            2021.12.18               false            PCI
video-nvidia-470xx            2021.12.18               false            PCI
video-hybrid-intel-nvidia-prime            2021.12.18               false            PCI
video-hybrid-amd-nvidia-prime            2021.12.18               false            PCI
video-hybrid-intel-nvidia-470xx-prime            2021.12.18               false            PCI
Yeah, as I said before, I got it from the “[Support/How-To] Compile old/legacy Nvidia Proprietary Drivers [2020-12-30 Update Issue]” post in the forum, made by a Manjaro member, because, as I’ve also stated, I had issues running the 390.
I’ve also tried installing the supported 390 drivers, it didn’t help, actually it seemed to make it worse, as doing lspci and lsmod would show the card is on, and the driver is running, but on the xorg log it would say it couldn’t start the driver or detect any device.
So, sorry if I want to use a driver that works for me that isn’t in your janky driver manager utility, and expecting to get any help from an user forum.
