I recently received a Infinitybookpro from Tuxedo Computers pre-installed with Manjaro and it’s great, but I’m having a problem where I accidentally checked autologin on configuration and now I am trying to override it. I have tried solutions like in this post
however overriding autologin by simply commenting out the lines didn’t stop the autologin from happening. Moreover changing the autologin session has no effect. I would like to disable autologin because I am trying to move to a different window manager and I like to have the option on the log-in screen.
I should have mentioned. I’m using sddm and kde-plasma, not xfce. moreover I have followed those steps however it has not worked, please see the problem I mentioned the original post, as that is the solution you have posted I think?
Sorry, I’m afraid I’m having problems with applying the behaviour. I unchecked the box and clicked apply and the checkbox reverted to being checked after I entered my password. I’m having the same issue when I’m checking boxes for, for example, changing the background for sddm. Any idea what might be causing this? Thanks
