SDDM autologin to plasmawayland issue
Hi! I’m writing this for future reference in case anyone has the same problem.
I had an issue with the SDDM autologin to the Plasma Wayland session. When I disabled autologin and selected the Plasma Wayland session manually, it started properly. However, with the SDDM autologin option it always started X instead of Wayland.
After searching online, I found several discussions about similar issues but no definitive solutions.
Then, I figured out that the issue was due to my ~/.zprofile configuration. It contained the following line to start X:
[[ -z $DISPLAY && $XDG_VTNR -eq 1 ]] && startx -- -keeptty -nolisten tcp > ~/.xorg.log 2>&1
After commenting out this line, SDDM autologin to the Plasma Wayland session started working properly.
It appears that SDDM autologin starts the shell as a “login shell”, which sources the ~/.zprofile, while regular SDDM login does not.
EDIT. Just in case I repeat, that I solved the issue myself and posted it here for future reference.
This is an unusual setting.
The behavior can be configured at → System Settings → Colors & Themes → Login Screen → Behaviour
I persuaded my installation to auto-login to Wayland by editing /etc/sddm.conf.d/kde_settings.conf and changing
Session=plasma
to
Session=plasmawayland
It needs to be in sddm.conf.d rather than sddm.conf, as the latter may get overwritten by an update.
I think I had this as a leftover from earlier time when I used autologin to tty and autostart X without display manager.
Later I installed SDDM, switched to Wayland and for a long time I could not figure out why manual login to Wayland works while autologin always starts X.
I used this same way of configuration and this very option and was surprised that it anyway started X. At last I’ve found this ~/.zprofile leftover configuration line.
